ZZ-4AO-2
ZZ-4AO-2
    B+BSMARTWORX
    ZLINX IO, 4AO, SOURCING
ZZ-4AO-2 数据手册
B&B ELECTRONICS Zlinx Wireless Modbus I/O-0712ds page 1/5 ©2009 B&B Electronics. All rights reserved Zlinx Wireless I/O Peer-to-Peer and Modbus I/O 9 Modular, Customizable Wire Replacement 9 128 / 256 Bit AES Encryption 9 Software Selectable RF Transmit Power 9 Software Selectable Over-the-air Data Rate 9 Modbus ASCII /RTU Compatible 9 Wide Operating Temperature 9 Active Repeater Functionality 9 10 to 40 VDC & 24 VAC Input Power Zlinx™ Wireless Modbus I/O - flexible enough to fit your applications. These plug-n-play units from B&B Electronics Wire Replacement (Peer-to-Peer Mode) combine traditional Modbus RTU remote analog and discrete I/O with built-in wireless connectivity. Wireless RTU serves as Modbus slave RTU in radio-based SCADA systems, or as a peer-to-peer communication platform. Replicate any analog or digital signal from a remote locationWirelessly! Use a pair of Zlinx™ Wireless I/O modules to read sensor inputs or control actuators in hard-top-reach locations. Inputs and outputs of the paired Zlinx radios will mirror each other, making it easy to add wireless I/O to any application. Three Ranges Available - Short, Medium, Long range. Active Repeaters - With built-in repeater functionality on -MR and 900 MHz -LR models, you can ensure vital signals get through. Modular - Just snap on your I/O and you're ready to go. Wide Temperature - Meets most indoor or outdoor applications. Rugged circuitry prevents signal degradation. 128 / 256 Bit AES Encryption – Secures your data. Selectable RF Transmit Power – Allows you to optimize the transmitter power for your application. Modbus Peer-to-peer or Peer to Multi-peer PRODUCT INFORMATION Selectable Over-the-air Data Rate – Allows you to decrease the OTA Data Rate on –LR and –LR-AU versions, effectively increasing the radio transmitter’s range. Exception Reporting – In Modbus mode, allows the reporting of possible problems with connected devices. Fail Safe – Allows you to set your I/O to a safe state in the event Seamlessly add wireless I/O to any Modbus application. Modbus is the most widely supported I/O protocol worldwide. With Zlinx Wireless I/O you can now bring wireless remote I/O into any Modbus system. Simply connect a Zlinx modem to and RS-232 or RS-485 port of the Modbus master and it can now poll up to 150 wireless I/O nodes – each node can be configured for 8 to 48 I/O points. of a communications failure. Calibration – Calculates correction factors to make I/O values better match your sensor. Communications Failure Alarm – Allows the first DO to be configured as a COM failure alarm indicator. Invert Output – You can invert the logic of all DO’s in peer-topeer mode. Monitor – You can use the Zlinx™ Manager Software to monitor your I/O. www.bb-elec.com orders@bb-elec.com support@bb-elec.com International Office: 707 Dayton Road PO Box 1040 Ottawa, IL 61350 USA 815-433-5100 Fax 433-5104 European Office: Westlink Commercial Park Oranmore Co. Galway Ireland +353 91 792444 Fax +353 91 792445 B&B ELECTRONICS Zlinx Wireless Modbus I/O-0712ds page 2/5 ©2009 B&B Electronics. All rights reserved Base Module Radio Properties Model No. Frequency Software Selectable RF Power Options ZZ24D-Nx-SR 10mW, 16mW, 25mW, 40mW, 63mW 2.4 GHz ZZ24D-Nx-MR Fixed 50mW 2.4 GHz ZZ9D-Nx-MR Fixed 100mW 900 MHz ZZ9D-Nx-LR 1mW,10mW, 100mW, 500mW, 1000mW 900 MHz ZZ9D-Nx-LR-AU 1mW, 10mW, 100mW, 500mW, 1000mW 900 MHz ZZ8D-Nx-LR 1mW, 23mW, 100mW, 159mW, 316mW 868 MHz Note: ZZ9D-Nx-LR and ZZ9D-Nx-LR-AU have software selectable OTA data rates. Range w/Supplied Antenna (indoor / outdoor) Max ZZ24D-Nx-SR 300 Feet (91 Meters) / 1 Mile (1.6 Kilometers) ZZ24D-Nx-MR 600 Feet (183 Meters) / 3 Miles (5 Kilometers) ZZ9D-Nx-MR 1500 Feet (457 Meters) / 7 Miles (11 Kilometers) ZZ9D-Nx-LR 3000 Feet (914 Meters) / 14 Miles (23 Kilometers) ZZ9D-Nx-LR-AU 3000 Feet (914 Meters) / 14 Miles (23 Kilometers) ZZ8D-Nx-LR 1800 Feet (549 Meters) / 25 Miles (40 Kilometers) *Note: 900 MHz units are not sold in Europe ** Note: 868 MHz units are not sold in North America Factory RF Power Setting 63mW 50mW 100mW 1000mW 1000mW 316mW AES Encryption 128 Bit N/A N/A 256 Bit 128 Bit 128 Bit Over-the-air Data Rate 250 Kbps 9.6 Kbps 9.6 Kbps 9.6 or 115.2 Kbps 9.6 or 115.2 Kbps 24 Kbps Range w/High Gain Antenna (Outdoor) Max N/A 10 Miles (16 Kilometers) 10 Miles (16 Kilometers) 40 Miles (64 Kilometers) 40 Miles (64 Kilometers) 25 Miles (40 Kilometers) Latency Base Module Modbus Digital Analog ZZ24D-xx-SR 8mS 15mS ZZxxD-xx-MR 56mS 365mS ZZ9D-xx-LR 9mS 104mS Latency times were measured in a clean RF environment with devices less than 3 feet apart. Add 45mS per analog expansion module and 25mS per digital expansion module. ZZ8D-Nx-LR radios have a 10% max duty cycle. Peer-to-Peer Digital 20mS 827mS 55mS Analog 25mS 643mS 52mS PRODUCT INFORMATION I/O Points Model No. ZZxD-NA-xx (Base) ZZxD-NB-xx (Base) ZZxD-NC-xx (Base) ZZxD-ND-xx (Base) ZZ-8DI-DC ZZ-8DO-T ZZ-8DO-T1 ZZ-4DI4DO-DCT ZZ-4DI4DO-DCT1 ZZ-4AI ZZ-4AO ZZ-4A0-2 ZZ-2AI2AO ZZ-8DO-R ZZ-4RTD1 Digital Inputs 2 (Pull-up, R) 4 (Pull-up, R) 2 (Pull-up, R) 4 (Pull-up, R) 8 (Pull-up, R) ----4 (Pull-up, R) 4 (Pull-up, R) ------------- Digital Outputs 2 (Sourcing) 4 (Sourcing) 2(Sinking) 4 (Sinking) --8 (Sourcing) 8 (Sinking) 4 (Sourcing) 4 (Sinking) --------8 (Relay) --- Analog Inputs 2 (mA, V) --2 (mA, V) ------------4 (mA, V) ----2 (mA, V) --4 (RTD) Analog Outputs 2 (V, mA, Sinking) --2 (V, mA, Sinking) --------------4 (V, mA, Sinking) 4 (V, mA, Sourcing) 2 (V, mA, Sinking) ----- Software Programming Kits – Required to program your system Description Model Number ZZ-PROG1-USB Programming Module (USB Interface), USB cable and Software CD Note: The Software CD is only available with the programming kit. Software and Firmware can also be downloaded at www.bb-elec.com www.bb-elec.com orders@bb-elec.com support@bb-elec.com International Office: 707 Dayton Road PO Box 1040 Ottawa, IL 61350 USA 815-433-5100 Fax 433-5104 European Office: Westlink Commercial Park Oranmore Co. Galway Ireland +353 91 792444 Fax +353 91 792445 B&B ELECTRONICS Zlinx Wireless Modbus I/O-0712ds page 3/5 ©2009 B&B Electronics. All rights reserved Specifications Voltage Range: Low Voltage (0): High Voltage (1): Pull Up Current: Frequency Input: Voltage Range: Number of Relays: Type: Output Connection: Common Connection: Ratings: Digital Inputs 0 to 48 VDC 0.8 V maximum 4.0 V minimum 38 micro-amps 2 DI inputs per module Software selectable as frequency counters, 0 to 5 KHz range. Digital Outputs 10 to 40 VDC (Sourcing) 0 to 48 VDC (Sinking) 40 mA per output Relay Outputs 8 C -normally open & normally closed 3.5mm removable terminal block (2 per output) 3.5mm removable terminal block 250VAC @ 8A, 30VDC @5A (maximum per bank of 4 as grouped on the label) Radio Properties (SR Models) Frequency: 2.4 GHz Output Power : 100 mW Receiver Sensitivity: -102 dbm Antenna: The included antenna is a 4.25 inch omni-directional with RPSMA connector. (p/n ZZ24D-ANT1) PRODUCT INFORMATION Radio Properties (2.4 GHz MR Models) Frequency: 2.4 GHz Output Power: 50mW Analog Inputs and Outputs 0 to 10 VDC or 0 to 20 mA ZZ-4AO-2 is an active current source. All others are passive Resolution: 12 Bit Input Accuracy: 0.2% full scale reading typical Output Accuracy: 0.27% full scale reading typical AI Load Resistance: 100 Mega Ohms when configured for voltage input 250 Ohms when configured for current input AO Max Output Current: 1 mA when configured for voltage output. AO Max Load 450 Ohms when configured For current output @ 12V Ranges: RTD Inputs 4 2, 3, and 4 wire PT100, PT1000 (Optimized for temperature coefficient of 385 C), Cu10 (Optimized for temperature coefficient of 427 C) Input Connection: 3.5mm removable terminal block (4 per output) Temperature Range: PT100 = (-) 200 to (+) 650 C PT1000 = (-) 200 to (+) 100 C Cu10 = (-) 100 to (+) 260 C Resolution: 0.1C cross at (-) 40 to (+) 80 C Accuracy @ 25 C: (+/-) 0.5 C typical Accuracy (-)40 to (+) 80C (+/-) 2.0 C maximum Number of RTD: Wire Configuration: Type: Receiver Sensitivity: 105 dbm @ 9.6K Antenna: The included antenna is a 4.25 inch omni-directional with RPSMA connector. p/n ZZ24D-ANT1 Radio Properties (900 MHz LR Models) Frequency: 900 MHz Output Power: 1W -100 dbm @ 115.2 K, -110 dbm @ Receiver Sensitivity: 9.6 K Antenna: The included antenna is a 6.5 inch omni-directional with RPSMA connector p/n ZZ9D-ANT1 Radio Properties (900 MHz MR Models) Frequency: 900 MHz Output Power: 100 mW Receiver Sensitivity: -100 @ 9.6K Antenna: The included antenna is a 6.5 inch omni-directional with RPSMA connector. p/n ZZ9D-ANT1 Radio Properties (868 MHz LR Models) Frequency: 868 MHz Output Power: 315 mW Receiver Sensitivity: -112 dbm Antenna: The included antenna is a 6.5 inch omni-directional with RPSMA connector p/n ZZ9D-ANT1 Receive Signal Strength: RF Data: Local Bus Data: Power: LED Indicators Tri-color – Off = No Signal Red = Weak Signal Yellow = Medium Signal Green = Strong Signal Green – Blinks with TD or RD Off = No Data Green – Blinks with TD or RD Off = No Data Red – On = Power applied Off = No Power Environmental Operating Temperature ZZ-8DO-R -40 to 55°C (-40 to 131°F) All Others -40 to 80°C (-40 to 176°F) Maximum Ambient Air Temp ZZ-8DO-R 55°C (131°F) All Others 80°C (176°F) Storage Temperature -40 to 85°C (-40 to 185°F) Operating Humidity 0 to 95% Non-condensing Enclosure Plastic IP30 Mounting 35mm DIN Rail Expansion 1 Base Module supports up to 6 Expansion Modules Dimensions 1.2 x 3.7 x 5.0 in (2.9 x 9.3 x 12.7 cm) www.bb-elec.com orders@bb-elec.com support@bb-elec.com International Office: 707 Dayton Road PO Box 1040 Ottawa, IL 61350 USA 815-433-5100 Fax 433-5104 European Office: Westlink Commercial Park Oranmore Co. Galway Ireland +353 91 792444 Fax +353 91 792445 B&B ELECTRONICS Zlinx Wireless Modbus I/O-0712ds page 4/5 ©2009 B&B Electronics. All rights reserved Software Windows ME/98/2000/XP/Win7 A software CD is provided with the programming kits and contains the Zlinx Manager software, Users Manual Supported OS and Quick Start Guide. Agency Approvals FCC Part 15 Class A CE Wiring Terminals Download DoC at www.bb-elec.com Download DoC at www.bb-elec.com Modules that are Class 1, Div 2 listed: PRODUCT INFORMATION Wire Type Conductors Wire Range Tightening Torque Field Wiring Temp Rating Power Consumption SR Models MR Models 900 MHz LR Models 868 MHz LR Models File Numbers E245458 (Class 1, Div 2) & E222870 (UL508) UL/cUL ZZ24D-NA-SR ZZ24D-NC-SR ZZ24D-NA-MR ZZ24D-NC-MR ZZ9D-NA-MR ZZ9D-NC-MR ZZ9D-NA-LR ZZ9D-NC-LR ZZ8D-NA-LR ZZ8D-NC-LR ZZ-4AI ZZ-2AI2AO ZZ-8DO-T ZZ-4DI4DO-DCT ZZ-8DO-R ZZ-4AO-2 Power (Base Modules) An external power supply is required (not included) Voltage 10-40 VDC, 24 VAC Class 2, (2.7A Maximum) Removable Terminal Block, 3.81 Power Connection mm spacing Source 85547 86247 88006 88746 88006 88746 88195 88938 88195 88938 136050 119183 313100 197045 40670 113996 Copper Wire Only One Conductor Per Terminal 28 to 16 AWG 1.7 lb – in 105°C Minimum (Sized for 60°C ampacity). 10.0 W 9.5 W 13.1 W 12.0 W Power (Expansion Modules) Class 2 Power Derived from Source Base modules Voltage and current listed on Product label. ZZ24D-Nx-SR (2.4GHz, Short range) ZZ9D-Nx-LR (900 MHz, Long range) ZZ-2AI2AO ZZ-4AI ZZ-4AO ZZ-4AO-2 ZZ-4DI4DO-DCT ZZ-4DI4DO-DCT1 ZZ-4RTD1 ZZ-8DI-DC ZZ-8DO-R ZZ-8DO-T ZZ-8DO-T1 ZZ-PROG1-USB Power Consumption ZZ-4AI ZZ-4AO ZZ-2AI2AO ZZ-8DI-DC ZZ-8DO-T ZZ-8DO-T1 ZZ-4DI4DO-DCT ZZ-4DI4DO-DCT1 1.0 W 1.1 W 1.2 W 0.4 W 15.8 W 1.1 W 8.1 W 1.0 W Class 1, Div 2 exceptions: ZZ-8DO-R 3.2 W ZZ-8DO-R is not UL508 listed ZZxxD-Nx-MR, ZZxxD-Nx-xR-AU and ZZ8D-Nx-xR models are not Class 1, Div 2 listed but are UL508 listed ZZ-4RTD1 0.4 W ZZ-4AO-2 6.0 W MTBF(Hours) ZZ24D-NB-SR ZZ24D-ND-SR ZZ24D-NB-MR ZZ24D-ND-MR ZZ9D-NB-MR ZZ9D-ND-MR ZZ9D-NB-LR ZZ9D-ND-LR ZZ8D-NB-LR ZZ8D-ND-LR ZZ-4AO ZZ-8DI-T ZZ-8DO-T1 ZZ-4DI4DO-DCT1 ZZ-4RTD1 137106 138362 142946 144909 144746 144909 143446 145422 143446 145422 113996 317530 317530 200795 243007 All Others Wiring Terminals Wire Type Conductors Wire Size Tightening Torque ZZ-DIN 1 ZZ-TB1 Zlinx Radio Modem Compatibility Radio Modem Zlinx Base I/O Module ZP24D-250RM-SR ZZ24D-Nx-SR ZP24D-96RM-MR ZZ24D-Nx-SR ZP9D-96RM-MR ZZ9D-Nx-MR ZP9D-115RM-LR ZZ9D-Nx-LR / ZZ9D-Nx-LR-AU ZP8D-24RM-LR ZZ8D-Nx-LR Outputs Relay Output, 250VAC 2 A General Purpose/Point 8 A General Purpose Total Low Voltage, Limited Energy Communications Protocol ZZ-8DO-R ZZ24D-ANT1 Copper Wire Only One Conductor Per Terminal 28 to 16 AWG Tightening Torque Replacement Parts Replacement DIN clip and spring For all ZZ products, also comes with spare screws for enclosure Replacement terminal block kit for ZZ products. Kit includes (1) Two position TB (3.81mm) (1) Four position TB (3.5mm) (1) Eight position TB (3.5mm) (1) Cover for local Bus 2.4 GHZ band antenna www.bb-elec.com orders@bb-elec.com support@bb-elec.com International Office: 707 Dayton Road PO Box 1040 Ottawa, IL 61350 USA 815-433-5100 Fax 433-5104 European Office: Westlink Commercial Park Oranmore Co. Galway Ireland +353 91 792444 Fax +353 91 792445 PRODUCT INFORMATION B&B ELECTRONICS Zlinx Wireless Modbus I/O-0712ds page 5/5 ©2009 B&B Electronics. All rights reserved www.bb-elec.com orders@bb-elec.com support@bb-elec.com International Office: 707 Dayton Road PO Box 1040 Ottawa, IL 61350 USA 815-433-5100 Fax 433-5104 European Office: Westlink Commercial Park Oranmore Co. Galway Ireland +353 91 792444 Fax +353 91 792445
ZZ-4AO-2 价格&库存
很抱歉,暂时无法提供与“ZZ-4AO-2”相匹配的价格&库存,您可以联系我们找货
