PCB Engraving Bits
0.005” / 0.005”, 10 Pack / 0.003” / 0.003”, 10 Pack
We recommend the PCB Engraving Bits for milling traces in PCBs and the Metal Engraving Bits
for traditional engraving applications with other materials. Engraving bits are great for milling
traces in PCBs because they are incredibly durable. You can mill traces in a fraction of the time
with engraving bits vs traditional flat end mills. To learn more about isolation milling PCBs with
engraving bits, check out our support guide here: Engraving Bit Isolation Milling.
The 0.005" tip diameter PCB Engraving Bit is capable of milling boards with 0.010" spacing.
The 0.003" tip diameter bit is capable of milling boards with spacing as small as 0.006" when
used with the Bantam Tools Desktop PCB Milling Machine or Othermill PRO.
https://www.bantamtools.com/products/pcb‐engraving‐bits 3‐7‐18
很抱歉,暂时无法提供与“TL1008-10”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+4892.216601+612.88991
- 5+4413.012235+552.85587
- 10+4241.3021210+531.34427
- 25+4041.0617825+506.25845
