BBBLE-SC-568
BBBLE-SC-568
    GHIELECTRONICS,LLC
    BEAGLEBONE BLUE WIRELESS
BBBLE-SC-568 数据手册
BeagleBone® Blue Spec sheet Specifications: a. Processor (Integrated in the OSD3358): i. AM335x 1GHz ARM® Cortex-A8 ii. SGX530 graphics accelerator iii.NEON floating-point accelerator iv. 2x PRU 32-bit 200MHz microcontrollers b. Memory: i. 512MB DDR3 800MHZ RAM (Integrated in the OSD3358) ii. 4GB 8-bit eMMC on-board flash storage iii.SD/MMC Connector for microSD c. Software Compatibility i. Debian ii. Ardupilot iii.ROS iv. Cloud9 IDE on Node.js w/ BoneScript library d. Connectivity i. High speed USB 2.0 Client port: Access to USB0, Client mode via microUSB ii. High speed USB 2.0 Host port: Access to USB1, Type A Socket, 500mA LS/FS/HS iii.WiLink 1835 WiFi 802.11 b/g/n 2.4GHz. Supports the following modes 1. 2x2 MIMO 2. AP 3. SmartConfig 4. STA 5. Wi-Fi Direct 6. Mesh over Wi-Fi based on 802.11s iv. WiLink 1835 Bluetooth 4.1 with BLE v. Serial port: 1. UART0, UART1, UART5 available via 4 pin JST-SH connectors 2. UART2 available via 6 pin JST-SH connector (EM-506 GPS style connector) 3. UART4 RX available via 3 pin DSM2 (JST-ZH) connector vi. I2C1 available via 4 pin JST-SH connector vii.SPI1 CS0 (S1.1) and SPI1 CS1 (S1.2) available via 6 pin JST-SH connectors viii.CAN available via 4 pin JST-SH connector (includes TCAN1051 CAN transceiver) ix. 8 GPIOs (GP0 and GPI1) available via 6 pin JST-SH connectors x. ADC inputs 0 to 3 available via 6 pin JST-SH connector xi. 3.3VDC and 5VDC power output via 4 pin JST-SH connector e. Power management: i. TPS65217C PMIC is used along with a separate LDO to provide power to the system (Integrated in the OSD3358) ii. 2 cell (2S) LiPo battery charger (powered by 9 – 18VDC DC Jack) iii.6VDC 4A regulator to drive servo motor outputs f. Debug Support: JTAG test points g. Power Source i. microUSB USB ii. 2 cell (2S) LiPo battery JST-XH connector iii.9 - 18VDC DC Jack h. User Input / Output i. Power Button ii. Reset Button iii.Boot Button iv. 2 user configurable buttons (MOD, PAU) v. 11 user configurable LEDs (USR0-3, Red, Green, WIFI, Battery 0-3); Charger LED; Power LED i. Motor Control (requires power from either DC Jack or 2S battery): i. 4 DC motor drivers ii. 4 Quadrature encoder inputs iii.8 Servo motor outputs j. Sensors i. 9 axis IMU ii. Barometer
BBBLE-SC-568 价格&库存
很抱歉,暂时无法提供与“BBBLE-SC-568”相匹配的价格&库存,您可以联系我们找货
