XWB-2U
XWB-2U
    BELDEN
    支架 安装支架
XWB-2U 数据手册
Faster. Easier. Better. 2- and 4-Post Distribution Rack Systems Modular High Density Racking System (HDRS) for network cross-connect Enclosures and Racks Applications These high-reliability products have been designed specifically for networking environments — from Telecom closets to world-class Data Centers — to help you make the best use of valuable real estate and simplify MACs (Moves, Adds and Changes). The HDRS is a well-engineered cross connect and hosting platform that offers you a high level of versatility and flexibility in systems design for ultimate network density and manageability. How It Works Create exactly the racking system you need from our selection of steel and aluminum distribution and server racks, combined with more than 50 standard cable management components and accessories. These items have been designed for complete compatibility and integration. The components include: • Distribution and server racks in aluminum or steel; knockdown or welded; 2 or 4 posts • Choice of low- or high-density vertical cable managers in single- or double-sided configurations • High-density vertical manager half door allows easy cable access and hinging of the doors to both right and left side • Horizontal cable managers with bend radius control and double-hinge cover • Accessories: Retention Gates, Divider Bars, Transition Channels and more How To Order Select any of the Distribution and Server Rack styles. Select any of the Vertical Cable Managers listed for Distribution and Server Racks. Choose any of the Accessories for the BHV Vertical Managers, Horizontal Managers or Transition Channels (See pages 44–45 for Technical Specifications and Options Tables). BHVH006* High-Density, Single-Sided Vertical Manager BHVL006* Low-Density, Single-Sided Vertical Manager WIDTH DEPTH HDRS Modular High-Density Racking System SINGLE SIDED WIDTH DEPTH DEPTH SINGLE SIDED Single-Sided Double-Sided DOUBLE SIDED BHVHH06 High-Density, Double-Sided Vertical Manager DEPTH BHVHL06 High/Low-Density, DoubleSided Vertical Manager *High- and low-density vertical manager shown here with optional back covers, BHBV06X. DOUBLE SIDED HDRS Vertical Manager Capacity Single-Sided Manager # of Cable 35% Fill High Low Width (in.) Depth (in.) Cat 6 0.250" dia. Cat 6A 0.295" dia. BHVH003 BHVH006 BHVH010 BHVH012 BHVL003 BHVL006 BHVL010 BHVL012 3.6 6 10 12 8.75 8.75 8.75 8.75 194 321 535 642 126 209 348 417 High/High High/Low Width (in.) Depth (in.) Cat 6 0.250" dia. Cat 6A 0.295" dia. BHVHH03 BHVHH06 BHVHH10 BHVHH12 BHVHL03 BHVHL06 BHVHL10 BHVHL12 3.6 6 10 12 13.75 13.75 13.75 13.75 388 642 1070 1283 252 417 696 835 Double-Sided Manager www.belden.com # of Cable 35% Fill 1.800.BELDEN.1 (800.235.3361) 43 2- and 4-Post Distribution Rack Systems (continued) Technical Specifications Enclosures and Racks Ordering Information Description XDR8419-310N1M and XDR8419-312N1M Weight Mounting** 2-Post Distribution Racks — Steel — Knockdown* #10-32 Tapped 3" Vertical Upright w/Angle Base 63 lbs 19" #12-24 Tapped 3" Vertical Upright w/Angle Base 63 lbs 19" Value Series Rack, #10-32 Tapped 3" Vertical Upright w/Angle Base 63 lbs 19" Value Series Rack, #12-24 Tapped 3" Vertical Upright w/Angle Base 63 lbs 19" 2-Post Distribution Racks Kit — Steel — Knockdown* Value Series Rack Kit, #10-32 Tapped 3" Vertical Upright w/Angle Base, Includes One 76 lbs 19" 4"x 4" Vertical Manager with Snap-On Cover (part # VCMFDR4X4) Value Series Rack Kit, #10-32 Tapped 3" Vertical Upright w/Angle Base, Includes Two 89 lbs 19" 4"x 4" Vertical Manager with Snap-On Cover (part # VCMFDR4X4) Value Series Rack Kit, #12-24 Tapped 3" Vertical Upright w/Angle Base, Includes One 76 lbs 19" 4"x 4" Vertical Manager with Snap-On Cover (part # VCMFDR4X4) Value Series Rack Kit, #12-24 Tapped 3" Vertical Upright w/Angle Base, Includes Two 89 lbs 19" 4"x 4" Vertical Manager with Snap-On Cover (part # VCMFDR4X4) 2-Post Distribution Racks — Steel — Welded #10-32 Tapped 3" Vertical Upright w/Angle Base – Welded 66 lbs 19" #12-24 Tapped 3" Vertical Upright w/Angle Base – Welded 66 lbs 19" Load Capacity Height/Rack Spaces Belden Part Number 1,000 lbs 84"/45RU XDR8419-310 1,000 lbs 84"/45RU XDR8419-312 1,000 lbs 84"/45RU XDR8419-310N 1,000 lbs 84"/45RU XDR8419-312N 1,000 lbs 84"/45RU XDR8419-310N1M 1,000 lbs 84"/45RU XDR8419-310N2M 1,000 lbs 84"/45RU XDR8419-312N1M 1,000 lbs 84"/45RU XDR8419-312N2M 1,000 lbs 84"/45RU XDR8419-310W 1,000 lbs 84"/45RU XDR8419-312W 2- and 4-Post Zone 4 Seismic Distribution Racks — Steel — Welded*** 2-Post Seismic Rack, #10-32 Tapped 6" Vertical Upright w/Angle Base 105 lbs 19" 900 lbs 84"/45RU 4-Post Seismic Rack, 28" Deep, #10-32 Tapped 6" Vertical Upright w/Angle Base 215 lbs 19" 900 lbs 84"/45RU 4-Post Seismic Rack, 32" Deep, #10-32 Tapped 6" Vertical Upright w/Angle Base 220 lbs 19" 900 lbs 84"/45RU 2-Post Distribution Racks — Aluminum — Knockdown* #12-24 Tapped, Black, Knockdown 3" Vertical Upright 30 lbs 19" 1,200 lbs 84"/45RU #12-24 Tapped, Black, Knockdown 6" Vertical Upright 41 lbs 19" 1,200 lbs 84"/45RU XDR8419-310N2M and XDR8419-312N2M * Knockdown rack shipped not assembled, assembly hardware is included ** For EIA-23" mounting consult Belden customer service *** 4-post seismic rack is made of two welded 2-post rack structures, linked with front to rear member, shipped unassembled **** 4-post server rack is not compatible with vertical managers (see page 45) 46 4-Post Distribution Racks — Steel — Knockdown* 4-Post Rack with Adjustable Depth 28"-32" -36", #10-32 Tapped 3" Vertical Upright 115 lbs 19" w/Angle Base 4-Post Rack with Adjustable Depth 28"-32" -36", #12-24 Tapped 3" Vertical Upright 115 lbs 19" w/Angle Base 4-Post Server Rack — Steel — Welded**** XM Series Black Frame with (4) Ajustable Mounting Rails, Square Hole Type with 6 mm Mounting Hardware Included. Frame Size 240 lbs 19" 24"W x 42"D x 85.6"H (45RU), Includes Levelers and Casters 1.800.BELDEN.1 (800.235.3361) XDRS8419-610 XDRS8419-61028 XDRS8419-61032 BHRR194 BHRR6194 1,500 lbs 84"/45RU XDR8419-3102836 1,500 lbs 84"/45RU XDR8419-3122836 2,000 lbs 85"/45RU X3M45-1-100000 www.belden.com Faster. Easier. Better. 2- and 4-Post Distribution Rack Managers and Accessories Belden Part Number Description Vertical Cable Managers Value Vertical Manager with Snap-On Cover 4"W x 4"D Single-Sided High-Density Vertical Manager w/Doors, 3 5/8"W x 84"H, Black Single-Sided High-Density Vertical Manager w/Doors, 6"W x 84"H, Black Single-Sided High-Density Vertical Manager w/Doors, 10"W x 84"H, Black Single-Sided High-Density Vertical Manager w/Doors, 12"W x 84"H, Black Single-Sided Low-Density Vertical Manager w/o Doors, 3 5/8"W x 84"H, Black Single-Sided Low-Density Vertical Manager w/o Doors, 6"W x 84"H, Black Single-Sided Low-Density Vertical Manager w/o Doors, 10"W x 84"H, Black Single-Sided Low-Density Vertical Manager w/o Doors, 12"W x 84"H, Black Double-Sided High-Density Vertical Managers w/Doors, 3 5/8"W x 84"H, Black Double-Sided High-Density Vertical Managers w/Doors, 6"W x 84"H, Black Double-Sided High-Density Vertical Managers w/Doors, 10"W x 84"H, Black Double-Sided High-Density Vertical Managers w/Doors, 12"W x 84"H, Black High/Low-Density Vertical Manager w/Front Door, 3 5/8"W x 84"H, Black High/Low-Density Vertical Manager w/Front Door, 6"W x 84"H, Black High/Low-Density Vertical Manager w/Front Door, 10"W x 84"H, Black High/Low-Density Vertical Manager w/Front Door, 12"W x 84"H, Black VCMFDR4X4 BHVH003 BHVH006 BHVH010 BHVH012 BHVL003 BHVL006 BHVL010 BHVL012 BHVHH03 BHVHH06 BHVHH10 BHVHH12 BHVHL03 BHVHL06 BHVHL10 BHVHL12 Accessories for BHV Vertical Managers 3 5/8"W, Black, Vertical Manager Backcover 6"W, Black, Vertical Manager Backcover 10"W, Black, Vertical Manager Backcover 12"W, Black, Vertical Manager Backcover 3 5/8"W, Black, Vertical Manager Doors (1 pr) 6"W, Black, Vertical Manager Doors (1 pr) 10"W, Black, Vertical Manager Doors (1 pr) 12"W, Black, Vertical Manager Doors (1 pr) Slack Management Spool Kit, Black Slack Management Spools (2), Black Gate Kit, 3 5/8"W, Black Gate Kit, 6"W, Black Gate Kit, 10"W, Black Gate Kit, 12"W, Black Retention Gate (6) 3 5/8"W, Black Retention Gate (6) 6"W, Black Retention Gate (6) 10"W, Black Retention Gate (6) 12"W, Black Finger Section, 11U, Black Rack Mount Finger Bracket, 11U, Black Divider Bar, 3 5/8"W, Black Divider Bar, 6"W, Black Divider Bar, 10"W, Black Divider Bar, 12"W, Black Fastener for Vertical Manager (100) Tie Mount for Vertical Manager (100) Horizontal Manager with Cover 19"W x 1RU, Black 19"W x 2RU, Black 19"W x 3RU, Black 19"W x 4RU, Black 1RU, Rack Mount, Finger Duct Manager 3.0"H x 3.0"D Deep with Cover 2RU, Rack Mount, Finger Duct Manager 3.0"H x 3.0"D Deep with Cover Transition Channel (Top transition channels are only compatible with knockdown racks) Top Transition Channel, 19"W x 6"D x Y"H, Black Top Transition Channel High-Density, 19"W x 6"D x 6"H, Black Lower Transition Channel, 19"W x 6"D x 1.75"H, Black Lower Transition Channel Double, 19"W x 6"D x 3.5"H, Black www.belden.com Enclosures and Racks Ordering Information BHBC03X BHBC06X BHBC10X BHBC12X BHDK03X BHDK06X BHDK10X BHDK12X BHSK020 BHSP020 BHGL03X BHGL06X BHGL10X BHGL12X BHGR03X BHGR06X BHGR10X BHGR12X BHFS11U BHFB11U BHDB03X BHDB06X BHDB10X BHDB12X BHPF100 BHSM100 VCMFDR4X4 BHBC10X (Vertical manager not included) 9512-1902N BHTT196 and BHTD196 BHH191UR BHH192UR BHH193UR BHH194UR 9512-1901 9512-1902N BHTT196 BHTTH196 BHTL196 BHTD196 1.800.BELDEN.1 (800.235.3361) BHH192UC Horizontal Manager 47 Enclosures and Racks XWR and XWB Series — Wall Mount Racks Hinged and swing-out for rear access in tight spaces Wall Mount Racks are available in two styles: hinged and swing-out. The hinged rack is 12" in height and features an adjustable lower shelf (adjusts 2" to 6"). The swingout rack is available in heights of 36" and 48" with 19" mounting rails. 2RU, 4RU and 6RU Wall Mount Brackets are also offered for mounting a limited number of components or pieces of equipment. XWR-1219 Wall Mount Rack in Hinged Style (shown in closed position with equipment mounted) XWR-3619-18 Swing-Out Style Wall Mount Rack 18.00 18.00 18.00 10-32 Holes XWB-2U 2RU Wall Mount Bracket 36.00 or 48.00 Reinf. gusset Cable tie holes 33.25 (19RU) or 45.50 (26RU) 36.00 or 48.00 33.25 (19RU) or 45.50 (26RU) 18.31 19.81 XPE-S0001 1RU rack attach to basket tray Ø4.00 Cable entry 18.00 XWR Swing-out Style Wall Mount Rack Heavy-Duty XWR Swing-Out Style Wall Mount Rack Ordering Information Description Wall Mount Racks Standard Swing-Out Rack: 36" Wall Mount Rack with 19" Mounting Rails Heavy Swing-Out Rack: 36" Wall Mount Rack with 19" Mounting Rails Standard Swing-Out Rack: 48" Wall Mount Rack with 19" Mounting Rails Heavy-Duty Swing-Out Rack: 48" Wall Mount Rack with 19" Mounting Rails Hinged Rack: 12" Wall Mount Rack, Hinged, 19" Mounting Rails, Adjustable Lower Shelf 2"–11" to Accomodate Equipment Space Wall Mount Brackets 2RU Wall Mount Bracket, Black 4RU Wall Mount Bracket, Black 6RU Wall Mount Bracket, Black 1RU rack, includes basket tray attachment hardware 48 H W D Weight Mounting Load Capacity Rack Spaces Belden Part Number 36" 36" 36" 36" 19.75" 19.75" 19.75" 19.75" 18" 18" 18" 18" 30 lbs 35 lbs 39 lbs 40 lbs 19" 19" 19" 19" 100 lbs 200 lbs 100 lbs 200 lbs 19RU 19RU 26RU 26RU XWR-3619-18 XWR-3619-18HD XWR-4819-18 XWR-4819-18HD 10.9" 19.5" 9.5" 26 lbs 19" 50 lbs 6RU XWR-1219 3.5" 7.0" 10.50" 2.0" 19" 19" 19" 19" 8" 8" 8" N/A 4 lbs 8 lbs 10 lbs 12 lbs 19" 19" 19" 19" 50 lbs 50 lbs 50 lbs 20 lbs 2RU 4RU 6RU 1RU XWB-2U XWB-4U XWB-6U XPE-S0001 1.800.BELDEN.1 (800.235.3361) www.belden.com Faster. Easier. Better. XSW Series — Swing Rack Free-standing swing-out rack used where space is limited • Rack can be assembled as a left or right hinge and open 90º • Rack can be positioned as close as 7" from wall • Equipment up to 18.5" deep can be pivoted • Cable management allows for cable routing without interference of the swing rack • Racks can be bolted side-to-side • Friction lock prevents rack movement while servicing 34.38 75.25 (43 RACK SPACES) 84.00 Wall Ø0.75 7.00 min 31.63 12.50 15.00 24.00 39.50 Approx. OPENED (will open to 90°) Enclosures and Racks The Swing Rack provides easy access to the rear of rack mounted equipment in a free-standing environment. It is ideal for applications where space is limited and rear access is essential. 34.375 5.00 5.00 4.12 Hinge 9.00 7.00 .25 x 1.25 obr (16) CLOSED Rack Mount Unit Rack Mount Unit 4.70 Caster (1) XSW Top View XSW Front View Optional Basket XSW-8419 Swing Rack (shown with equipment mounted) Ordering Information Description Swing Racks 84" Swing-Out Distribution Rack Accessories (Sold Separately) Top Mounting Wire Basket Power Strip Mounting Kit www.belden.com Weight Mounting Load Capacity Rack Spaces Belden Part Number 179 lbs 19" 500 lbs 34RU XSW-8419 — — — — — — — — XSW-0200 XSW-0100 1.800.BELDEN.1 (800.235.3361) 49
XWB-2U 价格&库存
很抱歉,暂时无法提供与“XWB-2U”相匹配的价格&库存,您可以联系我们找货
XWB-2U
    • 1+4198.920451+525.18874
