DT-04-18-BR-C
DT-04-18-BR-C
    BELDEN
    CBL TIE LOCKING BRN 18LBS 4.12"
DT-04-18-BR-C 数据手册
A BELDEN BRAND Diamond® Hardware Products St Drop Hardware Construction Hardware Bonding & Grounding Hardware Fastening Hardware Installation Supplies Customer Support: 800.800.6652 www.ppc-online.com 61 A BELDEN BRAND A BELDEN BRAND ® Diamond Hardware Products Table of Contents Diamond Hardware Overview The Diamond Difference ® ™ Pages 2-5 Bonding & Grounding Hardware Bonding Clamps 2-3 Pages 29-37 29-30 Broadband Drop System 4 Ground Blocks 31 CATV Bonding and Grounding Methods 5 Grounding Clamps 32 Grounding Straps 33 Mechanical - Split Bolt Connectors 34 Drop Hardware Pages 6-21 Mechanical - Jumper Clamps 34 Drop Wire Clamps 6-7 Mechanical - Ground Rod Clamps 35 Span Clamps 8-9 Mechanical - Grounding Conns & Clamps 36 Clamps - Conduit and Pipe 10-11 Brackets 12 Hooks 13 Rings, Screw Fixtures Cable Clips Fastening Hardware Pages 38-57 Cable Support System 38-40 14 Standard Cable Ties 41-43 15-17 Specialty Cable Ties 44-45 Cable Clamps 18 Stainless Steel Cable Ties 46-48 Cable Ties and Bushings 19 Identification Cable Ties 48 Drive Rings, Wire Loops 20 Beaded CableTies, Push Mount CableTies 49 Drive Pins, Drive Tools 21 Air Handling Cable Ties 50 Cold Weather Cable Ties 51 Cable Tie Mounting Pads 51-52 Cable Tie Screw Mounts 53 Construction Hardware Lashed Cable Supports Pages 22-28 22-23 Cable Tie Mounts Clamps 24 Cable Ties Identification Plates Hangers, Brackets, Hooks 25 Cable Tie Specialty Packs Tap Brackets Aerial Cable Damper 55 56-57 26-27 28 Installation Supplies Pages 58-59 Wall Plates 58 Hardware and Rough-In Products 59 Index Customer Support: 800.800.6652 54-55 Pages 60-62 www.ppc-online.com 1 A BELDEN BRAND A BELDEN BRAND ® The Diamond Difference™ Does Your Hardware Pass the Test of Time? Diamond® Products Stand the Test of Time. The unique, proprietary approach that we have to mechanical galvanizing, and the standards that we insist on for our raw materials, ensure that Diamond parts can withstand corrosive environments for decades, a factor that is important today since replacement costs are so high. The photographs below clearly demonstrate the Diamond Difference. Even after 672 hours under the same conditions, Diamond mechanically galvanized parts keep their integrity. Diamond® Advantage What is Mechanical Galvanizing? We mechanically galvanize to ensure that Diamond products will stand the test of time. It is a plating process whereby zinc is mechanically deposited on properly prepared steel parts. A uniform coating thickness of zinc is applied by placing the parts in a rotating barrel with the correct recipe of water, glass beads and various chemicals. The impact of the glass beads on the steel parts deposits a layer of zinc onto the metal surfaces. Subsequent layers build up until the required thickness is achieved. The zinc deposited onto the metal surface may be considered a sacrificial coating. Over time this coating slowly reacts with the environment (moisture and air) and becomes mottled producing 'white rust'. The appearance of white rust means that the coating is being sacrificed to protect the underlying steel part. •• Mechanically galvanized parts have a superior resistance to corrosion. •• It is the most effective method for small parts. •• The process does not clog the threads of nuts and bolts, thus parts can be put together quickly and easily. •• Threaded parts do not 'gall' producing more accurate torque- tension relationships. •• Eliminates the problem of Hydrogen Embrittlement. Heat- treated parts do not detemper or weaken since the galvanizing process takes place at room temperature. 1 2 3 4 The Diamond® Difference™ We do not depend on the process of mechanical galvanizing alone to provide us with products that will stand the test of time. •• Raw materials are carefully selected and must meet or exceed the standards we have established over the years. •• How these materials are combined and prepared is unique to the Belden Diamond method of manufacture. •• Our emphasis is on quality control and process management. •• Every stage of the manufacturing and galvanizing process is controlled and monitored. •• To achieve the Diamond Difference no corners can be cut and no process steps excluded. 5 The Mechanical Galvanizing Process www.ppc-online.com 2 A BELDEN BRAND Customer Support: 800.800.6652 Salt Spray Test Results 5% salt solution (as used in ASTM B117) is sprayed upon parts in a closed chamber until the first indication of red rust appears. Diamond Competitor 48 Hours First indication of Red Rust on competitor product. How Service Life in Hours* Equates to Service Life in Years in Different Environments Environment 48 Hours 336 Hours 672 Hours 850 Hours Rural 4.2 Years 30 Years 60 Years 75 Years Suburban 2.2 Years 16 Years 32 Years 40 Years Moderate Industrial Heavy Industrial 1.5 Years 11 Years 22 Years 28 Years 11 Months 6.5 Years 13 Years 17 Years *Under Test Conditions Information Source: Iron Age Magazine (Zinc Institute) Oct. 1980 Issue. 336 Hours Bell Spec Standard. 672 Hours First Indication of Red Rust on Diamond Product. Parts tested to ASTM B117 under laboratory conditions within Belden certified testing facility. Meeting Your Specifications We ensure consistent performance and quality by adhering to the following industry standards and specifications used within the Telecommunications Industry. Bell Core The Bell Operating Companies (RBOC's) borne of the AT&T divestiture were the first organizations to recognize the need for and to establish quality standards and specifications for pole line hardware in the USA. Bell Communications Research Inc. or 'Bellcore' specifications are acknowledged standards for pole line, drop and bonding/grounding hardware. SCTE Society of Cable Telecommunications Engineers (SCTE) is the professional association for the Cable Television industry. SCTE provides training, certification and standards to the industry and is accredited by ANSI as the industry's body of record. ANSI American National Standards Institute (ANSI) administers and coordinates U.S. standardization efforts through facilitation of consensus standards and conforming assessment systems. ANSI is the official United States representative to ISO and other international accreditation and standardization bodies. ISO The International Organization for Standardization (ISO) reviews, inspects and approves manufacturer facilities and methods then awards quality certification. Facilities must continue to meet the certification requirements to maintain their ISO quality status. Belden's plants are registered to ISO 9001-2000. ASTM The American Standards for Testing and Materials (ASTM) organization in conjunction with manufacturers and industry associations has established internationally recognized quality standards. The organization specifies materials, procedures and methods to assure conformance to its standards. UL Underwriter's Laboratories is an international safety standards organization, which has established testing criteria for electrical products to assure their safety for the end user. CSA The Canadian Standards Association (CSA) has established standards and test criteria to assure satisfactory performance and function of products destined for use in Canada. Customer Support: 800.800.6652 www.ppc-online.com 3 A BELDEN BRAND A BELDEN BRAND ® Diamond Hardware Broadband Drop System Overview www.ppc-online.com 4 A BELDEN BRAND Customer Support: 800.800.6652 ® Diamond Hardware Recommended CATV Bonding and Grounding Methods Bonding and Grounding Methods in Order as Recommended by NEC and SCTE: 1. Power ground system: a. Power ground service wire b. Power service ground rod c. External connector on power service meter box d. Power service entrance conduit (not conduit outlets) 2. Building steel that is bonded to power ground. 3. Metallic water pipe that is bonded to power ground. (water pipes are to be avoided due to the increase in plastic pipes) 4. Additional ground rod (see notes). Notes: • All Belden grounding devices shown are U.L. listed. • Always abide by local grounding codes and follow company sanctioned grounding procedures and priorities. • Cold water pipe ground is not recommended unless continuity can be guaranteed. Also, must be within 5 ft. of where water enters the home. • If ground wire is 20 ft. or more from the power ground, an additional ground rod must be installed and connected to the power ground by a #6 ground wire. (Option 4) • Minimum of #14 AWG solid copper wire required for bonding CATV systems. [NEC 820.40] Customer Support: 800.800.6652 www.ppc-online.com 5 A BELDEN BRAND A BELDEN BRAND ® Diamond Drop Hardware Drop Wire Clamps for CATV and Telephone Cable Universal Messenger Cable Drop Wire Clamp •• Permits cable to “float” free, fully protected from strain and chafing. •• Drop clamp for the suspension of a messengered drop cable between the pole, midspan and house. •• For use with RG59, RG6 and other cables •• Stainless steel bail wire and aluminum body. Installation: 1. Begin separation of the messenger wire from the cable using the end-edge of the SC02MFA-SS Drop Clamp. Note: Never use a knife or other sharp tool to separate messenger and cable. 2. Fit the cable and messenger wire into the SCO2MFASS Drop Clamp as shown, so that the Clamp Bail is between the two. 3. Grasp the separated end of the messenger and cable with one hand and grip the Clamp Body, as shown, with your other hand. Then, pull the SC02MFA-SS back, in a straight line, separating the length of messenger wire needed to make the wrap; about 15 to 18-inches. 4. Pull the messenger wire around the center of the bearing surface as shown, toward the rear or dropside of the Clamp. Note: If at the house end of the drop, this will be done while tensioning or “sagging” the drop. 5. Pass the messenger wire through the “L” Slots and begin the wrap about the SC02MFA-SS body, as shown. Part Number Description SC02MFA-SS Universal Messenger Drop Wire Clamp Inner Pack Outer Pack -- 125 1 2 3 4 5 6. Continue the messenger wire wrap for two full turns. 7. Pass the messenger wire through the “L” Slot, as shown, to the drop-side of the SC02MFA-SS and cut the excess wire away, or ground it to the strand. Note: For drop cable with larger messenger wire, one wrap is sufficient. Wrap the end of the wire around the end of the SC02MFA-SS and bring it back up the “L” Slots, then cut away the excess, or ground it to the strand. 6 7 www.ppc-online.com 6 A BELDEN BRAND Customer Support: 800.800.6652 Drop Hardware ® Diamond Drop Hardware Drop Wire Clamps for CATV and Telephone Cable "B" Drop Wire Clamp •• Used to support both ends of telephone drop, at strand and building. •• Suitable for 1-2 pair .200” max. height and .410’ max. width. •• 6 pair version: .300” max. height and .500" max. width. •• Stainless steel bailwire on all versions. •• Special Packages available. Please check with your PPC/Belden Representative. Part Number Description Material Pair Shim Type Inner Pack Outer Pack 23-44441 "B" Drop Wire Clamp Aluminum 1-2 Serrated -- 500 23-44444 "B" Drop Wire Clamp Aluminum (Bell Packaging) 1-2 Serrated 25 500 23-44445 "B" Drop Wire Clamp Aluminum 1-2 Serrated 2 250 23-82350 "B" Drop Wire Clamp Aluminum 6 Dimpled 1 75 23-82351 "B" Drop Wire Clamp Aluminum 6 Dimpled 25 150 23-88881 "B" Drop Wire Clamp (Bulk Packaging) 1-2 Serrated 25 500 23-88885 "B" Drop Wire Clamp 1-2 Serrated 2 250 Stainless Steel Stainless Steel Installation: 1. Lay cable in shell. 2. Place shim on top of cable with raised embossings against cable. 3. Insert wedge in shell (on top of shim) and pull to engage. (Small end of wedge should be initially engaged in track of large end of shell). 4. Place bailwire on “B” drop wire hook (ram’s horn)with wedge loose. Pull drop wire through clamp until proper sidewalk/alley clearance is achieved. 5. Grasp clamp (bailwire still on ram’s horn) and pull tightly to secure. Customer Support: 800.800.6652 www.ppc-online.com 7 A BELDEN BRAND A BELDEN BRAND ® Diamond Drop Hardware Span Clamps "Q" Span Clamp •• Provides drop wire take offs at mid-span. •• Steel components mechanically galvanized ASTM B695. Part Number Description 27-00185 "Q" Span Clamp Material Clamp Range Steel 1/4"-7/16" 1/4" -- 100
DT-04-18-BR-C
物料型号: 文档中列出了多种硬件产品的型号,例如SC02MFA-SS、23-44441、27-00185等,这些型号对应不同的硬件产品,如Drop Wire Clamp、"B" Drop Wire Clamp、"Q" Span Clamp等。
器件简介: 文档提供了各种硬件产品的简介,例如“Universal Messenger Cable Drop Wire Clamp”允许电缆在不受应变和磨损的情况下“自由浮动”,用于悬挂带信使线的下线电缆。
引脚分配: 文档中没有明确提到“引脚分配”,这通常用于电子元件,而不是硬件产品。
参数特性: 文档详细描述了产品的参数特性,例如尺寸、材料、适用电缆尺寸等。例如,"Q" Span Clamp的部件号、描述、材料、夹紧范围、猪尾直径等。
功能详解: 文档中对每种硬件产品的功能进行了详细解释,如Drop Wire Clamps的不同类型及其安装方法。
应用信息: 文档提供了硬件产品的应用信息,包括它们在CATV和电话电缆上的应用,以及如何使用这些硬件来支持电缆、管道或固定电线。
封装信息: 文档中没有提到“封装信息”,这通常指的是电子元件的封装类型,而不是硬件产品。
此外,文档还强调了Diamond®产品的耐用性和抗腐蚀性,通过机械镀锌工艺来确保产品可以经受长时间的腐蚀环境。文档还提供了关于不同环境条件下服务寿命的估算表,以及符合行业标准和规格的信息。
DT-04-18-BR-C 价格&库存
很抱歉,暂时无法提供与“DT-04-18-BR-C”相匹配的价格&库存,您可以联系我们找货
DT-04-18-BR-C
  • 100+0.24236100+0.03151
