ALTC-2 1/4
ALTC-2 1/4
    BERTECH
    2-1/4 EMI-RFI SHIELDING TAPE
ALTC-2 1/4 数据手册
Technical Datasheet EMI-RFI Shielding Tape RoHS Compliant ALTC Series EMI-RFI shielding tape is made of 2 mil thick aluminum foil with 1.2 mil acrylic adhesive. It is durable and conform to uneven or irregular surfaces Features: • Designed for EMI and RFI shielding applications • Wide operating temperature range up to 212°F • Resistance to flame, moisture, UV degradation and chemicals • High strength backing provides superior resistance to puncture and tear • Thermally conductive which makes it ideal for heating and cooling APPLICATIONS: Printed Circuit Board manufacturing and repair, Shielding in electronic industry & HVAC TYPICAL PHYSICAL PROPERTIES (1) Color Adhesion Type Film Thickness Adhesive Thickness Total Thickness Adhesion to Steel Shielding Effectiveness Operating Temperature Resistance to acids, oils, solvents Length (1) Silver Acrylic 2 Mil 1.2 Mil 3.2 Mil 35 Oz./In. 60dB-80dB(30MHz-1GHz) 40°C (-40°F) to 100°C (212°F) Excellent 60 Yards Specifications are subject to change at any time. If you have any questions, please contact us for the latest update. Bertech® makes no warranty, representation, or guarantee regarding the information contained herein or the suitability of its this product for any particular purpose, nor does Bertech® assume any liability whatsoever arising out of the application or use of this product. It is ultimately the responsibility of the customer to determine a product’s suitability for a particular application.
ALTC-2 1/4
物料型号:ALTC系列
器件简介:EMI-RFI屏蔽胶带由2密耳厚的铝箔和1.2密耳的丙烯酸胶粘剂制成,耐用且能贴合不平整或不规则表面。
引脚分配:文档中未提及引脚分配信息。
参数特性: - 颜色:银色 - 胶粘类型:丙烯酸 - 膜厚:2密耳 - 胶粘剂厚度:1.2密耳 - 总厚度:3.2密耳 - 对钢的粘附力:35盎司/英寸 - 屏蔽效能:60dB-80dB(30MHz-1GHz) - 工作温度范围:-40°C至212°F(40°C) - 耐酸、油、溶剂性:极好 - 长度:60码
功能详解:设计用于电磁干扰和射频干扰屏蔽应用,具有宽工作温度范围,抗火焰、潮湿、紫外线降解和化学品,高强度背衬提供优越的抗穿刺和撕裂性能,热传导性好,适合用于加热和冷却。
应用信息:适用于印刷电路板制造和维修、电子行业屏蔽以及暖通空调。
封装信息:文档中未提供封装信息
ALTC-2 1/4 价格&库存
很抱歉,暂时无法提供与“ALTC-2 1/4”相匹配的价格&库存,您可以联系我们找货
