PPF-50MM
PPF-50MM
    BERTECH
    50MM WIDE POLYIMIDE FILM
PPF-50MM 数据手册
Technical Datasheet Polyimide High Temperature Film RoHS & REACH Compliant PPF Series Polyimide High Temperature Film is made of 1 mil thick polyimide material. They are reliable and durable with a unique combination of electrical, thermal, chemical, and mechanical properties that withstand extreme temperatures, vibration, and other demanding environments. They are packaged on a 3" core and are 100 ft long. APPLICATIONS: Capacitor, coil and transformer insulation, substrates for PCB, motor slot liners, cable and wire assembly. TYPICAL PHYSICAL PROPERTIES (1) Color Adhesion Type Film Thickness UL Rating Elongation Operating Temperature Dielectric Strength Resistance to acids, oils, solvents Length Amber None 1 Mil UL-94-V-0 40 % -73°C (-100°F) - 260°C (500°F) 6,000 Volts Excellent 100 ft (1) Specifications are subject to change at any time. If you have any questions, please contact us for the latest update. Bertech® makes no warranty, representation, or guarantee regarding the information contained herein or the suitability of its this product for any particular purpose, nor does Bertech® assume any liability whatsoever arising out of the application or use of this product. It is ultimately the responsibility of the customer to determine a product’s suitability for a particular application.
PPF-50MM 价格&库存
很抱歉,暂时无法提供与“PPF-50MM”相匹配的价格&库存,您可以联系我们找货
PPF-50MM
