PPT0.51-150MM
PPT0.51-150MM
    BERTECH
    150MM POLYIMIDE HIGH TEMP TAPE
PPT0.51-150MM 数据手册
Technical Datasheet 0.5 Mil Polyimide High Temperature Tape with 1 Mil Silicone Adhesive RoHS & REACH Compliant PPT0.51 Series Polyimide High Temperature Tapes are made of 0.5 mil thick polyimide film with 1 mil thick silicone adhesive. These tapes are reliable and durable with a unique combination of electrical, thermal, chemical, and mechanical properties that withstand extreme temperatures, vibration, and other demanding environments. They are packaged on a 3" core and are 36 yards long. APPLICATIONS: 3D Printing, Aerospace Assembly, Auto Manufacturing, Electronic Assembly, Fiber Optics Manufacturing, and Solar Panels. TYPICAL PHYSICAL PROPERTIES (1) Color Adhesion Type Film Thickness Adhesive Thickness Total Thickness Adhesion to Steel Operating Temperature Dielectric Strength Resistance to acids, oils, solvents Length (1) Amber Silicone 0.5 Mil 1 Mil 1.5 Mil 12.5 Oz/In. 260°C (500°F) 3,000 Volts Excellent 36 Yards Specifications are subject to change at any time. If you have any questions, please contact us for the latest update. Bertech® makes no warranty, representation, or guarantee regarding the information contained herein or the suitability of its this product for any particular purpose, nor does Bertech® assume any liability whatsoever arising out of the application or use of this product. It is ultimately the responsibility of the customer to determine a product’s suitability for a particular application.
PPT0.51-150MM
1. 物料型号:PPT0.51系列 2. 器件简介:聚酰亚胺高温胶带,由0.5 mil厚的聚酰亚胺薄膜和1 mil厚的硅酮胶粘剂制成。这些胶带具有电气、热、化学和机械特性的独特组合,能够承受极端温度、振动和其他苛刻环境。 3. 引脚分配:文档中未提及引脚分配信息。 4. 参数特性: - 颜色:琥珀色 - 胶粘类型:硅酮 - 薄膜厚度:0.5 mil - 胶粘剂厚度:1 mil - 总厚度:1.5 mil - 对钢的粘附力:12.5 Oz/In. - 工作温度:260°C(500°F) - 介电强度:3,000伏特 - 对酸、油、溶剂的抵抗力:优秀 - 长度:36码 5. 功能详解:文档中未提供详细的功能解释,但提到胶带具有独特的电气、热、化学和机械特性,适用于极端环境。 6. 应用信息:3D打印、航空航天组装、汽车制造、电子组装、光纤制造和太阳能板。 7. 封装信息:胶带包装在3英寸的芯上,长度为36码。
PPT0.51-150MM 价格&库存
很抱歉,暂时无法提供与“PPT0.51-150MM”相匹配的价格&库存,您可以联系我们找货
