999-150 NT
999-150 NT
    BIVAR
    LED HOLDER RA 3MM 2LD NYL NAT
999-150 NT 数据手册
REV. B 0.130 [3.3mm] DESCRIPTION DATE 02/24/04 Engineering Update w/o Changes APPROVED M. C. 0.110 [2.8mm] 0.195 [5.0mm] SQ. 0.065 [1.7mm] 0.065 [1.7mm] 0.055 [1.4mm] 0.055 [1.4mm] 0.120 [3.0mm] R.060 [R1.5mm] R.085 [R2.2mm] C/L 0.030 [0.8mm] DIA. TYP. H F MT'L 999-125 A 999-125 BK B Ø.032+.003 -.002 TYP. 999-150 A 999-150 BK B 0.195 [5.0mm] Holder Pitch 999-175 A 999-175 BK B 999-200 A 999-200 BK B Holder Faces 0.175 [4.4mm] PART NO. 0.100 [2.5mm] LED Lead Recommended Mounting Holes for 999-XXX LED Holders C/L H F .125"(3.2mm) .180"(4.6mm) .000" .150"(3.8mm) .205"(5.2mm) .025"(.64mm) .175"(4.4mm) .230"(5.8mm) .050"(1.3mm) .200"(5.1mm) .255"(6.5mm) .075"(1.9mm) STANDARD TOLERANCE  ( UNLESS OTHERWISE SPECIFIED ) 3. MATERIAL B: NYLON 6/6, 94V-2, BLACK. BIVAR MATERIAL CODE 03-NL-BK. BASF ULTRAMID NYLON 6/6 A3K NATURAL W/BLACK PIGMENT ADDED. 2. MATERIAL A: NYLON 6/6, 94V-2, NATURAL. BIVAR MATERIAL CODE 03-NL. BASF ULTRAMID NYLON 6/6 A3K NATURAL. 1. GENERAL SPECIFICATIONS: BIVAR MOLDED COMPONENT SPECIFICATION BV00-E101. DECIMALS .X .XX .XXX ± .1 ± .01 ± .005 DESIGNED: Shane Irving CHECKED: M. Chen ANGULAR X° ± 1° DATE: 06/03/98 DATE: 02/24/03 4 THOMAS, IRVINE, CA. 92618 TEL: (949) 951-8808 FAX: (949) 951-3974 TITLE: T1 (3mm) VARIABLE CENTERLINE LED HOLDER REVISION: PART NO: 999-XXX XX CAGE CODE : 32559 B SHEET # 1 OF 1 CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING.
999-150 NT 价格&库存
很抱歉,暂时无法提供与“999-150 NT”相匹配的价格&库存,您可以联系我们找货
