ELM10855SYD
ELM10855SYD
    BIVAR
    LED ASSEMBLY
ELM10855SYD 数据手册
TYP. LEAD SOLDERING TEMPERATURE(1/16" FROM BODY) STORAGE TEMPERATURE OPERATING TEMPERATURE RANGE REVERSE CURRENT REVERSE VOLTAGE 2 1 M N P R T REV. 0.100 [2.5mm] Ø.032+.003 TYP.-.002 DESCRIPTION 5BC-F 5BC-Y/G-F 5BC-R/Y-F 5BC-A/G-F STANDARD TOLERANCE ± .1 ± .02 ± .010 T. Yin CHECKED: M. Doan DESIGNED: .X .XX .XXX DECIMALS 5V or 12V 1 2 DATE Bi-Color 1 2 07/26/12 11/09/12 09/20/13 09/12/15 07/27/17 ± 1° 07/26/12 DATE: 07/26/12 DATE: X° ANGULAR Red Yellow Red Amber £ FAX: (949) 951-3974 T CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING. SHEET # 1 OF 5 ELM1XXX5XX CAGE CODE : 32559 TITLE: EXTRUDED VERTICAL T-1¾ (5mm) LED NARROW PROFILE ASSY REVISION: PART NO: TEL: (949) 951-8808 4 THOMAS, IRVINE, CA. 92618 Green Green Yellow Green T. Y. T. Y. T. Y. J. C. J. C. APPROVED BI-COLOR POLARITY LED P/N (1) Cathode (2) Cathode Single Color 1 2 LED Offering List Update Removed LED Duplication From Offering List Corrected P/N Typo in BOM Updated LED Optical Characteristics Corrected P/N Typo in Sheet#3 & #4 ( UNLESS OTHERWISE SPECIFIED ) 1. LONG LEAD 0.100 [2.5mm] 2. SHORT LEAD 2 Recommended Mounting Holes 0.020 [0.5mm] SQ. L ABSOLUTE MAXIMUM RATINGS (Ta=25 C) ELM Series Spacer Dia. Ø.200 [Ø5.1mm] 5mm LED, Emitted Color and Lens Appearance ELM Spacer Length "L" -i.e. 0.120" length, use 120 -For metric, use whole number. i.e. 2MM, 10MM ELM1XXX5XX LED Dia. Ø.197 [Ø5.0mm] LED Flange Dia. Ø.224 [Ø5.7mm] Flat Edge Cathode ID 0.339 [8.6mm] Extruded, Self-Retaining LED Spacer ELM 1-XXX 1 2 1 T-1¾ (5mm) Flanged LED, See Pages 2 to 4 5XX-F 1 PART DESCRIPTION 1 PART NUMBER Q'TY ITEM ELM1XXX5BC-Y/G ELM1XXX5BC-R/Y ELM1XXX5BC ELM1XXX5BC-A/G ELM1XXX5BWC ELM1XXX5BWD ELM1XXX5BWT ELM1XXX5GC ELM1XXX5GD ELM1XXX5GT ELM1XXX5PGC ELM1XXX5PGD ELM1XXX5PGT ELM1XXX5YC ELM1XXX5YD ELM1XXX5YT ELM1XXX5AC ELM1XXX5AD ELM1XXX5AT ELM1XXX5HC ELM1XXX5HD ELM1XXX5HT ELM1XXX5RC ELM1XXX5RD ELM1XXX5RT LED Assy. No. GaN/SiC GaN/SiC GaN/SiC GaP/GaP GaP/GaP GaP/GaP GaP/GaP GaP/GaP GaP/GaP GaAsP/GaP GaAsP/GaP GaAsP/GaP GaAsP/GaP GaAsP/GaP GaAsP/GaP GaAsP/GaP GaAsP/GaP GaAsP/GaP GaP/GaP GaP/GaP GaP/GaP GaAsP/GaP GaP/GaP GaAsP/GaP GaP/GaP GaAsP/GaP GaAsP/GaP GaAsP/GaP GaP/GaP Material Chip Lens Peak Wave Emitted Appearance Length Color ʄp (nm) 430 BLUE WATER CLEAR 430 BLUE DIFFUSED 430 BLUE TINTED 568 GREEN WATER CLEAR 568 GREEN DIFFUSED 568 GREEN TINTED 555 PURE GREEN WATER CLEAR 555 PURE GREEN DIFFUSED 555 PURE GREEN TINTED 590 YELLOW WATER CLEAR 590 YELLOW DIFFUSED 590 YELLOW TINTED 605 AMBER WATER CLEAR 605 AMBER DIFFUSED 605 AMBER TINTED 625 HE RED WATER CLEAR 625 HE RED DIFFUSED 625 HE RED TINTED 700 RED WATER CLEAR 700 RED DIFFUSED 700 RED TINTED 605 AMBER WHITE DIFFUSED 568 GREEN 625 RED WHITE DIFFUSED 568 GREEN 625 RED WHITE DIFFUSED 590 YELLOW 590 YELLOW WHITE DIFFUSED 568 GREEN SEE SHEET #1 45 45 45 45 Viewing Angle 2ɽ½ (Deg) 20 45 20 35 45 35 35 45 35 35 45 35 35 45 35 35 45 35 35 45 35 T. Yin CHECKED: M. Doan DESIGNED: ±10% ALL VALUES ± 5° 07/26/12 DATE: 07/26/12 DATE: X° ANGULAR ( UNLESS OTHERWISE SPECIFIED ) £ APPROVED TEL: (949) 951-8808 FAX: (949) 951-3974 4 THOMAS, IRVINE, CA. 92618 5BC-Y/G-F 5BC-R/Y-F 5BC-F 5BC-A/G-F 5BWC-F 5BWD-F 5BWT-F 5GC-F 5GD-F 5GT-F 5PGC-F 5PGD-F 5PGT-F 5YC-F 5YD-F 5YT-F 5AC-F 5AD-F 5AT-F 5HC-F 5HD-F 5HT-F 5RC-F 5RD-F 5RT-F LED P/N DATE T CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING. SHEET # 2 OF 5 ELM1XXX5XX CAGE CODE : 32559 TITLE: EXTRUDED VERTICAL T-1¾ (5mm) LED NARROW PROFILE ASSY REVISION: PART NO: DESCRIPTION STANDARD TOLERANCE Electro-Optical Data @ 20mA If Iv Vf (mA) (mcd) (V) MAX TYP MAX TYP 25 4 4.5 25 25 4 4.5 15 25 4 4.5 30 30 2.1 2.8 40 30 2.1 2.8 25 30 2.1 2.8 40 30 2.2 2.8 10 30 2.2 2.8 10 30 2.2 2.8 10 30 2 2.8 40 30 2 2.8 25 30 2 2.8 40 30 2 2.8 40 30 2 2.8 25 30 2 2.8 40 30 2 2.8 40 30 2 2.8 25 30 2 2.8 40 20 2.1 2.8 2 20 2.1 2.8 2 20 2.1 2.8 2 30 2.0 2.8 6 30 2.1 2.8 6 30 2.0 2.8 6 30 2.1 2.8 8 30 2.0 2.8 6 30 2.0 2.8 5 30 2.0 2.8 5 30 2.1 2.8 8 REV. ELM1XXX5UBWC ELM1XXX5SGC ELM1XXX5SGD ELM1XXX5SGT ELM1XXX5SYC ELM1XXX5SYD ELM1XXX5SYT ELM1XXX5SRC ELM1XXX5SRD ELM1XXX5SRT ELM1XXX5UGC ELM1XXX5SUGC ELM1XXX5UYC ELM1XXX5SUYC ELM1XXX5UUYC ELM1XXX5UOC ELM1XXX5UOC ELM1XXX5URC ELM1XXX5SURC ELM1XXX5UWC LED Assy. No. InGaN/SiC GaP/GaP GaP/GaP GaP/GaP GaAsP/GaP GaAsP/GaP GaAsP/GaP GaAlAs/GaAs GaAlAs/GaAs GaAlAs/GaAs AlGaInP AlGaInP AlGaInP AlGaInP AlGaInP AlGaInP AlGaInP GaAlAs/GaAs AlGaInP InGaN/SiC Material Chip Peak Wave Length ʄp (nm) 468 568 568 568 590 590 590 645 645 645 570 570 590 590 590 625 625 645 640 6500K BLUE GREEN GREEN GREEN YELLOW YELLOW YELLOW SUPER RED SUPER RED SUPER RED GREEN GREEN YELLOW YELLOW YELLOW ORANGE ORANGE RED RED WHITE Emitted Color WATER CLEAR WATER CLEAR DIFFUSED TINTED WATER CLEAR DIFFUSED TINTED WATER CLEAR DIFFUSED TINTED WATER CLEAR WATER CLEAR WATER CLEAR WATER CLEAR WATER CLEAR WATER CLEAR WATER CLEAR WATER CLEAR WATER CLEAR WATER CLEAR Lens Appearance SEE SHEET #1 Viewing Angle 2ɽ½ (Deg) 15 35 40 35 35 40 35 35 40 35 35 35 30 35 35 35 35 30 35 30 T. Yin CHECKED: M. Doan DESIGNED: ±10% ALL VALUES ± 5° 07/26/12 DATE: 07/26/12 DATE: X° ANGULAR ( UNLESS OTHERWISE SPECIFIED ) £ APPROVED TEL: (949) 951-8808 FAX: (949) 951-3974 4 THOMAS, IRVINE, CA. 92618 5BWC2.515F 5SGC-F 5SGD-F 5SGT-F 5SYC-F 5SYD-F 5SYT-F 5SRC-F 5SRD-F 5SRT-F 5UGC-F 5SUGC-F 5UYC-F 5SUYC-F 5UUYC-F 5UOC-F 5SUOC-F 5URC-F 5SURC-F 5WC2.730F LED P/N DATE T CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING. SHEET # 3 OF 5 ELM1XXX5XX CAGE CODE : 32559 TITLE: EXTRUDED VERTICAL T-1¾ (5mm) LED NARROW PROFILE ASSY REVISION: PART NO: DESCRIPTION STANDARD TOLERANCE Electro-Optical Data @ 20mA Vf If Iv (V) (mA) (mcd) MAX TYP MAX TYP 50 3.2 3.6 8000 30 2.1 2.8 60 30 2.1 2.8 50 30 2.1 2.8 60 30 2 2.8 600 30 2 2.8 150 30 2 2.8 600 30 1.7 2.4 60 30 1.7 2.4 40 30 1.7 2.4 60 30 2.1 2.4 400 30 2.1 2.4 300 30 2 2.4 1000 30 2 2.4 700 30 2 2.4 500 30 1.8 2.4 1400 30 1.8 2.4 1300 30 1.7 2.4 400 30 1.8 2.4 500 100 3.5 4.2 2700 REV. LOW CURRENT ELM1XXX5BWDL ELM1XXX5PGDL ELM1XXX5GDL ELM1XXX5YDL ELM1XXX5ADL ELM1XXX5HDL ELM1XXX5SRDL 5 Volt ELM1XXX5BWD5V ELM1XXX5GC5V ELM1XXX5GD5V ELM1XXX5GT5V ELM1XXX5AD5V ELM1XXX5HD5V ELM1XXX5RD5V ELM1XXX5YD5V 12 Volt ELM1XXX5GC12V ELM1XXX5GD12V ELM1XXX5HC12V ELM1XXX5HD12V ELM1XXX5RC12V ELM1XXX5RD12V ELM1XXX5YC12V ELM1XXX5YD12V LED Assy. No. BLUE PURE GREEN GREEN YELLOW AMBER HE RED SUPER RED BLUE GREEN GREEN GREEN AMBER HE RED RED YELLOW GREEN GREEN HE RED HE RED RED RED YELLOW YELLOW 430 568 568 568 605 625 700 590 568 568 625 625 700 700 590 590 Emitted Color 430 555 568 590 605 625 645 Peak Wave Length ʄp (nm) WATER CLEAR DIFFUSED WATER CLEAR DIFFUSED WATER CLEAR DIFFUSED WATER CLEAR DIFFUSED DIFFUSED WATER CLEAR DIFFUSED TINTED DIFFUSED DIFFUSED DIFFUSED DIFFUSED DIFFUSED DIFFUSED DIFFUSED DIFFUSED DIFFUSED DIFFUSED DIFFUSED Lens Appearance 40 25 50 30 2 1.5 25 20 15 40 25 40 25 30 1.5 25 4 1 4 4 4 5 6 Iv (mcd) TYP 35 40 35 40 35 40 35 40 40 40 40 40 40 40 40 40 40 40 40 40 40 40 40 T. Yin CHECKED: M. Doan DESIGNED: ±10% ALL VALUES ± 5° 07/26/12 DATE: 07/26/12 DATE: X° ANGULAR ( UNLESS OTHERWISE SPECIFIED ) 5BWDL-F 5PGDL-F 5GDL-F 5YDL-F 5ADL-F 5HDL-F 5SRDL-F LED P/N DATE £ APPROVED FAX: (949) 951-3974 T CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING. SHEET # 4 OF 5 ELM1XXX5XX CAGE CODE : 32559 TITLE: EXTRUDED VERTICAL T-1¾ (5mm) LED NARROW PROFILE ASSY REVISION: PART NO: TEL: (949) 951-8808 4 THOMAS, IRVINE, CA. 92618 5GC12V-F 5GD12V-F 5HC12V-F 5HD12V-F 5RC12V-F 5RD12V-F 5YC12V-F 5YD12V-F 5BWD5V-F 5GC5V-F 5GD5V-F 5GT5V-F 5AD5V-F 5HD5V-F 5RD5V-F 5YD5V-F DESCRIPTION Viewing Angle 2ɽ½ (Deg) SEE SHEET #1 STANDARD TOLERANCE Electro-Optical Data Vf If (V) (mA) TYP TYP MAX Data @ 2mA 2 3.8 4.2 2 2.1 2.6 2 2.1 2.6 2 2 2.6 2 2 2.6 2 2 2.6 2 1.7 2.3 Data @ 5V 5 5 5 5 5 5 5 5 Data @ 12V 12 12 12 12 12 12 12 12 REV. TAPE & REEL 1,000 pcs / reel 14" X 2" REEL DIRECTION OF FEED 0.100 [2.5mm] TYP. 0.500 [12.7mm] TYP. SEE SHEET #1 DESCRIPTION ± .1 ± .02 ± .010 T. Yin CHECKED: M. Doan DESIGNED: .X .XX .XXX DECIMALS ± 1° 07/26/12 DATE: 07/26/12 DATE: X° ANGULAR ( UNLESS OTHERWISE SPECIFIED ) STANDARD TOLERANCE APPROVED £ 13.5 [345mm] REF. 16.5 [420mm] REF. DATE FAX: (949) 951-3974 T REVISION: CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING. SHEET # 5 OF 5 ELM1XXX5XX CAGE CODE : 32559 PART NO: EXTRUDED VERTICAL T-1¾ (5mm) LED NARROW PROFILE ASSY TITLE: TEL: (949) 951-8808 4 THOMAS, IRVINE, CA. 92618 AMMO PACK 2,000 pcs / box 2.5 [63.5mm] REF. LABEL 0.058 [1.5mm] MAX. 0.511 [13.0mm] MASKING TAPE 0.709 [18.0mm] CARBOARD REEL (.020" THICK) LONG LEAD ANODE TYP. 0.500 [12.7mm] TYP. NOTE: 1. STANDARD PART NUMBERS ARE PACKAGED IN LOOSE PIECES USING PACKAGING TRAYS 2. ADD "T" SUFFIX TO PART NUMBER FOR TAPE AND REEL PACKAGING OPTION (1,000 PCS/REEL) 3. ADD "A" SUFFIX TO PART NUMBER FOR AMMO PACK OPTION (2,000 PCS/BOX) 4. TAPE AND REEL PACKAGING COMPLY TO EIA-468-C Ø.158 [Ø4.0mm] TYP. 0.650 [16.5mm] STANDARD PACKAGING TRAY XXX* = ELM SPACER HEIGHT 0.650 + XXX* 0.250 [6.4mm] TYP. REV.
ELM10855SYD 价格&库存
很抱歉,暂时无法提供与“ELM10855SYD”相匹配的价格&库存,您可以联系我们找货
