TYP.
LEAD SOLDERING TEMPERATURE(1/16" FROM BODY)
STORAGE TEMPERATURE
OPERATING TEMPERATURE RANGE
REVERSE CURRENT
REVERSE VOLTAGE
2
1
M
N
P
R
T
REV.
0.100 [2.5mm]
Ø.032+.003
TYP.-.002
DESCRIPTION
5BC-F
5BC-Y/G-F
5BC-R/Y-F
5BC-A/G-F
STANDARD TOLERANCE
± .1
± .02
± .010
T. Yin
CHECKED:
M. Doan
DESIGNED:
.X
.XX
.XXX
DECIMALS
5V
or
12V
1
2
DATE
Bi-Color
1
2
07/26/12
11/09/12
09/20/13
09/12/15
07/27/17
± 1°
07/26/12
DATE:
07/26/12
DATE:
X°
ANGULAR
Red
Yellow
Red
Amber
FAX: (949) 951-3974
T
CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING.
SHEET # 1 OF 5
ELM1XXX5XX
CAGE CODE : 32559
TITLE:
EXTRUDED VERTICAL T-1¾
(5mm) LED NARROW PROFILE ASSY
REVISION:
PART NO:
TEL: (949) 951-8808
4 THOMAS, IRVINE, CA. 92618
Green
Green
Yellow
Green
T. Y.
T. Y.
T. Y.
J. C.
J. C.
APPROVED
BI-COLOR POLARITY
LED P/N (1) Cathode (2) Cathode
Single
Color
1
2
LED Offering List Update
Removed LED Duplication From Offering List
Corrected P/N Typo in BOM
Updated LED Optical Characteristics
Corrected P/N Typo in Sheet#3 & #4
( UNLESS OTHERWISE SPECIFIED )
1. LONG LEAD
0.100 [2.5mm]
2. SHORT LEAD
2
Recommended Mounting Holes
0.020 [0.5mm] SQ.
L
ABSOLUTE MAXIMUM RATINGS (Ta=25 C)
ELM Series
Spacer Dia.
Ø.200 [Ø5.1mm]
5mm LED,
Emitted Color and Lens
Appearance
ELM Spacer Length "L"
-i.e. 0.120" length, use 120
-For metric, use whole
number. i.e. 2MM, 10MM
ELM1XXX5XX
LED Dia.
Ø.197 [Ø5.0mm]
LED Flange Dia.
Ø.224 [Ø5.7mm]
Flat Edge
Cathode ID
0.339 [8.6mm]
Extruded, Self-Retaining LED Spacer
ELM 1-XXX
1
2
1
T-1¾ (5mm) Flanged LED, See Pages 2 to 4
5XX-F
1
PART DESCRIPTION
1
PART NUMBER
Q'TY
ITEM
ELM1XXX5BC-Y/G
ELM1XXX5BC-R/Y
ELM1XXX5BC
ELM1XXX5BC-A/G
ELM1XXX5BWC
ELM1XXX5BWD
ELM1XXX5BWT
ELM1XXX5GC
ELM1XXX5GD
ELM1XXX5GT
ELM1XXX5PGC
ELM1XXX5PGD
ELM1XXX5PGT
ELM1XXX5YC
ELM1XXX5YD
ELM1XXX5YT
ELM1XXX5AC
ELM1XXX5AD
ELM1XXX5AT
ELM1XXX5HC
ELM1XXX5HD
ELM1XXX5HT
ELM1XXX5RC
ELM1XXX5RD
ELM1XXX5RT
LED Assy. No.
GaN/SiC
GaN/SiC
GaN/SiC
GaP/GaP
GaP/GaP
GaP/GaP
GaP/GaP
GaP/GaP
GaP/GaP
GaAsP/GaP
GaAsP/GaP
GaAsP/GaP
GaAsP/GaP
GaAsP/GaP
GaAsP/GaP
GaAsP/GaP
GaAsP/GaP
GaAsP/GaP
GaP/GaP
GaP/GaP
GaP/GaP
GaAsP/GaP
GaP/GaP
GaAsP/GaP
GaP/GaP
GaAsP/GaP
GaAsP/GaP
GaAsP/GaP
GaP/GaP
Material
Chip
Lens
Peak Wave
Emitted
Appearance
Length
Color
ʄp (nm)
430
BLUE
WATER CLEAR
430
BLUE
DIFFUSED
430
BLUE
TINTED
568
GREEN
WATER CLEAR
568
GREEN
DIFFUSED
568
GREEN
TINTED
555
PURE GREEN WATER CLEAR
555
PURE GREEN
DIFFUSED
555
PURE GREEN
TINTED
590
YELLOW
WATER CLEAR
590
YELLOW
DIFFUSED
590
YELLOW
TINTED
605
AMBER
WATER CLEAR
605
AMBER
DIFFUSED
605
AMBER
TINTED
625
HE RED
WATER CLEAR
625
HE RED
DIFFUSED
625
HE RED
TINTED
700
RED
WATER CLEAR
700
RED
DIFFUSED
700
RED
TINTED
605
AMBER
WHITE DIFFUSED
568
GREEN
625
RED
WHITE DIFFUSED
568
GREEN
625
RED
WHITE DIFFUSED
590
YELLOW
590
YELLOW
WHITE DIFFUSED
568
GREEN
SEE SHEET #1
45
45
45
45
Viewing
Angle
2ɽ½
(Deg)
45
35
35
45
35
35
45
35
35
45
35
35
45
35
35
45
35
T. Yin
CHECKED:
M. Doan
DESIGNED:
±10% ALL VALUES
± 5°
07/26/12
DATE:
07/26/12
DATE:
X°
ANGULAR
APPROVED
TEL: (949) 951-8808
FAX: (949) 951-3974
5BC-Y/G-F
5BC-R/Y-F
5BC-F
5BC-A/G-F
5BWC-F
5BWD-F
5BWT-F
5GC-F
5GD-F
5GT-F
5PGC-F
5PGD-F
5PGT-F
5YC-F
5YD-F
5YT-F
5AC-F
5AD-F
5AT-F
5HC-F
5HD-F
5HT-F
5RC-F
5RD-F
5RT-F
LED P/N
DATE
T
SHEET # 2 OF 5
ELM1XXX5XX
CAGE CODE : 32559
TITLE:
REVISION:
PART NO:
DESCRIPTION
STANDARD TOLERANCE
Electro-Optical Data @ 20mA
If
Iv
Vf
(mA)
(mcd)
(V)
MAX
TYP
MAX
TYP
25
4
4.5
25
25
4
4.5
15
25
4
4.5
30
30
2.1
2.8
40
30
2.1
2.8
25
30
2.1
2.8
40
30
2.2
2.8
10
30
2.2
2.8
10
30
2.2
2.8
10
30
2
2.8
40
30
2
2.8
25
30
2
2.8
40
30
2
2.8
40
30
2
2.8
25
30
2
2.8
40
30
2
2.8
40
30
2
2.8
25
30
2
2.8
40
2.8
2
2.8
2
2.8
2
30
2.0
2.8
6
30
2.1
2.8
6
30
2.0
2.8
6
30
2.1
2.8
8
30
2.0
2.8
6
30
2.0
2.8
5
30
2.0
2.8
5
30
2.1
2.8
8
REV.
ELM1XXX5UBWC
ELM1XXX5SGC
ELM1XXX5SGD
ELM1XXX5SGT
ELM1XXX5SYC
ELM1XXX5SYD
ELM1XXX5SYT
ELM1XXX5SRC
ELM1XXX5SRD
ELM1XXX5SRT
ELM1XXX5UGC
ELM1XXX5SUGC
ELM1XXX5UYC
ELM1XXX5SUYC
ELM1XXX5UUYC
ELM1XXX5UOC
ELM1XXX5UOC
ELM1XXX5URC
ELM1XXX5SURC
ELM1XXX5UWC
LED Assy. No.
InGaN/SiC
GaP/GaP
GaP/GaP
GaP/GaP
GaAsP/GaP
GaAsP/GaP
GaAsP/GaP
GaAlAs/GaAs
GaAlAs/GaAs
GaAlAs/GaAs
AlGaInP
AlGaInP
AlGaInP
AlGaInP
AlGaInP
AlGaInP
AlGaInP
GaAlAs/GaAs
AlGaInP
InGaN/SiC
Material
Chip
Peak Wave
Length
ʄp (nm)
468
568
568
568
590
590
590
645
645
645
570
570
590
590
590
625
625
645
640
6500K
BLUE
GREEN
GREEN
GREEN
YELLOW
YELLOW
YELLOW
SUPER RED
SUPER RED
SUPER RED
GREEN
GREEN
YELLOW
YELLOW
YELLOW
ORANGE
ORANGE
RED
RED
WHITE
Emitted
Color
WATER CLEAR
WATER CLEAR
DIFFUSED
TINTED
WATER CLEAR
DIFFUSED
TINTED
WATER CLEAR
DIFFUSED
TINTED
WATER CLEAR
WATER CLEAR
WATER CLEAR
WATER CLEAR
WATER CLEAR
WATER CLEAR
WATER CLEAR
WATER CLEAR
WATER CLEAR
WATER CLEAR
Lens
Appearance
SEE SHEET #1
Viewing
Angle
2ɽ½
(Deg)
15
35
40
35
35
40
35
35
40
35
35
35
30
35
35
35
35
30
35
30
T. Yin
CHECKED:
M. Doan
DESIGNED:
±10% ALL VALUES
± 5°
07/26/12
DATE:
07/26/12
DATE:
X°
ANGULAR
APPROVED
TEL: (949) 951-8808
FAX: (949) 951-3974
5BWC2.515F
5SGC-F
5SGD-F
5SGT-F
5SYC-F
5SYD-F
5SYT-F
5SRC-F
5SRD-F
5SRT-F
5UGC-F
5SUGC-F
5UYC-F
5SUYC-F
5UUYC-F
5UOC-F
5SUOC-F
5URC-F
5SURC-F
5WC2.730F
LED P/N
DATE
T
SHEET # 3 OF 5
ELM1XXX5XX
CAGE CODE : 32559
TITLE:
REVISION:
PART NO:
DESCRIPTION
STANDARD TOLERANCE
Vf
If
Iv
(V)
(mA)
(mcd)
MAX
TYP
MAX
TYP
50
3.2
3.6
8000
30
2.1
2.8
60
30
2.1
2.8
50
30
2.1
2.8
60
30
2
2.8
600
30
2
2.8
150
30
2
2.8
600
30
1.7
2.4
60
30
1.7
2.4
40
30
1.7
2.4
60
30
2.1
2.4
400
30
2.1
2.4
300
30
2
2.4
1000
30
2
2.4
700
30
2
2.4
500
30
1.8
2.4
1400
30
1.8
2.4
1300
30
1.7
2.4
400
30
1.8
2.4
500
100
3.5
4.2
2700
REV.
LOW CURRENT
ELM1XXX5BWDL
ELM1XXX5PGDL
ELM1XXX5GDL
ELM1XXX5YDL
ELM1XXX5ADL
ELM1XXX5HDL
ELM1XXX5SRDL
5 Volt
ELM1XXX5BWD5V
ELM1XXX5GC5V
ELM1XXX5GD5V
ELM1XXX5GT5V
ELM1XXX5AD5V
ELM1XXX5HD5V
ELM1XXX5RD5V
ELM1XXX5YD5V
12 Volt
ELM1XXX5GC12V
ELM1XXX5GD12V
ELM1XXX5HC12V
ELM1XXX5HD12V
ELM1XXX5RC12V
ELM1XXX5RD12V
ELM1XXX5YC12V
ELM1XXX5YD12V
LED Assy. No.
BLUE
PURE GREEN
GREEN
YELLOW
AMBER
HE RED
SUPER RED
BLUE
GREEN
GREEN
GREEN
AMBER
HE RED
RED
YELLOW
GREEN
GREEN
HE RED
HE RED
RED
RED
YELLOW
YELLOW
430
568
568
568
605
625
700
590
568
568
625
625
700
700
590
590
Emitted
Color
430
555
568
590
605
625
645
Peak Wave
Length
ʄp (nm)
WATER CLEAR
DIFFUSED
WATER CLEAR
DIFFUSED
WATER CLEAR
DIFFUSED
WATER CLEAR
DIFFUSED
DIFFUSED
WATER CLEAR
DIFFUSED
TINTED
DIFFUSED
DIFFUSED
DIFFUSED
DIFFUSED
DIFFUSED
DIFFUSED
DIFFUSED
DIFFUSED
DIFFUSED
DIFFUSED
DIFFUSED
Lens
Appearance
40
25
50
30
2
1.5
25
40
25
40
25
30
1.5
25
4
1
4
4
4
5
6
Iv
(mcd)
TYP
35
40
35
40
35
40
35
40
40
40
40
40
40
40
40
40
40
40
40
40
40
40
40
T. Yin
CHECKED:
M. Doan
DESIGNED:
±10% ALL VALUES
± 5°
07/26/12
DATE:
07/26/12
DATE:
X°
ANGULAR
5BWDL-F
5PGDL-F
5GDL-F
5YDL-F
5ADL-F
5HDL-F
5SRDL-F
LED P/N
DATE
APPROVED
FAX: (949) 951-3974
T
SHEET # 4 OF 5
ELM1XXX5XX
CAGE CODE : 32559
TITLE:
REVISION:
PART NO:
TEL: (949) 951-8808
5GC12V-F
5GD12V-F
5HC12V-F
5HD12V-F
5RC12V-F
5RD12V-F
5YC12V-F
5YD12V-F
5BWD5V-F
5GC5V-F
5GD5V-F
5GT5V-F
5AD5V-F
5HD5V-F
5RD5V-F
5YD5V-F
DESCRIPTION
Viewing
Angle
2ɽ½
(Deg)
SEE SHEET #1
STANDARD TOLERANCE
Vf
If
(V)
(mA)
TYP
TYP
MAX
Data @ 2mA
2
3.8
4.2
2
2.1
2.6
2
2.1
2.6
2
2
2.6
2
2
2.6
2
2
2.6
2
1.7
2.3
Data @ 5V
5
5
5
5
5
5
5
5
Data @ 12V
12
12
12
12
12
12
12
12
REV.
TAPE & REEL
1,000 pcs / reel
14" X 2" REEL
DIRECTION OF FEED
0.100 [2.5mm]
TYP.
0.500 [12.7mm]
TYP.
SEE SHEET #1
DESCRIPTION
± .1
± .02
± .010
T. Yin
CHECKED:
M. Doan
DESIGNED:
.X
.XX
.XXX
DECIMALS
± 1°
07/26/12
DATE:
07/26/12
DATE:
X°
ANGULAR
STANDARD TOLERANCE
APPROVED
13.5 [345mm] REF.
16.5 [420mm] REF.
DATE
FAX: (949) 951-3974
T
REVISION:
SHEET # 5 OF 5
ELM1XXX5XX
CAGE CODE : 32559
PART NO:
TITLE:
TEL: (949) 951-8808
AMMO PACK
2,000 pcs / box
2.5 [63.5mm] REF.
LABEL
0.058 [1.5mm]
MAX.
0.511 [13.0mm]
MASKING TAPE
0.709 [18.0mm]
CARBOARD REEL
(.020" THICK)
LONG LEAD
ANODE
TYP.
0.500 [12.7mm]
TYP.
NOTE:
1. STANDARD PART NUMBERS ARE PACKAGED IN LOOSE PIECES USING PACKAGING TRAYS
2. ADD "T" SUFFIX TO PART NUMBER FOR TAPE AND REEL PACKAGING OPTION (1,000 PCS/REEL)
3. ADD "A" SUFFIX TO PART NUMBER FOR AMMO PACK OPTION (2,000 PCS/BOX)
4. TAPE AND REEL PACKAGING COMPLY TO EIA-468-C
Ø.158 [Ø4.0mm]
TYP.
0.650 [16.5mm]
STANDARD PACKAGING TRAY
XXX* = ELM SPACER HEIGHT
0.650 + XXX*
0.250 [6.4mm]
TYP.
REV.
很抱歉,暂时无法提供与“ELM13005SRDL”相匹配的价格&库存,您可以联系我们找货
