ELM38505GC
ELM38505GC
    BIVAR
    LED ASSEMBLY
ELM38505GC 数据手册
ITEM 1 2 Q'TY 1 1 PART NUMBER 5XX-F ELM 3-XXX REV. PART DESCRIPTION C D E F G H J K T-1 ¾ (5mm) Flange LED, See sheet 2 & 3 Extruded, Self-Retaining LED Spacer DATE DESCRIPTION 01/17/07 01/04/08 09/03/08 02/09/11 06/07/11 11/21/11 09/25/13 05/25/16 Changed Spacer from ELM3 to ELM8. Added -F to Sheets 2 and 3. Removed Tolerance Note. Added Bi-Color LEDs on Sheet 3. Added Tape & Reel Options. Tape & Reel Design Update. Corrected P/N Typo in BOM. Engineering Update w/o Changes. 1 APPROVED M. C. M. C. M. C. T. Y. T. Y. T. Y. T. Y. J. C. 2 SHORT LEAD L 0.346 [8.8mm] 0.020 [0.5mm] SQ. TYP. Flat Edge Cathode ID Ø.255 [Ø6.5mm] Spacer Dia. Ø0.197 [Ø5.0mm] LED Dia. 2 2 1 1 0.100 [2.5mm] 0.039 [1.0mm] Ø.032+.003 -.002 TYP. BI-COLOR POLARITY LED P/N (1) Cathode (2) Cathode 5BC-F Green Red 5BC-Y/G-F Green Yellow 0.100 [2.5mm] TYP. Recommended Mounting Holes ABSOLUTE MAXIMUM RATINGS (Ta = 25°C) STANDARD TOLERANCE DECIMALS REVERSE VOLTAGE 5V REVERSE CURRENT ( VR=5V) 100µA OPERATING TEMPERATURE RANGE -25°C ~ 85°C STORAGE TEMPERATURE -30°C ~ 100°C LEAD SOLDERING TEMPERATURE (1/16" FROM BODY) 260°C for 5 Seconds ® ( UNLESS OTHERWISE SPECIFIED ) .X .XX .XXX ± .1 ± .02 ± .010 DESIGNED: S. Dam CHECKED: T. Yin ANGULAR X° ± 1° DATE: 05/05/06 DATE: 05/05/06 4 THOMAS, IRVINE, CA. 92618 TEL: (949) 951-8808 FAX: (949) 951-3974 TITLE: Extruded Vertical T-1 ¾ (5mm) LED Standard Spacer Profile Assy REVISION: PART NO: ELM3XXX5XX CAGE CODE : 32559 K SHEET # 1 OF 4 CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING. REV. DATE DESCRIPTION APPROVED SEE SHEET #1 LED Assy. No. ELM3XXX5BWC ELM3XXX5BWD ELM3XXX5BWT ELM3XXX5GC ELM3XXX5GD ELM3XXX5GT ELM3XXX5PGC ELM3XXX5PGD ELM3XXX5PGT ELM3XXX5YC ELM3XXX5YD ELM3XXX5YT ELM3XXX5AC ELM3XXX5AD ELM3XXX5AT ELM3XXX5HC ELM3XXX5HD ELM3XXX5HT ELM3XXX5RC ELM3XXX5RD ELM3XXX5RT ELM3XXX5BC ELM3XXX5BC-Y/G Material GaN/SiC GaN/SiC GaN/SiC GaP/GaP GaP/GaP GaP/GaP GaP/GaP GaP/GaP GaP/GaP GaAsP/GaP GaAsP/GaP GaAsP/GaP GaAsP/GaP GaAsP/GaP GaAsP/GaP GaAsP/GaP GaAsP/GaP GaAsP/GaP GaP/GaP GaP/GaP GaP/GaP GaAsP/GaP GaP/GaP GaAsP/GaP GaP/GaP Chip Peak Wave Length 430 430 430 568 568 568 555 555 555 590 590 590 605 605 605 625 625 625 700 700 700 625 568 590 568 Emitted Color Lens Appearance BLUE WATER CLEAR BLUE DIFFUSED BLUE TINTED GREEN WATER CLEAR GREEN DIFFUSED GREEN TINTED PURE GREEN WATER CLEAR PURE GREEN DIFFUSED PURE GREEN TINTED YELLOW WATER CLEAR YELLOW DIFFUSED YELLOW TINTED AMBER WATER CLEAR AMBER DIFFUSED AMBER TINTED HE RED WATER CLEAR HE RED DIFFUSED HE RED TINTED RED WATER CLEAR RED DIFFUSED RED TINTED RED WHITE DIFFUSED GREEN YELLOW WHITE DIFFUSED GREEN Electro-Optical Data @ 20mA Vf If Iv (V) (mA) (mcd) MAX TYP MAX TYP 25 4 4.5 25 25 4 4.5 15 25 4 4.5 30 30 2.1 2.8 40 30 2.1 2.8 25 30 2.1 2.8 40 30 2.2 2.8 10 30 2.2 2.8 10 30 2.2 2.8 10 30 2 2.8 40 30 2 2.8 25 30 2 2.8 40 30 2 2.8 40 30 2 2.8 25 30 2 2.8 40 30 2 2.8 40 30 2 2.8 25 30 2 2.8 40 20 2.1 2.8 2 20 2.1 2.8 2 20 2.1 2.8 2 30 2.0 2.8 6 30 2.1 2.8 8 30 2.0 2.8 5 30 2.1 2.8 8 Viewing Angle 2θ½ (Deg) 20 45 20 35 45 35 35 45 35 35 45 35 35 45 35 35 45 35 35 45 35 5BWC-F 5BWD-F 5BWT-F 5GC-F 5GD-F 5GT-F 5PGC-F 5PGD-F 5PGT-F 5YC-F 5YD-F 5YT-F 5AC-F 5AD-F 5AT-F 5HC-F 5HD-F 5HT-F 5RC-F 5RD-F 5RT-F 45 5BC-F 45 5BC-Y/G-F LED P/N STANDARD TOLERANCE ® ( UNLESS OTHERWISE SPECIFIED ) 10% All Values ANGULAR 4 THOMAS, IRVINE, CA. 92618 TEL: (949) 951-8808 DESIGNED: S. Dam CHECKED: T. Yin DATE: 05/05/06 DATE: 05/05/06 FAX: (949) 951-3974 TITLE: Extruded Vertical T-1 ¾ (5mm) LED Standard Spacer Profile Assy REVISION: PART NO: ELM3XXX5XX CAGE CODE : 32559 K SHEET # 2 OF 4 CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING. REV. DATE DESCRIPTION APPROVED SEE SHEET #1 Max. Rating Peak Wave Length λ p(nm ) Em itted Color ELM3XXX5BWDL 430 BLUE ELM3XXX5PGDL 555 ELM3XXX5GDL LED Assy. No. Lens Appearance Electro-Optical Data @ 2m A If (m A) View ing Angle 2 ½ (Deg) Iv (m cd) Vf (V) MAX TYP MAX DIFFUSED 7 3.8 4.2 4 40 5BWDL-F PURE GREEN DIFFUSED 7 2.1 2.6 1 40 5PGDL-F 568 GREEN DIFFUSED 7 2.1 2.6 4 40 5GDL-F ELM3XXX5YDL 590 YELLOW DIFFUSED 7 2.0 2.6 4 40 5YDL-F ELM3XXX5ADL 605 AMBER DIFFUSED 7 2.0 2.6 4 40 5ADL-F ELM3XXX5HDL 625 HE RED DIFFUSED 7 2.0 2.6 5 40 5HDL-F ELM3XXX5SRDL 645 SUPER RED DIFFUSED 7 1.7 2.3 6 40 5SRDL-F Assembly P/N 5 Volt ELM3XXX5GD5V ELM3XXX5AD5V ELM3XXX5HD5V ELM3XXX5RD5V ELM3XXX5YD5V Peak Wave Length λp(nm) Emitted Color Lens Appearance GREEN AMBER HE RED RED YELLOW 568 605 625 700 590 DIFFUSED DIFFUSED DIFFUSED DIFFUSED DIFFUSED TYP LED P/N Electro-Optical Data Vf If Iv (V) (mA) (mcd) MAX TYP MAX TYP Data @ 5V 5 25 5 25 5 30 5 1.5 5 25 Viewing Angle 2 θ½ (Deg) LED P/N 40 40 40 40 40 5GD5V-F 5AD5V-F 5HD5V-F 5RD5V-F 5YD5V-F STANDARD TOLERANCE ® ( UNLESS OTHERWISE SPECIFIED ) 10% All Values ANGULAR 4 THOMAS, IRVINE, CA. 92618 TEL: (949) 951-8808 DESIGNED: S. Dam CHECKED: T. Yin DATE: 05/05/06 DATE: 05/05/06 FAX: (949) 951-3974 TITLE: Extruded Vertical T-1¾ (5mm) LED Standard Spacer Profile Assy REVISION: PART NO: ELM3XXX5XX CAGE CODE : 32559 K SHEET # 3 OF 4 CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING. REV. DATE DESCRIPTION APPROVED SEE SHEET #1 0.250 [6.4mm] TYP. 0.500 [12.7mm] TYP. 0.709 [18.0mm] CARBOARD REEL (.020" THICK) 0.650 + XXX* XXX* = ELM SPACER HEIGHT 0.650 [16.5mm] 0.511 [13.0mm] MASKING TAPE Ø.158 [Ø4.0mm] TYP. 0.100 [2.5mm] TYP. 0.500 [12.7mm] TYP. LONG LEAD ANODE TYP. 0.058 [1.5mm] MAX. DIRECTION OF FEED LABEL 16.5 [420mm] REF. 14" X 2" REEL 13.5 [345mm] REF. 2.5 [63.5mm] REF. STANDARD PACKAGING TRAY TAPE & REEL 1,000 pcs / reel AMMO PACK 2,000 pcs / box STANDARD TOLERANCE ® ( UNLESS OTHERWISE SPECIFIED ) DECIMALS NOTE: 1. STANDARD PART NUMBERS ARE PACKAGED IN LOOSE PIECES USING PACKAGING TRAYS 2. ADD "T" SUFFIX TO PART NUMBER FOR TAPE AND REEL PACKAGING OPTION (1,000 PCS/REEL) 3. ADD "A" SUFFIX TO PART NUMBER FOR AMMO PACK OPTION (2,000 PCS/BOX) 4. TAPE AND REEL PACKAGING COMPLY TO EIA-468-C .X .XX .XXX ± .1 ± .02 ± .010 DESIGNED: S. Dam CHECKED: T. Yin ANGULAR X° ± 1° DATE: 05/05/06 DATE: 05/05/06 4 THOMAS, IRVINE, CA. 92618 TEL: (949) 951-8808 FAX: (949) 951-3974 TITLE: Extruded Vertical T-1 3 4 (5mm) LED Standard Spacer Profile Assy REVISION: PART NO: ELM3XXX5XX CAGE CODE : 32559 K SHEET # 4 OF 4 CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING.
ELM38505GC 价格&库存
很抱歉,暂时无法提供与“ELM38505GC”相匹配的价格&库存,您可以联系我们找货
