ITEM
1
2
Q'TY
1
1
PART NUMBER
5XX-F
ELM 3-XXX
REV.
PART DESCRIPTION
C
D
E
F
G
H
J
K
T-1 ¾ (5mm) Flange LED, See sheet 2 & 3
Extruded, Self-Retaining LED Spacer
DATE
DESCRIPTION
01/17/07
01/04/08
09/03/08
02/09/11
06/07/11
11/21/11
09/25/13
05/25/16
Changed Spacer from ELM3 to ELM8.
Added -F to Sheets 2 and 3.
Removed Tolerance Note.
Added Bi-Color LEDs on Sheet 3.
Added Tape & Reel Options.
Tape & Reel Design Update.
Corrected P/N Typo in BOM.
Engineering Update w/o Changes.
1
APPROVED
M. C.
M. C.
M. C.
T. Y.
T. Y.
T. Y.
T. Y.
J. C.
2
SHORT LEAD
L
0.346 [8.8mm]
0.020 [0.5mm] SQ. TYP.
Flat Edge
Cathode ID
Ø.255 [Ø6.5mm]
Spacer Dia.
Ø0.197 [Ø5.0mm]
LED Dia.
2
2
1
1
0.100 [2.5mm]
0.039 [1.0mm]
Ø.032+.003
-.002
TYP.
BI-COLOR POLARITY
LED P/N (1) Cathode (2) Cathode
5BC-F
Green
Red
5BC-Y/G-F
Green
Yellow
0.100 [2.5mm] TYP.
Recommended Mounting Holes
ABSOLUTE MAXIMUM RATINGS (Ta = 25°C)
STANDARD TOLERANCE
DECIMALS
REVERSE VOLTAGE
5V
REVERSE CURRENT ( VR=5V)
100µA
OPERATING TEMPERATURE RANGE
-25°C ~ 85°C
STORAGE TEMPERATURE
-30°C ~ 100°C
LEAD SOLDERING TEMPERATURE (1/16" FROM BODY)
260°C for 5 Seconds
( UNLESS OTHERWISE SPECIFIED )
.X
.XX
.XXX
± .1
± .02
± .010
DESIGNED:
S. Dam
CHECKED:
T. Yin
ANGULAR
X°
± 1°
DATE:
05/05/06
DATE:
05/05/06
4 THOMAS, IRVINE, CA. 92618
TEL: (949) 951-8808
FAX: (949) 951-3974
TITLE: Extruded Vertical T-1 ¾ (5mm)
LED Standard Spacer Profile Assy
REVISION:
PART NO:
ELM3XXX5XX
CAGE CODE : 32559
K
SHEET # 1 OF 4
CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING.
REV.
DATE
DESCRIPTION
APPROVED
SEE SHEET #1
LED Assy. No.
ELM3XXX5BWC
ELM3XXX5BWD
ELM3XXX5BWT
ELM3XXX5GC
ELM3XXX5GD
ELM3XXX5GT
ELM3XXX5PGC
ELM3XXX5PGD
ELM3XXX5PGT
ELM3XXX5YC
ELM3XXX5YD
ELM3XXX5YT
ELM3XXX5AC
ELM3XXX5AD
ELM3XXX5AT
ELM3XXX5HC
ELM3XXX5HD
ELM3XXX5HT
ELM3XXX5RC
ELM3XXX5RD
ELM3XXX5RT
ELM3XXX5BC
ELM3XXX5BC-Y/G
Material
GaN/SiC
GaN/SiC
GaN/SiC
GaP/GaP
GaP/GaP
GaP/GaP
GaP/GaP
GaP/GaP
GaP/GaP
GaAsP/GaP
GaAsP/GaP
GaAsP/GaP
GaAsP/GaP
GaAsP/GaP
GaAsP/GaP
GaAsP/GaP
GaAsP/GaP
GaAsP/GaP
GaP/GaP
GaP/GaP
GaP/GaP
GaAsP/GaP
GaP/GaP
GaAsP/GaP
GaP/GaP
Chip
Peak
Wave
Length
430
430
430
568
568
568
555
555
555
590
590
590
605
605
605
625
625
625
700
700
700
625
568
590
568
Emitted Color
Lens
Appearance
BLUE
WATER CLEAR
BLUE
DIFFUSED
BLUE
TINTED
GREEN
WATER CLEAR
GREEN
DIFFUSED
GREEN
TINTED
PURE GREEN
WATER CLEAR
PURE GREEN
DIFFUSED
PURE GREEN
TINTED
YELLOW
WATER CLEAR
YELLOW
DIFFUSED
YELLOW
TINTED
AMBER
WATER CLEAR
AMBER
DIFFUSED
AMBER
TINTED
HE RED
WATER CLEAR
HE RED
DIFFUSED
HE RED
TINTED
RED
WATER CLEAR
RED
DIFFUSED
RED
TINTED
RED
WHITE DIFFUSED
GREEN
YELLOW
WHITE DIFFUSED
GREEN
Electro-Optical Data @ 20mA
Vf
If
Iv
(V)
(mA)
(mcd)
MAX
TYP
MAX
TYP
25
4
4.5
25
25
4
4.5
15
25
4
4.5
30
30
2.1
2.8
40
30
2.1
2.8
25
30
2.1
2.8
40
30
2.2
2.8
10
30
2.2
2.8
10
30
2.2
2.8
10
30
2
2.8
40
30
2
2.8
25
30
2
2.8
40
30
2
2.8
40
30
2
2.8
25
30
2
2.8
40
30
2
2.8
40
30
2
2.8
25
30
2
2.8
40
2.8
2
2.8
2
2.8
2
30
2.0
2.8
6
30
2.1
2.8
8
30
2.0
2.8
5
30
2.1
2.8
8
Viewing
Angle
2θ½
(Deg)
45
35
35
45
35
35
45
35
35
45
35
35
45
35
35
45
35
5BWC-F
5BWD-F
5BWT-F
5GC-F
5GD-F
5GT-F
5PGC-F
5PGD-F
5PGT-F
5YC-F
5YD-F
5YT-F
5AC-F
5AD-F
5AT-F
5HC-F
5HD-F
5HT-F
5RC-F
5RD-F
5RT-F
45
5BC-F
45
5BC-Y/G-F
LED P/N
STANDARD TOLERANCE
10% All Values
ANGULAR
TEL: (949) 951-8808
DESIGNED:
S. Dam
CHECKED:
T. Yin
DATE:
05/05/06
DATE:
05/05/06
FAX: (949) 951-3974
REVISION:
PART NO:
ELM3XXX5XX
CAGE CODE : 32559
K
SHEET # 2 OF 4
REV.
DATE
DESCRIPTION
APPROVED
SEE SHEET #1
Max. Rating
Peak Wave
Length
λ p(nm )
Em itted
Color
ELM3XXX5BWDL
430
BLUE
ELM3XXX5PGDL
555
ELM3XXX5GDL
LED Assy. No.
Lens
Appearance
Electro-Optical Data @ 2m A
If
(m A)
View ing
Angle
2 ½
(Deg)
Iv
(m cd)
Vf
(V)
MAX
TYP
MAX
DIFFUSED
7
3.8
4.2
4
40
5BWDL-F
PURE GREEN
DIFFUSED
7
2.1
2.6
1
40
5PGDL-F
568
GREEN
DIFFUSED
7
2.1
2.6
4
40
5GDL-F
ELM3XXX5YDL
590
YELLOW
DIFFUSED
7
2.0
2.6
4
40
5YDL-F
ELM3XXX5ADL
605
AMBER
DIFFUSED
7
2.0
2.6
4
40
5ADL-F
ELM3XXX5HDL
625
HE RED
DIFFUSED
7
2.0
2.6
5
40
5HDL-F
ELM3XXX5SRDL
645
SUPER RED
DIFFUSED
7
1.7
2.3
6
40
5SRDL-F
Assembly P/N
5 Volt
ELM3XXX5GD5V
ELM3XXX5AD5V
ELM3XXX5HD5V
ELM3XXX5RD5V
ELM3XXX5YD5V
Peak Wave
Length
λp(nm)
Emitted
Color
Lens
Appearance
GREEN
AMBER
HE RED
RED
YELLOW
568
605
625
700
590
DIFFUSED
DIFFUSED
DIFFUSED
DIFFUSED
DIFFUSED
TYP
LED P/N
Vf
If
Iv
(V)
(mA)
(mcd)
MAX
TYP
MAX
TYP
Data @ 5V
5
25
5
25
5
30
5
1.5
5
25
Viewing
Angle
2 θ½
(Deg)
LED P/N
40
40
40
40
40
5GD5V-F
5AD5V-F
5HD5V-F
5RD5V-F
5YD5V-F
STANDARD TOLERANCE
10% All Values
ANGULAR
TEL: (949) 951-8808
DESIGNED:
S. Dam
CHECKED:
T. Yin
DATE:
05/05/06
DATE:
05/05/06
FAX: (949) 951-3974
TITLE: Extruded Vertical T-1¾ (5mm)
REVISION:
PART NO:
ELM3XXX5XX
CAGE CODE : 32559
K
SHEET # 3 OF 4
REV.
DATE
DESCRIPTION
APPROVED
SEE SHEET #1
0.250 [6.4mm]
TYP.
0.500 [12.7mm]
TYP.
0.709 [18.0mm]
CARBOARD REEL
(.020" THICK)
0.650 + XXX*
XXX* = ELM SPACER HEIGHT
0.650 [16.5mm]
0.511 [13.0mm]
MASKING TAPE
Ø.158 [Ø4.0mm]
TYP.
0.100 [2.5mm]
TYP.
0.500 [12.7mm]
TYP.
LONG LEAD
ANODE
TYP.
0.058 [1.5mm]
MAX.
DIRECTION OF FEED
LABEL
16.5 [420mm] REF.
14" X 2" REEL
13.5 [345mm] REF.
2.5 [63.5mm] REF.
STANDARD PACKAGING TRAY
TAPE & REEL
1,000 pcs / reel
AMMO PACK
2,000 pcs / box
STANDARD TOLERANCE
DECIMALS
NOTE:
1. STANDARD PART NUMBERS ARE PACKAGED IN LOOSE PIECES USING PACKAGING TRAYS
2. ADD "T" SUFFIX TO PART NUMBER FOR TAPE AND REEL PACKAGING OPTION (1,000 PCS/REEL)
3. ADD "A" SUFFIX TO PART NUMBER FOR AMMO PACK OPTION (2,000 PCS/BOX)
4. TAPE AND REEL PACKAGING COMPLY TO EIA-468-C
.X
.XX
.XXX
± .1
± .02
± .010
DESIGNED:
S. Dam
CHECKED:
T. Yin
ANGULAR
X°
± 1°
DATE:
05/05/06
DATE:
05/05/06
TEL: (949) 951-8808
FAX: (949) 951-3974
TITLE: Extruded Vertical T-1 3 4 (5mm)
REVISION:
PART NO:
ELM3XXX5XX
CAGE CODE : 32559
K
SHEET # 4 OF 4
很抱歉,暂时无法提供与“ELM32005RDL”相匹配的价格&库存,您可以联系我们找货
