ELM5615R5YD
ELM5615R5YD
    BIVAR
    LED ASSEMBLY
ELM5615R5YD 数据手册
PART NUMBER REV. ITEM Q'TY 1 1 3XX-F T-1 (3mm) Flanged LED, See Pages 2 to 4 2 1 ELM 5-XXX Extruded, Self-Retaining Narrow LED Spacer PART DESCRIPTION K L M N P R T 1 Flat Edge Cathode ID 0.209 [5.3mm] DESCRIPTION Added Bi-Color LED Polarity Diagram Added Tape & Reel Options Tape & Reel Design Update LED Offering List Update Corrected LED Typo Corrected P/N Typo in BOM Updated LED Optical Characteristics DATE APPROVED 03/29/10 06/07/11 11/21/11 07/27/12 08/09/13 09/19/13 09/12/15 T. Y. T. Y. T. Y. T. Y. T. Y. T. Y. J. C. 2 L 2. SHORT LEAD 0.020 [0.5mm]SQ. TYP. Ø.155 [Ø3.9mm] Spacer Dia. 2 1 2 2 2 1 1 1 Single Color 0.100 [2.5mm] 5V or 12V Bi-Color Ø.118 [Ø3.0mm] LED Dia. BI-COLOR POLARITY 1. LONG LEAD 0.03 [0.8mm] (1) Cathode (2) Cathode LED P/N 3BC-F Green Red Green 3BC-Y/G-F Yellow Yellow 3BC-R/Y-F Red 3BC-A/G-F Green Amber Ø.032+.003 TYP.-.002 0.100 [2.5mm] Recommended Mounting Holes ABSOLUTE MAXIMUM RATINGS (Ta=25 C) REVERSE VOLTAGE REVERSE CURRENT OPERATING TEMPERATURE RANGE DECIMALS .X .XX .XXX ± .1 ± .02 ± .010 DESIGNED: STORAGE TEMPERATURE LEAD SOLDERING TEMPERATURE(1/16" FROM BODY) ® STANDARD TOLERANCE ( UNLESS OTHERWISE SPECIFIED ) Minh Doan CHECKED: T. Yin ANGULAR X° ± 1° 4 THOMAS, IRVINE, CA. 92618 TEL: (949) 951-8808 FAX: (949) 951-3974 EXTRUDED VERTICAL T-1 (3mm) LED STANDARD PROFILE SPACER ASSY TITLE: DATE: 07/27/12 DATE: 07/27/12 PART NO: REVISION: ELM5XXX3XX CAGE CODE : 32559 T SHEET # 1 OF 5 CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING. REV. DATE DESCRIPTION APPROVED SEE SHEET #1. LED Assy. No. ELM5XXX3BWC ELM5XXX3BWD ELM5XXX3BWT ELM5XXX3GC ELM5XXX3GD ELM5XXX3GT ELM5XXX3PGC ELM5XXX3PGD ELM5XXX3PGT ELM5XXX3YC ELM5XXX3YD ELM5XXX3YT ELM5XXX3AC ELM5XXX3AD ELM5XXX3AT ELM5XXX3HC ELM5XXX3HD ELM5XXX3HT ELM5XXX3RC ELM5XXX3RD ELM5XXX3RT ELM5XXX3BC‐A/G ELM5XXX3BC ELM5XXX3BC‐R/Y ELM5XXX3BC‐Y/G Material GaN/SiC GaN/SiC GaN/SiC GaP/GaP GaP/GaP GaP/GaP GaP/GaP GaP/GaP GaP/GaP GaAsP/GaP GaAsP/GaP GaAsP/GaP GaAsP/GaP GaAsP/GaP GaAsP/GaP GaAsP/GaP GaAsP/GaP GaAsP/GaP GaP/GaP GaP/GaP GaP/GaP GaAsP/GaP GaP/GaP GaAsP/GaP GaP/GaP GaAsP/GaP GaAsP/GaP GaAsP/GaP GaP/GaP Chip Peak  Wave  Length 430 430 430 568 568 568 555 555 555 590 590 590 605 605 605 625 625 625 700 700 700 605 568 625 568 625 590 590 568 Emitted Color BLUE BLUE BLUE GREEN GREEN GREEN PURE GREEN PURE GREEN PURE GREEN YELLOW YELLOW YELLOW AMBER AMBER AMBER HE RED HE RED HE RED RED RED RED AMBER GREEN RED GREEN RED YELLOW YELLOW GREEN Lens Appearance WATER CLEAR DIFFUSED TINTED WATER CLEAR DIFFUSED TINTED WATER CLEAR DIFFUSED TINTED WATER CLEAR DIFFUSED TINTED WATER CLEAR DIFFUSED TINTED WATER CLEAR DIFFUSED TINTED WATER CLEAR DIFFUSED TINTED DIFFUSED DIFFUSED DIFFUSED DIFFUSED Electro‐Optical Data @ 20mA If Iv Vf (mA) (mcd) (V) MAX TYP MAX TYP 25 4 4.5 15 25 4 4.5 10 25 4 4.5 15 30 2.1 2.8 40 30 2.1 2.8 25 30 2.1 2.8 40 30 2.2 2.8 10 30 2.2 2.8 5 30 2.2 2.8 10 30 2 2.8 40 30 2 2.8 20 30 2 2.8 40 30 2 2.8 40 30 2 2.8 25 30 2 2.8 40 30 2 2.8 50 30 2 2.8 30 30 2 2.8 50 20 2.1 2.8 2.5 20 2.1 2.8 2 20 2.1 2.8 2.5 30 2.0 2.8 6 30 2.1 2.8 6 30 2.0 2.8 6 30 2.1 2.8 6 30 2.0 2.8 6 30 2.0 2.8 4 30 2.0 2.8 4 30 2.1 2.8 6 Viewing  Angle LED P/N 2 θ ½ (Deg) 20 3BWC‐F 35 3BWD‐F 20 3BWT‐F 20 3GC‐F 35 3GD‐F 20 3GT‐F 20 3PGC‐F 35 3PGD‐F 20 3PGT‐F 20 3YC‐F 35 3YD‐F 20 3YT‐F 20 3AC‐F 35 3AD‐F 20 3AT‐F 20 3HC‐F 35 3HD‐F 20 3HT‐F 35 3RC‐F 20 3RD‐F 20 3RT‐F 45 3BC‐A/G‐F 45 3BC‐F 45 3BC‐R/Y‐F 45 3BC‐Y/G‐F STANDARD TOLERANCE ® ( UNLESS OTHERWISE SPECIFIED ) ±10% ALL VALUES ANGULAR X° ± 5° 4 THOMAS, IRVINE, CA. 92618 TEL: (949) 951-8808 FAX: (949) 951-3974 TITLE: EXTRUDED VERTICAL T-1 (3mm) LED STANDARD PROFILE SPACER ASSY DESIGNED: Minh Doan CHECKED: T. Yin DATE: 07/27/12 DATE: 07/27/12 PART NO: REVISION: ELM5XXX3XX CAGE CODE : 32559 T SHEET # 2 OF 5 CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING. REV. DATE DESCRIPTION APPROVED SEE SHEET #1. LED Assy. No. ELM5XXX3UBWC ELM5XXX3SGC ELM5XXX3SGD ELM5XXX3SGT ELM5XXX3SYC ELM5XXX3SYD ELM5XXX3SYT ELM5XXX3SAC ELM5XXX3SAD ELM5XXX3SAT ELM5XXX3SRC ELM5XXX3SRD ELM5XXX3SRT ELM5XXX3UGC ELM5XXX3SUGC ELM5XXX3UYC ELM5XXX3SUYC ELM5XXX3UUYC ELM5XXX3UOC ELM5XXX3SUOC ELM5XXX3URC ELM5XXX3SURC ELM5XXX3UWC Material GaN/SiC GaP/GaP GaP/GaP GaP/GaP GaAsP/GaP GaAsP/GaP GaAsP/GaP AlGaInP AlGaInP AlGaInP GaAlAs/GaAs GaAlAs/GaAs GaAlAs/GaAs AlGaInP AlGaInP AlGaInP AlGaInP AlGaInP AlGaInP AlGaInP GaAlAs/GaAs AlGaInP InGaN/Sappire Chip Peak  Wave  Length 470 568 568 568 590 590 590 605 605 605 645 645 645 570 570 590 590 590 625 625 645 640 6500K Emitted  Color BLUE GREEN GREEN GREEN YELLOW YELLOW YELLOW AMBER AMBER AMBER SUPER RED SUPER RED SUPER RED GREEN GREEN YELLOW YELLOW YELLOW ORANGE ORANGE RED RED WHITE Lens Appearance WATER CLEAR WATER CLEAR DIFFUSED TINTED WATER CLEAR DIFFUSED TINTED WATER CLEAR DIFFUSED TINTED WATER CLEAR DIFFUSED TINTED WATER CLEAR WATER CLEAR WATER CLEAR WATER CLEAR WATER CLEAR WATER CLEAR WATER CLEAR WATER CLEAR WATER CLEAR WATER CLEAR Electro‐Optical Data @ 20mA Vf If Iv (V) (mA) (mcd) MAX TYP MAX TYP 30 4 4.5 400 30 2.1 2.8 50 30 2.1 2.8 30 30 2.1 2.8 50 30 2.0 2.8 50 30 2.0 2.8 30 30 2.0 2.8 50 30 1.8 2.4 300 30 1.8 2.4 100 30 1.8 2.4 300 30 1.7 2.4 60 30 1.7 2.4 40 30 1.7 2.4 60 30 2.1 2.4 200 30 2.1 2.4 300 30 2.0 2.4 300 30 2.0 2.4 400 30 2.0 2.4 600 30 1.8 2.4 300 30 1.8 2.4 400 30 1.7 2.4 200 30 1.8 2.4 200 30 3.2 3.6 6000 Viewing  Angle LED P/N 2 θ ½ (Deg) 30 3UBWC‐0.6K‐F 20 3SGC‐F 35 3SGD‐F 20 3SGT‐F 20 3SYC‐F 35 3SYD‐F 20 3SYT‐F 20 3SAC‐F 35 3SAD‐F 20 3SAT‐F 20 3SRC‐F 35 3SRD‐F 20 3SRT‐F 20 3UGC‐F 35 3SUGC‐F 20 3UYC‐F 20 3SUYC‐F 35 3UUYC‐F 20 3UOC‐F 20 3SUOC‐F 35 3URC‐F 20 3SURC‐F 35 3UWC1.035C‐F ® STANDARD TOLERANCE ( UNLESS OTHERWISE SPECIFIED ) ±10% ALL VALUES ANGULAR X° ± 5° 4 THOMAS, IRVINE, CA. 92618 TEL: (949) 951-8808 FAX: (949) 951-3974 TITLE: EXTRUDED VERTICAL T-1 (3mm) LED STANDARD PROFILE SPACER ASSY DESIGNED: Minh Doan CHECKED: T. Yin DATE: 07/27/12 DATE: 07/27/12 PART NO: REVISION: ELM5XXX3XX CAGE CODE : 32559 T SHEET # 3 OF 5 CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING. REV. DATE DESCRIPTION APPROVED SEE SHEET #1. Absolute Max. Ratings Material Chip Peak Wave Length Emitted Color ELM5XXX3BWDL GaN/siC λ p(nm) 430 BLUE DIFFUSED ELM5XXX3GDL GaP/GaP 568 GREEN ELM5XXX3PGDL GaP/GaP 555 PURE GREEN LED Assy. No. Lens Appearance Electro-Optical Data @ 2mA Vf (V) Iv (mcd) Viewing Angle 2 ½ (Deg) LED P/N 3BWDL-F Pd If Peak (mW) (mA) If(mA) TYP MAX 20 7 - 3.8 4.2 2.5 35 DIFFUSED 10 7 - 2.1 2.6 4.0 35 3GDL-F DIFFUSED 10 7 - 2.1 2.6 0.2 35 3PGDL-F TYP ELM5XXX3YDL GaAsP/GaP 590 YELLOW DIFFUSED 10 7 - 2.0 2.6 2.0 35 3YDL-F ELM5XXX3ADL GaAsP/GaP 605 AMBER DIFFUSED 10 7 - 2.0 2.6 4.0 35 3ADL-F ELM5XXX3HDL GaAsP/GaP 625 HE RED DIFFUSED 10 7 - 2.0 2.6 2.5 35 3HDL-F ELM5XXX3RDL GaP/GaP ELM5XXX3SRDL GaAIAs/GaAs LED Assy. No. 5 Volt ELM5XXX3BWD5V ELM5XXX3GC5V ELM5XXX3GD5V ELM5XXX3GT5V ELM5XXX3AD5V ELM5XXX3HD5V ELM5XXX3RD5V ELM5XXX3YD5V 12 Volt ELM5XXX3GC12V ELM5XXX3GD12V ELM5XXX3HC12V ELM5XXX3HD12V ELM5XXX3RC12V ELM5XXX3RD12V ELM5XXX3YC12V ELM5XXX3YD12V 700 RED DIFFUSED 10 7 - 2.1 2.6 0.5 35 3RDL-F 645 RED DIFFUSED 10 7 - 2.0 - 8.0 35 3SRDL-F Peak Wave Length λp(nm) Emitted Color Lens Appearance BLUE GREEN GREEN GREEN AMBER HE RED RED YELLOW 430 568 568 568 605 625 700 590 DIFFUSED WATER CLEAR DIFFUSED TINTED DIFFUSED DIFFUSED DIFFUSED DIFFUSED GREEN GREEN HE RED HE RED RED RED YELLOW YELLOW 568 568 625 625 700 700 590 590 WATER CLEAR DIFFUSED WATER CLEAR DIFFUSED WATER CLEAR DIFFUSED WATER CLEAR DIFFUSED Electro-Optical Data Vf If Iv (V) (mA) (mcd) MAX TYP MAX TYP Data @ 5V 5 10 5 40 5 25 5 40 5 25 5 30 5 2 5 20 Data @ 12V 12 40 12 25 12 50 12 30 12 6 12 2 12 40 12 25 Viewing Angle 2 θ½ (Deg) LED P/N 35 20 35 20 35 35 35 35 3BWD5V-F 3GC5V-F 3GD5V-F 3GT5V-F 3AD5V-F 3HD5V-F 3RD5V-F 3YD5V-F 20 35 20 35 20 35 20 35 3GC12V-F 3GD12V-F 3HC12V-F 3HD12V-F 3RC12V-F 3RD12V-F 3YC12V-F 3YD12V-F ® STANDARD TOLERANCE ( UNLESS OTHERWISE SPECIFIED ) ±10% ALL VALUES ANGULAR X° ± 5° 4 THOMAS, IRVINE, CA. 92618 TEL: (949) 951-8808 FAX: (949) 951-3974 TITLE: EXTRUDED VERTICAL T-1 (3mm) LED STANDARD PROFILE SPACER ASSY DESIGNED: Minh Doan CHECKED: T. Yin DATE: 07/27/12 DATE: 07/27/12 PART NO: REVISION: ELM5XXX3XX CAGE CODE : 32559 T SHEET # 4 OF 5 CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING. REV. DATE DESCRIPTION APPROVED SEE SHEET #1. 0.250 [6.4mm] TYP. 0.500 [12.7mm] TYP. 0.709 [18.0mm] CARBOARD REEL (.020" THICK) 0.650 + XXX* XXX* = ELM SPACER HEIGHT 0.650 [16.5mm] 0.511 [13.0mm] MASKING TAPE Ø.158 [Ø4.0mm] TYP. 0.100 [2.5mm] TYP. 0.500 [12.7mm] TYP. LONG LEAD ANODE TYP. 0.058 [1.5mm] MAX. DIRECTION OF FEED LABEL 16.5 [420mm] REF. 14" X 2" REEL 13.5 [345mm] REF. 2.5 [63.5mm] REF. STANDARD PACKAGING TRAY TAPE & REEL 1,000 pcs / reel AMMO PACK 2,000 pcs / box ® STANDARD TOLERANCE ( UNLESS OTHERWISE SPECIFIED ) DECIMALS NOTE: 1. STANDARD PART NUMBERS ARE PACKAGED IN LOOSE PIECES USING PACKAGING TRAYS 2. ADD "T" SUFFIX TO PART NUMBER FOR TAPE AND REEL PACKAGING OPTION (1,000 PCS/REEL) 3. ADD "A" SUFFIX TO PART NUMBER FOR AMMO PACK OPTION (2,000 PCS/BOX) 4. TAPE AND REEL PACKAGING COMPLY TO EIA-468-C .X .XX .XXX ± .1 ± .02 ± .010 DESIGNED: Minh Doan CHECKED: T. Yin ANGULAR X° ± 1° 4 THOMAS, IRVINE, CA. 92618 TEL: (949) 951-8808 FAX: (949) 951-3974 TITLE: EXTRUDED VERTICAL T-1 (3mm) LED STANDARD PROFILE SPACER ASSY DATE: 07/27/12 DATE: 07/27/12 PART NO: REVISION: ELM5XXX3XX CAGE CODE : 32559 T SHEET # 5 OF 5 CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING.
ELM5615R5YD 价格&库存
很抱歉,暂时无法提供与“ELM5615R5YD”相匹配的价格&库存,您可以联系我们找货
