FLP25R60.0-UBW
FLP25R60.0-UBW
    BIVAR
    LED ASSEMBLY
FLP25R60.0-UBW 数据手册
ITEM 1 2 Q'TY 1 1 PART NUMBER FLPR2-XX FLP25-XX.X PART DESCRIPTION Flexible LIght Pipe 2mm Adapter, Right Angle w/ LED, See page 2 Flexible Light Pipe Lens Cap Assembly, 2mm REV. A B C D E F NOTE: FLPR2-XX ADAPTER SHIPPED NON-ASSEMBLED SEE TABLE 1 DATE APPROVED 09/14/09 04/26/12 11/16/12 09/15/15 08/15/18 11/13/18 T. Y. T. Y. T. Y. J. C. M. C. M. C. 0.240 [6.1mm] 0.210 [5.3mm] 0.320 [8.1mm] 0.545 [13.8mm] 1 L 0.064 [1.6mm] DESCRIPTION Engineering Release Replaced 3UWC-0.6K-F with 3UWC1.035C-F Updated Table For Length "L" Updated LED Optical Characteristics Updated LED Tables Updated LED Tables 2 0.045 [1.2mm] 0.300 [7.6mm] 0.100 [2.5mm] 0.214 [5.4mm] 0.570 [14.5mm] TABLE 1 " L "* SINGLE COLOR LED SHORT LEAD CATHODE Tolerance 1.0" ~ 16.0" 16.1" ~ 40.0" 40.1" ~ 80.0" 80.1" ~ 3,940.0" BI-COLOR LED'S * Available in 0.1" increments only SHOULDER OF HOLDER +.003 -.002 0.300 [7.6mm] SHORT LEAD CATHODE RED YELLOW LONG LEAD CATHODE GREEN GREEN LED PART NO. 3xBCC-F 3BC-Y/G-F 0.100 [2.5mm] Recommended Mounting Holes ( Panel Thickness = 0.100" ) RECOMMENDED FOOTPRINT STANDARD TOLERANCE (UNLESS OTHERWISE SPECIFIED) DECIMALS ANGULAR 4 THOMAS, IRVINE, CA. 92618 TEL: (949) 951-8808 REVERSE VOLTAGE TITLE: REVERSE CURRENT DESIGNED: OPERATING TEMPERATURE RANGE STORAGE TEMPERATURE LEAD SOLDERING TEMPERATURE(1/16" FROM BODY) B. OLIVER REVISED: K. BARON CHECKED: TD. NGUYEN DATE: FLP25RX.X-XX 11/13/18 F CAGE CODE: 11/13/18 DATE: REVISION: PART NO: 09/14/09 DATE: FAX: (949) 951-3974 FLEXIBLE LIGHT PIPE ASSY, 7mm ROUND, RIGHT ANGLE 32559 SCALE: NONE SHEET # 1 OF CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING 3 REV. DESCRIPTION DATE APPROVED See Sheet 1 VISIT WWW.BIVAR.COM FOR CURRENT LED DATASHEETS LED DETAILS ON DATASHEETS TAKE PRECEDENCE OVER DETAILS SHOWN HERE FLEXIBLE LIGHT PIPE SERIES Emitted Colors "L" LENGTH, inches available in 0.1" increments only e.g. 6.0, 11.5 PART NO: SCALE: REVISION: FLP25RX.X-XX F SHEET # 2 OF 3 CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING REV. DESCRIPTION DATE APPROVED See Sheet 1 VISIT WWW.BIVAR.COM FOR CURRENT LED DATASHEETS LED DETAILS ON DATASHEETS TAKE PRECEDENCE OVER DETAILS SHOWN HERE FLEXIBLE LIGHT PIPE SERIES Emitted Colors "L" LENGTH, inches available in 0.1" increments only e.g. 6.0, 11.5 PART NO: SCALE: REVISION: FLP25RX.X-XX F SHEET # 3 OF 3 CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING
FLP25R60.0-UBW 价格&库存
很抱歉,暂时无法提供与“FLP25R60.0-UBW”相匹配的价格&库存,您可以联系我们找货
