FLP5V2.0-UBW.6K
FLP5V2.0-UBW.6K
    BIVAR
    LED ASSEMBLY
FLP5V2.0-UBW.6K 数据手册
REV. PART DESCRIPTION ITEM Q'TY PART NUMBER 1 1 FLPV-XX Flexible Light Pipe Adapter,Vertical, w/LED 2 1 FLP5-XX.X Flexible Light-Pipe Lens Cap Assembly, 7mm Round A B C D E F DESCRIPTION Engineering Release. 3UWC-0.6K-F Changed to 3UWC1.035C-F Updated Table For Length "L" Updated LED Optical Characteristics Updated LED Tables Updated LED Tables DATE APPROVED 07/14/08 04/03/12 11/16/12 09/15/15 08/15/18 11/13/18 M. C. T. Y. T. Y. J. C. M. C. M. C. NOTE: FLPV-XXX ADAPTER SHIPPED NON-ASSEMBLED L 0.064 [1.6mm] 0.21 [5.4mm] SEE TABLE 1 0.320 [8.1mm] 0.240 [6.1mm] 0.210 [5.3mm] 0.100 [2.5mm] 0.495 [12.6mm] 1 0.045 [1.2mm] TABLE 1 0.57 [14.5mm] " L "* 2 Tolerance 1.0" ~ 16.0" 16.1" ~ 40.0" 40.1" ~ 80.0" 80.1" ~ 3,940.0" * Available in 0.1" increments only BI-COLOR LED'S +.003 -.002 SHORT LEAD CATHODE RED YELLOW 0.100 [2.5mm] Recommended Mounting Holes ( Panel Thickness = 0.100" ) LED PART NO. 3xBCC-F 3BC-Y/G-F LONG LEAD CATHODE GREEN GREEN RECOMMENDED FOOTPRINT STANDARD TOLERANCE (UNLESS OTHERWISE SPECIFIED) DECIMALS ANGULAR 4 THOMAS, IRVINE, CA. 92618 TEL: (949) 951-8808 REVERSE VOLTAGE REVERSE CURRENT OPERATING TEMPERATURE RANGE VERTICAL, 7mm LENS CAP W/LED DESIGNED: R. PAJE REVISED: STORAGE TEMPERATURE LEAD SOLDERING TEMPERATURE(1/16" FROM BODY) FAX: (949) 951-3974 TITLE: FLEXIBLE LIGHT-PIPE ASSY K. BARON CHECKED: TD. NGUYEN DATE: PART NO: 07/14/08 DATE: 11/13/18 F CAGE CODE: 11/13/18 DATE: REVISION: FLP5VX.X-XX 32559 SCALE: NONE SHEET # 1 OF CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING 3 REV. DATE DESCRIPTION APPROVED See Sheet 1 VISIT WWW.BIVAR.COM FOR CURRENT LED DATASHEETS LED DETAILS ON DATASHEETS TAKE PRECEDENCE OVER DETAILS SHOWN HERE FLEXIBLE LIGHT PIPE SERIES Emitted Colors "L" LENGTH, inches available in 0.1" increments only e.g. 6.0, 11.5 REVISION: PART NO: FLP5VX.X-XX SCALE: F SHEET # 2 OF 3 CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING REV. DATE DESCRIPTION APPROVED See Sheet 1 VISIT WWW.BIVAR.COM FOR CURRENT LED DATASHEETS LED DETAILS ON DATASHEETS TAKE PRECEDENCE OVER DETAILS SHOWN HERE FLEXIBLE LIGHT PIPE SERIES Emitted Colors "L" LENGTH, inches available in 0.1" increments only e.g. 6.0, 11.5 REVISION: PART NO: FLP5VX.X-XX SCALE: F SHEET # 3 OF 3 CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING
FLP5V2.0-UBW.6K 价格&库存
很抱歉,暂时无法提供与“FLP5V2.0-UBW.6K”相匹配的价格&库存,您可以联系我们找货
