FR3-6.0-UB-F6PD67PR
FR3-6.0-UB-F6PD67PR
    BIVAR
    LED ASSEMBLY
FR3-6.0-UB-F6PD67PR 数据手册
REV. DESCRIPTION A Engineering Release B Updated LED Tables DATE APPROVED 05/12/17 08/14/18 J. C. M. C. *Length "X.X" Tolerance 2.0" ~ 16.0" 16.1" ~ 40.0" 40.1" ~ 80.0" 80.1" ~ 500.0" X.X* Flange Diameter 0.11 [2.8mm] 0.320 [8.1mm] M6x0.75 Thread 0.545 [13.8mm] Lens Diameter 0.240 [6.1mm] 0.210 [5.3mm] 0.100 [2.5mm] 0.58 [14.7mm] 0.300 [7.6mm] SINGLE COLOR LED SHORT LEAD CATHODE BI-COLOR LED'S Sealing Ring Pre-Installed 0.39 [10.0mm] REF. M6x0.75 Hex Nut Included M6 Split Lock Washer Included SHORT LEAD CATHODE LED PART NO. LONG LEAD CATHODE RED 3SBCC-F GREEN Part Number Configuration Lens Options: +.003 -.002 SHOULDER OF HOLDER LED Color, See Page 2 0.300 [7.6mm] +.003 -.002 Recommended Mounting Hole 1.5mm-6mm Panel Thickness 0.25 Nm Mounting Torque Lens Options: - Clear Fresnel - Diffused Length in 0.1" Increments Only STANDARD TOLERANCE 0.100 [2.5mm] (UNLESS OTHERWISE SPECIFIED) DECIMALS ANGULAR 4 THOMAS, IRVINE, CA. 92618 Recommended Footprint TEL: (949) 951-8808 FAX: (949) 951-3974 TITLE: NOTES: 1. SEALED TO IP67 RATING 2. ROHS COMPLIANT 3. MOUNTING HARDWARE AND ADAPTER SHIPPED NON-ASSEMBLED 4. MINIMUM BEND RADIUS OF FLEXIBLE LIGHT PIPE: 1.06" [27mm] DESIGNED: TD. NGUYEN REVISED: D. GILBREATH CHECKED: TD. NGUYEN IP67 RATED PANEL MOUNT FLP INDICATOR, RIGHT ANGLE DATE: REVISION: PART NO: FR3-X.X-XXX-F6PX67PR 04/30/17 B DATE: CAGE CODE: 08/14/18 DATE: 08/14/18 32559 SCALE: NONE SHEET # 1 OF CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING 2 REV. DESCRIPTION DATE APPROVED SEE SHEET #1 VISIT WWW.BIVAR.COM FOR CURRENT LED DATASHEETS LED DETAILS ON DATASHEETS TAKE PRECEDENCE OVER DETAILS SHOWN HERE ABSOLUTE MAXIMUM RATINGS (Ta=25 C) REVERSE VOLTAGE 5V REVERSE CURRENT OPERATING TEMPERATURE RANGE -25 C ~ +85 C STORAGE TEMPERATURE -30 C ~ +100 C LEAD SOLDERING TEMPERATURE(1/16" FROM BODY) 260 C FOR 5 SECONDS REVISION: PART NO: FR3-X.X-XXX-F6PX67PR SCALE: B SHEET # 2 OF 2 CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING
FR3-6.0-UB-F6PD67PR 价格&库存
很抱歉,暂时无法提供与“FR3-6.0-UB-F6PD67PR”相匹配的价格&库存,您可以联系我们找货
