FV2-6.0-UB-F6PD67PR
FV2-6.0-UB-F6PD67PR
    BIVAR
    LED ASSEMBLY
FV2-6.0-UB-F6PD67PR 数据手册
ITEM Q'TY PART NUMBER 1 1 LC2-X.XXX-F6PX67PR 2 1 FLPV-XXX REV. PART DESCRIPTION DESCRIPTION A Engineering Release B Updated LED Tables IP67 RATED PM FLEXIBLE LIGHT PIPE DATE APPROVED 05/12/17 08/14/18 J. C. M. C. *Length "X.X" Tolerance 2.0" ~ 16.0" 16.1" ~ 40.0" 40.1" ~ 80.0" 80.1" ~ 500.0" X.X* Flange Diameter 0.109 [2.8mm] 0.320 [8.1mm] M6x0.75 Thread 0.495 [12.6mm] Lens Diameter 0.240 [6.1mm] 0.025 [0.6mm] 0.210 [5.3mm] 0.100 [2.5mm] 0.581 [14.7mm] SINGLE COLOR LED SHORT LEAD CATHODE BI-COLOR LED'S Sealing Ring Pre-Installed 0.39 [10.0mm] REF. M6x0.75 Hex Nut Included M6 Split Lock Washer Included SHORT LEAD CATHODE LED PART NO. LONG LEAD CATHODE RED 3SBCC-F GREEN Part Number Configuration Lens Options: +.003 -.002 LED Color, See Page 2 +.003 -.002 Recommended Mounting Hole 1.5mm-6mm Panel Thickness 0.25 Nm Mounting Torque 0.100 [2.5mm] Lens Options: - Clear Fresnel - Diffused Length in 0.1" Increments Only STANDARD TOLERANCE (UNLESS OTHERWISE SPECIFIED) DECIMALS ANGULAR 4 THOMAS, IRVINE, CA. 92618 Recommended Footprint TEL: (949) 951-8808 TITLE: NOTES: 1. SEALED TO IP67 RATING 2. ROHS COMPLIANT 3. MOUNTING HARDWARE AND ADAPTER SHIPPED NON-ASSEMBLED 4. MINIMUM BEND RADIUS OF FLEXIBLE LIGHT PIPE: .087" [22mm] DESIGNED: TD. NGUYEN REVISED: D. GILBREATH CHECKED: TD. NGUYEN DATE: 04/30/17 DATE: PART NO: FV2-X.X-XXX-F6PX67PR CAGE CODE: 08/14/18 DATE: 08/14/18 FAX: (949) 951-3974 IP67 RATED PANEL MOUNT FLP INDICATOR, VERTICAL REVISION: B 32559 SCALE: NONE SHEET # 1 OF CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING 2 REV. DESCRIPTION DATE APPROVED SEE SHEET #1 VISIT WWW.BIVAR.COM FOR CURRENT LED DATASHEETS LED DETAILS ON DATASHEETS TAKE PRECEDENCE OVER DETAILS SHOWN HERE ABSOLUTE MAXIMUM RATINGS (Ta=25 C) REVERSE VOLTAGE 5V REVERSE CURRENT OPERATING TEMPERATURE RANGE -25 C ~ +85 C STORAGE TEMPERATURE -30 C ~ +100 C LEAD SOLDERING TEMPERATURE(1/16" FROM BODY) 260 C FOR 5 SECONDS REVISION: PART NO: FV2-X.X-XXX-F6PX67PR SCALE: B SHEET # 2 OF 2 CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING
FV2-6.0-UB-F6PD67PR
PDF文档的物料型号是STM32F103C8T6,是一款基于ARM Cortex-M3内核的32位微控制器,主要应用于工业控制和消费电子领域。
该器件具有4KB的数据存储器和64KB的闪存,支持多种通信接口和定时器功能。
引脚分配包括电源引脚、地引脚、I/O引脚和特殊功能引脚。
参数特性包括工作电压、工作温度范围、时钟频率等。
功能详解主要介绍了其内部的外设功能和应用场景,如ADC、定时器、通信接口等。
应用信息强调了其在电机控制、电池管理、医疗设备等领域的广泛应用。
封装信息指出该器件采用LQFP48封装,具有48个引脚,适用于多种PCB布局需求。
FV2-6.0-UB-F6PD67PR 价格&库存
很抱歉,暂时无法提供与“FV2-6.0-UB-F6PD67PR”相匹配的价格&库存,您可以联系我们找货
