REV.
ITEM
Q'TY
1
1
H-220C-LP
T-1 (3mm) Bi-Level LED Holder, 90° Mount
2
2
3XX-S
T-1 (3mm) N-Flange Shouldered LED, See Following Pages
PART DESCRIPTION
PART NUMBER
1
A
B
C
D
E
DESCRIPTION
Engineering Update w/o Changes
Updated to Shouldered LEDs
Locating Pin Suffix
Updated LED Offering List
Updated LED Optical Characteristics
DATE
APPROVED
03/05/04
04/01/08
04/03/12
06/25/12
09/15/15
M. C.
M. C.
T. Y.
T. Y.
J. C.
2
0.122 [3.1mm]
TYP.
0.174 [4.4mm]
Ø.118 [Ø3.0mm]
0.354 [9.0mm]
0.300 [7.6mm]
0.378 [9.6mm]
0.100 [2.5mm]
0.138 [3.5mm]
0.062 [1.6mm]
BI-COLOR POLARITY
LED P/N (1) Cathode (2) Cathode
3BC
Green
Red
3BC-Y/G
Green
Yellow
Yellow
3BC-R/Y
Red
3BC-A/G
Green
Amber
0.079 [2.0mm]
0.121 [3.1mm]
0.100 [2.5mm]
0.100 [2.5mm]
Holder Face
Ø.079+.003
-.002
Ø.032+.003
-.002
0.020 [0.5mm] SQ. TYP.
0.221 [5.6mm]
0.121 [3.1mm]
0.079 [2.0mm]
2
1
Standard
1
2
5 & 12 V
1
2
Bi-Color
1
2
TYP.
0.100 [2.5mm]
Recommended Mounting Holes
NOTE: P/N DESIGNATION
H220CXXDX-LP
H-400 Holder
Series
- " " Standard LED
- "L" Low Current LED
- "5V" 5V LED
Color of top LED
- Use "X" if blank
Lens Appearance
Color of Bottom LED
- Use "X" if blank
-If LEDs are the same,
use e.g. H200CGD
All Green Diffused LEDs
ABSOLUTE MAXIMUM RATINGS (Ta=25° C)
REVERSE VOLTAGE
REVERSE CURRENT
OPERATING TEMPERATURE RANGE
STANDARD TOLERANCE
DECIMALS
.X
.XX
.XXX
± .1
± .02
± .010
DESIGNED:
STORAGE TEMPERATURE
LEAD SOLDERING TEMPERATURE(1/16" FROM BODY)
( UNLESS OTHERWISE SPECIFIED )
T. Yin
CHECKED:
D. Green
ANGULAR
X°
± 1°
4 THOMAS, IRVINE, CA. 92618
TEL: (949) 951-8808
FAX: (949) 951-3974
TITLE:
DATE:
03/05/04
DATE:
03/05/04
T-1 (3MM) 90° BI-LEVEL
LED LOCATOR PIN LED ASSY
REVISION:
PART NO:
H220CXX-LP
CAGE CODE : 32559
E
SHEET # 1 OF 4
CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING.
REV.
DATE
DESCRIPTION
APPROVED
SEE SHEET#1.
LED Assy. No.
H220CBWC‐LP
H220CBWD‐LP
H220CBWT‐LP
H220CGC‐LP
H220CGD‐LP
H220CGT‐LP
H220CPGC‐LP
H220CPGD‐LP
H220CPGT‐LP
H220CYC‐LP
H220CYD‐LP
H220CYT‐LP
H220CAC‐LP
H220CAD‐LP
H220CAT‐LP
H220CHC‐LP
H220CHD‐LP
H220CHT‐LP
H220CRC‐LP
H220CRD‐LP
H220CRT‐LP
H220CBC‐A/G‐LP
H220CBC‐LP
H220CBC‐R/Y‐LP
H220CBC‐Y/G‐LP
Material
GaN/SiC
GaN/SiC
GaN/SiC
GaP/GaP
GaP/GaP
GaP/GaP
GaP/GaP
GaP/GaP
GaP/GaP
GaAsP/GaP
GaAsP/GaP
GaAsP/GaP
GaAsP/GaP
GaAsP/GaP
GaAsP/GaP
GaAsP/GaP
GaAsP/GaP
GaAsP/GaP
GaP/GaP
GaP/GaP
GaP/GaP
GaAsP/GaP
GaP/GaP
GaAsP/GaP
GaP/GaP
GaAsP/GaP
GaAsP/GaP
GaAsP/GaP
GaP/GaP
Chip
Peak
Wave
Length
430
430
430
568
568
568
555
555
555
590
590
590
605
605
605
625
625
625
700
700
700
605
568
625
568
625
590
590
568
Emitted Color
BLUE
BLUE
BLUE
GREEN
GREEN
GREEN
PURE GREEN
PURE GREEN
PURE GREEN
YELLOW
YELLOW
YELLOW
AMBER
AMBER
AMBER
HE RED
HE RED
HE RED
RED
RED
RED
AMBER
GREEN
RED
GREEN
RED
YELLOW
YELLOW
GREEN
Lens
Appearance
WATER CLEAR
DIFFUSED
TINTED
WATER CLEAR
DIFFUSED
TINTED
WATER CLEAR
DIFFUSED
TINTED
WATER CLEAR
DIFFUSED
TINTED
WATER CLEAR
DIFFUSED
TINTED
WATER CLEAR
DIFFUSED
TINTED
WATER CLEAR
DIFFUSED
TINTED
DIFFUSED
DIFFUSED
DIFFUSED
DIFFUSED
Electro‐Optical Data @ 20mA
Vf
If
Iv
(V)
(mA)
(mcd)
MAX
TYP
MAX
TYP
25
4.0
4.5
25
25
4.0
4.5
10
25
4.0
4.5
25
30
2.1
2.8
40
30
2.1
2.8
25
30
2.1
2.8
40
30
2.2
2.8
10
30
2.2
2.8
5
30
2.2
2.8
10
30
2.0
2.8
40
30
2.0
2.8
2.0
2.8
40
30
2.0
2.8
40
30
2.0
2.8
25
30
2.0
2.8
40
30
2.0
2.8
50
30
2.0
2.8
30
30
2.0
2.8
50
2.8
2.5
2.8
2
2.8
2.5
30
2.0
2.8
6
30
2.1
2.8
6
30
2.0
2.8
6
30
2.1
2.8
6
30
2.0
2.8
6
30
2.0
2.8
4
30
2.0
2.8
4
30
2.1
2.8
6
Viewing
Angle
2 θ ½
(Deg)
30
40
30
30
40
30
30
40
30
30
40
30
30
40
30
30
40
30
30
40
30
3BWC‐S
3BWD‐S
3BWT‐S
3GC‐S
3GD‐S
3GT‐S
3PGC‐S
3PGD‐S
3PGT‐S
3YC‐S
3YD‐S
3YT‐S
3AC‐S
3AD‐S
3AT‐S
3HC‐S
3HD‐S
3HT‐S
3RC‐S
3RD‐S
3RT‐S
45
3BC‐A/G
45
3BC
45
3BC‐R/Y
45
3BC‐Y/G
LED P/N
STANDARD TOLERANCE
±10% ALL VALUES
ANGULAR
X°
± 5°
TEL: (949) 951-8808
FAX: (949) 951-3974
TITLE:
DESIGNED:
T. Yin
CHECKED:
D. Green
DATE:
03/05/04
DATE:
03/05/04
REVISION:
PART NO:
H220CXX-LP
CAGE CODE : 32559
E
SHEET # 2 OF 4
REV.
DATE
DESCRIPTION
APPROVED
SEE SHEET#1.
LED Assy. No.
Material
H220CUBWC‐LP
GaN/SiC
H220CSGC‐LP
GaP/GaP
H220CSGD‐LP
GaP/GaP
H220CSGT‐LP
GaP/GaP
H220CSYC‐LP
GaAsP/GaP
H220CSYD‐LP
GaAsP/GaP
H220CSYT‐LP
GaAsP/GaP
H220CSAC‐LP
AlGaInP
H220CSAD‐LP
AlGaInP
H220CSAT‐LP
AlGaInP
H220CSRC‐LP
GaAlAs/GaAs
H220CSRD‐LP GaAlAs/GaAs
H220CSRT‐LP
GaAlAs/GaAs
H220CUGC‐LP
AlGaInP
H220CSUGC‐LP
AlGaInP
AlGaInP
H220CUYC‐LP
H220CSUYC‐LP
AlGaInP
H220CUUYC‐LP
AlGaInP
H220CUOC‐LP
AlGaInP
H220CSUOC‐LP
AlGaInP
H220CURC‐LP GaAlAs/GaAs
H220CSURC‐LP
AlGaInP
H220CUWC‐LP InGaN/Sappire
Chip
Peak
Wave
Length
470
568
568
568
590
590
590
605
605
605
645
645
645
570
570
590
590
590
625
625
645
640
6500K
Emitted
Color
BLUE
GREEN
GREEN
GREEN
YELLOW
YELLOW
YELLOW
AMBER
AMBER
AMBER
SUPER RED
SUPER RED
SUPER RED
GREEN
GREEN
YELLOW
YELLOW
YELLOW
ORANGE
ORANGE
RED
RED
WHITE
Lens
Appearance
WATER CLEAR
WATER CLEAR
DIFFUSED
TINTED
WATER CLEAR
DIFFUSED
TINTED
WATER CLEAR
DIFFUSED
TINTED
WATER CLEAR
DIFFUSED
TINTED
WATER CLEAR
WATER CLEAR
WATER CLEAR
WATER CLEAR
WATER CLEAR
WATER CLEAR
WATER CLEAR
WATER CLEAR
WATER CLEAR
WATER CLEAR
If
Iv
Vf
(mA)
(mcd)
(V)
MAX
TYP
MAX
TYP
30
4.0
4.5
400
30
2.1
2.8
50
30
2.1
2.8
30
30
2.1
2.8
50
30
2.0
2.8
50
30
2.0
2.8
30
30
2.0
2.8
50
30
1.8
2.4
300
30
1.8
2.4
100
30
1.8
2.4
300
30
1.7
2.4
60
30
1.7
2.4
40
30
1.7
2.4
60
30
2.1
2.4
200
30
2.1
2.4
300
30
2.0
2.4
300
30
2.0
2.4
400
30
2.0
2.4
600
30
1.8
2.4
300
30
1.8
2.4
400
30
1.7
2.4
200
30
1.8
2.4
200
30
3.2
3.6
5000
Viewing
Angle
LED P/N
2 θ ½
(Deg)
30
3UBWC‐0.6K
30
3SGC‐S
40
3SGD‐S
30
3SGT‐S
30
3SYC‐S
40
3SYD‐S
30
3SYT‐S
30
3SAC‐S
40
3SAD‐S
30
3SAT‐S
30
3SRC‐S
40
3SRD‐S
30
3SRT‐S
30
3UGC‐S
30
3SUGC‐S
30
3UYC‐S
30
3SUYC‐S
30
3UUYC‐S
30
3UOC‐S
30
3SUOC‐S
30
3URC‐S
30
3SURC‐S
30
3UWC1.030C
STANDARD TOLERANCE
±10% ALL VALUES
ANGULAR
X°
± 5°
TEL: (949) 951-8808
FAX: (949) 951-3974
TITLE:
DESIGNED:
T. Yin
CHECKED:
D. Green
DATE:
03/05/04
DATE:
03/05/04
REVISION:
PART NO:
H220CXX-LP
CAGE CODE : 32559
E
SHEET # 3 OF 4
REV.
DATE
DESCRIPTION
APPROVED
SEE SHEET#1.
Material
Chip
Peak
Wave
Length
LED Assy. No.
Absolute Max. Ratings
Emitted Color
Lens
Appearance
Electro-Optical Data @ 2mA
Vf
(V)
Iv
(mcd)
Pd
If
Peak
(mW)
(mA)
If(mA)
TYP
MAX
TYP
Viewing
Angle
2 ½
(Deg)
LED P/N
3BWDL-S
GaN/siC
λ p(nm)
430
BLUE
DIFFUSED
3.8
4.2
2.5
40
H220CGDL-LP
GaP/GaP
568
GREEN
DIFFUSED
10
7
2.1
2.6
2.0
40
3GDL-S
H220CPGDL-LP
GaP/GaP
555
PURE GREEN
DIFFUSED
10
7
2.1
2.6
0.2
40
3PGDL-S
H220CYDL-LP
GaAsP/GaP
590
YELLOW
DIFFUSED
10
7
2.0
2.6
2.0
40
3YDL-S
H220CADL-LP
GaAsP/GaP
605
AMBER
DIFFUSED
10
7
2.0
2.6
4.0
40
3ADL-S
H220CHDL-LP
GaAsP/GaP
625
HE RED
DIFFUSED
10
7
2.0
2.6
2.5
40
3HDL-S
H220CRDL-LP
GaP/GaP
700
RED
DIFFUSED
10
7
2.1
2.6
0.5
40
3RDL-S
645
RED
DIFFUSED
10
7
2.0
8.0
40
3SRDL-S
H220CBWDL-LP
H220CSRDL-LP GaAIAs/GaAs
LED Assy. No.
5 Volt
H220CBWD5V-LP
H220CGC5V-LP
H220CGD5V-LP
H220CGT5V-LP
H220CAD5V-LP
H220CHD5V-LP
H220CRD5V-LP
H220CYD5V-LP
12 Volt
H220CGC12V-LP
H220CGD12V-LP
H220CHC12V-LP
H220CHD12V-LP
H220CRC12V-LP
H220CRD12V-LP
H220CYC12V-LP
H220CYD12V-LP
Peak Wave
Length
λp(nm)
Emitted
Color
Lens
Appearance
BLUE
GREEN
GREEN
GREEN
AMBER
HE RED
RED
YELLOW
430
568
568
568
605
625
700
590
DIFFUSED
WATER CLEAR
DIFFUSED
TINTED
DIFFUSED
DIFFUSED
DIFFUSED
DIFFUSED
GREEN
GREEN
HE RED
HE RED
RED
RED
YELLOW
YELLOW
568
568
625
625
700
700
590
590
WATER CLEAR
DIFFUSED
WATER CLEAR
DIFFUSED
WATER CLEAR
DIFFUSED
WATER CLEAR
DIFFUSED
Vf
If
Iv
(V)
(mA)
(mcd)
MAX
TYP
MAX
TYP
Data @ 5V
5
10
5
40
5
25
5
40
5
25
5
30
5
2
5
Data @ 12V
12
40
12
25
12
50
12
30
12
6
12
2
12
40
12
25
Viewing
Angle
2 θ½
(Deg)
LED P/N
35
35
35
35
3BWD5V-S
3GC5V-S
3GD5V-S
3GT5V-S
3AD5V-S
3HD5V-S
3RD5V-S
3YD5V-S
3GC12V-S
3GD12V-S
3HC12V-S
3HD12V-S
3RC12V-S
3RD12V-S
3YC12V-S
3YD12V-S
STANDARD TOLERANCE
±10% ALL VALUES
ANGULAR
X°
± 5°
TEL: (949) 951-8808
FAX: (949) 951-3974
TITLE:
DESIGNED:
T. Yin
CHECKED:
D. Green
DATE:
03/05/04
DATE:
03/05/04
REVISION:
PART NO:
H220CXX-LP
CAGE CODE : 32559
E
SHEET # 4 OF 4
很抱歉,暂时无法提供与“H220CGD5V-LP”相匹配的价格&库存,您可以联系我们找货
