H220CHD5V-LP
H220CHD5V-LP
    BIVAR
    LED ASSEMBLY
H220CHD5V-LP 数据手册
REV. ITEM Q'TY 1 1 H-220C-LP T-1 (3mm) Bi-Level LED Holder, 90° Mount 2 2 3XX-S T-1 (3mm) N-Flange Shouldered LED, See Following Pages PART DESCRIPTION PART NUMBER 1 A B C D E DESCRIPTION Engineering Update w/o Changes Updated to Shouldered LEDs Locating Pin Suffix Updated LED Offering List Updated LED Optical Characteristics DATE APPROVED 03/05/04 04/01/08 04/03/12 06/25/12 09/15/15 M. C. M. C. T. Y. T. Y. J. C. 2 0.122 [3.1mm] TYP. 0.174 [4.4mm] Ø.118 [Ø3.0mm] 0.354 [9.0mm] 0.300 [7.6mm] 0.378 [9.6mm] 0.100 [2.5mm] 0.138 [3.5mm] 0.062 [1.6mm] BI-COLOR POLARITY LED P/N (1) Cathode (2) Cathode 3BC Green Red 3BC-Y/G Green Yellow Yellow 3BC-R/Y Red 3BC-A/G Green Amber 0.079 [2.0mm] 0.121 [3.1mm] 0.100 [2.5mm] 0.100 [2.5mm] Holder Face Ø.079+.003 -.002 Ø.032+.003 -.002 0.020 [0.5mm] SQ. TYP. 0.221 [5.6mm] 0.121 [3.1mm] 0.079 [2.0mm] 2 1 Standard 1 2 5 & 12 V 1 2 Bi-Color 1 2 TYP. 0.100 [2.5mm] Recommended Mounting Holes NOTE: P/N DESIGNATION H220CXXDX-LP H-400 Holder Series - " " Standard LED - "L" Low Current LED - "5V" 5V LED Color of top LED - Use "X" if blank Lens Appearance Color of Bottom LED - Use "X" if blank -If LEDs are the same, use e.g. H200CGD All Green Diffused LEDs ABSOLUTE MAXIMUM RATINGS (Ta=25° C) REVERSE VOLTAGE REVERSE CURRENT OPERATING TEMPERATURE RANGE STANDARD TOLERANCE DECIMALS .X .XX .XXX ± .1 ± .02 ± .010 DESIGNED: STORAGE TEMPERATURE LEAD SOLDERING TEMPERATURE(1/16" FROM BODY) ® ( UNLESS OTHERWISE SPECIFIED ) T. Yin CHECKED: D. Green ANGULAR X° ± 1° 4 THOMAS, IRVINE, CA. 92618 TEL: (949) 951-8808 FAX: (949) 951-3974 TITLE: DATE: 03/05/04 DATE: 03/05/04 T-1 (3MM) 90° BI-LEVEL LED LOCATOR PIN LED ASSY REVISION: PART NO: H220CXX-LP CAGE CODE : 32559 E SHEET # 1 OF 4 CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING. REV. DATE DESCRIPTION APPROVED SEE SHEET#1. LED Assy. No. H220CBWC‐LP H220CBWD‐LP H220CBWT‐LP H220CGC‐LP H220CGD‐LP H220CGT‐LP H220CPGC‐LP H220CPGD‐LP H220CPGT‐LP H220CYC‐LP H220CYD‐LP H220CYT‐LP H220CAC‐LP H220CAD‐LP H220CAT‐LP H220CHC‐LP H220CHD‐LP H220CHT‐LP H220CRC‐LP H220CRD‐LP H220CRT‐LP H220CBC‐A/G‐LP H220CBC‐LP H220CBC‐R/Y‐LP H220CBC‐Y/G‐LP Material GaN/SiC GaN/SiC GaN/SiC GaP/GaP GaP/GaP GaP/GaP GaP/GaP GaP/GaP GaP/GaP GaAsP/GaP GaAsP/GaP GaAsP/GaP GaAsP/GaP GaAsP/GaP GaAsP/GaP GaAsP/GaP GaAsP/GaP GaAsP/GaP GaP/GaP GaP/GaP GaP/GaP GaAsP/GaP GaP/GaP GaAsP/GaP GaP/GaP GaAsP/GaP GaAsP/GaP GaAsP/GaP GaP/GaP Chip Peak  Wave  Length 430 430 430 568 568 568 555 555 555 590 590 590 605 605 605 625 625 625 700 700 700 605 568 625 568 625 590 590 568 Emitted Color BLUE BLUE BLUE GREEN GREEN GREEN PURE GREEN PURE GREEN PURE GREEN YELLOW YELLOW YELLOW AMBER AMBER AMBER HE RED HE RED HE RED RED RED RED AMBER GREEN RED GREEN RED YELLOW YELLOW GREEN Lens Appearance WATER CLEAR DIFFUSED TINTED WATER CLEAR DIFFUSED TINTED WATER CLEAR DIFFUSED TINTED WATER CLEAR DIFFUSED TINTED WATER CLEAR DIFFUSED TINTED WATER CLEAR DIFFUSED TINTED WATER CLEAR DIFFUSED TINTED DIFFUSED DIFFUSED DIFFUSED DIFFUSED Electro‐Optical Data @ 20mA Vf If Iv (V) (mA) (mcd) MAX TYP MAX TYP 25 4.0 4.5 25 25 4.0 4.5 10 25 4.0 4.5 25 30 2.1 2.8 40 30 2.1 2.8 25 30 2.1 2.8 40 30 2.2 2.8 10 30 2.2 2.8 5 30 2.2 2.8 10 30 2.0 2.8 40 30 2.0 2.8 20 30 2.0 2.8 40 30 2.0 2.8 40 30 2.0 2.8 25 30 2.0 2.8 40 30 2.0 2.8 50 30 2.0 2.8 30 30 2.0 2.8 50 20 2.1 2.8 2.5 20 2.1 2.8 2 20 2.1 2.8 2.5 30 2.0 2.8 6 30 2.1 2.8 6 30 2.0 2.8 6 30 2.1 2.8 6 30 2.0 2.8 6 30 2.0 2.8 4 30 2.0 2.8 4 30 2.1 2.8 6 Viewing  Angle 2 θ ½ (Deg) 30 40 30 30 40 30 30 40 30 30 40 30 30 40 30 30 40 30 30 40 30 3BWC‐S 3BWD‐S 3BWT‐S 3GC‐S 3GD‐S 3GT‐S 3PGC‐S 3PGD‐S 3PGT‐S 3YC‐S 3YD‐S 3YT‐S 3AC‐S 3AD‐S 3AT‐S 3HC‐S 3HD‐S 3HT‐S 3RC‐S 3RD‐S 3RT‐S 45 3BC‐A/G 45 3BC 45 3BC‐R/Y 45 3BC‐Y/G LED P/N STANDARD TOLERANCE ® ( UNLESS OTHERWISE SPECIFIED ) ±10% ALL VALUES ANGULAR X° ± 5° 4 THOMAS, IRVINE, CA. 92618 TEL: (949) 951-8808 FAX: (949) 951-3974 TITLE: DESIGNED: T. Yin CHECKED: D. Green DATE: 03/05/04 DATE: 03/05/04 T-1 (3MM) 90° BI-LEVEL LED LOCATOR PIN LED ASSY REVISION: PART NO: H220CXX-LP CAGE CODE : 32559 E SHEET # 2 OF 4 CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING. REV. DATE DESCRIPTION APPROVED SEE SHEET#1. LED Assy. No. Material H220CUBWC‐LP GaN/SiC H220CSGC‐LP GaP/GaP H220CSGD‐LP GaP/GaP H220CSGT‐LP GaP/GaP H220CSYC‐LP GaAsP/GaP H220CSYD‐LP GaAsP/GaP H220CSYT‐LP GaAsP/GaP H220CSAC‐LP AlGaInP H220CSAD‐LP AlGaInP H220CSAT‐LP AlGaInP H220CSRC‐LP GaAlAs/GaAs H220CSRD‐LP GaAlAs/GaAs H220CSRT‐LP GaAlAs/GaAs H220CUGC‐LP AlGaInP H220CSUGC‐LP AlGaInP AlGaInP H220CUYC‐LP H220CSUYC‐LP AlGaInP H220CUUYC‐LP AlGaInP H220CUOC‐LP AlGaInP H220CSUOC‐LP AlGaInP H220CURC‐LP GaAlAs/GaAs H220CSURC‐LP AlGaInP H220CUWC‐LP InGaN/Sappire Chip Peak  Wave  Length 470 568 568 568 590 590 590 605 605 605 645 645 645 570 570 590 590 590 625 625 645 640 6500K Emitted  Color BLUE GREEN GREEN GREEN YELLOW YELLOW YELLOW AMBER AMBER AMBER SUPER RED SUPER RED SUPER RED GREEN GREEN YELLOW YELLOW YELLOW ORANGE ORANGE RED RED WHITE Lens Appearance WATER CLEAR WATER CLEAR DIFFUSED TINTED WATER CLEAR DIFFUSED TINTED WATER CLEAR DIFFUSED TINTED WATER CLEAR DIFFUSED TINTED WATER CLEAR WATER CLEAR WATER CLEAR WATER CLEAR WATER CLEAR WATER CLEAR WATER CLEAR WATER CLEAR WATER CLEAR WATER CLEAR Electro‐Optical Data @ 20mA If Iv Vf (mA) (mcd) (V) MAX TYP MAX TYP 30 4.0 4.5 400 30 2.1 2.8 50 30 2.1 2.8 30 30 2.1 2.8 50 30 2.0 2.8 50 30 2.0 2.8 30 30 2.0 2.8 50 30 1.8 2.4 300 30 1.8 2.4 100 30 1.8 2.4 300 30 1.7 2.4 60 30 1.7 2.4 40 30 1.7 2.4 60 30 2.1 2.4 200 30 2.1 2.4 300 30 2.0 2.4 300 30 2.0 2.4 400 30 2.0 2.4 600 30 1.8 2.4 300 30 1.8 2.4 400 30 1.7 2.4 200 30 1.8 2.4 200 30 3.2 3.6 5000 Viewing  Angle LED P/N 2 θ ½ (Deg) 30 3UBWC‐0.6K 30 3SGC‐S 40 3SGD‐S 30 3SGT‐S 30 3SYC‐S 40 3SYD‐S 30 3SYT‐S 30 3SAC‐S 40 3SAD‐S 30 3SAT‐S 30 3SRC‐S 40 3SRD‐S 30 3SRT‐S 30 3UGC‐S 30 3SUGC‐S 30 3UYC‐S 30 3SUYC‐S 30 3UUYC‐S 30 3UOC‐S 30 3SUOC‐S 30 3URC‐S 30 3SURC‐S 30 3UWC1.030C STANDARD TOLERANCE ® ( UNLESS OTHERWISE SPECIFIED ) ±10% ALL VALUES ANGULAR X° ± 5° 4 THOMAS, IRVINE, CA. 92618 TEL: (949) 951-8808 FAX: (949) 951-3974 TITLE: DESIGNED: T. Yin CHECKED: D. Green DATE: 03/05/04 DATE: 03/05/04 T-1 (3MM) 90° BI-LEVEL LED LOCATOR PIN LED ASSY REVISION: PART NO: H220CXX-LP CAGE CODE : 32559 E SHEET # 3 OF 4 CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING. REV. DATE DESCRIPTION APPROVED SEE SHEET#1. Material Chip Peak Wave Length LED Assy. No. Absolute Max. Ratings Emitted Color Lens Appearance Electro-Optical Data @ 2mA Vf (V) Iv (mcd) Pd If Peak (mW) (mA) If(mA) TYP MAX TYP Viewing Angle 2 ½ (Deg) LED P/N 3BWDL-S GaN/siC λ p(nm) 430 BLUE DIFFUSED 20 7 - 3.8 4.2 2.5 40 H220CGDL-LP GaP/GaP 568 GREEN DIFFUSED 10 7 - 2.1 2.6 2.0 40 3GDL-S H220CPGDL-LP GaP/GaP 555 PURE GREEN DIFFUSED 10 7 - 2.1 2.6 0.2 40 3PGDL-S H220CYDL-LP GaAsP/GaP 590 YELLOW DIFFUSED 10 7 - 2.0 2.6 2.0 40 3YDL-S H220CADL-LP GaAsP/GaP 605 AMBER DIFFUSED 10 7 - 2.0 2.6 4.0 40 3ADL-S H220CHDL-LP GaAsP/GaP 625 HE RED DIFFUSED 10 7 - 2.0 2.6 2.5 40 3HDL-S H220CRDL-LP GaP/GaP 700 RED DIFFUSED 10 7 - 2.1 2.6 0.5 40 3RDL-S 645 RED DIFFUSED 10 7 - 2.0 - 8.0 40 3SRDL-S H220CBWDL-LP H220CSRDL-LP GaAIAs/GaAs LED Assy. No. 5 Volt H220CBWD5V-LP H220CGC5V-LP H220CGD5V-LP H220CGT5V-LP H220CAD5V-LP H220CHD5V-LP H220CRD5V-LP H220CYD5V-LP 12 Volt H220CGC12V-LP H220CGD12V-LP H220CHC12V-LP H220CHD12V-LP H220CRC12V-LP H220CRD12V-LP H220CYC12V-LP H220CYD12V-LP Peak Wave Length λp(nm) Emitted Color Lens Appearance BLUE GREEN GREEN GREEN AMBER HE RED RED YELLOW 430 568 568 568 605 625 700 590 DIFFUSED WATER CLEAR DIFFUSED TINTED DIFFUSED DIFFUSED DIFFUSED DIFFUSED GREEN GREEN HE RED HE RED RED RED YELLOW YELLOW 568 568 625 625 700 700 590 590 WATER CLEAR DIFFUSED WATER CLEAR DIFFUSED WATER CLEAR DIFFUSED WATER CLEAR DIFFUSED Electro-Optical Data Vf If Iv (V) (mA) (mcd) MAX TYP MAX TYP Data @ 5V 5 10 5 40 5 25 5 40 5 25 5 30 5 2 5 20 Data @ 12V 12 40 12 25 12 50 12 30 12 6 12 2 12 40 12 25 Viewing Angle 2 θ½ (Deg) LED P/N 35 20 35 20 35 35 35 35 3BWD5V-S 3GC5V-S 3GD5V-S 3GT5V-S 3AD5V-S 3HD5V-S 3RD5V-S 3YD5V-S 20 35 20 35 20 35 20 35 3GC12V-S 3GD12V-S 3HC12V-S 3HD12V-S 3RC12V-S 3RD12V-S 3YC12V-S 3YD12V-S STANDARD TOLERANCE ® ( UNLESS OTHERWISE SPECIFIED ) ±10% ALL VALUES ANGULAR X° ± 5° 4 THOMAS, IRVINE, CA. 92618 TEL: (949) 951-8808 FAX: (949) 951-3974 TITLE: DESIGNED: T. Yin CHECKED: D. Green DATE: 03/05/04 DATE: 03/05/04 T-1 (3MM) 90° BI-LEVEL LED LOCATOR PIN LED ASSY REVISION: PART NO: H220CXX-LP CAGE CODE : 32559 E SHEET # 4 OF 4 CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING.
H220CHD5V-LP 价格&库存
很抱歉,暂时无法提供与“H220CHD5V-LP”相匹配的价格&库存,您可以联系我们找货
