H278CSRSGD
H278CSRSGD
    BIVAR
    LED ASSEMBLY
H278CSRSGD 数据手册
ITEM Q'TY PART NUMBER REV. PART DESCRIPTION 1 1 H-278C-2 T-1¾ (5mm) Bi-Level LED Holder, 90° Mount 2 2 5XX T-1¾ (5mm) Non-Flange LED, See Following Pages 1 2 0.170 [4.3mm] TYP. 0.240 [6.1mm] C D E F G H J DATE APPROVED 02/28/05 02/14/07 02/27/07 03/04/09 05/29/12 06/19/12 09/15/15 M. C. M. C. M. C. T. Y. T. Y. T. Y. J. C. DESCRIPTION Corrected Holder from H-278C to H-278C-1. Changed Holder from H-278C-1 to H-278C-2. Changed LED Protrusion from .180 to .170 Added P/N Designation Note Added H278CGAD Updated LED Offering List Updated LED Optical Characteristics 0.433 [11.0mm] Ø.197 [Ø5.0mm] TYP. 0.380 [9.7mm] 0.500 [12.7mm] 0.130 [3.3mm] 0.157 [4.0mm] 0.100 [2.5mm] 1 2 Standard 1 2 5 & 12 V 1 2 Bi-Color 1 2 0.310 [7.9mm] 0.220 [5.6mm] 0.020 [0.5mm] SQ. TYP. BI-COLOR POLARITY LED P/N (1) Cathode (2) Cathode Red 5BC Green Yellow 5BC-Y/G Green Red 5BC-R/Y Yellow Amber 5BC-A/G Green NOTE: P/N CONFIGURATION H278CYGDL H278 Holder Series Color of top LED - Use "X" if blank Color of bottom LED - Use "X" if blank - " " Standard LED - "L" Low Current LED - "5V" 5V LED - "12V" 12V LED 0.220 [5.6mm] 0.090 [2.3mm] Lens Appearance 0.100 [2.5mm] LED Lead -If LEDs are the same, use e.g. H278CGD Recommended Mounting Holes All Green LEDs ABSOLUTE MAXIMUM RATINGS (Ta=25° C) REVERSE VOLTAGE Holder Face Ø.032+.003 -.002 TYP. 5V REVERSE CURRENT 100uA OPERATING TEMPERATURE RANGE -25° C - 85° C STORAGE TEMPERATURE -30° C - 100° C LEAD SOLDERING TEMPERATURE(1/16" FROM BODY) 260° C FOR 5 SECONDS STANDARD TOLERANCE ® ( UNLESS OTHERWISE SPECIFIED ) DECIMALS .X .XX .XXX ± .1 ± .02 ± .010 DESIGNED: T. Yin CHECKED: D. Green ANGULAR X° ± 1° 4 THOMAS, IRVINE, CA. 92618 TEL: (949) 951-8808 TITLE: DATE: 03/05/04 DATE: 03/05/04 PART NO: FAX: (949) 951-3974 T-1¾ (5MM) 90° BI-LEVEL LED ASSY REVISION: H278CXX CAGE CODE : 32559 J SHEET # 1 OF 4 CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING. REV. DATE DESCRIPTION APPROVED SEE SHEET#1. LED Assy. No. H278CBWC H278CBWD H278CBWT H278CGC H278CGD H278CGT H278CUGC H278CPGC H278CPGD H278CPGT H278CYC H278CYD H278CYT H278CAC H278CAD H278CAT H278CHC H278CHD H278CHT H278CRC H278CRD H278CRT H278CBC‐A/G H278CBC H278CBC‐R/Y H278CBC‐Y/G Material GaN/SiC GaN/SiC GaN/SiC GaP/GaP GaP/GaP GaP/GaP AlGaInP GaP/GaP GaP/GaP GaP/GaP GaAsP/GaP GaAsP/GaP GaAsP/GaP GaAsP/GaP GaAsP/GaP GaAsP/GaP GaAsP/GaP GaAsP/GaP GaAsP/GaP GaP/GaP GaP/GaP GaP/GaP GaAsP/GaP GaP/GaP GaAsP/GaP GaP/GaP GaAsP/GaP GaAsP/GaP GaAsP/GaP GaP/GaP Chip Peak  Wave  Length 430 430 430 568 568 568 570 555 555 555 590 590 590 605 605 605 625 625 625 700 700 700 605 568 625 568 625 590 590 568 Emitted Color BLUE BLUE BLUE GREEN GREEN GREEN GREEN PURE GREEN PURE GREEN PURE GREEN YELLOW YELLOW YELLOW AMBER AMBER AMBER HE RED HE RED HE RED RED RED RED AMBER GREEN RED GREEN RED YELLOW YELLOW GREEN Lens Appearance WATER CLEAR DIFFUSED TINTED WATER CLEAR DIFFUSED TINTED WATER CLEAR WATER CLEAR DIFFUSED TINTED WATER CLEAR DIFFUSED TINTED WATER CLEAR DIFFUSED TINTED WATER CLEAR DIFFUSED TINTED WATER CLEAR DIFFUSED TINTED WHITE DIFFUSED WHITE DIFFUSED WHITE DIFFUSED WHITE DIFFUSED Electro‐Optical Data @ 20mA Vf If Iv (V) (mA) (mcd) MAX TYP MAX TYP 25 4.0 4.5 25 25 4.0 4.5 15 25 4.0 4.5 30 30 2.1 2.8 40 30 2.1 2.8 25 30 2.1 2.8 40 30 2.1 2.4 600 30 2.2 2.8 10 30 2.2 2.8 10 30 2.2 2.8 10 30 2.0 2.8 40 30 2.0 2.8 25 30 2.0 2.8 40 30 2.0 2.8 40 30 2.0 2.8 25 30 2.0 2.8 40 30 2.0 2.8 40 30 2.0 2.8 25 30 2.0 2.8 40 20 2.1 2.8 2 20 2.1 2.8 2 20 2.1 2.8 2 30 2.0 2.8 6 30 2.1 2.8 6 30 2.0 2.8 6 30 2.1 2.8 8 30 2.0 2.8 6 30 2.0 2.8 5 30 2.0 2.8 5 30 2.1 2.8 8 Viewing  Angle 2 θ ½ (Deg) 20 45 20 35 45 35 35 35 45 35 35 45 35 35 45 35 35 45 35 35 45 35 LED P/N 5BWC 5BWD 5BWT 5GC 5GD 5GT 5UGC 5PGC 5PGD 5PGT 5YC 5YD 5YT 5AC 5AD 5AT 5HC 5HD 5HT 5RC 5RD 5RT 45 5BC‐A/G 45 5BC 45 5BC‐R/Y 45 5BC‐Y/G STANDARD TOLERANCE ® ( UNLESS OTHERWISE SPECIFIED ) ±10% ALL VALUES ANGULAR X° ± 5° 4 THOMAS, IRVINE, CA. 92618 TEL: (949) 951-8808 TITLE: DESIGNED: T. Yin CHECKED: D. Green DATE: 03/05/04 DATE: 03/05/04 PART NO: FAX: (949) 951-3974 T-1¾ (5MM) 90° BI-LEVEL LED ASSY REVISION: H278CXX CAGE CODE : 32559 J SHEET # 2 OF 4 CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING. REV. DATE DESCRIPTION APPROVED SEE SHEET#1. LED Assy. No. H278CUBWC H278CSGC H278CSGD H278CSGT H278CSYC H278CSYD H278CSYT H278CSRC H278CSRD H278CSRT H278CUGC H278CSUGC H278CUYC H278CSUYC H278CUUYC H278CUOC H278CUOC H278CURC H278CSURC H278CUWC Material InGaN/SiC GaP/GaP GaP/GaP GaP/GaP GaAsP/GaP GaAsP/GaP GaAsP/GaP GaAlAs/GaAs GaAlAs/GaAs GaAlAs/GaAs AlGaInP AlGaInP AlGaInP AlGaInP AlGaInP AlGaInP AlGaInP GaAlAs/GaAs AlGaInP InGaN/SiC Chip Peak  Wave  Length 468 568 568 568 590 590 590 645 645 645 570 570 590 590 590 625 625 645 640 6500K Emitted  Color BLUE GREEN GREEN GREEN YELLOW YELLOW YELLOW SUPER RED SUPER RED SUPER RED GREEN GREEN YELLOW YELLOW YELLOW ORANGE ORANGE RED RED WHITE Lens Appearance WATER CLEAR WATER CLEAR DIFFUSED TINTED WATER CLEAR DIFFUSED TINTED WATER CLEAR DIFFUSED TINTED WATER CLEAR WATER CLEAR WATER CLEAR WATER CLEAR WATER CLEAR WATER CLEAR WATER CLEAR WATER CLEAR WATER CLEAR WATER CLEAR Electro‐Optical Data @ 20mA If Iv Vf (mA) (mcd) (V) MAX TYP MAX TYP 50 3.2 3.6 5000 30 2.1 2.8 60 30 2.1 2.8 50 30 2.1 2.8 60 30 2.0 2.8 600 30 2.0 2.8 150 30 2.0 2.8 600 30 1.7 2.4 60 30 1.7 2.4 40 30 1.7 2.4 60 30 2.1 2.4 400 30 2.1 2.4 300 30 2.0 2.4 1000 30 2.0 2.4 700 30 2.0 2.4 500 30 1.8 2.4 1400 30 1.8 2.4 1300 30 1.7 2.4 400 30 1.8 2.4 500 100 3.5 4.2 2700 Viewing  Angle LED P/N 2 θ ½ (Deg) 15 5BWC2.515 35 5SGC 45 5SGD 35 5SGT 35 5SYC 45 5SYD 35 5SYT 35 5SRC 45 5SRD 35 5SRT 35 5UGC 35 5SUGC 30 5UYC 35 5SUYC 35 5UUYC 35 5UOC 35 5SUOC 30 5URC 35 5SURC 30 5WC2.730 STANDARD TOLERANCE ® ( UNLESS OTHERWISE SPECIFIED ) ±10% ALL VALUES ANGULAR X° ± 5° 4 THOMAS, IRVINE, CA. 92618 TEL: (949) 951-8808 TITLE: DESIGNED: T. Yin CHECKED: D. Green DATE: 03/05/04 DATE: 03/05/04 PART NO: FAX: (949) 951-3974 T-1¾ (5MM) 90° BI-LEVEL LED ASSY REVISION: H278CXX CAGE CODE : 32559 J SHEET # 3 OF 4 CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING. REV. DATE DESCRIPTION APPROVED SEE SHEET#1. Max. Rating Electro-Optical Data @ 2m A MAX TYP MAX TYP View ing Angle 2 ½ (Deg) DIFFUSED 7 3.8 4.2 4 45 5BWDL PURE GREEN DIFFUSED 7 2.1 2.6 1 45 5PGDL 568 GREEN DIFFUSED 7 2.1 2.6 4 45 5GDL H278CYDL 590 YELLOW DIFFUSED 7 2.0 2.6 4 45 5YDL H278CADL 605 AMBER DIFFUSED 7 2.0 2.6 4 45 5ADL H278CHDL 625 HE RED DIFFUSED 7 2.0 2.6 5 45 5HDL H278CSRDL 645 SUPER RED DIFFUSED 7 1.7 2.3 6 45 5SRDL Viewing Angle 2 θ½ (Deg) LED P/N 45 35 45 35 45 45 45 45 5BWD5V 5GC5V 5GD5V 5GT5V 5AD5V 5HD5V 5RD5V 5YD5V 35 45 35 45 35 45 35 45 5GC12V 5GD12V 5HC12V 5HD12V 5RC12V 5RD12V 5YC12V 5YD12V Peak Wave Length λp(nm ) Em itted Color H278CBWDL 430 BLUE H278CPGDL 555 H278CGDL LED Assy. No. LED Assy. No. 5 Volt H278CBWD5V H278CGC5V H278CGD5V H278CGT5V H278CAD5V H278CHD5V H278CRD5V H278CYD5V 12 Volt H278CGC12V H278CGD12V H278CHC12V H278CHD12V H278CRC12V H278CRD12V H278CYC12V H278CYD12V Lens Appearance If (m A) Peak Wave Length λp(nm) Emitted Color Lens Appearance BLUE GREEN GREEN GREEN AMBER HE RED RED YELLOW 430 568 568 568 605 625 700 590 DIFFUSED WATER CLEAR DIFFUSED TINTED DIFFUSED DIFFUSED DIFFUSED DIFFUSED GREEN GREEN HE RED HE RED RED RED YELLOW YELLOW 568 568 625 625 700 700 590 590 WATER CLEAR DIFFUSED WATER CLEAR DIFFUSED WATER CLEAR DIFFUSED WATER CLEAR DIFFUSED Iv (m cd) Vf (V) Electro-Optical Data Vf If Iv (V) (mA) (mcd) MAX TYP MAX TYP Data @ 5V 5 15 5 40 5 25 5 40 5 25 5 30 5 1.5 5 25 Data @ 12V 12 40 12 25 12 50 12 30 12 2 12 1.5 12 25 12 20 LED P/N STANDARD TOLERANCE ® ( UNLESS OTHERWISE SPECIFIED ) ±10% ALL VALUES ANGULAR X° ± 5° 4 THOMAS, IRVINE, CA. 92618 TEL: (949) 951-8808 TITLE: DESIGNED: T. Yin CHECKED: D. Green DATE: 03/05/04 DATE: 03/05/04 PART NO: FAX: (949) 951-3974 T-1¾ (5MM) 90° BI-LEVEL LED ASSY REVISION: H278CXX CAGE CODE : 32559 J SHEET # 4 OF 4 CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING.
H278CSRSGD 价格&库存
很抱歉,暂时无法提供与“H278CSRSGD”相匹配的价格&库存,您可以联系我们找货
