H301CBC-A/G-100
H301CBC-A/G-100
    BIVAR
    LED ASSEMBLY
H301CBC-A/G-100 数据手册
ITEM Q'TY 1 1 H-301C-1-XXX T-1 (3mm) Bi-Level LED Holder, 90° Mount, Var. C/L 2 2 3BC-X T-1 (3mm) N-Flange Shouldered LED, See Page 2 PART NUMBER REV. PART DESCRIPTION 1 DATE APPROVED 05/25/11 06/24/16 T. Y. J. C. DESCRIPTION A Engineering Release B Engineering Update w/o Changes 2 0.094 [2.4mm] TYP. 0.170 [4.3mm] 0.320 [8.1mm] Ø.118 [Ø3.0mm] TYP. C/L 2 L C/L 1 0.100 [2.5mm] Polarity Mark 0.157 [4.0mm] 0.285 [7.2mm] 0.185 [4.7mm] 0.020 [0.5mm] LED P/N (1) CATHODE (2) CATHODE 3BC GREEN RED 3BC-A/G AMBER GREEN 3BC-R/Y RED YELLOW 3BC-Y/G YELLOW GREEN Available Centerlines L XXX C/L 1 C/L 2 .100 (2.5) .300 (7.6) .415 (10.6) 100 120 .120 (3.0) .320 (8.1) .435 (11.0) 140 .140 (3.6) .340 (8.6) .455 (11.6) 160 .160 (4.1) .360 (9.1) .475 (12.1) 180 .180 (4.6) .380 (9.7) .495 (12.6) SQ. TYP. Holder Face Ø.032+.003 -.002 0.185 [4.7mm] TYP. 0.100 [2.5mm] TYP. 0.100 [2.5mm] LED Lead Recommended Mounting Holes STANDARD TOLERANCE ® ( UNLESS OTHERWISE SPECIFIED ) DECIMALS ABSOLUTE MAXIMUM RATINGS (Ta=25° C) OPERATING TEMPERATURE RANGE .X .XX .XXX ± .1 ± .02 ± .010 DESIGNED: STORAGE TEMPERATURE LEAD SOLDERING TEMPERATURE(1/16" FROM BODY) M. Myers CHECKED: R. Paje ANGULAR X° ± 1° 4 THOMAS, IRVINE, CA. 92618 TEL: (949) 951-8808 TITLE: DATE: 05/25/11 DATE: 05/25/11 FAX: (949) 951-3974 T-1 (3MM) 90° BI-LEVEL VAR. C/L LED ASSY REVISION: PART NO: H301CBC-XX-XXX CAGE CODE : 32559 B SHEET # 1 OF 2 CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING. REV. DATE DESCRIPTION APPROVED SEE SHEET #1 LED Assy. No. H301CBC-XXX H301CBC-A/G-XXX H301CBC-R/Y-XXX H301CBC-Y/G-XXX Peak Wave Length λp(nm ) Electro-Optical Data @ 20m A Em itted Color 625 RED 568 GREEN 605 AMBER 568 GREEN 625 RED 590 YELLOW 590 YELLOW 568 GREEN Lens Appearance WHITE DIFFUSED WHITE DIFFUSED WHITE DIFFUSED WHITE DIFFUSED TYP TYP MAX TYP View ing Angle 2 ½ (Deg) 20 2.0 2.8 6 45 20 2.1 2.8 6 45 20 2.0 2.8 6 45 20 2.1 2.8 6 45 20 2.0 2.8 6 45 20 2.0 2.8 4 45 20 2.0 2.8 4 45 20 2.1 2.8 6 45 If (m A) Iv (m cd) Vf (V) LED P/N 3BC 3BC-A/G 3BC-R/Y 3BC-Y/G PART NUMBER DESIGNATION H301CBC-XX-XXX* * XXX = Centerline "C/L" Centerline "C/L1" LED Colors Series STANDARD TOLERANCE ® ( UNLESS OTHERWISE SPECIFIED ) ±10% ALL VALUES ANGULAR 4 THOMAS, IRVINE, CA. 92618 TEL: (949) 951-8808 TITLE: DESIGNED: M. Myers CHECKED: R. Paje DATE: 05/25/11 DATE: 05/25/11 FAX: (949) 951-3974 T-1 (3MM) 90° BI-LEVEL VAR. C/L LED ASSY REVISION: PART NO: H301CBC-XX-XXX CAGE CODE : 32559 B SHEET # 2 OF 2 CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING.
H301CBC-A/G-100 价格&库存
很抱歉,暂时无法提供与“H301CBC-A/G-100”相匹配的价格&库存,您可以联系我们找货
