H310CGHYDL
H310CGHYDL
    BIVAR
    LED ASSEMBLY
H310CGHYDL 数据手册
REV. ITEM Q'TY 1 1 H-311C T-1 (3mm) Tri-Level LED Holder, 90° Mount 2 3 3XX-201-S T-1 (3mm) Extended Profile Shouldered LED, See Page 2 See P/N Configuration for LED Qty PART NUMBER PART DESCRIPTION 1 DESCRIPTION D Added H310CRDL Spec E Added H310CBC Spec F Removed -RP Spec G Added 3ADL-201-S Spec H Removed Part Numbers, See Page 2 J Engineering Update w/o Changes DATE APPROVED 08/13/08 10/14/08 09/21/09 03/05/10 03/05/15 06/24/16 M. C. M. C. T. Y. T. Y. J. C. J. C. 2 0.079 [2.0mm] TYP. 0.450 [11.4mm] 0.170 [4.3mm] Ø.118 [Ø3.0mm] TYP. 0.500 [12.7mm] 0.600 [15.2mm] 0.300 [7.6mm] 0.100 [2.5mm] Cathode I.D. Mark NOTE: P/N Configuration 0.157 [4.0mm] 0.100 [2.5mm] 0.385 [9.8mm] 0.285 [7.2mm] 0.185 [4.7mm] 0.020 [0.5mm] H310CXXXDX H31X Holder Series Color of top LED - Use "X" if blank - " " Standard 20 mA LED - "L" Low Current 2mA LED Color of middle LED - Use "X" if blank Green Cathode Red Cathode Diffused Lens Holder Face 0.185 [4.7mm] Color of bottom LED - Use "X" if blank e.g. H 3 1 0 C H X S G D L Series SQ. TYP. Ø.032+.003 -.002 TYP. 0.100 [2.5mm] Low Current LEDs Diffused Lens Appearance Super Green, bottom LED No LED HE Red, top LED -If LEDs are the same, use e.g. H310CGD 0.200 [5.1mm] 0.100 [2.5mm] LED Lead Recommended Mounting Holes All Green, Standard 20 mA LEDs ABSOLUTE MAXIMUM RATINGS (Ta=25° C) REVERSE VOLTAGE REVERSE CURRENT OPERATING TEMPERATURE RANGE STANDARD TOLERANCE DECIMALS .X .XX .XXX ± .1 ± .02 ± .010 DESIGNED: STORAGE TEMPERATURE LEAD SOLDERING TEMPERATURE(1/16" FROM BODY) ® ( UNLESS OTHERWISE SPECIFIED ) T. Yin CHECKED: D. Green ANGULAR X° ± 1° 4 THOMAS, IRVINE, CA. 92618 TEL: (949) 951-8808 TITLE: DATE: 03/08/04 DATE: 03/08/04 PART NO: FAX: (949) 951-3974 T-1 (3mm) 90° TRI-LEVEL LED ASSY REVISION: H310CXX CAGE CODE : 32559 J SHEET # 1 OF 2 CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING. REV. DATE DESCRIPTION APPROVED SEE SHEET #1 LED Assy. No. STANDARD H310CBWD H310CGD H310CGC H310CGT H310CSGC H310CYD H310CYT H310CSYC H310CHD H310CRD H310CRC H310CRT H310CSRD H310CSRC H310CBC LOW CURRENT H310CADL H310CGDL H310CYDL H310CHDL H310CRDL Electro-Optical Data Peak Wave Length λ p(nm ) Em itted Color Lens Appearance 430 568 568 568 568 590 590 590 625 700 700 700 645 645 BLUE GREEN GREEN GREEN SUPER GREEN YELLOW YELLOW SUPER YELLOW HE RED RED RED RED SUPER RED SUPER RED DIFFUSED DIFFUSED WATER CLEAR TINTED WATER CLEAR DIFFUSED TINTED WATER CLEAR DIFFUSED DIFFUSED WATER CLEAR TINTED DIFFUSED WATER CLEAR 635 568 HE RED GREEN WHITE DIFFUSED 605 568 590 625 700 AMBER GREEN YELLOW HE RED RED DIFFUSED DIFFUSED DIFFUSED DIFFUSED DIFFUSED Vf If Iv (V) (m A) (m cd) TYP TYP MAX TYP Data @ 20m A 20 4.0 4.5 10 20 2.1 2.8 25 20 2.1 2.8 40 20 2.1 2.8 40 20 2.1 2.8 50 20 2.0 2.8 20 20 2.0 2.8 40 20 2.0 2.8 50 20 2.0 2.8 30 20 2.1 2.8 2 20 2.1 2.8 3 20 2.1 2.8 3 20 1.7 2.4 40 20 1.7 2.4 60 20 2.0 20 2.1 Data @ 2m A 2 2.0 2 2.1 2 2.0 2 2.0 2 2.1 View ing Angle 2 ½ (Deg) LED P/N 35 35 20 20 20 35 20 20 35 35 20 20 35 20 3BWD-201-S 3GD-201-S 3GC-201-S 3GT-201-S 3SGC-201-S 3YD-201-S 3YT-201-S 3SYC-201-S 3HD-201-S 3RD-201-S 3RC-201-S 3RT-201-S 3SRD-201-S 3SRC-201-S 2.8 2.8 6 6 45 45 3BC-201 2.8 2.8 2.6 2.6 2.8 2 2 2 3 0.2 35 35 35 35 35 3ADL-201-S 3GDL-201-S 3YDL-201-S 3HDL-201-S 3RDL-201-S STANDARD TOLERANCE ® ( UNLESS OTHERWISE SPECIFIED ) ±10% ALL VALUES ANGULAR 4 THOMAS, IRVINE, CA. 92618 TEL: (949) 951-8808 TITLE: DESIGNED: T. Yin CHECKED: D. Green DATE: 03/08/04 DATE: 03/08/04 PART NO: FAX: (949) 951-3974 T-1 (3mm) 90° TRI-LEVEL LED ASSY REVISION: H310CXX CAGE CODE : 32559 J SHEET # 2 OF 2 CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING.
H310CGHYDL
1. 物料型号:文档列出了两种物料型号,H-311C 和 3XX-201-S。 - H-311C 是 T-1 (3mm) 三级 LED 支架,90° 安装。 - 3XX-201-S 是 T-1 (3mm) 扩展轮廓带肩 LED,具体配置见第2页。
2. 器件简介:文档提到了不同版本的修订记录,包括添加和删除规格说明。
3. 引脚分配:文档中没有明确提到引脚分配,但提供了 LED 支架和 LED 的配置信息。
4. 参数特性:提供了 LED 支架的尺寸信息,例如 0.079 英寸典型值,0.170 英寸最大值等。
5. 功能详解:文档详细列出了不同颜色 LED 的峰值波长、发射颜色、透镜外观、电光数据、视场角度和 LED 型号。
6. 应用信息:文档中没有直接提到应用信息,但提供了 LED 支架和 LED 的配置信息,可以推断这些信息对应用选择很重要。
7. 封装信息:文档提供了 LED 支架的封装信息,包括尺寸和颜色代码。
H310CGHYDL 价格&库存
很抱歉,暂时无法提供与“H310CGHYDL”相匹配的价格&库存,您可以联系我们找货
