H310CYGYD
H310CYGYD
    BIVAR
    LED ASSEMBLY
H310CYGYD 数据手册
ITEM 1 2 3 Q'TY 1 2 1 PART NUMBER REV. PART DESCRIPTION A T-1 (3mm) Tri-Level LED Holder T-1 (3mm) Non-Flange LED T-1 (3mm) Non-Flange LED H-311C 3YD-201 3GD-201 1 DESCRIPTION DATE Engineering Release. APPROVED 01/03/07 M. C. 0.07 [1.8mm] 0.170 [4.3mm] 0.450 [11.4mm] Ø0.118 [Ø3.0mm]TYP. 2 3 0.500 [12.7mm] 0.300 [7.6mm] 0.600 [15.2mm] Holder Face 2 0.200 [5.1mm] 0.157 [4.0mm] Cathode ID 0.100 [2.5mm] Ø.032 +.003 TYP. -.002 0.185 [4.7mm] 0.100 [2.5mm] 0.100 [2.5mm] 0.100 [2.5mm]LED Lead 0.020 [0.5mm]SQ. TYP. 0.385 [9.8mm] Recommended Mounting Holes 0.285 [7.2mm] 0.185 [4.7mm] LED Part No. 3YD-201 3GD-201 Material GaAsP/GaP GaP/GaP Chip Peak Wave Length lp(nm) 585 565 Absolute Maximum Ratings Lens Appearance Dl (nm) Pd (mW) If (mA) Peak If (mA) DIFFUSED DIFFUSED 35 30 80 80 30 30 150 150 Emitted Color YELLOW GREEN ABSOLUTE MAXIMUM RATINGS (Ta = 25°C) 5V REVERSE CURRENT ( VR=5V) 100 µA OPERATING TEMPERATURE RANGE -25°C ~ 85°C STORAGE TEMPERATURE -30°C ~ 100°C LEAD SOLDERING TEMPERATURE (1/16" FROM BODY) 260°C for 5 Seconds 2.1 2.2 2.6 2.6 Viewing Angle (Deg) 20 30 45 45 STANDARD TOLERANCE  ( UNLESS OTHERWISE SPECIFIED ) DECIMALS REVERSE VOLTAGE Electro-Optical Data @ 20mA Vf lv (V) (mcd) Typ. Typ. Max. .X ± .1 .XX ± .02 .XXX ± .010 DESIGNED: Sonny Dam CHECKED: D. Beckman ANGULAR X° ± 1° DATE: 01/03/07 DATE: 01/03/07 4 THOMAS, IRVINE, CA. 92618 TEL: (949) 951-8808 FAX: (949) 951-3974 TITLE: T-1 (3mm) Tri-Level LED Assembly REVISION: PART NO: H310CYGYD CAGE CODE : 32559 A SHEET # 1 OF 1 CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING.
H310CYGYD 价格&库存
很抱歉,暂时无法提供与“H310CYGYD”相匹配的价格&库存,您可以联系我们找货
