H315CGYHDL
H315CGYHDL
    BIVAR
    LED ASSEMBLY
H315CGYHDL 数据手册
REV. ITEM Q'TY 1 1 H-310C T-1 (3mm) Tri-Level LED Holder, 90° Mount, Interlocking 2 3 3XX-201-S T-1 (3mm) Extended Profile Shouldered LED, See Page 2 PART NUMBER PART DESCRIPTION 1 DESCRIPTION A B C D E Engineering Update w/o Changes LED Package Change to 3XX-201-S LEDs Typo, H315SRD should be H315CSRD Removed Part Numbers, See Page 2 Engineering Update w/o Changes DATE APPROVED 03/08/04 12/14/07 06/22/12 03/04/15 06/24/16 M. C. M. C. M. C. J. C. J. C. 2 0.079 [2.0mm] TYP. 0.170 [4.3mm] Ø.118 [Ø3.0mm] 0.450 [11.4mm] TYP. 0.500 [12.7mm] 0.600 [15.2mm] 0.300 [7.6mm] 0.100 [2.5mm] Cathode I.D. Mark 0.157 [4.0mm] 0.100 [2.5mm] 0.385 [9.8mm] 0.285 [7.2mm] 0.185 [4.7mm] 0.020 [0.5mm] SQ. TYP. NOTE: P/N CONFIGURATION H315CYGYDL H315 Holder Series Color of top LED - Use "X" if blank Holder Faces - " " Standard LED - "L" Low Current LED Color of middle LED - Use "X" if blank Lens Appearance Color of bottom LED - Use "X" if blank 0.100 [2.5mm] 0.200 [5.1mm] 0.174 [4.4mm] Holder Pitch 0.100 [2.5mm] LED Lead -If LEDs are the same, use e.g. H315CGD All Green LEDs ABSOLUTE MAXIMUM RATINGS (Ta=25° C) REVERSE VOLTAGE REVERSE CURRENT OPERATING TEMPERATURE RANGE Recommended Mounting Holes STANDARD TOLERANCE LEAD SOLDERING TEMPERATURE(1/16" FROM BODY) ® ( UNLESS OTHERWISE SPECIFIED ) DECIMALS .X .XX .XXX ± .1 ± .02 ± .010 DESIGNED: STORAGE TEMPERATURE Ø.032+.003 -.002 TYP. 0.185 [4.7mm] T. Yin CHECKED: D. Green ANGULAR X° ± 1° 4 THOMAS, IRVINE, CA. 92618 TEL: (949) 951-8808 TITLE: DATE: 03/08/04 DATE: 03/08/04 PART NO: FAX: (949) 951-3974 T-1 (3MM) INTERLOCKING 90° TRI-LEVEL LED ASSY REVISION: H315CXX CAGE CODE : 32559 E SHEET # 1 OF 2 CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING. REV. DATE DESCRIPTION APPROVED SEE SHEET #1 LED Assy. No. STANDARD H315CBWD H315CGD H315CYD H315CHD H315CRD H315CSRD LOW CURRENT H315CGDL H315CYDL H315CHDL Electro-Optical Data Peak Wave Length λ p(nm ) Em itted Color Lens Appearance 430 565 585 635 655 660 BLUE GREEN YELLOW HE RED RED SUPER RED DIFFUSED DIFFUSED DIFFUSED DIFFUSED DIFFUSED DIFFUSED 565 585 635 GREEN YELLOW HE RED DIFFUSED DIFFUSED DIFFUSED View ing Angle LED P/N Vf If Iv 2 ½ (V) (m A) (m cd) (Deg) TYP TYP MAX TYP Data @ 20m A 20 4.0 4.5 20 45 3BWD-201-S 20 2.2 2.6 30 45 3GD-201-S 20 2.1 2.6 20 45 3YD-201-S 20 2.0 2.6 30 45 3HD-201-S 20 1.7 2.0 6 45 3RD-201-S 20 2.2 2.6 90 45 3SRD-201-S Data @ 2m A 2 1.8 2.6 6 45 3GDL-201-S 2 1.8 2.6 4 45 3YDL-201-S 2 1.8 2.6 6 45 3HDL-201-S STANDARD TOLERANCE ® ( UNLESS OTHERWISE SPECIFIED ) ±10% ALL VALUES ANGULAR 4 THOMAS, IRVINE, CA. 92618 TEL: (949) 951-8808 TITLE: DESIGNED: T. Yin CHECKED: D. Green DATE: 03/08/04 DATE: 03/08/04 PART NO: FAX: (949) 951-3974 T-1 (3MM) INTERLOCKING 90° TRI-LEVEL LED ASSY REVISION: H315CXX CAGE CODE : 32559 E SHEET # 2 OF 2 CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING.
H315CGYHDL 价格&库存
很抱歉,暂时无法提供与“H315CGYHDL”相匹配的价格&库存,您可以联系我们找货
