H320CGGHD5V-LP
H320CGGHD5V-LP
    BIVAR
    LED ASSEMBLY
H320CGGHD5V-LP 数据手册
REV. ITEM Q'TY 1 1 H-320C-LP T-1 (3mm) Tri-Level LED Holder, 90° Mount 2 3 3XX-S T-1 (3mm) N-Flange LED, See Page 2 PART NUMBER PART DESCRIPTION 1 A B C D 2 DESCRIPTION Engineering Update w/o Changes Updated LEDs to Shouldered Added P/N Designation Engineering Update w/o Changes DATE APPROVED 03/08/04 02/28/08 04/03/12 06/24/16 M. C. M. C. T. Y. J. C. 0.122 [3.1mm] TYP. 0.453 [11.5mm] 0.173 [4.4mm] Ø.118 [Ø3.0mm] TYP. 0.500 [12.7mm] 0.579 [14.7mm] 0.300 [7.6mm] 0.100 [2.5mm] 0.157 [4.0mm] 0.067 [1.7mm] 0.100 [2.5mm] 0.020 [0.5mm] SQ. TYP. 0.121 [3.1mm] 0.221 [5.6mm] 0.321 [8.2mm] 0.079 [2.0mm] CATHODE 0.079 [2.0mm] 0.121 [3.1mm] 0.100 [2.5mm] 0.200 [5.1mm] Holder Face NOTE: P/N DESIGNATION H320CXXXDX-LP Ø.079+.003 -.002 +.003 Ø.032-.002 TYP. 0.100 [2.5mm] Recommended Mounting Holes H-400 Holder Series - " " Standard LED - "L" Low Current LED - "5V" 5V LED Color of top LED - Use "X" if blank Lens Appearance Color of Second from top LED - Use "X" if blank -If LEDs are the same, use e.g. H200CGD Color of Bottom LED - Use "X" if blank ABSOLUTE MAXIMUM RATINGS (Ta=25° C) REVERSE VOLTAGE REVERSE CURRENT OPERATING TEMPERATURE RANGE STORAGE TEMPERATURE LEAD SOLDERING TEMPERATURE(1/16" FROM BODY) All Green Diffused LEDs STANDARD TOLERANCE ® ( UNLESS OTHERWISE SPECIFIED ) DECIMALS .X .XX .XXX ± .1 ± .02 ± .010 DESIGNED: T. Yin CHECKED: D. Green ANGULAR X° ± 1° 4 THOMAS, IRVINE, CA. 92618 TEL: (949) 951-8808 FAX: (949) 951-3974 T-1 (3MM) 90° TRI-LEVEL LED LOCATOR PIN LED ASSY REVISION: PART NO: TITLE: DATE: 03/08/04 DATE: 03/08/04 H320CXX-LP CAGE CODE : 32559 D SHEET # 1 OF 2 CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING. REV. DATE DESCRIPTION APPROVED SEE SHEET #1 LED Assy. No. STANDARD H320CBWD-LP H320CGD-LP H320CYD-LP H320CHD-LP H320CRD-LP H320CSRD-LP LOW CURRENT H320CGDL-LP H320CYDL-LP H320CHDL-LP 5 VOLT H320CGD5V-LP H320CYD5V-LP H320CHD5V-LP Electro-Optical Data Peak Wave Length λ p(nm ) Em itted Color Lens Appearance 430 565 585 635 655 660 BLUE GREEN YELLOW HE RED RED SUPER RED DIFFUSED DIFFUSED DIFFUSED DIFFUSED DIFFUSED DIFFUSED 565 585 635 GREEN YELLOW HE RED DIFFUSED DIFFUSED DIFFUSED 565 585 635 GREEN YELLOW HE RED DIFFUSED DIFFUSED DIFFUSED View ing Angle Vf 2 ½ If Iv (V) (m A) (m cd) (Deg) TYP TYP MAX TYP Data @ 20mA 20 4.0 4.5 20 45 20 2.2 2.6 30 45 20 2.1 2.6 20 45 20 2.0 2.6 30 45 20 1.7 2.0 6 45 20 1.7 2.6 90 45 Data @ 2mA 2 1.9 2.2 6 45 2 1.9 2.2 4 45 2 1.8 2.2 6 45 Data @ 5V 10 5.0 30 45 10 5.0 20 45 10 5.0 30 45 LED P/N 3BWD-S 3GD-S 3YD-S 3HD-S 3RD-S 3SRD-S 3GDL-S 3YDL-S 3HDL-S 3GD5V-S 3YD5V-S 3HD5V-S STANDARD TOLERANCE ® ( UNLESS OTHERWISE SPECIFIED ) ±10% ALL VALUES ANGULAR 4 THOMAS, IRVINE, CA. 92618 TEL: (949) 951-8808 FAX: (949) 951-3974 TITLE: DESIGNED: T. Yin CHECKED: D. Green DATE: 03/08/04 DATE: 03/08/04 T-1 (3MM) 90° TRI-LEVEL LED LOCATOR PIN LED ASSY REVISION: PART NO: H320CXX-LP CAGE CODE : 32559 D SHEET # 2 OF 2 CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING.
H320CGGHD5V-LP 价格&库存
很抱歉,暂时无法提供与“H320CGGHD5V-LP”相匹配的价格&库存,您可以联系我们找货
