H400CHD5V
H400CHD5V
    BIVAR
    LED ASSEMBLY
H400CHD5V 数据手册
REV. PART DESCRIPTION PART NUMBER ITEM Q'TY 1 1 H-400C T-1 (3mm) Quad-Level LED Holder, 90° Mount, Interlocking 2 1 3XX-LL T-1 (3mm) N-Flange LED, Long Leads 3 3 3XX-S T-1 (3mm) N-Flange Shouldered LED, See Page 2 DATE DESCRIPTION E Updated to Previous Protrusion F Added P/N Designation G Added H400CAD Specs H Updated LED Protrusion Dimension J Engineering Update w/o Changes APPROVED M. C. M. C. T. Y. T. Y. J. C. 04/10/08 09/30/08 04/13/09 08/11/11 08/04/16 Holder Faces 0.215 [5.5mm] Ø.032+.003 TYP. -.002 0.075 [1.9mm] 0.150 [3.8mm] 1 0.170 [4.3mm] Ø.118 [Ø3.0mm] 2 3 0.175 [4.4mm] Holder Pitch 0.100 [2.5mm] LED Lead 0.225 [5.7mm] Recommended Mounting Holes 0.04 [1.0mm] MAX. 0.560 [14.2mm] TYP. NOTE: P/N DESIGNATION 0.740 [18.8mm] H400CXXXXDX 0.540 [13.7mm] Cathode I.D. Mark H-400 Holder Series 0.840 [21.3mm] Color of top LED - Use "X" if blank 0.157 [4.0mm] -If LEDs are the same, use e.g. H400CGD 0.100 [2.5mm] 0.440 [11.2mm] 0.365 [9.3mm] 0.290 [7.4mm] 0.215 [5.5mm] SQ. TYP. 0.020 [0.5mm] REVERSE CURRENT OPERATING TEMPERATURE RANGE STORAGE TEMPERATURE LEAD SOLDERING TEMPERATURE(1/16" FROM BODY) Color of bottom LED - Use "X" if blank Color of 3rd from top LED - Use "X" if blank 0.140 [3.6mm] REVERSE VOLTAGE Lens Appearance Color of 2nd from top LED - Use "X" if blank 0.340 [8.6mm] ABSOLUTE MAXIMUM RATINGS (Ta=25° C) - " " Standard LED - "L" Low Current LED - "5V" 5V LED All Green Diffused LEDs STANDARD TOLERANCE ® ( UNLESS OTHERWISE SPECIFIED ) DECIMALS .X .XX .XXX ± .1 ± .02 ± .010 DESIGNED: T. Yin CHECKED: D. Green ANGULAR X° ± 1° 4 THOMAS, IRVINE, CA. 92618 TEL: (949) 951-8808 TITLE: DATE: 03/08/04 DATE: 03/08/04 PART NO: FAX: (949) 951-3974 T-1 (3MM) INTERLOCKING 90° QUAD-LEVEL LED ASSY REVISION: H400CXX CAGE CODE : 32559 J SHEET # 1 OF 2 CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING. REV. DATE DESCRIPTION APPROVED SEE SHEET #1 Peak Wave LED Assy. No. Length λ p(nm ) Electro-Optical Data Em itted Color Lens Appearance If (m A) TYP STANDARD Iv (m cd) Vf (V) TYP MAX TYP View ing Angle 2 ½ (Deg) LED P/N Data @ 20m A H400CAD 605 AMBER DIFFUSED 20 2.0 2.8 25 40 3AD-S H400CBWD 430 BLUE DIFFUSED 20 4.0 4.5 10 40 3BWD-S H400CGD 568 GREEN DIFFUSED 20 2.1 2.8 25 40 3GD-S H400CYD 590 YELLOW DIFFUSED 20 2.0 2.8 20 40 3YD-S H400CHD 625 HE RED DIFFUSED 20 2.0 2.8 30 40 3HD-S H400CRD 700 RED DIFFUSED 20 2.1 2.8 2 40 3RD-S H400CSRD 645 SUPER RED DIFFUSED 20 1.7 2.4 40 40 3SRD-S LOW CURRENT Data @ 2m A H400CGDL 568 GREEN DIFFUSED 2 2.1 2.6 2 40 3GDL-S H400CYDL 590 YELLOW DIFFUSED 2 2.0 2.6 2 40 3YDL-S H400CHDL 625 HE RED DIFFUSED 2 2.0 2.6 3 40 3HDL-S 5 VOLT Data @ 5V H400CGD5V 568 GREEN DIFFUSED 8 - 5.0 25 40 3GD5V-S H400CYD5V 590 YELLOW DIFFUSED 8 - 5.0 20 40 3YD5V-S H400CHD5V 625 HE RED DIFFUSED 8 - 5.0 30 40 3HD5V-S STANDARD TOLERANCE ® ( UNLESS OTHERWISE SPECIFIED ) ±10% ALL VALUES ANGULAR 4 THOMAS, IRVINE, CA. 92618 TEL: (949) 951-8808 TITLE: DESIGNED: T. Yin CHECKED: D. Green DATE: 03/08/04 DATE: 03/08/04 PART NO: FAX: (949) 951-3974 T-1 (3MM) INTERLOCKING 90° QUAD-LEVEL LED ASSY REVISION: H400CXX CAGE CODE : 32559 J SHEET # 2 OF 2 CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING.
H400CHD5V 价格&库存
很抱歉,暂时无法提供与“H400CHD5V”相匹配的价格&库存,您可以联系我们找货
