H401CHD5V
H401CHD5V
    BIVAR
    LED ASSEMBLY
H401CHD5V 数据手册
REV. ITEM Q'TY PART DESCRIPTION 1 1 H-401C T-1 (3mm) Quad-Level LED Holder, 90° Mount 2 1 3XX-LL T-1 (3mm) N-Flange LED, Long Leads 3 3 3XX-S T-1 (3mm) N-Flange Shouldered LED, See Page 2 PART NUMBER DATE DESCRIPTION Updated Protrusion and H401CRDL Updated to Previous Protrusion Updated P/N Designation Note and Protrusion Added H401CAD Specs Engineering Update w/o Changes E F G H J 03/13/08 04/10/08 11/10/08 04/13/09 08/04/16 APPROVED M. C. M. C. T. Y. T. Y. J. C. 2 1 0.04 [1.0mm] MAX. 0.560 [14.2mm] 0.170 [4.3mm] Ø.118 [Ø3.0mm] TYP. 3 0.740 [18.8mm] 0.840 [21.3mm] 0.540 [13.7mm] 0.340 [8.6mm] Cathode I.D. Mark 0.140 [3.6mm] 0.157 [4.0mm] 0.100 [2.5mm] NOTE: P/N DESIGNATION H401CXXXXDX H-401C Holder Series Color of top LED - Use "X" if blank 0.365 [9.3mm] 0.290 [7.4mm] 0.215 [5.5mm] 0.020 [0.5mm] SQ. TYP. 0.440 [11.2mm] - " " Standard LED - "L" Low Current LED - "5V" 5V LED Holder Face 0.215 [5.5mm] Lens Appearance Color of 2nd from top LED - Use "X" if blank Color of bottom LED - Use "X" if blank Color of 3rd from top LED - Use "X" if blank Ø.032+.003 -.002 TYP. 0.075 [1.9mm] 0.150 [3.8mm] 0.225 [5.7mm] -If LEDs are the same, use e.g. H401CGD 0.100 [2.5mm]LED Lead Recommended Mounting Holes All Green Diffused LEDs ABSOLUTE MAXIMUM RATINGS (Ta=25° C) REVERSE VOLTAGE REVERSE CURRENT OPERATING TEMPERATURE RANGE STORAGE TEMPERATURE LEAD SOLDERING TEMPERATURE(1/16" FROM BODY) STANDARD TOLERANCE ® ( UNLESS OTHERWISE SPECIFIED ) DECIMALS .X .XX .XXX ± .1 ± .02 ± .010 DESIGNED: T. Yin CHECKED: D. Green ANGULAR X° ± 1° 4 THOMAS, IRVINE, CA. 92618 TEL: (949) 951-8808 FAX: (949) 951-3974 T-1 (3mm) SINGLE STATION 90° QUAD-LEVEL ASSEMBLY REVISION: PART NO: TITLE: DATE: 03/08/04 DATE: 03/08/04 H401CXX CAGE CODE : 32559 J SHEET # 1 OF 2 CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING. REV. DATE DESCRIPTION APPROVED SEE SHEET #1 Peak Wave LED Assy. No. Length λ p(nm ) Electro-Optical Data Em itted Color Lens Appearance MAX TYP If (m A) TYP STANDARD TYP View ing Angle 2 ½ (Deg) Iv (m cd) Vf (V) LED P/N Data @ 20m A H401CAD 605 AMBER DIFFUSED 20 2.0 2.8 25 40 3AD-S H401CBWD 430 BLUE DIFFUSED 20 4.0 4.5 10 40 3BWD-S H401CGD 568 GREEN DIFFUSED 20 2.1 2.8 25 40 3GD-S H401CYD 590 YELLOW DIFFUSED 20 2.0 2.8 20 40 3YD-S H401CHD 625 HE RED DIFFUSED 20 2.0 2.8 30 40 3HD-S H401CRD 700 RED DIFFUSED 20 2.1 2.8 2 40 3RD-S H401CSRD 645 SUPER RED DIFFUSED 20 1.7 2.4 40 40 3SRD-S LOW CURRENT Data @ 2m A H401CGDL 568 GREEN DIFFUSED 2 2.1 2.6 2 40 3GDL-S H401CYDL 590 YELLOW DIFFUSED 2 2.0 2.6 2 40 3YDL-S H401CHDL 625 HE RED DIFFUSED 2 2.0 2.6 3 40 3HDL-S H401CRDL 700 RED DIFFUSED 2 2.1 2.6 0.5 40 3RDL-S 5 VOLT Data @ 5V H401CGD5V 568 GREEN DIFFUSED 8 - 5.0 25 40 3GD5V-S H401CYD5V 590 YELLOW DIFFUSED 8 - 5.0 20 40 3YD5V-S H401CHD5V 625 HE RED DIFFUSED 8 - 5.0 30 40 3HD5V-S STANDARD TOLERANCE ® ( UNLESS OTHERWISE SPECIFIED ) ±10% ALL VALUES ANGULAR 4 THOMAS, IRVINE, CA. 92618 TEL: (949) 951-8808 FAX: (949) 951-3974 TITLE: DESIGNED: T. Yin CHECKED: D. Green DATE: 03/08/04 DATE: 03/08/04 T-1 (3mm) SINGLE STATION 90° QUAD-LEVEL ASSEMBLY REVISION: PART NO: H401CXX CAGE CODE : 32559 J SHEET # 2 OF 2 CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING.
H401CHD5V 价格&库存
很抱歉,暂时无法提供与“H401CHD5V”相匹配的价格&库存,您可以联系我们找货
