REV.
PART DESCRIPTION
PART NUMBER
ITEM
Q'TY
1
1
H-480C
Quad-Level 2X3mm LED Holder
2
4
R3XXX
2x3mm Rectangular LED
1
DATE
DESCRIPTION
C Updated LED Protrusion
D Added P/N Designation Note
E Added H480CRD Specs
F Added All R3XXX LED Specs
G Engineering Update w/o Changes
09/15/06
10/30/08
12/04/08
08/01/11
08/04/16
APPROVED
M. C.
T. Y.
T. Y.
T. Y.
J. C.
2
0.085 [2.2mm] TYP.
0.200 [5.1mm]
0.122 [3.1mm]
0.550 [14.0mm]
0.075 [1.9mm]
TYP.
0.300 [7.6mm]
0.470 [11.9mm]
0.400 [10.2mm]
0.200 [5.1mm]
0.100 [2.5mm]
0.157 [4.0mm]
1
2
0.100 [2.5mm]
Single Color 1
0.390 [9.9mm]
0.290 [7.4mm]
0.190 [4.8mm]
0.020 [0.5mm]
2
0.490 [12.4mm]
Bi-Color 1
SQ. TYP.
2
NOTE: P/N DESIGNATION
BI-COLOR POLARITY
LED P/N (1) CATHODE (2) CATHODE
RED
R3BC
GREEN
R3BC-Y/G
YELLOW
GREEN
Holder
Face
TYP.
- Blank for Standard LED
- "L" for Low Current LED
- "5V" for 5V LED
Color of top LED
- Use "X" if blank
0.190 [4.8mm]
Ø.032+.003
-.002
H480CXXXXDX
H-480C
Holder Series
0.100 [2.5mm]
Lens Appearance
Color of 2nd from top LED
- Use "X" if blank
Color of bottom LED
- Use "X" if blank
Color of 3rd from top LED
- Use "X" if blank
0.100 [2.5mm]
0.200 [5.1mm]
0.300 [7.6mm]
-If LEDs are the same,
use e.g. H480CGD
Recommended Mounting Holes
ABSOLUTE MAXIMUM RATINGS (Ta=25° C)
REVERSE VOLTAGE
REVERSE CURRENT
OPERATING TEMPERATURE RANGE
All Green LEDs
STANDARD TOLERANCE
DECIMALS
.X
.XX
.XXX
± .1
± .02
± .010
DESIGNED:
STORAGE TEMPERATURE
LEAD SOLDERING TEMPERATURE(1/16" FROM BODY)
( UNLESS OTHERWISE SPECIFIED )
T. Yin
CHECKED:
D. Green
ANGULAR
X°
± 1°
4 THOMAS, IRVINE, CA. 92618
TEL: (949) 951-8808
FAX: (949) 951-3974
RECTANGULAR 2X3MM
90° QUAD-LEVEL LED ASSEMBLY
TITLE:
DATE:
03/08/04
DATE:
03/08/04
PART NO:
REVISION:
H480CXX
CAGE CODE : 32559
G
SHEET # 1 OF 3
CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING.
REV.
DATE
DESCRIPTION
APPROVED
SEE SHEET #1
LED Assy.
No.
Peak Wave
Length
λp (nm )
Electro-Optical Data
Em itted
Color
Lens
Appearance
MAX
TYP
If
(m A)
TYP
STANDARD
TYP
View ing
Angle
2 ½
(Deg)
Iv
(m cd)
Vf
(V)
LED P/N
Data @ 20m A
H480CAC
605
AMBER
WATER CLEAR
2.8
8.0
80
R3AC
H480CAD
605
AMBER
DIFFUSED
2.8
8.0
100
R3AD
H480CAT
605
AMBER
TINTED
2.8
8.0
80
R3AT
H480CBWD
430
BLUE
DIFFUSED
4.5
4.0
100
R3BWD
H480CGC
568
GREEN
WATER CLEAR
2.8
8.0
80
R3GC
H480CGD
568
GREEN
DIFFUSED
2.8
6.0
100
R3GD
H480CGT
568
GREEN
TINTED
2.8
8.0
80
R3GT
H480CYC
590
YELLOW
WATER CLEAR
2.8
6.0
80
R3YC
H480CYD
590
YELLOW
DIFFUSED
2.8
4.0
100
R3YD
H480CYT
590
YELLOW
TINTED
2.8
6.0
80
R3YT
H480CHC
625
HE RED
WATER CLEAR
2.8
8.0
80
R3HC
H480CHD
625
HE RED
DIFFUSED
2.8
6.0
100
R3HD
H480CHT
625
HE RED
TINTED
2.8
8.0
80
R3HT
H480CRC
700
RED
WATER CLEAR
2.8
1.0
80
R3RC
H480CRD
700
RED
DIFFUSED
2.8
0.5
100
R3RD
H480CRT
700
RED
TINTED
2.8
1.0
80
R3RT
625
RED
2.8
3.0
120
R3BC
568
GREEN
2.8
2.5
590
YELLOW
2.8
2.5
120
R3BC-Y/G
568
GREEN
2.8
2.5
H480CBC
H480CBC-YG
DIFFUSED
DIFFUSED
STANDARD TOLERANCE
±10% ALL VALUES
ANGULAR
TEL: (949) 951-8808
FAX: (949) 951-3974
RECTANGULAR 2X3MM
TITLE:
DESIGNED:
T. Yin
CHECKED:
D. Green
DATE:
03/08/04
DATE:
03/08/04
PART NO:
REVISION:
H480CXX
CAGE CODE : 32559
G
SHEET # 2 OF 3
REV.
DATE
DESCRIPTION
APPROVED
SEE SHEET #1
LED Assy.
No.
Peak Wave
Length
λp (nm )
Em itted
Color
Lens
Appearance
TYP
LOW CURRENT
TYP
MAX
TYP
View ing
Angle
2 ½
(Deg)
If
(m A)
Iv
(m cd)
Vf
(V)
LED P/N
Data @ 2m A
H480CGDL
568
GREEN
DIFFUSED
2
2.1
2.8
0.4
100
R3GDL
H480CYDL
590
YELLOW
DIFFUSED
2
2.0
2.8
0.3
100
R3YDL
H480CHDL
625
HE RED
DIFFUSED
2
2.0
2.8
0.4
100
R3HDL
H480CRDL
700
RED
DIFFUSED
2
2.1
2.8
0.2
100
R3RDL
5 VOLT
Data @ 5V
H480CAC5V
605
AMBER
CLEAR
8
5.0
8.0
80
R3AC5V
H480CAD5V
605
AMBER
DIFFUSED
8
5.0
6.0
100
R3AD5V
H480CAT5V
605
AMBER
TINTED
8
5.0
8.0
80
R3AT5V
H480CBWD5V
430
BLUE
DIFFUSED
8
5.0
4.0
100
R3BWD5V
H480CGC5V
568
GREEN
CLEAR
8
5.0
8.0
80
R3GC5V
H480CGD5V
568
GREEN
DIFFUSED
8
5.0
6.0
100
R3GD5V
H480CGT5V
568
GREEN
TINTED
8
5.0
8.0
100
R3GT5V
H480CYC5V
590
YELLOW
CLEAR
8
5.0
6.0
80
R3YC5V
H480CYD5V
590
YELLOW
DIFFUSED
8
5.0
4.0
100
R3YD5V
H480CYT5V
590
YELLOW
TINTED
8
5.0
6.0
80
R3YT5V
H480CHC5V
625
HE RED
CLEAR
8
5.0
8.0
80
R3HC5V
H480CHD5V
625
HE RED
DIFFUSED
8
5.0
6.0
100
R3HD5V
H480CHT5V
625
HE RED
TINTED
8
5.0
8.0
80
R3HT5V
H480CRC5V
700
RED
CLEAR
8
5.0
1.0
80
R3RC5V
H480CRD5V
700
RED
DIFFUSED
8
5.0
0.5
100
R3RD5V
H480CRT5V
700
RED
TINTED
8
5.0
1.0
80
R3RT5V
STANDARD TOLERANCE
±10% ALL VALUES
ANGULAR
TEL: (949) 951-8808
FAX: (949) 951-3974
RECTANGULAR 2X3MM
TITLE:
DESIGNED:
T. Yin
CHECKED:
D. Green
DATE:
03/08/04
DATE:
03/08/04
PART NO:
REVISION:
H480CXX
CAGE CODE : 32559
G
SHEET # 3 OF 3
很抱歉,暂时无法提供与“H480CHYYGD”相匹配的价格&库存,您可以联系我们找货
