H480CHD5V
H480CHD5V
    BIVAR
    LED ASSEMBLY
H480CHD5V 数据手册
REV. PART DESCRIPTION PART NUMBER ITEM Q'TY 1 1 H-480C Quad-Level 2X3mm LED Holder 2 4 R3XXX 2x3mm Rectangular LED 1 DATE DESCRIPTION C Updated LED Protrusion D Added P/N Designation Note E Added H480CRD Specs F Added All R3XXX LED Specs G Engineering Update w/o Changes 09/15/06 10/30/08 12/04/08 08/01/11 08/04/16 APPROVED M. C. T. Y. T. Y. T. Y. J. C. 2 0.085 [2.2mm] TYP. 0.200 [5.1mm] 0.122 [3.1mm] 0.550 [14.0mm] 0.075 [1.9mm] TYP. 0.300 [7.6mm] 0.470 [11.9mm] 0.400 [10.2mm] 0.200 [5.1mm] 0.100 [2.5mm] 0.157 [4.0mm] 1 2 0.100 [2.5mm] Single Color 1 0.390 [9.9mm] 0.290 [7.4mm] 0.190 [4.8mm] 0.020 [0.5mm] 2 0.490 [12.4mm] Bi-Color 1 SQ. TYP. 2 NOTE: P/N DESIGNATION BI-COLOR POLARITY LED P/N (1) CATHODE (2) CATHODE RED R3BC GREEN R3BC-Y/G YELLOW GREEN Holder Face TYP. - Blank for Standard LED - "L" for Low Current LED - "5V" for 5V LED Color of top LED - Use "X" if blank 0.190 [4.8mm] Ø.032+.003 -.002 H480CXXXXDX H-480C Holder Series 0.100 [2.5mm] Lens Appearance Color of 2nd from top LED - Use "X" if blank Color of bottom LED - Use "X" if blank Color of 3rd from top LED - Use "X" if blank 0.100 [2.5mm] 0.200 [5.1mm] 0.300 [7.6mm] -If LEDs are the same, use e.g. H480CGD Recommended Mounting Holes ABSOLUTE MAXIMUM RATINGS (Ta=25° C) REVERSE VOLTAGE REVERSE CURRENT OPERATING TEMPERATURE RANGE All Green LEDs STANDARD TOLERANCE DECIMALS .X .XX .XXX ± .1 ± .02 ± .010 DESIGNED: STORAGE TEMPERATURE LEAD SOLDERING TEMPERATURE(1/16" FROM BODY) ® ( UNLESS OTHERWISE SPECIFIED ) T. Yin CHECKED: D. Green ANGULAR X° ± 1° 4 THOMAS, IRVINE, CA. 92618 TEL: (949) 951-8808 FAX: (949) 951-3974 RECTANGULAR 2X3MM 90° QUAD-LEVEL LED ASSEMBLY TITLE: DATE: 03/08/04 DATE: 03/08/04 PART NO: REVISION: H480CXX CAGE CODE : 32559 G SHEET # 1 OF 3 CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING. REV. DATE DESCRIPTION APPROVED SEE SHEET #1 LED Assy. No. Peak Wave Length λp (nm ) Electro-Optical Data Em itted Color Lens Appearance MAX TYP If (m A) TYP STANDARD TYP View ing Angle 2 ½ (Deg) Iv (m cd) Vf (V) LED P/N Data @ 20m A H480CAC 605 AMBER WATER CLEAR 20 2.0 2.8 8.0 80 R3AC H480CAD 605 AMBER DIFFUSED 20 2.0 2.8 8.0 100 R3AD H480CAT 605 AMBER TINTED 20 2.0 2.8 8.0 80 R3AT H480CBWD 430 BLUE DIFFUSED 20 4.0 4.5 4.0 100 R3BWD H480CGC 568 GREEN WATER CLEAR 20 2.1 2.8 8.0 80 R3GC H480CGD 568 GREEN DIFFUSED 20 2.1 2.8 6.0 100 R3GD H480CGT 568 GREEN TINTED 20 2.1 2.8 8.0 80 R3GT H480CYC 590 YELLOW WATER CLEAR 20 2.0 2.8 6.0 80 R3YC H480CYD 590 YELLOW DIFFUSED 20 2.0 2.8 4.0 100 R3YD H480CYT 590 YELLOW TINTED 20 2.0 2.8 6.0 80 R3YT H480CHC 625 HE RED WATER CLEAR 20 2.0 2.8 8.0 80 R3HC H480CHD 625 HE RED DIFFUSED 20 2.0 2.8 6.0 100 R3HD H480CHT 625 HE RED TINTED 20 2.0 2.8 8.0 80 R3HT H480CRC 700 RED WATER CLEAR 20 2.1 2.8 1.0 80 R3RC H480CRD 700 RED DIFFUSED 20 2.1 2.8 0.5 100 R3RD H480CRT 700 RED TINTED 20 2.1 2.8 1.0 80 R3RT 625 RED 20 2.0 2.8 3.0 120 R3BC 568 GREEN 20 2.1 2.8 2.5 590 YELLOW 20 2.0 2.8 2.5 120 R3BC-Y/G 568 GREEN 20 2 2.8 2.5 H480CBC H480CBC-YG DIFFUSED DIFFUSED STANDARD TOLERANCE ® ( UNLESS OTHERWISE SPECIFIED ) ±10% ALL VALUES ANGULAR 4 THOMAS, IRVINE, CA. 92618 TEL: (949) 951-8808 FAX: (949) 951-3974 RECTANGULAR 2X3MM 90° QUAD-LEVEL LED ASSEMBLY TITLE: DESIGNED: T. Yin CHECKED: D. Green DATE: 03/08/04 DATE: 03/08/04 PART NO: REVISION: H480CXX CAGE CODE : 32559 G SHEET # 2 OF 3 CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING. REV. DATE DESCRIPTION APPROVED SEE SHEET #1 LED Assy. No. Peak Wave Length λp (nm ) Electro-Optical Data Em itted Color Lens Appearance TYP LOW CURRENT TYP MAX TYP View ing Angle 2 ½ (Deg) If (m A) Iv (m cd) Vf (V) LED P/N Data @ 2m A H480CGDL 568 GREEN DIFFUSED 2 2.1 2.8 0.4 100 R3GDL H480CYDL 590 YELLOW DIFFUSED 2 2.0 2.8 0.3 100 R3YDL H480CHDL 625 HE RED DIFFUSED 2 2.0 2.8 0.4 100 R3HDL H480CRDL 700 RED DIFFUSED 2 2.1 2.8 0.2 100 R3RDL 5 VOLT Data @ 5V H480CAC5V 605 AMBER CLEAR 8 - 5.0 8.0 80 R3AC5V H480CAD5V 605 AMBER DIFFUSED 8 - 5.0 6.0 100 R3AD5V H480CAT5V 605 AMBER TINTED 8 - 5.0 8.0 80 R3AT5V H480CBWD5V 430 BLUE DIFFUSED 8 - 5.0 4.0 100 R3BWD5V H480CGC5V 568 GREEN CLEAR 8 - 5.0 8.0 80 R3GC5V H480CGD5V 568 GREEN DIFFUSED 8 - 5.0 6.0 100 R3GD5V H480CGT5V 568 GREEN TINTED 8 - 5.0 8.0 100 R3GT5V H480CYC5V 590 YELLOW CLEAR 8 - 5.0 6.0 80 R3YC5V H480CYD5V 590 YELLOW DIFFUSED 8 - 5.0 4.0 100 R3YD5V H480CYT5V 590 YELLOW TINTED 8 - 5.0 6.0 80 R3YT5V H480CHC5V 625 HE RED CLEAR 8 - 5.0 8.0 80 R3HC5V H480CHD5V 625 HE RED DIFFUSED 8 - 5.0 6.0 100 R3HD5V H480CHT5V 625 HE RED TINTED 8 - 5.0 8.0 80 R3HT5V H480CRC5V 700 RED CLEAR 8 - 5.0 1.0 80 R3RC5V H480CRD5V 700 RED DIFFUSED 8 - 5.0 0.5 100 R3RD5V H480CRT5V 700 RED TINTED 8 - 5.0 1.0 80 R3RT5V STANDARD TOLERANCE ® ( UNLESS OTHERWISE SPECIFIED ) ±10% ALL VALUES ANGULAR 4 THOMAS, IRVINE, CA. 92618 TEL: (949) 951-8808 FAX: (949) 951-3974 RECTANGULAR 2X3MM 90° QUAD-LEVEL LED ASSEMBLY TITLE: DESIGNED: T. Yin CHECKED: D. Green DATE: 03/08/04 DATE: 03/08/04 PART NO: REVISION: H480CXX CAGE CODE : 32559 G SHEET # 3 OF 3 CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING.
H480CHD5V 价格&库存
很抱歉,暂时无法提供与“H480CHD5V”相匹配的价格&库存,您可以联系我们找货
