LTM3203PGC
LTM3203PGC
    BIVAR
    LED ASSEMBLY
LTM3203PGC 数据手册
ITEM 1 2 Q'TY 1 1 PART NUMBER REV. PART DESCRIPTION LTM-XXX 3XX-S DATE APPROVED 07/17/06 10/12/11 06/25/16 M. C. T. Y. J. C. DESCRIPTION A Engineering Release B LED Update C Added 3GTL-S and 3HTL-S Specs Molded, Self-Retaining LED Mount T-1 (3mm) Shouldered LED, See Page 2 & 3 (1.0 [25.4mm]) H 0.17 [4.3mm] SHORT LEAD 0.100 [2.5mm] Ø.200 [Ø5.1mm] Ø.04 [Ø1.0mm] 2 Ø.120 [Ø3.0mm]LED TYP. 0.020 [0.5mm] SQ. TYP. Ø.150 [Ø3.8mm] 0.020 [0.5mm] 1 PART NO. H PART NO. H PART NO. LTM-120 .120(3.1) LTM-300 .300(7.6) LTM-490 .490(12.5) LTM-130 .130(3.3) LTM-310 .310(7.9) LTM-500 .500(12.7) LTM-140 .140(3.6) LTM-320 .320(8.1) LTM-520 .520(13.2) LTM-150 .150(3.8) LTM-330 .330(8.4) LTM-550 .550(14.0) LTM-160 .160(4.1) LTM-340 .340(8.6) LTM-570 .570(14.5) LTM-170 .170(4.3) LTM-350 .350(8.9) LTM-600 .600(15.2) LTM-180 .180(4.6) LTM-360 .360(9.1) LTM-620 .620(15.8) LTM-190 .190(4.8) LTM-370 .370(9.4) LTM-650 .650(16.5) LTM-200 .200(5.1) LTM-380 .380(9.7) LTM-670 .670(17.0) LTM-210 .210(5.3) LTM-390 .390(9.9) LTM-700 .700(17.8) LTM-220 .220(5.6) LTM-400 .400(10.2) LTM-720 .720(18.3) LTM-230 .230(5.8) LTM-410 .410(10.4) LTM-750 .750(19.1) LTM-240 .240(6.1) LTM-420 .420(10.7) LTM-770 .770(19.6) LTM-250 .250(6.4) LTM-430 .430(10.9) LTM-800 .800(20.3) LTM-260 .260(6.6) LTM-440 .440(11.2) LTM-820 .820(20.8) LTM-270 .270(6.9) LTM-450 .450(11.4) LTM-850 .850(21.6) LTM-280 .280(7.1) LTM-460 .460(11.7) LTM-870 .870(22.1) LTM-290 .290(7.4) LTM-480 .480(12.2) LTM-900 .900(22.9) [ ] +0.1mm Ø.032+.003 -.002 Ø0.8mm-0.1mm TYP. H 0.100 [2.5mm] RECOMMENDED MOUNTING HOLES EXAMPLE: LTM5003GD LED Color & Lens Appearance LTM Height "H" Series STANDARD TOLERANCE ABSOLUTE MAXIMUM RATINGS (Ta=25° C) REVERSE VOLTAGE REVERSE CURRENT OPERATING TEMPERATURE RANGE STORAGE TEMPERATURE LEAD SOLDERING TEMPERATURE(1/16" FROM BODY) ® ( UNLESS OTHERWISE SPECIFIED ) DECIMALS .X .XX .XXX ± .1 ± .02 ± .010 DESIGNED: S. Dam CHECKED: T. Yin ANGULAR X° ± 1° DATE: 07/17/06 DATE: 07/17/06 4 THOMAS, IRVINE, CA. 92618 TEL: (949) 951-8808 FAX: (949) 951-3974 TITLE: MOLDED, SELF-RETAINING T1 (3mm) LED MOUNT ASSEMBLY REVISION: PART NO: LTMXXX3XX CAGE CODE : 32559 C SHEET # 1 OF 3 CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING. REV. DATE DESCRIPTION APPROVED SEE SHEET #1 Electro-Optical Data Chip LED Assy. No. Material Peak Wave Length λp(nm) Emitted Color 430 430 430 555 555 555 568 568 568 568 568 568 590 590 590 605 605 605 605 605 605 625 625 625 700 700 700 645 645 645 BLUE BLUE BLUE PURE GREEN PURE GREEN PURE GREEN GREEN GREEN GREEN SUPER GREEN SUPER GREEN SUPER GREEN YELLOW YELLOW YELLOW AMBER AMBER AMBER SUPER AMBER SUPER AMBER SUPER AMBER HE RED HE RED HE RED RED RED RED SUPER RED SUPER RED SUPER RED Lens Appearance TYP MAX Data @ 20mA STANDARD LTMXXX3BWC LTMXXX3BWD LTMXXX3BWT LTMXXX3PGC LTMXXX3PGD LTMXXX3PGT LTMXXX3GC LTMXXX3GD LTMXXX3GT LTMXXX3SGC LTMXXX3SGD LTMXXX3SGT LTMXXX3YC LTMXXX3YD LTMXXX3YT LTMXXX3AC LTMXXX3AD LTMXXX3AT LTMXXX3SAC LTMXXX3SAD LTMXXX3SAT LTMXXX3HC LTMXXX3HD LTMXXX3HT LTMXXX3RC LTMXXX3RD LTMXXX3RT LTMXXX3SRC LTMXXX3SRD LTMXXX3SRT GaN/SiC GaN/SiC GaN/SiC GaP/GaP GaP/GaP GaP/GaP GaP/GaP GaP/GaP GaP/GaP GaP/GaP GaP/GaP GaP/GaP GaAsP/GaP GaAsP/GaP GaAsP/GaP GaAsP/GaP GaAsP/GaP GaAsP/GaP AlGaInP AlGaInP AlGaInP GaAsP/GaP GaAsP/GaP GaAsP/GaP GaP/GaP GaP/GaP GaP/GaP GaAlAs/GaAs GaAlAs/GaAs GaAlAs/GaAs Vf (V) WATER CLEAR DIFFUSED TINTED WATER CLEAR DIFFUSED TINTED WATER CLEAR DIFFUSED TINTED WATER CLEAR DIFFUSED TINTED WATER CLEAR DIFFUSED TINTED WATER CLEAR DIFFUSED TINTED WATER CLEAR DIFFUSED TINTED WATER CLEAR DIFFUSED TINTED WATER CLEAR DIFFUSED TINTED WATER CLEAR DIFFUSED TINTED 4.0 4.0 4.0 2.2 2.2 2.2 2.1 2.1 2.1 2.1 2.1 2.1 2.0 2.0 2.0 2.0 2.0 2.0 1.8 1.8 1.8 2.0 2.0 2.0 2.1 2.1 2.1 1.7 1.7 1.7 4.5 4.5 4.5 2.8 2.8 2.8 2.8 2.8 2.8 2.8 2.8 2.8 2.8 2.8 2.8 2.8 2.8 2.8 2.4 2.4 2.4 2.8 2.8 2.8 2.8 2.8 2.8 2.4 2.4 2.4 Iv (mcd) TYP Viewing Angle 2 θ½ (Deg) LED P/N 25 10 25 10 5 10 40 25 40 50 30 50 40 20 40 40 25 40 300 100 300 50 30 50 2.5 2 2.5 60 40 60 30 40 30 30 40 30 30 40 30 30 40 30 30 40 30 30 40 30 30 40 30 30 40 30 30 40 30 30 40 30 3BWC-S 3BWD-S 3BWT-S 3PGC-S 3PGD-S 3PGT-S 3GC-S 3GD-S 3GT-S 3SGC-S 3SGD-S 3SGT-S 3YC-S 3YD-S 3YT-S 3AC-S 3AD-S 3AT-S 3SAC-S 3SAD-S 3SAT-S 3HC-S 3HD-S 3HT-S 3RC-S 3RD-S 3RT-S 3SRC-S 3SRD-S 3SRT-S STANDARD TOLERANCE ® ( UNLESS OTHERWISE SPECIFIED ) 10% All Values ANGULAR 4 THOMAS, IRVINE, CA. 92618 TEL: (949) 951-8808 DESIGNED: S. Dam CHECKED: T. Yin DATE: 07/17/06 DATE: 07/17/06 FAX: (949) 951-3974 TITLE: MOLDED, SELF-RETAINING T1 (3mm) LED MOUNT ASSEMBLY REVISION: PART NO: LTMXXX3XX CAGE CODE : 32559 SHEET # C 2 OF 3 CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING. REV. DATE DESCRIPTION APPROVED SEE SHEET #1 LED Assy. No. Material Chip Peak Wave Length λp(nm) Emitted Color Lens Appearance BLUE GREEN GREEN PURE GREEN YELLOW AMBER HE RED HE RED RED DIFFUSED DIFFUSED TINTED DIFFUSED DIFFUSED DIFFUSED DIFFUSED TINTED DIFFUSED Emitted Color Lens Appearance GREEN GREEN GREEN YELLOW AMBER HE RED RED WATER CLEAR DIFFUSED TINTED DIFFUSED DIFFUSED DIFFUSED DIFFUSED LOW CURRENT LTMXXXBWDL LTMXXXGDL LTMXXXGTL LTMXXXPGDL LTMXXXYDL LTMXXXADL LTMXXXHDL LTMXXXHTL LTMXXXRDL LED Assy. No. GaN/siC GaP/GaP GaP/GaP GaP/GaP GaAsP/GaP GaAsP/GaP GaAsP/GaP GaAsP/GaP GaP/GaP Material 430 568 568 555 590 605 625 635 700 Chip Peak Wave Length λp(nm) 5 VOLT LTMXXX3GC5V LTMXXX3GD5V LTMXXX3GT5V LTMXXX3YD5V LTMXXX3AD5V LTMXXX3HD5V LTMXXX3RD5V GaP/GaP GaP/GaP GaP/GaP GaAsP/GaP GaAsP/GaP GaAsP/GaP GaP/GaP 568 568 568 590 605 625 700 Electro-Optical Data Vf Iv (V) (mcd) TYP MAX TYP Data @ 2mA 3.8 2.1 1.8 2.1 2.0 2.0 2.0 1.8 2.1 4.2 2.6 2.2 2.6 2.6 2.6 2.6 2.2 2.6 2.5 2 7.5 0.2 2 4 2.5 6.5 0.5 Electro-Optical Data Vf Iv (V) (mcd) TYP MAX TYP Data @ 5V / / / / / / / 5.0 5.0 5.0 5.0 5.0 5.0 5.0 40 25 40 20 25 30 2 Viewing Angle 2 θ½ (Deg) LED P/N 40 40 30 40 40 40 40 30 40 3BWDL-S 3GDL-S 3GTL-S 3PGDL-S 3YDL-S 3ADL-S 3HDL-S 3HTL-S 3RDL-S Viewing Angle 2 θ½ (Deg) LED P/N 30 40 30 40 40 40 40 3GC5V-S 3GD5V-S 3GT5V-S 3YD5V-S 3AD5V-S 3HD5V-S 3RD5V-S STANDARD TOLERANCE ® ( UNLESS OTHERWISE SPECIFIED ) 10% All Values ANGULAR 4 THOMAS, IRVINE, CA. 92618 TEL: (949) 951-8808 DESIGNED: S. Dam CHECKED: T. Yin DATE: 07/17/06 DATE: 07/17/06 FAX: (949) 951-3974 TITLE: MOLDED, SELF-RETAINING T1 (3mm) LED MOUNT ASSEMBLY REVISION: PART NO: LTMXXX3XX CAGE CODE : 32559 SHEET # C 3 OF 3 CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING.
LTM3203PGC 价格&库存
很抱歉,暂时无法提供与“LTM3203PGC”相匹配的价格&库存,您可以联系我们找货
