LTM7505HD5V
LTM7505HD5V
    BIVAR
    LED ASSEMBLY
LTM7505HD5V 数据手册
ITEM Q'TY PART NUMBER REV. PART DESCRIPTION 1 1 LTM-XXX Molded, Self-Retaining LED Mount 2 1 5XX-F T-1 3/4 (5mm) Flanged LED, See Pages 2 & 3 DATE APPROVED 09/30/03 07/28/10 06/25/16 M. C. T. Y. J. C. DESCRIPTION A Engineering Release B LED Data Update C Engineering Update w/o Changes H 0.945 [24.0mm] Ø.200 [Ø5.1mm] (1.57 @ -LL) MIN. LTM DIA. 0.339 [8.6mm] CATHODE FLAT EDGE CATHODE ID 0.039 [1.0mm] MIN. PART NO. LTM-120 LTM-130 LTM-140 LTM-150 LTM-160 LTM-170 LTM-180 LTM-190 LTM-200 LTM-210 LTM-220 LTM-230 LTM-240 LTM-250 LTM-260 LTM-270 LTM-280 LTM-290 H .120(3.1) .130(3.3) .140(3.6) .150(3.8) .160(4.1) .170(4.3) .180(4.6) .190(4.8) .200(5.1) .210(5.3) .220(5.6) .230(5.8) .240(6.1) .250(6.4) .260(6.6) .270(6.9) .280(7.1) .290(7.4) PART NO. LTM-300 LTM-310 LTM-320 LTM-330 LTM-340 LTM-350 LTM-360 LTM-370 LTM-380 LTM-390 LTM-400 LTM-410 LTM-420 LTM-430 LTM-440 LTM-450 LTM-460 LTM-480 H .300(7.6) .310(7.9) .320(8.1) .330(8.4) .340(8.6) .350(8.9) .360(9.1) .370(9.4) .380(9.7) .390(9.9) .400(10.2) .410(10.4) .420(10.7) .430(10.9) .440(11.2) .450(11.4) .460(11.7) .480(12.2) PART NO. LTM-490 LTM-500 LTM-520 LTM-550 LTM-570 LTM-600 LTM-620 LTM-650 LTM-670 LTM-700 LTM-720 LTM-750 LTM-770 LTM-800 LTM-820 LTM-850 LTM-870 LTM-900 0.100 [2.5mm] H .490(12.5) .500(12.7) .520(13.2) .550(14.0) .570(14.5) .600(15.2) .620(15.8) .650(16.5) .670(17.0) .700(17.8) .720(18.3) .750(19.1) .770(19.6) .800(20.3) .820(20.8) .850(21.6) .870(22.1) .900(22.9) 0.040 [1.0mm] 0.020 [0.5mm] Ø.197 [Ø5.0mm] LED DIA. 0.020 [0.5mm] Ø.220 [Ø5.6mm] SQ. FLANGE DIM. EXAMPLE: LTM5005GD Ø.032+.003 TYP. -.002 LED Color & Lens Appearance. Omit -F when ordering. 0.100 [2.5mm] LTM Height "H" Recommended Mounting Holes Series ABSOLUTE MAXIMUM RATINGS (Ta = 25°C) STANDARD TOLERANCE DECIMALS REVERSE VOLTAGE 5V REVERSE CURRENT ( VR=5V) 100µA OPERATING TEMPERATURE RANGE -25°C ~ 85°C STORAGE TEMPERATURE -30°C ~ 100°C LEAD SOLDERING TEMPERATURE (1/16" FROM BODY) 260°C for 5 Seconds ® ( UNLESS OTHERWISE SPECIFIED ) .X .XX .XXX ± .1 ± .02 ± .010 DESIGNED: D. Green CHECKED: M. Chen ANGULAR X° ± 1° 4 THOMAS, IRVINE, CA. 92618 TEL: (949) 951-8808 FAX: (949) 951-3974 TITLE: MOLDED, SELF-RETAINING T-1 3/4 (5mm) LED MOUNT ASSEMBLY DATE: 09/30/03 DATE: 09/30/03 PART NO: REVISION: LTMXXX5XX CAGE CODE : 32559 C SHEET # 1 OF 3 CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING. REV. DATE DESCRIPTION APPROVED SEE SHEET #1 LED Assy. No. Electro-Optical Data Peak Wave Length λp(nm) Emitted Color 605 605 605 430 430 430 568 568 568 625 625 625 555 555 555 700 700 700 590 590 590 AMBER AMBER AMBER BLUE BLUE BLUE GREEN GREEN GREEN HE RED HE RED HE RED PURE GREEN PURE GREEN PURE GREEN RED RED RED YELLOW YELLOW YELLOW Lens Appearance TYP MAX Data @ 20mA STANDARD LTMXXX5AC LTMXXX5AD LTMXXX5AT LTMXXX5BWC LTMXXX5BWD LTMXXX5BWT LTMXXX5GC LTMXXX5GD LTMXXX5GT LTMXXX5HC LTMXXX5HD LTMXXX5HT LTMXXX5PGC LTMXXX5PGD LTMXXX5PGT LTMXXX5RC LTMXXX5RD LTMXXX5RT LTMXXX5YC LTMXXX5YD LTMXXX5YT Vf (V) WATER CLEAR DIFFUSED TINTED WATER CLEAR DIFFUSED TINTED WATER CLEAR DIFFUSED TINTED WATER CLEAR DIFFUSED TINTED WATER CLEAR DIFFUSED TINTED WATER CLEAR DIFFUSED TINTED WATER CLEAR DIFFUSED TINTED 2.0 2.0 2.0 4.0 4.0 4.0 2.1 2.1 2.1 2.0 2.0 2.0 2.2 2.2 2.2 2.1 2.1 2.1 2.0 2.0 2.0 2.8 2.8 2.8 4.5 4.5 4.5 2.8 2.8 2.8 2.8 2.8 2.8 2.8 2.8 2.8 2.8 2.8 2.8 2.8 2.8 2.8 Iv (mcd) TYP Viewing Angle 2 θ½ (Deg) LED P/N 40 25 40 30 15 30 40 25 40 50 40 50 10 10 10 2 1.5 2 40 25 40 35 40 35 25 40 25 35 40 35 35 40 35 35 40 35 35 40 35 35 40 35 5AC-F 5AD-F 5AT-F 5BWC-F 5BWD-F 5BWT-F 5GC-F 5GD-F 5GT-F 5HC-F 5HD-F 5HT-F 5PGC-F 5PGD-F 5PGT-F 5RC-F 5RD-F 5RT-F 5YC-F 5YD-F 5YT-F STANDARD TOLERANCE ® ( UNLESS OTHERWISE SPECIFIED ) DECIMALS ANGULAR 4 THOMAS, IRVINE, CA. 92618 TEL: (949) 951-8808 FAX: (949) 951-3974 TITLE: MOLDED, SELF-RETAINING T-1 3/4 (5mm) LED MOUNT ASSEMBLY DESIGNED: D. Green CHECKED: M. Chen DATE: 09/30/03 DATE: 09/30/03 PART NO: REVISION: LTMXXX5XX CAGE CODE : 32559 C SHEET # 2 OF 3 CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING. REV. DATE DESCRIPTION APPROVED SEE SHEET #1 LED Assy. No. Peak Wave Length λp(nm) Emitted Color Lens Appearance 605 430 568 625 555 645 590 AMBER BLUE GREEN HE RED PURE GREEN RED YELLOW DIFFUSED DIFFUSED DIFFUSED DIFFUSED DIFFUSED DIFFUSED DIFFUSED LOW CURRENT LTMXXX5ADL LTMXXX5BWDL LTMXXX5GDL LTMXXX5HDL LTMXXX5PGDL LTMXXX5SRDL LTMXXX5YDL LED Assy. No. Peak Wave Length λp(nm) Emitted Color Lens Appearance 605 430 568 625 700 590 AMBER BLUE GREEN HE RED RED YELLOW DIFFUSED DIFFUSED DIFFUSED DIFFUSED DIFFUSED DIFFUSED 5 VOLT LTMXXX5AD5V LTMXXX5BWD5V LTMXXX5GD5V LTMXXX5HD5V LTMXXX5RD5V LTMXXX5YD5V Electro-Optical Data Iv Vf (mcd) (V) TYP MAX TYP Data @ 2mA 2.0 3.8 2.1 2.0 2.1 1.7 2.0 2.6 4.2 2.6 2.6 2.6 2.3 2.6 4 4 4 5 1 6 4 Electro-Optical Data Iv Vf (mcd) (V) TYP MAX TYP Data @ 5V - 5.0 5.0 5.0 5.0 5.0 5.0 25 15 25 30 1.5 25 Viewing Angle 2 θ½ (Deg) LED P/N 40 40 40 40 40 40 40 5ADL-F 5BWDL-F 5GDL-F 5HDL-F 5PGDL-F 5SRDL-F 5YDL-F Viewing Angle 2 θ½ (Deg) LED P/N 40 40 40 40 40 40 5AD5V-F 5BWD5V-F 5GD5V-F 5HD5V-F 5RD5V-F 5YD5V-F STANDARD TOLERANCE ® ( UNLESS OTHERWISE SPECIFIED ) DECIMALS ANGULAR 4 THOMAS, IRVINE, CA. 92618 TEL: (949) 951-8808 FAX: (949) 951-3974 TITLE: MOLDED, SELF-RETAINING T-1 3/4 (5mm) LED MOUNT ASSEMBLY DESIGNED: D. Green CHECKED: M. Chen DATE: 09/30/03 DATE: 09/30/03 PART NO: REVISION: LTMXXX5XX CAGE CODE : 32559 C SHEET # 3 OF 3 CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING.
LTM7505HD5V 价格&库存
很抱歉,暂时无法提供与“LTM7505HD5V”相匹配的价格&库存,您可以联系我们找货
