PART NUMBER
REV.
ITEM
Q'TY
1
1
MPC5
Chrome Panel Mount Holder, 5mm
2
1
5XX-F
T-1 3/4 (5mm) Flanged LED, P.2. Note P/N Designation
3
1
BWS24-1007-BK
24AWG Wire Lead U.L. 1007, Black
4
1
BWS24-1007-RD
24AWG Wire Lead U.L. 1007, Red
5
2
BST200-BK
Shrink Tubing, Black, 0.5" Cut Length
6
1
2665S020000
Leoco 2665 Series 2.54 (.100") Crimp Type Socket, 1x
7
2
2653TPB0001
Leoco Terminal# 2653TPB0001 (Reel), 2653TPB00A1 (Bulk)
PART DESCRIPTION
X.X +0.20
-0.05
0.578 [14.7mm]
0.094 [2.4mm]
0.190 [4.8mm]
Ø.392 [Ø10.0mm]
Flange
2
1
5MM Flanged LED
5
TYP.
3
T. Y.
J. C.
Red Wire:
Red Anode
Solid
Black Wire:
Green Anode
0.100 [2.5mm]
4
APPROVED
Bi-Color
0.550 [14.0mm]
0.200 [5.1mm]
Ø.196 [Ø5.0mm]
DATE
02/06/09
08/14/16
DESCRIPTION
A Engineering Release
B Engineering Update w/o Changes
0.100 [2.5mm]
M8 Spring Lock Washer
6 7
M8X.75 Nut, Stainless Steel
Ø.315+.005
-.000
P/N Designation:
MPC5GD5VW6.5 -CC
Connector
Note: Mounting Hardware included, packed separately
Wire Length "X.X", inches
- " " Standard LED
- "5V" 5V LED
- "L" Low Current LED
Recommended Mounting Hole
LED Color & Lens Appearance
Series
ABSOLUTE MAXIMUM RATINGS (Ta = 25°C)
STANDARD TOLERANCE
DECIMALS
REVERSE VOLTAGE
5V
REVERSE CURRENT ( VR=5V)
100µA
OPERATING TEMPERATURE RANGE
-25°C ~ 85°C
STORAGE TEMPERATURE
-30°C ~ 100°C
LEAD SOLDERING TEMPERATURE (1/16" FROM BODY)
260°C for 5 Seconds
( UNLESS OTHERWISE SPECIFIED )
.X
.XX
.XXX
± .1
± .02
± .010
DESIGNED:
R. Paje
CHECKED:
F. Jensen
ANGULAR
X°
± 1°
4 THOMAS, IRVINE, CA. 92618
TEL: (949) 951-8808
FAX: (949) 951-3974
TITLE:
CHROME PANEL MOUNT ASSY
DATE:
02/06/09
DATE:
02/06/09
REVISION:
PART NO:
MPC5XXWX.X-CC
CAGE CODE : 32559
B
SHEET # 1 OF 2
CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING.
REV.
DATE
DESCRIPTION
APPROVED
SEE SHEET #1
Assy P/N
Peak Wave
Length
λp(nm )
Electro-Optical
Data @ 20m A
Em itted Color
Lens
Appearance
If
(m A)
Iv
(m cd)
Vf
(V)
MAX
TYP
MAX
TYP
View ing
Angle
2 ½
(Deg)
LED P/N
MPC5BWCWX.X-CC
430
BLUE
WATER CLEAR
25
4.0
4.5
50
5BWC-F
MPC5BWDWX.X-CC
430
BLUE
DIFFUSED
25
4.0
4.5
5BWD-F
MPC5BWTWX.X-CC
430
BLUE
TINTED
25
4.0
4.5
50
5BWT-F
MPC5GCWX.X-CC
565
GREEN
WATER CLEAR
30
2.2
2.6
150
5GC-F
MPC5GDWX.X-CC
565
GREEN
DIFFUSED
30
2.2
2.6
70
45
5GD-F
MPC5GTWX.X-CC
565
GREEN
TINTED
30
2.2
2.6
150
5GT-F
MPC5YCWX.X-CC
585
YELLOW
WATER CLEAR
30
2.1
2.6
140
5YC-F
MPC5YDWX.X-CC
585
YELLOW
DIFFUSED
30
2.1
2.6
70
45
5YD-F
MPC5YTWX.X-CC
585
YELLOW
TINTED
30
2.1
2.6
140
5YT-F
MPC5ACWX.X-CC
610
AMBER
WATER CLEAR
30
2.2
2.6
70
5AC-F
MPC5ADWX.X-CC
610
AMBER
DIFFUSED
30
2.2
2.6
45
45
5AD-F
MPC5ATWX.X-CC
610
AMBER
TINTED
30
2.2
2.6
70
5AT-F
MPC5HCWX.X-CC
635
HE RED
WATER CLEAR
30
2.0
2.6
150
5HC-F
MPC5HDWX.X-CC
635
HE RED
DIFFUSED
30
2.0
2.6
80
45
5HD-F
MPC5HTWX.X-CC
635
HE RED
TINTED
30
2.0
2.6
150
5HT-F
MPC5RCWX.X-CC
655
RED
WATER CLEAR
40
1.7
2.0
15
5RC-F
MPC5RDWX.X-CC
655
RED
DIFFUSED
40
1.7
2.0
5
45
5RD-F
MPC5RTWX.X-CC
655
RED
TINTED
40
1.7
2.0
15
5RT-F
MPC5SRCWX.X-CC
660
SUPER RED
WATER CLEAR
2.6
350
5SRC-F
MPC5SRDWX.X-CC
660
SUPER RED
DIFFUSED
2.6
90
45
5SRD-F
MPC5SRTWX.X-CC
660
SUPER RED
TINTED
2.6
350
5SRT-F
635
HE RED
45
2.0
2.6
45
50
5BC-F
568
GREEN
30
2.2
2.6
45
568
GREEN
5
25
40
5GD5V-F
MPC5YD5VWX.X-CC
590
YELLOW
DIFFUSED
8
5
25
40
5YD5V-F
MPC5HD5VWX.X-CC
625
HE RED
DIFFUSED
8
5
30
40
5HD5V-F
MPC5BCWX.X-CC
WHITE DIFFUSED
5 VOLT
MPC5GD5VWX.X-CC
Data @ 5V
DIFFUSED
8
STANDARD TOLERANCE
DECIMALS
ANGULAR
TEL: (949) 951-8808
FAX: (949) 951-3974
TITLE:
DESIGNED:
R. Paje
CHECKED:
F. Jensen
DATE:
02/06/09
DATE:
02/06/09
REVISION:
PART NO:
MPC5XXWX.X-CC
CAGE CODE : 32559
B
SHEET # 2 OF 2
很抱歉,暂时无法提供与“MPC5GD5VW4.0-CC”相匹配的价格&库存,您可以联系我们找货
