PM5UOC
PM5UOC
    BIVAR
    LED ASSEMBLY
PM5UOC 数据手册
ITEM Q'TY PART NUMBER 1 1 PM5-XXX 2 1 5XX REV. PART DESCRIPTION LED holder, Panel Mount, Press Fit (5mm) PM5 (Standard LED), PM5-5V (5V LED), & PM5-12V (12V LED ) T1 ¾ (5mm) Non-Flange LED, See Following Pages 0.190 [4.8mm] 0.030 [0.8mm] DATE APPROVED 12/20/05 02/09/10 05/01/12 11/13/12 09/15/15 M. C. T. Y. T. Y. T. Y. J. C. DESCRIPTION Engineering Release. Added Bi-Color Specs. Updated LED Offering. Updated BOM item 1. Updated LED Optical Characteristics. Ø.280 [Ø7.1mm] Flange 0.68 [17.3mm] 0.530 [13.5mm] A B C D E 0.040 [1.0mm] 2 2 2 2 1 1 1 0.100 [2.5mm] 0.117 [3.0mm] Ø.190 [Ø4.8mm] LED 2 1 0.020 [0.5mm]SQ. TYP. 1 Single Color Ø.245 [Ø6.2mm] Body 5V or 12V Bi-Color BI-COLOR POLARITY LED P/N (1) Cathode (2) Cathode 5BC Red Green Yellow 5BC-Y/G Green Red 5BC-R/Y Yellow Amber 5BC-A/G Green Ø.032+.003 TYP. -.002 Ø.250+.003 -.002 0.100 [2.5mm] TYP. Recommended Mounting Holes Recommended Mounting Hole ABSOLUTE MAXIMUM RATINGS (Ta = 25°C) STANDARD TOLERANCE DECIMALS REVERSE VOLTAGE 5V REVERSE CURRENT ( VR=5V) 100µA OPERATING TEMPERATURE RANGE -25°C ~ 85°C STORAGE TEMPERATURE -30°C ~ 100°C LEAD SOLDERING TEMPERATURE (1/16" FROM BODY) 260°C for 5 Seconds ® ( UNLESS OTHERWISE SPECIFIED ) .X .XX .XXX ± .1 ± .02 ± .010 DESIGNED: Sonny Dam CHECKED: T. Yin ANGULAR X° ± 1° 4 THOMAS, IRVINE, CA. 92618 TEL: (949) 951-8808 FAX: (949) 951-3974 TITLE: STD PANEL MOUNT INDICATORS DATE: 12/20/05 DATE: 12/20/05 PART NO: REVISION: PM5XX CAGE CODE : 32559 E SHEET # 1 OF 4 CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING. REV. DATE DESCRIPTION APPROVED SEE SHEET #1. LED Assy.No. PM5BWC PM5BWD PM5BWT PM5GC PM5GD PM5GT PM5PGC PM5PGD PM5PGT PM5YC PM5YD PM5YT PM5AC PM5AD PM5AT PM5HC PM5HD PM5HT PM5RC PM5RD PM5RT PM5BC‐A/G PM5BC PM5BC‐R/Y PM5BC‐Y/G Material GaN/SiC GaN/SiC GaN/SiC GaP/GaP GaP/GaP GaP/GaP GaP/GaP GaP/GaP GaP/GaP GaAsp/GaP GaAsp/GaP GaAsp/GaP GaAsp/GaP GaAsp/GaP GaAsp/GaP GaAsp/GaP GaAsp/GaP GaAsp/GaP GaP/GaP GaP/GaP GaP/GaP GaAsp/GaP GaP/GaP GaAsp/GaP GaP/GaP GaAsp/GaP GaP/GaP GaAsp/GaP GaP/GaP Chip Peak Wave Length 430 430 430 568 568 568 555 555 555 590 590 590 605 605 605 625 625 625 700 700 700 605 568 625 568 625 590 590 568 Emitted Color BLUE BLUE BLUE GREEN GREEN GREEN PURE GREEN PURE GREEN PURE GREEN YELLOW YELLOW YELLOW AMBER AMBER AMBER HE RED HE RED HE RED RED RED RED AMBER GREEN RED GREEN RED YELLOW YELLOW GREEN Lens Appearance WATER CLEAR DIFFUSED TINTED  WATER CLEAR DIFFUSED TINTED  WATER CLEAR DIFFUSED TINTED  WATER CLEAR DIFFUSED TINTED  WATER CLEAR DIFFUSED TINTED  WATER CLEAR DIFFUSED TINTED  WATER CLEAR DIFFUSED TINTED  WHITE DIFFUSED WHITE DIFFUSED WHITE DIFFUSED WHITE DIFFUSED Electro‐Optical Data @20mA lf lv Vf (mA) (mcd) (V) MAX TYP MAX TYP 25 4.0 4.5 25 25 4.0 4.5 15 25 4.0 4.5 30 30 2.1 2.8 40 30 2.1 2.8 25 30 2.1 2.8 40 30 2.2 2.8 10 30 2.2 2.8 10 30 2.2 2.8 10 30 2.0 2.8 40 30 2.0 2.8 25 30 2.0 2.8 40 30 2.0 2.8 40 30 2.0 2.8 25 30 2.0 2.8 40 30 2.0 2.8 40 30 2.0 2.8 25 30 2.0 2.8 40 20 2.1 2.8 2 20 2.1 2.8 2 20 2.1 2.8 2 30 2.0 2.8 6 30 2.1 2.8 6 30 2.0 2.8 6 30 2.1 2.8 8 30 2.0 2.8 6 30 2.0 2.8 5 30 2.0 2.8 5 30 2.1 2.8 8 Viewing Angle 2 θ 1/2 (Deg) 20 45 20 35 45 35 35 45 35 35 45 35 35 45 35 35 45 35 35 45 35 LED P/N 5BWC 5BWD 5BWT 5GC 5GD 5GT 5PGC 5PGD 5PGT 5YC 5YD 5YT 5AC 5AD 5AT 5HC 5HD 5HT 5RC 5RD 5RT 45 5BC‐A/G 45 5BC 45 5BC‐R/Y 45 5BC‐Y/G STANDARD TOLERANCE ® ( UNLESS OTHERWISE SPECIFIED ) ±10% ALL VALUES ANGULAR X° ± 1° 4 THOMAS, IRVINE, CA. 92618 TEL: (949) 951-8808 FAX: (949) 951-3974 TITLE: STD PANEL MOUNT INDICATORS DESIGNED: Sonny Dam CHECKED: T. Yin DATE: 12/20/05 DATE: 12/20/05 REVISION: PART NO: PM5XX CAGE CODE : 32559 E SHEET # 2 OF 4 CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING. REV. DATE DESCRIPTION APPROVED SEE SHEET #1. LED Assy.No. PM5UBWC PM5SGC PM5SGD PM5SGT PM5SYC PM5SYD PM5SYT PM5SRC PM5SRD PM5SRT PM5UGC PMTSUGC PM5UYC PM5SUYC PM5UOC PM5UOC PM5SUOC PM5URC PM5SURC PM5UWC Material lnGaN/SiC GaP/GaP GaP/GaP GaP/GaP GaAsP/GaP GaAsP/GaP GaAsP/GaP GaAIAs/GaAs GaAIAs/GaAs GaAIAs/GaAs AlGalnP AlGalnP AlGalnP AlGalnP AlGalnP AlGalnP AlGalnP GaAIAs/GaAs AlGalnP lnGaN/SiC Chip Peak Wave Length 468 568 568 568 590 590 590 645 645 645 570 570 590 590 590 625 625 645 640 6500K Emitted Color Lens Appearance BLUE GREEN GREEN GREEN YELLOW YELLOW YELLOW SUPER RED SUPER RED SUPER RED GREEN GREEN YELLOW YELLOW YELLOW ORANGE ORANGE RED RED WHITE WATER CLEAR WATER CLEAR DIFFUSED TINTED WATER CLEAR DIFFUSED TINTED WATER CLEAR DIFFUSED TINTED WATER CLEAR WATER CLEAR WATER CLEAR WATER CLEAR WATER CLEAR WATER CLEAR WATER CLEAR WATER CLEAR WATER CLEAR WATER CLEAR Electro‐Optical Data @20mA lf lv Vf (mA) (mcd) (V) MAX TYP MAX TYP 50 3.2 3.6 5000 30 2.1 2.8 60 30 2.1 2.8 50 30 2.1 2.8 60 30 2.0 2.8 600 30 2.0 2.8 150 30 2.0 2.8 600 30 1.7 2.4 60 30 1.7 2.4 40 30 1.7 2.4 60 30 2.1 2.4 600 30 2.1 2.4 300 30 2.0 2.4 1000 30 2.0 2.4 700 30 2.0 2.4 500 30 1.8 2.4 1400 30 1.8 2.4 1300 30 1.7 2.4 400 30 1.8 2.4 500 100 3.5 4.2 2700 Viewing Angle LED P/N 2 θ 1/2 (Deg) 15 5BWC2.515 35 5SGC 40 5SGD 35 5SGT 35 5SYC 40 5SYD 35 5SYT 35 5SRC 40 5SRD 35 5SRT 35 5UGC 35 5SUGC 30 5UYC 35 5SUYC 35 5UUYC 35 5UOC 35 5SUOC 30 5URC 35 5SURC 30 5WC2.730 STANDARD TOLERANCE ® ( UNLESS OTHERWISE SPECIFIED ) ±10% ALL VALUES ANGULAR X° ± 1° 4 THOMAS, IRVINE, CA. 92618 TEL: (949) 951-8808 FAX: (949) 951-3974 TITLE: STD PANEL MOUNT INDICATORS DESIGNED: Sonny Dam CHECKED: T. Yin DATE: 12/20/05 DATE: 12/20/05 REVISION: PART NO: PM5XX CAGE CODE : 32559 E SHEET # 3 OF 4 CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING. REV. DATE DESCRIPTION APPROVED SEE SHEET #1. LED Assy. No. Max. Rating Peak Wave Length λ p(nm ) Em itted Color Lens Appearance Electro-Optical Data @ 2m A If (m A) MAX Iv (m cd) Vf (V) TYP MAX TYP View ing Angle 2 ½ (Deg) LED P/N PM5BWDL 430 BLUE DIFFUSED 7 3.8 4.2 4 45 5BWDL PM5PGDL 555 PURE GREEN DIFFUSED 7 2.1 2.6 1 45 5PGDL PM5GDL 568 GREEN DIFFUSED 7 2.1 2.6 5 45 5GDL PM5YDL 590 YELLOW DIFFUSED 7 2.0 2.6 4 45 5YDL PM5ADL 605 AMBER DIFFUSED 7 2.0 2.6 4 45 5ADL PM5HDL 625 HE RED DIFFUSED 7 2.0 2.6 5 45 5HDL PM5SRDL 645 SUPER RED DIFFUSED 7 1.7 2.3 6 45 5SRDL LED Assy. No. 5 Volt PM5BWD5V PM5GC5V PM5GD5V PM5GT5V PM5AD5V PM5HD5V PM5RD5V PM5YD5V 12 Volt PM5GC12V PM5GD12V PM5HC12V PM5HD12V PM5RC12V PM5RD12V PM5YC12V PM5YD12V Peak Wave Length λp(nm) Emitted Color Lens Appearance BLUE GREEN GREEN GREEN AMBER HE RED RED YELLOW 430 568 568 568 605 625 700 590 DIFFUSED WATER CLEAR DIFFUSED TINTED DIFFUSED DIFFUSED DIFFUSED DIFFUSED GREEN GREEN HE RED HE RED RED RED YELLOW YELLOW 568 568 625 625 700 700 590 590 WATER CLEAR DIFFUSED WATER CLEAR DIFFUSED WATER CLEAR DIFFUSED WATER CLEAR DIFFUSED Electro-Optical Data Vf If Iv (V) (mA) (mcd) MAX TYP MAX TYP Data @ 5V 5 15 5 40 5 25 5 40 5 25 5 30 5 1.5 5 25 Data @ 12V 12 40 12 25 12 50 12 30 12 2 12 1.5 12 25 12 20 Viewing Angle 2 θ½ (Deg) LED P/N 40 40 40 40 40 40 40 40 5BWD5V 5GC5V 5GD5V 5GT5V 5AD5V 5HD5V 5RD5V 5YD5V 35 40 35 40 35 40 35 40 5GC12V 5GD12V 5HC12V 5HD12V 5RC12V 5RD12V 5YC12V 5YD12V STANDARD TOLERANCE ® ( UNLESS OTHERWISE SPECIFIED ) ±10% ALL VALUES ANGULAR X° ± 1° 4 THOMAS, IRVINE, CA. 92618 TEL: (949) 951-8808 FAX: (949) 951-3974 TITLE: STD PANEL MOUNT INDICATORS DESIGNED: Sonny Dam CHECKED: T. Yin DATE: 12/20/05 DATE: 12/20/05 PART NO: REVISION: PM5XX CAGE CODE : 32559 E SHEET # 4 OF 4 CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING. Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: BIVAR: PM5GD12V PM5HD12V PM5YD12V
PM5UOC 价格&库存
很抱歉,暂时无法提供与“PM5UOC”相匹配的价格&库存,您可以联系我们找货
