SLM2005HDL-LS
SLM2005HDL-LS
    BIVAR
    LED ASSEMBLY
SLM2005HDL-LS 数据手册
ITEM 1 2 3 Q'TY 1 1 1 PART NUMBER REV. PART DESCRIPTION Molded Self-Retaining LED Mount T1 ¾ (5mm) Flanged LED, See Page 2 & 3 Light Shield SLM-XXX 5XX-F LS-1 DATE DESCRIPTION APPROVED A Engineering Release 06/15/10 B Added Low Current & 5V LED Specs on Page 3 06/26/16 T. Y. J. C. H NOTE: LIGHT SHIELD SHIPPED ASSEMBLED SH REF. Ø.230 [Ø5.8mm] 0.210 [5.3mm] Ø.290 [Ø7.4mm] 0.025 [0.6mm] UNCUT LEADS Ø.045 [Ø1.1mm] TYP. 3 CATHODE I.D. MARKING 2 Ø.197 [Ø5.0mm] SHORT LEAD CATHODE 1 0.02 [0.5mm]SQ. TYP. PART NO. SH ( Ref.) H PART NO. SH ( Ref.) H PART NO. SH ( Ref.) H PART NO. SH ( Ref.) H SLM-140 .140 (3.6mm) .285 (7.1mm) SLM-280 .280 (7.1mm) .425 (10.8mm) SLM-420 .420 (10.7mm) .565 (14.3mm) SLM-670 .670 (17.0mm) .815 (20.7mm) SLM-150 .150 (3.8mm) .295 (7.2mm) SLM-290 .290 (7.4mm) .435 (11.0mm) SLM-430 .430 (10.9mm) .575 (14.6mm) SLM-690 .690 (17.5mm) .835 (21.2mm) SLM-160 .160 (4.1mm) .305 (7.7mm) SLM-300 .300 (7.6mm) .445 (11.3mm) SLM-440 .440 (11.2mm) .585 (14.9mm) SLM-710 .710 (18.0mm) .855 (21.7mm) SLM-170 .170 (4.3mm) .315 (8.0mm) SLM-310 .310 (7.9mm) .455 (11.6mm) SLM-450 .450 (11.4mm) .595 (15.1mm) SLM-730 .730 (18.5mm) .875 (22.2mm) SLM-180 .180 (4.6mm) .325 (8.3mm) SLM-320 .320 (8.1mm) .465 (11.8mm) SLM-470 .470 (11.9mm) .615 (15.6mm) SLM-750 .750 (19.1mm) .895 (22.7mm) SLM-190 .190 (4.8mm) .335 (8.5mm) SLM-330 .330 (8.4mm) .475 (12.1mm) SLM-490 .490 (12.4mm) .635 (16.1mm) SLM-770 .770 (19.6mm) .915 (23.2mm) SLM-200 .200 (5.1mm) .345 (8.8mm) SLM-340 .340 (8.6mm) .485 (12.3mm) SLM-510 .510 (13.0mm) .655 (16.6mm) SLM-790 .790 (20.1mm) .935 (23.7mm) SLM-210 .210 (5.3mm) .355 (9.0mm) SLM-350 .350 (8.9mm) .495 (12.6mm) SLM-530 .530 (13.5mm) .675 (17.1mm) SLM-810 .810 (20.6mm) .955 (24.3mm) SLM-220 .220 (5.6mm) .365 (9.3mm) SLM-360 .360 (9.1mm) .505 (12.8mm) SLM-550 .550 (13.8mm) .695 (17.5mm) SLM-830 .830 (21.1mm) .975 (24.8mm) SLM-230 .230 (5.8mm) .375 (9.5mm) SLM-370 .370 (9.4mm) .515 (13.1mm) SLM-570 .570 (14.5mm) .715 (18.2mm) SLM-850 .850 (21.6mm) .995 (25.3mm) SLM-240 .240 (6.1mm) .385 (9.8mm) SLM-380 .380 (9.7mm) .525 (13.3mm) SLM-590 .590 (15.0mm) .735 (18.6mm) SLM-870 .870 (22.1mm) 1.015 (25.8mm) SLM-250 .250 (6.4mm) .395 (10.0mm) SLM-390 .390 (9.9mm) .535 (13.6mm) SLM-610 .610 (15.5mm) .755 (19.2mm) SLM-890 .890 (22.6mm) 1.035 (26.3mm) SLM-260 .260 (6.6mm) .405 (10.3mm) SLM-400 .400 (10.2mm) .545 (13.8mm) SLM-630 .630 (16.0mm) .775 (19.7mm) SLM-270 .270 (6.9mm) .415 (10.5mm) SLM-410 .410 (10.4mm) .555 (14.1mm) SLM-650 .650 (16.5mm) .795 (20.2mm) ABSOLUTE MAXIMUM RATINGS (Ta = 25°C) REVERSE VOLTAGE 5V REVERSE CURRENT ( VR=5V) 100µA OPERATING TEMPERATURE RANGE -25°C ~ 85°C STORAGE TEMPERATURE -30°C ~ 100°C LEAD SOLDERING TEMPERATURE (1/16" FROM BODY) 260°C for 5 Seconds STANDARD TOLERANCE ® ( UNLESS OTHERWISE SPECIFIED ) DECIMALS .X .XX .XXX ± .1 ± .02 ± .010 DESIGNED: R. Paje CHECKED: T. Yin ANGULAR X° ± 1° 4 THOMAS, IRVINE, CA. 92618 TEL: (949) 951-8808 TITLE: DATE: 06/15/10 DATE: 06/15/10 FAX: (949) 951-3974 MOLDED, SELF-RETAINING LED ASSEMBLY W/ LIGHT SHIELD PART NO: REVISION: SLMXXX5XXX-LS CAGE CODE : 32559 B SHEET # 1 OF 3 CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING. REV. DATE DESCRIPTION APPROVED SEE SHEET #1 Chip Assy Part No. Material Peak Wave Length λ p(nm ) Electro-Optical Data Em itted Color Lens Appearance Vf (V) TYP STANDARD MAX Iv (m cd) TYP View ing Angle 2 ½ (Deg) LED Part No. Data @ 20m A SLMXXX5BWC-LS GaN/SiC 430 BLUE WATER CLEAR 4.0 4.5 30 25 5BWC-F SLMXXX5BWD-LS GaN/SiC 430 BLUE DIFFUSED 4.0 4.5 15 40 5BWD-F SLMXXX5BWT-LS GaN/SiC 430 BLUE TINTED 4.0 4.5 30 25 5BWT-F SLMXXX5PGC-LS GaP/GaP 555 PURE GREEN WATER CLEAR 2.2 2.8 10 35 5PGC-F SLMXXX5PGD-LS GaP/GaP 555 PURE GREEN DIFFUSED 2.2 2.8 10 40 5PGD-F SLMXXX5PGT-LS GaP/GaP 555 PURE GREEN TINTED 2.2 2.8 10 35 5PGT-F SLMXXX5GC-LS GaP/GaP 568 GREEN WATER CLEAR 2.1 2.8 40 35 5GC-F SLMXXX5GD-LS GaP/GaP 568 GREEN DIFFUSED 2.1 2.8 25 40 5GD-F SLMXXX5GT-LS GaP/GaP 568 GREEN TINTED 2.1 2.8 40 35 5GT-F SLMXXX5YC-LS GaAsP/GaP 590 YELLOW WATER CLEAR 2.0 2.8 40 35 5YC-F SLMXXX5YD-LS GaAsP/GaP 590 YELLOW DIFFUSED 2.0 2.8 25 40 5YD-F SLMXXX5YT-LS GaAsP/GaP 590 YELLOW TINTED 2.0 2.8 40 35 5YT-F SLMXXX5HC-LS GaAsP/GaP 625 HE RED WATER CLEAR 2.0 2.8 50 35 5HC-F SLMXXX5HD-LS GaAsP/GaP 625 HE RED DIFFUSED 2.0 2.8 40 40 5HD-F SLMXXX5HT-LS GaAsP/GaP 625 HE RED TINTED 2.0 2.8 50 35 5HT-F SLMXXX5RC-LS GaP/GaP 700 RED WATER CLEAR 2.1 2.8 2 35 5RC-F SLMXXX5RD-LS GaP/GaP 700 RED DIFFUSED 2.1 2.8 1.5 40 5RD-F SLMXXX5RT-LS GaP/GaP 700 RED TINTED 2.1 2.8 2 35 5RT-F STANDARD TOLERANCE ® ( UNLESS OTHERWISE SPECIFIED ) ±10% ALL VALUES ANGULAR 4 THOMAS, IRVINE, CA. 92618 TEL: (949) 951-8808 FAX: (949) 951-3974 TITLE: MOLDED, SELF-RETAINING LED ASSEMBLY W/ LIGHT SHIELD DESIGNED: R. Paje CHECKED: T. Yin DATE: 06/15/10 DATE: 06/15/10 REVISION: PART NO: SLMXXX5XXX-LS CAGE CODE : 32559 B SHEET # 2 OF 3 CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING. REV. DATE DESCRIPTION APPROVED SEE SHEET #1 Chip Assy Part No. Material Peak Wave Length λ p(nm) Electro-Optical Data Emitted Color Lens Appearance Vf (V) TYP LOW CURRENT MAX Iv (mcd) TYP View ing Angle 2 ½ (Deg) LED Part No. Data @ 2m A SLMXXX5BWDL-LS GaN/SiC 430 BLUE DIFFUSED 3.8 4.2 4 40 5BWDL-F SLMXXX5GDL-LS GaP/GaP 568 GREEN DIFFUSED 2.1 2.6 4 40 5GDL-F SLMXXX5YDL-LS GaAsP/GaP 590 YELLOW DIFFUSED 2.0 2.6 4 40 5YDL-F SLMXXX5ADL-LS GaAsP/GaP 605 AMBER DIFFUSED 2.0 2.6 4 40 5ADL-F SLMXXX5HDL-LS GaAsP/GaP 625 HE RED DIFFUSED 2.0 2.6 5 40 5HDL-F GaAlAs/GaAs 645 RED DIFFUSED 1.7 2.3 6 40 5SRDL-F View ing Angle 2 ½ (Deg) LED Part No. SLMXXX5SRDL-LS Chip Assy Part No. Material Peak Wave Length λ p(nm) Electro-Optical Data Emitted Color Lens Appearance Vf (V) TYP 5 VOLT MAX Iv (mcd) TYP Data @ 5V SLMXXX5BWD5V-LS GaN/SiC 430 BLUE DIFFUSED - 5.0 15 40 5BWD5V-F SLMXXX5GD5V-LS GaP/GaP 568 GREEN DIFFUSED - 5.0 25 40 5GD5V-F SLMXXX5YD5V-LS GaAsP/GaP 590 YELLOW DIFFUSED - 5.0 25 40 5YD5V-F SLMXXX5AD5V-LS GaAsP/GaP 605 AMBER DIFFUSED - 5.0 25 40 5AD5V-F SLMXXX5HD5V-LS GaAsP/GaP 625 HE RED DIFFUSED - 5.0 30 40 5HD5V-F SLMXXX5RD5V-LS GaP/GaP 700 RED DIFFUSED - 5.0 1.5 40 5RD5V-F STANDARD TOLERANCE ® ( UNLESS OTHERWISE SPECIFIED ) ±10% ALL VALUES ANGULAR 4 THOMAS, IRVINE, CA. 92618 TEL: (949) 951-8808 FAX: (949) 951-3974 TITLE: MOLDED, SELF-RETAINING LED ASSEMBLY W/ LIGHT SHIELD DESIGNED: R. Paje CHECKED: T. Yin DATE: 06/15/10 DATE: 06/15/10 REVISION: PART NO: SLMXXX5XXX-LS CAGE CODE : 32559 B SHEET # 3 OF 3 CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING.
SLM2005HDL-LS 价格&库存
很抱歉,暂时无法提供与“SLM2005HDL-LS”相匹配的价格&库存,您可以联系我们找货
