SMFLP
SMFLP
    BIVAR
    SMD
    SMT FLP ADAPTER
SMFLP 数据手册
REV. E DESCRIPTION 0.48 [12.1mm] APPROVED M. C. Ø.17 [Ø4.2mm] 0.125 [3.2mm] 0.100 [2.5mm] DATE 03/08/04 Engineering Update w/o Changes 0.350 [8.9mm] 0.290 [7.4mm] 0.20 [5.0mm] 0.430 [10.9mm] Ø.068 [Ø1.7mm] 0.350 [8.9mm] Ø.074 [Ø1.9mm] RIBS 0.275 [7.0mm] 0.14 [3.4mm] Ø.101+.003 -.002 TYP. 0.150 [3.8mm] SQ. 0.290 [7.4mm] Recommended Soldering Pattern & Mounting Holes 2. MATERIAL: NYLON 6/6 , 94V-0, BLACK, BIVAR MATERIAL CODE 22-BK RTP POLYAMIDE NYLON 6/6, RTP 0200 FR BLACK 1. GENERAL SPECIFICATIONS: BIVAR MOLDED COMPONENT SPECIFICATION BV00-E101. STANDARD TOLERANCE  ( UNLESS OTHERWISE SPECIFIED ) DECIMALS .X .XX .XXX ± .1 ± .01 ± .005 DESIGNED: Michael Chen CHECKED: E. M. Muldoon ANGULAR X° ± 1° DATE: 01/15/02 DATE: 02/18/02 4 THOMAS, IRVINE, CA. 92618 TEL: (949) 951-8808 FAX: (949) 951-3974 TITLE: ADAPTER, SURFACE MOUNT FLEXIBLE LIGHT PIPE PART NO: SMFLP CAGE CODE : 32559 REVISION: E SHEET # 1 OF 1 CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING.
SMFLP 价格&库存
很抱歉,暂时无法提供与“SMFLP”相匹配的价格&库存,您可以联系我们找货
SMFLP
    • 1+7.230281+0.93813
    • 10+5.0462910+0.65476
    • 100+3.67318100+0.47659
    • 500+3.05825500+0.39681
    • 1000+2.856491000+0.37063
    • 2000+2.685082000+0.34839
    • 5000+2.497715000+0.32408
    • 10000+2.3808310000+0.30891
    • 25000+2.2534025000+0.29238
    库存:11387
    SMFLP
    • 43+18.3675943+2.38318
    库存:45
    SMFLP
      库存:2800
