TO-200-150H
TO-200-150H
    BIVAR
    SPACER GEN PURP
TO-200-150H 数据手册
REV. C D E F G H J K DESCRIPTION Updated Part Thickness Offered Corrected TO-13 OD Typo Added Figure H Removed Part Numbers from Part Offering, Table 1 Removed Part Numbers, See Page 2 Add Part Number, See Page 2 Engineering Update w/o Changes Corrected Typo Dimensions on Page 2 & 3 DATE APPROVED 09/08/10 07/03/12 07/18/12 07/01/14 03/06/15 03/31/15 05/13/16 07/29/16 T. Y. T. Y. T. Y. J. C. J. C. J. C. J. C. J. C. R O.D. O.D. I.D. O.D. O.D. O.D. I.D. L I.D. CAVITY DIA. CAVITY DEPTH THICKNESS FIG. A S.W. S.W. L S R FIG. B W SQ. W S.D. FIG. C FIG. D FIG. E W FIG. F S.D. FIG. G FIG. H TABLE 1 EXAMPLE: TO-200-100E Suffix I.D. (see Table 1) Part Thickness TO Style Series L C/C SUFFIX I.D. NONE E CR DR H XH I.D. DESCRIPTION Wax Effervescent Color Removed Detergent Removed Salt Extra Hard NOTES Offered for all part numbers. Offered for all part numbers. Offered for all part numbers. Offered for all part numbers. Not offered for P/Ns: TO-10, TO-11, TO-64, TO-65, TO-68. Not offered for P/Ns: TO-10, TO-11, TO-64, TO-65, TO-68. STANDARD TOLERANCE ® ( UNLESS OTHERWISE SPECIFIED ) DECIMALS .X .XX .XXX ± .1 ± .01 ± .005 DESIGNED: D. Green CHECKED: M. Chen ANGULAR X° ± 1° 4 THOMAS, IRVINE, CA. 92618 TEL: (949) 951-8808 TITLE: DATE: 10/15/03 DATE: 10/15/03 PART NO: FAX: (949) 951-3974 DISS-O-PADS, WASH-AWAY SPACERS REVISION: TO-XXX-XXX CAGE CODE : 32559 K SHEET # 1 OF 3 CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING. REV DESCRIPTION DATE APPROVED SEE SHEET #1 TO-5 PART NO. I.D. THICKNESS O.D. FIG. TO-5 TO-5 .225 (5.7mm) .375 (9.5mm) .030, .040, .050, .060, .070, .085, .090, .100, .120, .130, .150, .170, .200 A Spacer TO-6 .250 (6.4mm) .375 (9.5mm) .030, .040, .050, .060, .070, .090, .100, .120, .130, .150, .160, .180, .190 A I.C. Spacer TO-9 .300 (7.6mm) .437 (11.1mm) .030, .040, .050, .070, .080, .090, .100, .120, .130, .150, .180, .200 A - TO-13 .225 (5.7mm) .310 (7.9mm) .030, .040, .050, .060, .070, .080, .090, .100, .120, .130, .150 A Epoxy Case TO-18 PART NO. I.D. O.D. CAVITY DIA. .125 (3.2mm) .310 (7.9mm) TO-16 .125 (3.2mm) .205 (5.2mm) - TO-17 .170 (4.3mm) .250 (6.4mm) TO-18 .125 (3.2mm) .250 (6.4mm) TO-20 .125 (3.2mm) .290 (7.4mm) TO-27 .125 (3.2mm) .290 (7.4mm) THICKNESS CAVITY DEPTH .215 (5.5mm) TO-12 .065 (1.7mm) FIG. TO-18 .080, .090, .100, .120, .130, .180 B .250 (6.4mm) L.S. - .030, .040, .045, .050, .060, .070, .080, .090, .100, .120, .130, .150, .175, .200 A Epoxy Case - - .030, .035, .040, .050, .060, .070, .090, .100, .120, .130, .140, .150, .170, .180, .200 A Thin Walls - - .030, .040, .045, .050, .055, .060, .070, .080, .090, .100, .120, .125, .130, .150, .170, .190, .200, .250 A Standard .070, .090, .100, .120, .130, .150 B .200 (5.1mm) L.S. .030, .040, .050, .060, .070, .090, .100, .120, .130 A Heavy Walls .200 (5.1mm) - .065 (1.7mm) - AXIAL PART NO. TO-21 I.D. O.D. .125 (3.2mm) THICKNESS SLOT DEPTH SLOT WIDTH FIG. .250 (6.4mm) .050, .070, .080, .090, .100, .120, .130, .150, .170, .200, .230, .250 .045 (1.1mm) .060 (1.5mm) C TO-35 - .440 (11.2mm) .100, .120, .130, .140, .150, .170, .180, .190, .220, .230, .250 .065 (1.7mm) .230 (5.8mm) H TO-36 - .187 (4.7mm) .050, .060, .070, .080, .090, .100, .120, .130, .150 .040 (1.0mm) .080 (2.0mm) H TO-37 - .156 (4.0mm) .050, .070, .080, .090, .100, .120 .025 (.64mm) .050 (1.3mm) H ON-END/CORDWOOD I.D. O.D. CAVITY DIA. CAVITY DEPTH TO-7 .075 (1.9mm) .175 (4.4mm) - - .030, .040, .050, .060, .070, .090, .100, .120, .130, .150, .180, .210 A TO-8 .062 (1.6mm) .156 (4.0mm) - - .030, .035, .040, .050, .055, .060, .065, .070, .080, .085, .090, .100, .105, .120, .130, .150, .160, .190, .200, .210 A TO-10 .040 (1.0mm) .085 (2.2mm) - - .025, .030, .040, .050, .060, .065, .070, .080, .090, .100 A TO-11 .045 (1.1mm) .100 (2.5mm) - - .030, .040, .050, .060, .070, .080, .100, .110, .120 A TO-26 .070 (1.8mm) .187 (4.7mm) - - .030, .040, .050, .060, .070, .090, .100, .120, .125, .150 A TO-40 .045 (1.1mm) .156 (4.0mm) - - .030, .040, .050, .060, .070, .080, .090, .100, .120, .130, .150, .160 A TO-64 .045 (1.1mm) .140 (3.6mm) - - .030, .035, .040, .050, .060, .070, .090, .100, .120, .125, .130, .140, .150, .160, .175 A TO-65 .075 (1.9mm) .140 (3.6mm) - - .030, .035, .040, .045, .050, .060, .070, .080, .090, .100, .120, .125, .130, .150, .175 A TO-67 .045 (1.1mm) .140 (3.6mm) .090 (2.3mm) .025 (.64mm) .050, .055, .060, .070, .090, .100, .120, .130 B TO-68 .045 (1.1mm) .110 (2.8mm) .075 (1.9mm) .025 (.64mm) .040, .050, .055, .060, .070, .090, .100, .120, .130, .150, .160 B PART NO. FIG. THICKNESS SOLID FIG. STANDARD TOLERANCE TO-29 - .156 (4.0mm) .040, .050, .060, .070, .090, .100, .120, .130 D ( UNLESS OTHERWISE SPECIFIED ) TO-31 - .125 (3.2mm) .040, .050, .060, .070, .090, .100, .120, .130 D TO-32 - .187 (4.7mm) .030, .040, .050, .060, .070, .080, .090, .100, .120, .130 D .X .XX .XXX TO-33 - .250 (6.4mm) .030, .040, .050, .060, .070, .080, .090, .100, .120, .130 D PART NO. I.D. O.D. THICKNESS DECIMALS ± .1 ± .01 ± .005 DESIGNED: TO-34 - .375 (9.5mm) .040, .050, .060, .070, .090, .100, .120, .130, .250 D D. Green CHECKED: M. Chen ANGULAR X° ± 1° ® 4 THOMAS, IRVINE, CA. 92618 TEL: (949) 951-8808 TITLE: DATE: 10/15/03 DATE: 10/15/03 PART NO: FAX: (949) 951-3974 DISS-O-PADS, WASH-AWAY SPACERS REVISION: TO-XXX-XXX CAGE CODE : 32559 K SHEET # 2 OF 3 CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING. REV DESCRIPTION DATE APPROVED SEE SHEET #1 GENERAL PURPOSE PART NO. I.D. O.D. THICKNESS FIG. TO-46 .090 (2.3mm) .250 (6.4mm) .030, .040, .050, .060, .070, .090, .100, .120, .130, .150, .200, .240 A TO-19 .250 (6.4mm) .480 (12.2mm) .030, .040, .050, .060, .070, .090, .100, .120, .130, .150, .190, .200, .230, .250 A TO-22 .225 (5.7mm) .437 (11.1mm) .030, .040, .050, .060, .070, .080, .090, .100, .110, .120, .130, .150, .190, .200, .250 A TO-23 .090 (2.3mm) .310 (7.9mm) .030, .040, .050, .055, .060, .070, .090, .100, .120, .130, .150, .180, .190, .200, .250 A TO-24 .090 (2.3mm) .340 (8.6mm) .030, .040, .050, .060, .070, .090, .100, .120, .130, .150 A TO-30 .275 (7.0mm) .397 (10.0mm) .030, .040, .050, .060, .070, .090, .100, .120, .130, .150 A TO-25 .180 (4.6mm) .480 (12.2mm) .030, .040, .050, .060, .070, .090, .100, .120, .130, .150, .250 A TO-28 .172 (4.4mm) .343 (8.7mm) .030, .040, .050, .060, .070, .090, .100, .120, .130, .180, .190 A TO-41 .156 (4.0mm) .360 (9.1mm) .030, .040, .050, .060, .070, .090, .100, .120, .130, .140 A TO-42 .250 (6.4mm) .438 (11.1mm) .030, .040, .050, .060, .070, .090, .100, .120, .130 A RECTANGULAR & SQUARE PART NO. L W THICKNESS TO-100 .670 (17.0mm) .100 (2.5mm) TO-101 .562 (14.3mm) .185 (4.7mm) TO-102 .505 (12.8mm) .160 (4.1mm) TO-116 .666 (16.9mm) .300 (7.6mm) .063 (1.6mm) R .031 (.79mm) FIG. .030, .035, .040, .045, .050, .060, .065, .070, .075, .080, .090, .100, .120, .130, .150, .200 E Rectangular - .030, .040, .050, .060, .070, .080, .090, .100, .120, .130, .150, .160, .220 E Rectangular - .040, .050, .060, .070, .090, .100, .120, .130, .150 E Rectangular .030, .040, .050, .055, .060, .065, .070, .075, .080, .090, .100, .110, .120, .125, .130, .150, .180, .200 E Rectangular TO-117 .666 (16.9mm) .281 (7.1mm) .100 (2.54mm) .030, .040, .050, .060, .070, .080, .090, .100, .120, .125, .130, .140, .150, .160 E Rectangular TO-118 .705 (17.9mm) .260 (6.6mm) .080 (2.0mm) .030, .040, .050, .060, .070, .080, .090, .100, .110, .120, .130, .150, .160, .170, .175, .200 E Rectangular TO-120 .085 (2.2mm) .085 (2.2mm) - .030, .035, .040, .045, .050, .060, .070, .090, .100, .120 F Square TO-121 .095 (2.4mm) .095 (2.4mm) - .030, .035, .040, .045, .050, .060, .070, .075, .085, .090, .095, .100, .120 F Square RADIAL & AXIAL DEVICE PART NO. C/C S W TO-200 .100 (2.5mm) .035 (.89mm) .095 (2.4mm) TO-201 .150 (3.8mm) .035 (.89mm) TO-203 .200 (5.1mm) .035 (.89mm) TO-204 .250 (6.4mm) TO-205 L THICKNESS FIG. .190 (4.8mm) .030, .035, .040, .050, .060, .070, .080, .090, .100, .120, .130, .150 G .095 (2.4mm) .240 (6.1mm) .030, .040, .050, .060, .070, .090, .100, .120, .130, .150 G .095 (2.4mm) .290 (7.4mm) .030, .040, .050, .060, .070, .090, .100, .120, .130, .140, .150, .200 G .040 (1.0mm) .145 (3.7mm) .340 (8.6mm) .040, .050, .060, .070, .080, .090, .100, .120, .130, .150 G .300 (7.6mm) .040 (1.0mm) .145 (3.7mm) .390 (9.9mm) .040, .050, .060, .070, .090, .100, .120, .130, .150, .215 G TO-206 .400 (10.2mm) .045 (1.1mm) .195 (5.0mm) .490 (12.4mm) .040, .050, .060, .070, .080, .090, .100, .120, .130, .150, .215 G TO-207 .500 (12.7mm) .045 (1.1mm) .195 (5.0mm) .590 (15.0mm) .040, .050, .060, .070, .090, .100, .120, .130, .150 G STANDARD TOLERANCE ® ( UNLESS OTHERWISE SPECIFIED ) DECIMALS .X .XX .XXX ± .1 ± .01 ± .005 DESIGNED: D. Green CHECKED: M. Chen ANGULAR X° ± 1° 4 THOMAS, IRVINE, CA. 92618 TEL: (949) 951-8808 TITLE: DATE: 10/15/03 DATE: 10/15/03 PART NO: FAX: (949) 951-3974 DISS-O-PADS, WASH-AWAY SPACERS REVISION: TO-XXX-XXX CAGE CODE : 32559 K SHEET # 3 OF 3 CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING.
TO-200-150H 价格&库存
很抱歉,暂时无法提供与“TO-200-150H”相匹配的价格&库存,您可以联系我们找货
