TL 5A
TL 5A
    B&K
    40.0"(1016.00mm) 香蕉插头,单路 至 接线夹,绝缘 插接线
TL 5A 数据手册
General Accessories Power Supply & Oscilloscope Probes TLPS Power Supply Accessory Kit This accessory kit combines safety and functionality. A must have for anyone who uses a power supply, this kit is ideal for use with power supplies in educational, service and maintenance, and manufacturing applications. TLPWR1 High Current Premium Test Lead Accessory High quality red and black cable with externally braided wrap with large fork-type spade connectors for connecting to high current power supplies or DC loads. ■■ Medium and large insulated alligator clips ■■ Black and red components ■■ Sense lead included ■■ Length: 2 m ■■ Rated current: 60 A ■■ Gauge: 8 AWG ■■ Connector inner diameter: 8 mm (approximate) ■■ Connector outer width: 15 mm (approximate) ■■ Wire material: flexible silicon jacket Description Qty. IEC Rating Max current Retractile leads, 120cm *2 600 V CAT II 25 A 6/4mm Spade lug adapters *2 33 VDC/ 70 VAC 36 A Standard alligator clips *2 300 V CAT I 3A 4mm Banana plug adapters *2 33 VDC/ 70 VAC 36 A Insulated alligator clips *3 600 V CAT IV 36 A Sense lead pair, 1 m *1 33 VDC/ 70 VAC 3A *Colors: Black & Red TL 5A & TL 30 Power Supply Leads CC545 General Purpose Power Supply Accessory Kit This kit provides everything needed to put a bench power supply to work. The kit includes 3 high capacity test leads with retractile sleeve plugs. Rated at 600 V CAT II and 36 A, the leads provide safe connection to either standard or sheathed jacks while its silicone jacket wire stays flexible under all conditions. ■■ High capacity retractable sheath silicone jacketed leads ■■ Extra-large insulated alligator clips ■■ Black, red and green components ■■ Storage case Description Qty. 68 Description TL 30 Qty. IEC rating Max current Model Leads, 4 mm banana plug leads, 100 cm Carrying Cases *2 33 VDC/ 70 VAC 5A TL 5A Cables, #10 lug to battery clip, 75 cm *2 33 VDC/ 70 VAC 30 A TL 30 *Colors: Black & Red IEC rating Max current Retractile lead, 100 cm *3 600 V CAT II 36 A 6/4mm spade lug adapter *3 33 Vdc/ 70 Vac 36 A BNC cable assembly, 100 cm 1 500 Vrms 3A BNC female to double banana plugs 1 500 Vrms 3A Banana plug adapter *3 33 Vdc/ 70 Vac 36 A BNC male to double binding posts 1 500 Vrms 3A Insulated alligator clip *3 600 V CAT IV 36 A *Colors: Black, red & green TL 5A CP62 300 kHz AC/DC Oscilloscope Current Clamp Probe The CP62 current probe allows a general purpose oscilloscope to display AC and DC current signals up to 100 A Peak (70 A RMS). The CP62 current probe can also make AC and DC measurements with a multimeter by using the recommended accessory TL62 (BNC-to-banana) plug adapter. ■■ 50 mA to 100 Apk ■■ DC to 300 kHz General Accessories Oscilloscope Probes PR-60 Active Differential Probe Passive Oscilloscope Probes High bandwidth, high impedance 10x passive voltage probe with 10 MΩ input impedance. All probes are RoHS (2002/95/EC) compliant. Allows for safe and accurate floating measurements with your standard analog or digital oscilloscope. Applications ■■ Switching power supply designs ■■ Motor drive design ■■ Electronic ballast design Specifications PR250B Bandwidth 17/150 MHz 250 MHz 500 MHz 200 MHz Attenuation 1x/10x 10x 10x 100x 100 MΩ Type Specifications PR-60 Bandwidth 25 MHz (-3 dB) Attenuation ratio x10/x100 Accuracy ±2% Rise time 14 ns Input impedance 4 MΩ/10 pF each side to ground Max. differential ±700 V (DC+Peak AC) Max. common mode ±700 V (DC+Peak AC) Output voltage Max. amplitude ±7 V (into 2 kΩ load) Offset (Typical) ≤±5 mV, -10°to 40° C Noise (Typical) 1.5 to 2 mV 1 Ω @ 1 kHz 8 Ω @ 1 MHz CMRR 50Hz 86 dB 20kHz 66 dB 200kHz 56 dB Probes Sprung hooks (B/R) Length of input lines 45 cm Operating temperature 14° to 104°F (-10° to 40°C) Power requirements 4 x AA batteries Certification IEC61010-1 CATIII PR500B PR2000B 5 mm Passive Voltage Input impedance 1/10 MΩ 10 MΩ 10 MΩ Input capacitance ≈45/12 pF ≈12 pF ≈10 pF ≈5 pF Rise time 20/2.3 ns 1.4 ns 0.7 ns 1.8 ns IEC rating 300 V CAT II 300 V CAT II 300 V CAT II 2,000 V CAT I Compensation 10−30 pF 10−30 pF 6–22 pF 10−30 pF Cable length Input voltage Source impedance PR150B 1.2 m Attenuation accuracy - - - 6% Voltage coefficient (VCR) - - - ≤30 ppm/V Operating temperature 0° to +50° C Humidity 85% RH or less (at 35° C) PR 32A RF Detector Probe Specifications PR 32 A Bandwidth 100 kHz - 950 MHz Accuracy ±3 dB Voltage 200 V HF voltage 50 Veff Actuating Voltage 250 mV Input capacitance 5 pF Cable length 1.2 m Body color Black General Purpose Passive Probes This full line of probes increases the versatility of your oscilloscope with both fixed and switchable attenuation. Each probe includes a full accessory kit with a sprung hook, replacement tip and BNC adapter. All models are compliant to IEC61010-031. Specifications Passive probes PR 33A PR 37 AG Model PR-55 High voltage (passive) PR 37AR PR 100A PR-55 Bandwidth (MHz) 15/90 6/150 6/150 250 50 Attenuation x1/x10 x1/x10/REF x1/x10/REF x100 x1000 Input impedance R(MΩ) 1/10 1/10 1/10 100 100 Capacitance (pF) 46/16 100/15 100/15 6.5 1 Voltage (VDC+AC max) 600 600 600 1,200 10,000 Compensation (pF) 10-35 10-35 10-35 10-35 10-30 Cable length 1.2 m 1.2 m 1.2 m 1.2 m 2.0 m Model PR 37AR www.bkprecision.com 69 General Accessories Signal Interconnect Kits CT 2701 General Purpose Universal Coaxial Adapter Kit This kit provides a convenient solution for most interconnection needs. The included 6 universal adapters allows assembly of hundreds of different configurations: male-to-male, female-to-female, male-to-female, in-series and between-series for BNC, TNC, N-Type, F, RCA, SMA, UHF and Mini-UHF. CC 510 General Purpose Function Generator Kit This kit provides a range of BNC and N Type coaxial interconnection for basic function / arbitrary waveform generators use. All components feature standard BNC or N Type interfaces with 50 Ω impedance and gold plated center contacts to ensure accurate repeatable measurements. The kit is provided in a convenient foam lined storage case for easy selection and use. Description Qty. Frequency range Max. VSWR BNC cable assembly, 100 cm 2 DC - 1 GHz 1.20:1 @ 1 GHz BNC feed-thru terminator, 2 W 1 DC - 1 GHz 1.20:1 @ 1 GHz BNC tee, female-male-female 1 DC - 4 GHz N/A BNC female to double banana plugs 2 N/A N/A BNC female to N type male 1 DC - 4 GHz 1.30:1 @ 4 GHz BNC female to N type female 1 DC - 4 GHz 1.30:1 @ 4 GHz BNC attenuator, 20 dB (10x) 2 W 1 DC - 4 GHz 1.25:1 @ 4 GHz ■■ Convenient interconnection kit ■■ BNC, TNC, N, SMA, RCA, F, SMA & Mini-UHF connectors ■■ Tarnish resistant nickel finish ■■ Gold plated center contacts ■■ Zippered storage case Description­ Qty. Universal adapters 6 BNC male adapters 2 BNC female adapters 2 F male adapter 1 F female adapter 1 N Type male adapters 2 N Type female adapters 2 RCA male adapter 1 RCA female adapter 1 SMA male adapter 1 SMA female adapter 1 TNC male adapters 2 TNC female adapters 2 UHF male adapters 2 UHF female adapters 2 Mini-UHF male adapter 1 Mini-UHF female adapter 1 CC500 General Purpose BNC & N Type Adapter Kit This general purpose BNC & N type adapter kit provides a comprehensive range of in-series and between-series BNC and N type coaxial adapters for basic RF testing and troubleshooting needs. TLFG Function Generator Accessory Kit The kit provides convenience and functionality to get a user up and running quickly. The kit eliminates the time consuming start-up task of collecting cables and adapters. Description 70 Qty. Frequency range Max. VSWR BNC cable assembly, 120 cm 2 DC - 1 GHz 1.20:1 @ 1 GHz BNC (f) breakout w/miniature alligator clips 1 DC - 1 GHz N/A BNC (f) breakout w/Ø.031 sockets 1 DC - 1 GHz N/A ■■ 12-piece kit ■■ BNC & N type 50 Ω connectors ■■ Gold plated center contacts ■■ Storage case Description Qty. Frequency range Max. VSWR BNC tee female-male-female 1 DC - 4 GHz N/A N type female-female 1 DC - 8 GHz 1.30:1 @ 8 GHz N type male-male 1 DC - 8 GHz 1.30:1 @ 8 GHz N type tee female-male-female 1 DC - 8 GHz N/A BNC female to N type male 1 DC - 4 GHz 1.30:1 @ 4 GHz BNC male to N type female 1 DC - 4 GHz 1.30:1 @ 4 GHz BNC female-female 1 DC - 4 GHz 1.30:1 @ 4 GHz BNC male-male 1 DC - 4 GHz 1.30:1 @ 4 GHz MiniFlex IC clips, black & red pair *2 N/A N/A BNC female to N type female 1 DC - 4 GHz 1.30:1 @ 4 GHz MicroFlex IC Clips, black & red pair *2 N/A N/A BNC Tee female-female-female 1 DC - 4 GHz N/A BNC tee, female-male-female 1 DC - 4 GHz N/A N type tee female-female-female 1 DC - 8 GHz N/A BNC female to N type male 1 DC - 4 GHz 1.30:1 @ 4 GHz N type right-angle male-female 1 DC - 8 GHz 1.35:1 @ 8 GHz *black & red pair General Accessories Multimeters PR 28A 40 kV High Voltage DMM Probe For voltage measurements above the specifications of general purpose probes. Specifications PR 28A Attenuation x1000 Voltage (AC) 20 kV Voltage (DC) 40 kV Bandwidth 60 Hz Input impedance 1000 MΩ Accuracy (AC & DC) ±3% Cable length 1.2 m TL500B High Performance Bench DMM Accessory Kit This kit of accessories was assembled to facilitate requirements by high-performance bench digital multimeters (DMMs) users. All the most popular accessories in one kit. The kit offers MiniProbe test probe, with spring-loaded tips for fine probing; MiniPRO and MiniFlex test clips for small and micro connections; and for those larger test points, both spade lug and banana plug adapters, two pairs of test leads for 4-wire measurements or calibration hookups, an insulated BNC male to sheathed banana jack adapter, and an insulated SMD tweezer set for surface-mount component testing. ■■ Silicone jacketed test lead wire ■■ MiniProbe w/spring loaded stainless steel tips ■■ Packaged in plastic case ■■ RoHS (2002/95/EC) TL-50B Maxi-Pro DMM Kit Complete accessory kit for all your testing needs. Includes soft, flexible silicone lead wire for easy movement. ■■ IEC61010-031 compliant ■■ Silicone lead wire length (1.5 m) ■■ Tri-fold velcro pouch Description TL-50B 4 mm straight to right-angle silicone leads, 1.5 m 1000 V CAT III 12 A Probe bodies w/Ø2 mm tip 1000 V CAT III 36 A Pincer style clips 1000 V CAT III 6A Alligator clips 300 V CAT I 3A Spade lug adapters 42 V (1000 V) - 36 A Banana plug adapters 42 V (1000 V) - 36 A Fully insulated alligator clips 1000 V CAT III 20 A TL 8 Surface Mount Tweezers ■■ Two conductor leads ■■ 400 Vrms, 1 A Qty. Description Color (4) Test lead 4 mm sheathed P-RaP silicon 0.75, 100 cm (2) black, (2) red (2) Spring tip MiniPRO - 4 mm jack (1) black, (1) red (1) Insulated BNC male adapter - 4 mm safety jacks - (2) Adapter - 4 mm banana plug to jack (1) black, (1) red (2) MiniFlex clip - 4 mm jack-silicon 0.40, 10 cm (1) black, (1) red (2) Adapter 6 mm spade 4 mm jack (1) black, (1) red (2) Lead MiniPRO-J-PVC 0.40, 10 cm (1) black, (1) red (1) Tweezer test lead set- 4 mm P, w/PVC pouch - TL 130B General Purpose DMM Kit If you need only one basic accessory kit for your meter, this is the one. Attach probes or clips to the sheath plug to complete your test. Soft, flexible silicone leads make movement easy. Kit is voltage and current rated for electronic or electrical applications. ■■ IEC61010-2-031 compliant ■■ Silicone lead wire length (1.5 m) ■■ Tri-fold velcro pouch Description TL 130B 4 mm straight to right-angle silicone leads, 1.5 m 1000 V CAT III 12 A Probe bodies w/Ø2mm tip 1000 V CAT III 36 A Alligator style clips 1000 V CAT III 20 A Alligator clips 300 V CAT I 3A CP3 DC/AC Current Clamp ■■ Converts any DMM to a current clamp ■■ Measures current without disconnecting circuit under test ■■ Measures to 400 A DC or AC ■■ Outputs 1 mV per Amp, operates on 2 V range of any DMM Specifications CP 3 (Accuracy specified at 18° to 28°C) Current range TL37 Red and Black CAT III 1000 V (CAT IV 600 V) Test Leads Right angled sheathed banana replacement 10A test leads for digital multimeters. With tip cap on, they are rated to CAT III 1000V, CAT IV 600V, with tip cap off, they are CAT II 1000V. 2 A to 400 A, DC or AC Frequency Response (AC) 50 Hz - 400 Hz Accuracy ±(2% reading + 2 A) Input resistance 10 kΩ min. Maximum conductor size 30 mm Power requirement 9 V battery, NEDA 1604 Battery life 100 hr typical Operating temperature 0° to 40°C,
TL 5A 价格&库存
很抱歉,暂时无法提供与“TL 5A”相匹配的价格&库存,您可以联系我们找货
TL 5A
    • 1+119.67582
    库存:244
    TL 5A
    • 1+132.125631+16.56881
    库存:304
