H100
H100
    GLOBALSPECIALTIES
    WIDE RANGE LIGHT METER
H100 数据手册
INSTRUCTION MANUAL Models: H100 Light Meter Table of Content 1. Product Introduction ………………………………………… 3 1-1 Features ………………….………………………… 3 1-2 Applications ……………………………………...… 3 2. Safety Information …………………………………………… 4 2-1 Cautions ………………………………..………..… 4 2-2 Safety Symbols ………………………..…..……… 4 3. Specifications ……………………………………...…………. 5 4. Operation Instructions ……………………………………… 4-1 Unit Diagram ……………………………………… 4-2 Measuring Procedure ……………………….…... 4-3 Zero Adjust ………………………..……………… 4-4 Data Hold ……………………………….………… 4-5 Peak Hold ……………………....………………… 4-6 Data Record ……………………………………… 7 7 8 8 8 8 9 5. Auto Power Off Disable …………………………………… 9 6. RS232 PC Serial Interface Information …………………. 10 7. Battery Replacement ..…………………………………….. 11 8. Service Information …………………………………..……. 12 9. Warranty Information ………………………………………. 13 To see all available accessories and downloadable software, please visit www.anaheimscientific.com 1. Product Introduction 1-1 Features Two year warranty Large LCD display with bar graph Wide measurement ranges: 40.00/400.0/4,000/40,000/400,000lux Display resolution: 0.04lux to 100lux, 0.01ft-cd to 10ft-cd lux or foot-candle unit selection 4 light type select (Tungsten, Fluorescent, Sodium or Mercury) Sensor meet C.I.E. spectrum, 2 filters Data hold, Record (max., min.) DC 1.5V battery ( UM-4, AAA) x 6  Longer battery life compared to 9V          1-2 Applications      Science Experiments Photography Manufacturing Agriculture Artistry 3 2. Safety Information Read the following safety information carefully before attempting to operate or service the meter. Only qualified personnel should perform repairs or servicing not covered in this manual. 2-1 Cautions!  DO NOT submerge the products mentioned in this manual in water or any other types of liquids.  This product is not designed for use in medical applications. The product can only be used to measure body temperature simply for reference. 2-2 Safety Symbols Dangerous, refer to this manual before using the meter. Conforms to requirements of European Union and European Fare Trade Association (EFTA). Battery level is low. Don’t dispose this product as unsorted municipal waste. This instrument conforms to the following standards: EN61326: Electrical equipment for measurement, control and laboratory use. IEC61000-4-2: Electrostatic discharge immunity test. IEC61000-4-3: Radiated, radio-frequency, electromagnetic field immunity test. IEC61000-4-8: Power frequency magnetic field immunity test. 4 3. Specifications Display Measurement Ranges Unit of Measurement Measurable Lighting Sources Sensor Display values: Unit lux fc (foot-candle) Accuracies: lux fc (foot-candle) Zero Adjust Peak Hold Data Hold Memory Power Off Over and Under Range Indicator 5 Digit LCD with bar graph indicator 40.00/400.0/4,000/40,000/400,000lux lux or Foot-Candle (fc) Tungsten, Fluorescent, Sodium or Mercury Lamps Photo diode & color correction filter, spectrum meets C.I.E. Cosine correction factor standards Range 40 400 4,000 40,000 400,000 4 40 400 4,000 40,000 Range 40 400 4,000 40,000 400,000 4 40 400 4,000 40,000 In Range Display 0 to 40.00 Lux 36.0 to 400.0 Lux 360 to 4,000 Lux 3,600 to 40,000 Lux 10,000 to 400,000 Lux 0 to 3.720 Fc 3.35 to 37.20 Fc 33.5 to 372.0 Fc 335 to 3,720 Fc 930 to 37,200 Fc Resolution 0.01 Lux 0. 1 Lux 1 Lux 10 Lux 100 Lux 0.001 Fc 0.01 Fc 0. 1 Fc 1 Fc 10 Fc Accuracy** ± ( 3% rdg + 0.5 % F.S. ) < 100,000 Lux : ± ( 3% rdg + 0.5 % F.S. )* ± ( 3% rdg + 0.5 % F.S. ) < 9,300 Fc : ± ( 3% rdg + 0.5 % F.S. )* 40.00lux range only Displays peak value Display freeze Saves MAX. or MIN values with recall Auto or manual control Over range indicator: " _ _ _ _ " (top of the display) Under range indicator: "_ _ _ _" (bottom of the display) 5 Data Output Operating Environment Power Supply RS-232 Serial data output 32° to 122°F (0° to 50°C),
很抱歉,暂时无法提供与“H100”相匹配的价格&库存,您可以联系我们找货
