RFM3004
RFM3004
    B&K
    RFP3000 系列 RF 测试仪
RFM3004 数据手册
Data Sheet RF Power Meter RFM3000 Series GPIB model option LAN Features and benefits n Compatible with RFP3000 Series USB RF Peak Power Sensors n Capture/display/analyze peak and average power The RFM3000 Series of meters work in combination with B&K Precision's RFP3000 Series of USB RF Peak Power Sensors to extend their capabilities and eliminate the need for a remote computer. This benchtop solution supports capturing, displaying, and analyzing peak and average RF power in both the time and statistical domains through an intuitive, multi-touch touchscreen display. n Independent or synchronous multi-channel measurements (up to 4 channels) n Trigger n Test Two on-screen markers can be dragged over a waveform for greater measurement details. A selection of useful trigger options and channel synchronization settings provide the perfect tool set for working with multiple channel measurements. synchronization source for sensor verification n Display 16 common power measurements n Ethernet:10/100/1000 n Supports Model RFM3002 RFM3004 RFM3002-GPIB RFM3004-GPIB Configuration 2 Channels 4 Channels 2 Channels with GPIB 4 Channels with GPIB n HDMI BaseT; HiSLIP SCPI-1999.0 output for mirror display n Sensors can be used as standalone instruments Measurement modes Measurement modes can be quickly changed form Continuous to Pulse or Statistical modes with one touch. Continuous mode For simple, intuitive measurements of repetitive waveforms, the RFM3000 Series Continuous Mode of operation provides a numeric display of average, maximum and minimum signal powers. Technical data subject to change © B&K Precision Corp. 2021 Pulsed mode Analysis of fast-rising single pulses or pulses with short pulse repetition intervals (PRIs) requires an instrument with sophisticated trigger and data acquisition capability. Within Pulsed Mode, more than 16 pulse parameters can be measured. bkprecision.com Statistical mode Complementary Cumulative Distribution Function or CCDF plot shows the rate of occurrence of a specific crest factor for signals, such as those used in 5G, 4G/LTE, and Wi-Fi applications. RF Power Meter RFM3000 Series Addressing RF communications and radar measurement challenges Wi-Fi and wireless communication signal analysis Characterization and compliance testing of Wi-Fi and LTE chipsets and devices involves significant challenges for design and test engineers. With multiple-input, multiple-output (MIMO) architectures and channel bandwidths up to 160 MHz,testing is complex, especially when measuring RF power per channel and time alignment between channels. The RFM3000 Series enables packet power measurements to be performed independently on multiple synchronous or asynchronous transmit chains with a common timebase shared among sensors. Between marker measurements Use markers to define a portion of the waveform on which to make measurements. “Between Marker” measurements are ideal for monitoring specific portions of a packet over long intervals. 1 2 m S Peak-to-average power By comparing the peak-to-average power ratio, or crest factor (CF), of input and output signals of an RF transmission chain, engineers can assess circuit linearity. Additional insight can be provided with the RFM3000 Series statistical mode Complementary Cumulative Distribution Function (CCDF) plot displaying the rate of occurrence of a specific CF. As an amplifier output compresses, the CF will reduce and the CCDF plot will move left. Crest factor Indication of amplifier output compression 2 bkprecision.com RF Power Meter RFM3000 Series Addressing radar measurement challenges Secondary Surveillance Radar (SSR) Design, verification, troubleshooting and maintenance of secondary surveillance radar (e.g. IFF-based radar) has never been more demanding. Secondary Surveillance Radar (SSR) Proper design and operation of SSR systems is critical to the safety and security of aviation. The RFM3000 Series can be used to easily and accurately capture SSR waveforms. Markers enable measurements on specific portions of the waveform. Rise time and resolution Industry-leading rise time (< 3 ns) enables characterization of the most demanding radar signals. Utilize the superior 100 ps time resolution to zoom and uncover signal characteristics that might otherwise be missed. Pulse measurements Users can take advantage of the RFM3000 Series automated pulse measurement feature to measure and calculate 16 common power and timing parameters and display the parameters of interest: rise-time, fall time, pulse width, off-time, period, pulse repetition frequency, duty cycle, pulse peak, pulse overshoot, pulse average, waveform average, top level power, droop, bottom level power, edge delay, and pulse edge skew between channels. 3 bkprecision.com RF Power Meter RFM3000 Series Front panel Sync port Sync ports to source or receive triggers for timing and synchronization 5-inch WVGA touch display Multi-touch display with intuitive user interface Intuitive control One touch to quickly access presets and favorite functions USB host Connect up to 4 USB sensors for multi-channel measurements RF out Test source to verify sensor operation Measurement modes Touch to select Continues, Pulse or Statistical mode, and select between Graph and Text Rear panel Optional GPIB interface External trigger input HDMI interface HDMI output for remote front panel display 4 Auxiliary sensor and Sync inputs LAN interface LAN connectivity to ethernet bkprecision.com RF Power Meter RFM3000 Series Specifications RFM3000 Series Channels 2 or 4 channels Display Display Size 5-inch WVGA multi-touch display with intuitive graphical user interface Graph (power vs time) - Numeric (numeric data) - Statistical measurements - CCDF Display Modes Marker Measurements (in Automatic measurements (pulse, statistical, and marker measurements) Graph view) Markers (vertical cursors) Settable in time relative to the trigger position Marker Independently Avg, Min and Max Power at a specified time offset Interval Between Markers Avg, Min and Max Power over the defined interval Pair of Markers Ratio of power values at each marker Pulse Mode Automatic Measurements Pulse rise-time - Pulse fall-time - Pulse width - Pulse off-time - Pulse period - Pulse repetition frequency Pulse duty cycle - Waveform average - Pulse peak - Pulse average - Pulse overshoot - Pulse droop Top level power - Bottom level power - Edge delay - Pulse edge skew between channels Statistical Mode Automatic Measurements Peak power - Average power - Minimum power - Peak to average ratio - Dynamic range Percent at cursor - Crest factor at cursor - Crest factor at various percents Trigger Synchronization Internal trig distribution Mode Normal, Auto, Auto Pk-to-Pk, Free Run Source Any connected RTP Series sensor (via SMB’s) or rear panel external trigger Internal Level Range -40 dBm to +20 dBm (sensor dependent) External Level Range ± 5 volts or TTL Slope + or - Hold-off, Min Pulse Width, Max Trigger Rate Sensor and timebase dependent Time Base 5 Time Base Resolution, Range, Accuracy Sensor dependent Time Base Display Sweeping or roll mode Trigger Delay Range Sensor dependent Trigger Delay Resolution 0.02 divisions bkprecision.com RF Power Meter RFM3000 Series Specifications (cont.) Note: All specifications apply to the unit after a temperature stabilization time of 15 minutes over an ambient temperature range of 23 °C ± 5 °C. Specifications are valid for single unit operation only. RFM3000 Series Inputs/Outputs (front panel) USB with SMB trigger port Test Source (optional rear panel placement) 4 ports USB2.0: Type A receptacle, 4 ports SMB(f) 50 MHz 1.00 mW (0 dBm) ± 2.3% (0.1 dB) typical Inputs/Outputs (rear panel) LAN 10/100 Ethernet: RJ-45 modular socket USB with SMB trigger port 4 ports USB2.0: Type A receptacle, 4 ports SMB(f) User Selectable Status, trigger, or voltage output Range -10 V to +10 V (Analog bipolar) Accuracy ±200 mV (±100 mV typical) Linearity 0.4% typical 0 to 10 V (Analog unipolar) Multi I/O Connector 0 or 5 V (Logic) Remote Control Command Set SCPI-1999.0 LAN Ethernet: 10/100/1000 BaseT; HiSLIP GPIB Optional Regulatory Compliance CE compliance with the following European Union directives Low Voltage Directive: 2014/35/EU, RoHS Directive: 2011/65/EU, WEEE Directive 2012/19/EU, Electromagnetic Compatibility Directive (EMC): 2014/30/EU and Environmental: MIL-PRF-28800F, Class 3 Power Requirements 90 to 260 VAC, 47 to 60 Hz; 90 to 135 VAC, 47 to 400 Hz; 30 W (35 VA) max General 6 Operating Temperature 0 to 50 °C (32 to 122 °F) Storage Temperature -40 to +70 °C (-40 to 158 °F) Humidity 95% maximum, non-condensing Altitude Operation up to 15,000 feet (4600 m) Shock Withstands ± 30 G, 11 ms impulse in X, Y, and Z axes Vibration Withstands 2 G sine, 5 to 55 Hz; 2 G random, 5 to 500 Hz Warranty 3 Years Dimensions (excluding connectors) (H x W x D) 3.5" x 8.3" x 11.2" (89 x 211 x 284 mm) Weight 4.8 lbs (2.2 kg) Included Accessories Power cord Optional Accessories RKRFM Full-width 19” Rack Mount Kit (includes handles & hardware for mounting one or two meters) bkprecision.com RF Power Meter RFM3000 Series Specifications Ordering Information RFM3000 Series RFM3002 RFM3004 RFM3002-GPIB RFM3004-GPIB RF Power Meter with 2 active channels RF Power Meter with 4 active channels RF Power Meter with 2 active channels and GPIB RF Power Meter with 4 active channels and GPIB High-performance USB power sensors The RFM3000 Series Power Meter utilizes RFP power sensors with industry leading performance and capabilities. All RFP sensors incorporate Real-Time Power Processing technology, which virtually eliminates gaps in measurement suffered by other power sensors and enables industry leading measurement speeds. In terms of RF performance, the RFP3000 Series Real-Time Peak Power Sensors are the fastest responding sensors with 3 ns rise times and 195 MHz of video bandwidth. RFP3000 Series real-time peak power sensors n 50 MHz to 6 GHz, 18 GHz and 40 GHz peak power RF sensors n Up to 195 MHz video bandwidth with 3 ns rise time n Crest n 10 factor and statistical measurements (e.g., CCDF) GS/s effective sample rate n Real-Time Power Processing technology with virtually zero measurement latency n 100,000 n 80 measurements per second dB dynamic range n Synchronized 7 multi-channel measurements v060821 For more information on the RF sensors see the RFP3000 Series data sheet bkprecision.com About B&K Precision For more than 60 years, B&K Precision has provided reliable and value-priced test and measurement instruments worldwide. Our headquarters in Yorba Linda, California houses our administrative and executive functions as well as sales and marketing, design, service, and repair. Our European customers are most familiar with B&K through our French subsidiary, Sefram. Engineers in Asia know us through our B+K Precision Taiwan operation. Our B&K Brasil office supports our expanding customer base in Brazil and other South American countries. The independent service center in Singapore services customers in Singapore, Malaysia, Vietnam, and Indonesia. Sefram St. Etienne, France B&K Headquarters Yorba Linda, California, USA B&K Taiwan Taipei, Taiwan B&K Brasil Sao Paolo, Brazil B&K Precision group member Independent service center Quality Management System B&K Precision Corporation is an ISO9001 registered company employing traceable quality management practices for all processes including product development, service, and calibration. ISO9001:2015 Certification body NSF-ISR Certificate number 6Z241-IS8 Dynamics Circuit Singapore Service center location Video Library View product overviews, demonstrations, and application videos in English, Spanish and Portuguese. http://www.youtube.com/user/BKPrecisionVideos Product Applications Browse all of our supported product and mobile applications. http://bkprecision.com/product-applications
RFM3004 价格&库存
很抱歉,暂时无法提供与“RFM3004”相匹配的价格&库存,您可以联系我们找货
RFM3004
