Data sheet
BMA255
Data sheet
BMA255
Digital, triaxial acceleration sensor
Page 1
Bosch Sensortec
BMA255: Data sheet
Document revision
1.2
Document release date
01 August 2014
Document number
BST-BMA255-DS004-05
Technical reference code(s)
0 273 141 171
Notes
Data in this document are subject to change without notice.
Product photos and pictures are for illustration purposes only and
may differ from the real product’s appearance.
Not intended for publishing
BST-BMA255-DS004-05 | Revision 1.2 | August 2014
Bosch Sensortec
© Bosch Sensortec GmbH reserves all rights even in the event of industrial property rights. We reserve all rights of disposal such as copying and passing on to
third parties. BOSCH and the symbol are registered trademarks of Robert Bosch GmbH, Germany.
Note: Specifications within this document are subject to change without notice.
BMA255
Data sheet
Page 2
BMA255
12 BIT, DIGITAL, TRIAXIAL ACCELERATION SENSOR WITH INTELLIGENT
ON-CHIP MOTION-TRIGGERED INTERRUPT CONTROLLER
Key features
Ultra-Small package
Digital interface
Programmable functionality
On-chip FIFO
On-chip interrupt controller
Ultra-low power
Temperature sensor
RoHS compliant, halogen-free
LGA package (12 pins), footprint 2mm x 2mm,
height 0.95mm
SPI (4-wire, 3-wire), I²C, 2 interrupt pins
VDDIO voltage range: 1.2V to 3.6V
Acceleration ranges ±2g/±4g/±8g/±16g
Low-pass filter bandwidths 1kHz - 0V) or vice versa.
When the VDDIO supply is switched off, all interface pins (CSB, SDI, SCK, PS) must be kept
close to GNDIO potential.
The device contains a power-on reset (POR) generator. It resets the logic part and the register
values after powering-on VDD and VDDIO. Please note, that all application specific settings which
are not equal to the default settings (refer to 6.2 register map), must be re-set to its designated
values after POR.
There are no constraints on the switching sequence of both supply voltages. In case the I²C
interface shall be used, a direct electrical connection between VDDIO supply and the PS pin is
needed in order to ensure reliable protocol selection. For SPI interface mode the PS pin must
be directly connected to GNDIO.
Bosch Sensortec
BMA255
Data sheet
Page 14
4.2 Power modes
The BMA255 has six different power modes. Besides normal mode, which represents the fully
operational state of the device, there are five energy saving modes: deep-suspend mode,
suspend mode, standby mode, low-power mode 1 and low-power mode 2.
The possible transitions between the power modes are illustrated in figure 2:
DEEPSUSPEND
Mode
NORMAL
Mode
SUSPEND
Mode
Low Power
Mode 1
STANDBY
Mode
Low Power
Mode 2
Figure 2: Power mode transition diagram
After power-up BMA255 is in normal mode so that all parts of the device are held powered-up
and data acquisition is performed continuously.
In deep-suspend mode the device reaches the lowest possible power consumption. Only the
interface section is kept alive. No data acquisition is performed and the content of the
configuration registers is lost. Deep suspend mode is entered (left) by writing ‘1’ (‘0’) to the
(0x11) deep_suspend bit while (0x11) suspend bit is set to ‘0’. The I2C watchdog timer remains
functional. The (0x11) deep_ suspend bit, the (0x34) spi3 bit, (0x34) i2c_wdt_en bit and the
(0x34) i2c_wdt_sel bit are functional in deep-suspend mode. Equally the interrupt level and
driver configuration registers (0x20) int1_lvl, (0x20) int1_od, (0x20) int2_lvl, and (0x20) int2_od
are accessible. Still it is possible to enter normal mode by performing a softreset as described in
chapter 4.8. Please note, that all application specific settings which are not equal to the default
settings (refer to 6.2 register map), must be re-set to its designated values after leaving deepsuspend mode.
Bosch Sensortec
BMA255
Data sheet
Page 15
In suspend mode the whole analog part is powered down. No data acquisition is performed.
While in suspend mode the latest acceleration data and the content of all configuration registers
are kept. Writing to and reading from registers is supported except from the (0x3E)
fifo_config_1, (0x30) fifo_config_0 and (0x3F) fifo_data register. It is possible to enter normal
mode by performing a softreset as described in chapter 4.8.
Suspend mode is entered (left) by writing ´1´ (´0´) to the (0x11) suspend bit after bit (0x12)
lowpower_mode has been set to ‘0’. Although write access to registers is supported at the full
interface clock speed (SCL or SCK), a waiting period must be inserted between two
consecutive write cycles (please refer also to section 7.2.1).
In standby mode the analog part is powered down, while the digital part remains largely
operational. No data acquisition is performed. Reading and writing registers is supported
without any restrictions. The latest acceleration data and the content of all configuration
registers are kept. Standby mode is entered (left) by writing ´1´ (´0´) to the (0x11) suspend bit
after bit (0x12) lowpower_mode has been set to ‘1’. It is also possible to enter normal mode by
In low-power mode 1, the device is periodically switching between a sleep phase and a wakeup phase. The wake-up phase essentially corresponds to operation in normal mode with
complete power-up of the circuitry. The sleep phase essentially corresponds to operation in
suspend mode. Low-power mode is entered (left) by writing ´1´ (´0´) to the (0x11) lowpower_en
bit with bit (0x12) lowpower_mode set to ‘0’. Read access to registers is possible except from
the (0x3F) fifo_data register. However, unless the register access is synchronised with the
wake-up phase, the restrictions of the suspend mode apply.
Low-power mode 2 is very similar to low-power mode 1, but register access is possible at any
time without restrictions. It consumes more power than low-power mode 1. In low-power mode
2 the device is periodically switching between a sleep phase and a wake-up phase. The wakeup phase essentially corresponds to operation in normal mode with complete power-up of the
circuitry. The sleep phase essentially corresponds to operation in standby mode. Low-power
mode is entered (left) by writing ´1´ (´0´) to the (0x11) lowpower_en bit with bit (0x12)
lowpower_mode set to ‘1’.
The timing behaviour of the low-power modes 1 and 2 depends on the setting of the (0x12)
sleeptimer_mode bit. When (0x12) sleeptimer_mode is set to ‘0’, the event-driven time-base
mode (EDT) is selected. In EDT the duration of the wake-up phase depends on the number of
samples required by the enabled interrupt engines. If an interrupt is detected, the device stays
in the wake-up phase as long as the interrupt condition endures (non-latched interrupt), or until
the latch time expires (temporary interrupt), or until the interrupt is reset (latched interrupt). If no
interrupt is detected, the device enters the sleep phase immediately after the required number
of acceleration samples have been taken and an active interface access cycle has ended. The
EDT mode is recommended for power-critical applications which do not use the FIFO. Also,
EDT mode is compatible with legacy BST sensors. Figure 3 shows the timing diagram for lowpower modes 1 and 2 when EDT is selected.
Bosch Sensortec
BMA255
Data sheet
Settle
Sample
Sample
Sample
Settle
Sample
Settle
Sample
Sample
Active phase
Sample
tACTIVE
State
Sleep phase
Page 16
tSLEEP
tSLEEP
t
Figure 3: Timing Diagram for low-power mode 1/2, EDT
When (0x12) sleeptimer_mode is set to ‘1’, the equidistant-sampling mode (EST) is selected.
The use of the EST mode is recommended when the FIFO is used since it ensures that
equidistant samples are sampled into the FIFO regardless of whether the active phase is
extended by active interrupt engines or interface activity. In EST mode the sleep time tSLEEP is
defined as shown in Figure 4. The FIFO sampling time tSAMPLE is the sum of the sleep time tSLEEP
and the sensor data sampling time tSSMP. Since interrupt engines can extend the active phase to
exceed the sleep time tSLEEP, equidistant sampling is only guaranteed if the bandwidth has been
chosen such that 1/(2 * bw) = n * tSLEEP where n is an integer. If this condition is infringed,
equidistant sampling is not possible. Once the sleep time has elapsed the device will store the
next available sample in the FIFO. This set-up condition is not recommended as it may result in
timing jitter.
Sampled into FIFO
tSLEEP
tSSMP
tSAMPLE
tSLEEP
Settle
Sample
Settle
Sample
Sample
Sample
Settle
Sample
Sleep phase
Settle
Sample
Sample
Active phase
Sample
State
tSLEEP
tSAMPLE
tSAMPLE
t
Figure 4: Timing Diagram for low-power mode 1/2, EST
Bosch Sensortec
BMA255
Data sheet
Page 17
The sleep time for lower-power mode 1 and 2 is set by the (0x11) sleep_dur bits as shown in
the following table:
Table 3: Sleep phase duration settings
(0x11)
sleep_dur
0000b
0001b
0010b
0011b
0100b
0101b
0110b
0111b
1000b
1001b
1010b
1011b
1100b
1101b
1110b
1111b
Sleep Phase
Duration
tsleep
0.5ms
0.5ms
0.5ms
0.5ms
0.5ms
0.5ms
1ms
2ms
4ms
6ms
10ms
25ms
50ms
100ms
500ms
1s
The current consumption of the BMA255 in low-power mode 1 (IDDlp1) and low-power mode 2
(IDDlp2) can be estimated with the following formulae:
I DDlp1
I DDlp 2
t sleep I DDsum t active I DD
t sleep t active
t sleep I DDsbm t active I DD
t sleep t active
When estimating the length of the wake-up phase tactive, the corresponding typical wake-up time,
tw,up1 or tw,up2 and tut (given in Table 4) have to be considered:
If bandwidth is >=31.25 Hz:
tactive = tut + tw,up1 - 0.9 ms (or tactive = tut + tw,up2 - 0.9 ms)
else:
tactive = 4 tut + tw,up1 - 0.9 ms (or tactive = 4 tut + tw,up2 - 0.9 ms)
During the wake-up phase all analog modules are held powered-up, while during the sleep
phase most analog modules are powered down. Consequently, a wake-up time of at least tw,up1
(tw,up2) is needed to settle the analog modules so that reliable acceleration data are generated.
Bosch Sensortec
BMA255
Data sheet
Page 18
4.3 Sensor data
4.3.1 Acceleration data
The width of acceleration data is 12 bits given in two´s complement representation. The 12 bits
for each axis are split into an MSB upper part (one byte containing bits 11 to 4) and an LSB
lower part (one byte containing bits 3 to 0 of acceleration and a (0x02, 0x04, 0x06) new_data
flag). Reading the acceleration data registers shall always start with the LSB part. In order to
ensure the integrity of the acceleration data, the content of an MSB register is locked by reading
the corresponding LSB register (shadowing procedure). When shadowing is enabled, the MSB
must always be read in order to remove the data lock. The shadowing procedure can be
disabled (enabled) by writing ´1´ (´0´) to the bit shadow_dis. With shadowing disabled, the
content of both MSB and LSB registers is updated by a new value immediately. Unused bits of
the LSB registers may have any value and should be ignored. The (0x02, 0x04, 0x06)
new_data flag of each LSB register is set if the data registers have been updated. The flag is
reset if either the corresponding MSB or LSB part is read.
Two different streams of acceleration data are available, unfiltered and filtered. The unfiltered
data is sampled with 2kHz. The sampling rate of the filtered data depends on the selected filter
bandwidth and is always twice the selected bandwidth (BW = ODR/2). Which kind of data is
stored in the acceleration data registers depends on bit (0x13) data_high_bw. If (0x13)
data_high_bw is ´0´ (´1´), then filtered (unfiltered) data is stored in the registers. Both data
streams are offset-compensated.
The bandwidth of filtered acceleration data is determined by setting the (0x10) bw bit as
followed:
Table 4: Bandwidth configuration
bw
Bandwidth
00xxx
01000
01001
01010
01011
01100
01101
01110
01111
1xxxx
7.81Hz
15.63Hz
31.25Hz
62.5Hz
125Hz
250Hz
500Hz
1000Hz
Update Time
tut
64ms
32ms
16ms
8ms
4ms
2ms
1ms
0.5ms
*) Note: Settings 00xxx result in a bandwidth of 7.81 Hz; settings 1xxxx result in a bandwidth of
1000 Hz. It is recommended to actively set an application specific and an appropriate bandwidth
and to use the range from ´01000b´ to ´01111b´ only in order to be compatible with future
products.
Bosch Sensortec
BMA255
Data sheet
Page 19
The BMA255 supports four different acceleration measurement ranges. A measurement range
is selected by setting the (0x0F) range bits as follows:
Table 5: Range selection
Range
0011
0101
1000
1100
others
Acceleration
measurement
range
±2g
±4g
±8g
±16g
reserved
Resolution
0.98mg/LSB
1.95mg/LSB
3.91mg/LSB
7.81mg/LSB
4.3.2 Temperature sensor
The width of temperature data is 8 bits given in two´s complement representation. Temperature
values are available in the (0x08) temp register.
The slope of the temperature sensor is 0.5K/LSB, its center temperature is 23°C [(0x08) temp =
0x00].
Bosch Sensortec
BMA255
Data sheet
Page 20
4.4 Self-test
This feature permits to check the sensor functionality by applying electrostatic forces to the
sensor core instead of external accelerations. By actually deflecting the seismic mass, the
entire signal path of the sensor can be tested. Activating the self-test results in a static offset of
the acceleration data; any external acceleration or gravitational force applied to the sensor
during active self-test will be observed in the output as a superposition of both acceleration and
self-test signal.
Before the self-test is enabled the g-range should be set to 4 g. The self-test is activated
individually for each axis by writing the proper value to the (0x32) self_test_axis bits (´01b´ for xaxis, ´10b´ for y-axis, ´11b´ for z-axis, ´00b´ to deactivate self-test). It is possible to control the
direction of the deflection through bit (0x32) self_test_sign. The excitation occurs in negative
(positive) direction if (0x32) self_test_sign = ´0b´ (´1b´). After the self-test is enabled, the user
should wait 50ms before interpreting the acceleration data.
In order to ensure a proper interpretation of the self-test signal it is recommended to perform the
self-test for both (positive and negative) directions and then to calculate the difference of the
resulting acceleration values. Table 6 shows the minimum differences for each axis. The
actually measured signal differences can be significantly larger.
Table 6: Self-test difference values
resulting minimum
difference signal
x-axis signal
y-axis signal
z-axis signal
800 mg
800 mg
400 mg
It is recommended to perform a reset of the device after a self-test has been performed. If the
reset cannot be performed, the following sequence must be kept to prevent unwanted interrupt
generation: disable interrupts, change parameters of interrupts, wait for at least 50ms, enable
desired interrupts.
Bosch Sensortec
BMA255
Data sheet
Page 21
4.5 Offset compensation
Offsets in measured signals can have several causes but they are always unwanted and
disturbing in many cases. Therefore, the BMA255 offers an advanced set of four digital offset
compensation methods which are closely matched to each other. These are slow, fast, and
manual compensation as well as inline calibration.
The compensation is performed with unfiltered data, and is then applied to both, unfiltered and
filtered data. If necessary the result of this computation is saturated to prevent any overflow
errors (the smallest or biggest possible value is set, depending on the sign). However, the
registers used to read and write compensation values have a width of 8 bits.
An overview of the offset compensation principle is given in figure 5:
I2C/SPI/NVM mapping
12 bit acceleration data range
+-16g
+-8g
+-4g
8g
Sign
4g
4g
Sign
2g
2g
2g
Sign
1g
1g
1g
1g
500mg
500mg
500mg
500mg
500mg
250mg
250mg
250mg
250mg
250mg
125mg
125mg
125mg
125mg
62.5mg
62.5mg
62.5mg
62.5mg
31.2mg
31.2mg
31.2mg
31.2mg
31.2mg
15.6mg
15.6mg
15.6mg
15.6mg
15.6mg
7.8mg
7.8mg
7.8mg
7.8mg
3.9mg
3.9mg
MSB
125mg
Read/
Write
62.5mg
LSB
Sign
Sign
+-2g
MSB
MSB
1.9mg
LSB
MSB
LSB
MSB
LSB
LSB
7.8mg
3.9mg
1.9mg
0.97mg
Figure 5: Principle of offset compensation
Bosch Sensortec
BMA255
Data sheet
Page 22
The public offset compensation registers (0x38) offset_x, (0x39) offset_y, (0x3A) offset_z are
images of the corresponding registers in the NVM. With each image update (see section 4.6
Non-volatile memory for details) the contents of the NVM registers are written to the public
registers. The public registers can be over-written by the user at any time. After changing the
contents of the public registers by either an image update or manually, all 8bit values are
extended to 12bit values for internal computation. In the opposite direction, if an internally
computed value changes it is converted to an 8bit value and stored in the public register.
Depending on the selected g-range the conversion from 12bit to 8bit values can result in a loss
of accuracy of one to several LSB. This is shown in figure 5.
In case an internally computed compensation value is too small or too large to fit into the
corresponding register, it is saturated in order to prevent an overflow error.
By writing ´1´ to the (0x36) offset_reset bit, all offset compensation registers are reset to zero.
Bosch Sensortec
BMA255
Data sheet
Page 23
4.5.1 Slow compensation
st
Slow compensation is based on a 1 order high-pass filter, which continuously drives the
average value of the output data stream of each axis to zero. The bandwidth of the high-pass
filter is configured with bit (0x37) cut_off according to Table 7.
Table 7: Compensation period settings
(0x37)
cut_off
high-pass filter
bandwidth
Example
bw = 500 Hz
0b
1b
*bw: please insert selected decimal data bandwidth value [Hz] from table 4
The slow compensation can be enabled (disabled) for each axis independently by setting the
bits (0x36) hp_x_en, hp_y_en, hp_z_en to ´1´ (´0´), respectively.
Slow compensation should not be used in combination with low-power mode. In low-power
mode the conditions (availability of necessary data) for proper function of slow compensation
are not fulfilled.
4.5.2 Fast compensation
Fast compensation is a one-shot process by which the compensation value is set in such a way
that when added to the raw acceleration, the resulting acceleration value of each axis
approaches the target value. This is best suited for “end-of-line trimming” with the customer’s
device positioned in a well-defined orientation. For fast compensation the g-range has to be
switched to 2g.
The algorithm in detail: An average of 16 consecutive acceleration values is computed and the
difference between target value and computed value is written to (0x38, 0x39, 0x3A)
offset_filt_x/y/z. The public registers (0x38, 0x39, 0x3A) offset_filt_x/y/z are updated with the
contents of the internal registers (using saturation if necessary) and can be read by the user.
Fast compensation is triggered for each axis individually by setting the (0x36) cal_trigger bits as
shown in Table 8:
Table 8: Fast compensation axis selection
(0x36)
cal_trigger
00b
01b
10b
11b
Selected Axis
none
x
y
z
Bosch Sensortec
BMA255
Data sheet
Page 24
Register (0x36) cal_trigger is a write-only register. Once triggered, the status of the fast
correction process is reflected in the status bit (0x36) cal_rdy. Bit (0x36) cal_rdy is ‘0’ while the
correction is in progress. Otherwise it is ‘1’. Bit (0x36) cal_rdy is ´0´ when (0x36) cal_trigger is
not ´00´.
For the fast offset compensation, the compensation target can be chosen by setting the bits
(0x37) offset_target_x, (0x37) offset_target_y, and (0x37) offset_target_z according to Table 9:
Table 9: Offset target settings
(0x37)
offset_target_x/y/z
00b
01b
10b
11b
Target value
0g
+1g
-1g
0g
Fast compensation should not be used in combination with any of the low-power modes. In lowpower mode the conditions (availability of necessary data) for proper function of fast
compensation are not fulfilled.
4.5.3 Manual compensation
The contents of the public compensation registers (0x38, 0x39, 0x3A) offset_filt_x/y/z can be
set manually via the digital interface. It is recommended to write into these registers directly
after a new data interrupt has occurred in order not to disturb running offset computations.
Writing to the offset compensation registers is not allowed while the fast compensation
procedure is running.
4.5.4 Inline calibration
For certain applications, it is often desirable to calibrate the offset once and to store the
compensation values permanently. This can be achieved by using one of the aforementioned
offset compensation methods to determine the proper compensation values and then storing
these values permanently in the NVM. See section 4.6 Non-volatile memory for details of the
storing procedure.
Each time the device is reset, the compensation values are loaded from the non-volatile
memory into the image registers and used for offset compensation until they are possibly
overwritten using one of the other compensation methods.
Bosch Sensortec
BMA255
Data sheet
Page 25
The entire memory of the BMA255 consists of three different kinds of registers: hard-wired,
volatile, and non-volatile. Part of it can be both read and written by the user. Access to nonvolatile memory is only possible through (volatile) image registers.
Altogether, there are eight registers (octets) with NVM backup which are accessible by the user.
The addresses of the image registers range from 0x38 to 0x3C. While the addresses up to
0x3A are used for offset compensation (see 4.4 Offset Compensation), addresses 0x3B and
0x3C are general purpose registers not linked to any sensor-specific functionality.
The content of the NVM is loaded to the image registers after a reset (either POR or softreset)
or after a user request which is performed by writing ´1´ to the write-only bit (0x33) nvm_load.
As long as the image update is in progress, bit (0x33) nvm_rdy is ´0´, otherwise it is ´1´.
The image registers can be read and written like any other register.
Writing to the NVM is a three-step procedure:
1. Write the new contents to the image registers.
2. Write ´1´ to bit (0x33) nvm_prog_mode in order to unlock the NVM.
3. Write ´1´ to bit (0x33) nvm_prog_trig and keep ´1´ in bit (0x33) nvm_prog_mode in order
to trigger the write process.
Writing to the NVM always renews the entire NVM contents. It is possible to check the write
status by reading bit (0x33) nvm_rdy. While (0x33) nvm_rdy = ´0´, the write process is still in
progress; if (0x33) nvm_rdy = ´1´, then writing is completed. As long as the write process is
ongoing, no change of power mode and image registers is allowed. Also, the NVM write cycle
must not be initiated while image registers are updated, in low-power mode, and in suspend
mode.
Please note that the number of permitted NVM write-cycles is limited as specified in Table 1.
The number of remaining write-cycles can be obtained by reading bits (0x33) nvm_remain.
Bosch Sensortec
BMA255
Data sheet
Page 26
4.7 Interrupt controller
The BMA255 is equipped with eight programmable interrupt engines. Each interrupt can be
independently enabled and configured. If the trigger condition of an enabled interrupt is fulfilled,
the corresponding status bit is set to ´1´ and the selected interrupt pin is activated. The BMA255
provides two interrupt pins, INT1 and INT2; interrupts can be freely mapped to any of these
pins. The state of a specific interrupt pin is derived from a logic ´or´ combination of all interrupts
mapped to it.
The interrupt status registers are updated when a new data word is written into the acceleration
data registers. If an interrupt is disabled, all active status bits associated with it are immediately
reset.
4.7.1 General features
An interrupt is cleared depending on the selected interrupt mode, which is common to all
interrupts. There are three different interrupt modes: non-latched, latched, and temporary. The
mode is selected by the (0x21) latch_int bits according to Table 10.
Table 10: Interrupt mode selection
(0x21)
latch_int
0000b
0001b
0010b
0011b
0100b
0101b
0110b
0111b
1000b
1001b
1010b
1011b
1100b
1101b
1110b
1111b
Interrupt mode
non-latched
temporary, 250ms
temporary, 500ms
temporary, 1s
temporary, 2s
temporary, 4s
temporary, 8s
latched
non-latched
temporary, 250µs
temporary, 500µs
temporary, 1ms
temporary, 12.5ms
temporary, 25ms
temporary, 50ms
latched
An interrupt is generated if its activation condition is met. It can not be cleared as long as the
activation condition is fulfilled. In the non-latched mode the interrupt status bit and the selected
pin (the contribution to the ´or´ condition for INT1 and/or INT2) are cleared as soon as the
activation condition is no more valid. Exceptions to this behavior are the new data, orientation,
and flat interrupts, which are automatically reset after a fixed time.
Bosch Sensortec
BMA255
Data sheet
Page 27
In latched mode an asserted interrupt status and the selected pin are cleared by writing ´1´ to
bit (0x21) reset_int. If the activation condition still holds when it is cleared, the interrupt status is
asserted again with the next change of the acceleration registers.
In the temporary mode an asserted interrupt and selected pin are cleared after a defined period
of time. The behaviour of the different interrupt modes is shown graphically in figure 6. The
timings in this mode are subject to the same tolerances as the bandwidths (see Table 1).
internal signal from
interrupt engine
interrupt output
non-latched
latch period
temporary
latched
Figure 6: Interrupt modes
Several interrupt engines can use either unfiltered or filtered acceleration data as their input. For
these interrupts, the source can be selected with the bits in register (0x1E). These are (0x1E)
int_src_data, (0x1E) int_src_tap, (0x1E) int_src_slo_no_mot, (0x1E) int_src_slope, (0x1E)
int_src_high, and (0x1E) int_src_low. Setting the respective bits to ´0´ (´1´) selects filtered
(unfiltered) data as input. The orientation recognition and flat detection interrupt always use
filtered input data.
It is strongly recommended to set interrupt parameters prior to enabling the interrupt. Changing
parameters of an already enabled interrupt may cause unwanted interrupt generation and
generation of a false interrupt history. A safe way to change parameters of an enabled interrupt
is to keep the following sequence: disable the desired interrupt, change parameters, wait for at
least 10ms, and then re-enable the desired interrupt.
4.7.2 Mapping to physical interrupt pins (inttype to INT Pin#)
Registers (0x19) to (0x1B) are dedicated to mapping of interrupts to the interrupt pins “INT1” or
“INT2”. Setting (0x19) int1_”inttype” to ´1´ (´0´) maps (unmaps) “inttype” to pin “INT1”.
Correspondingly setting (0x1B) int2_”inttype” to ´1´ (´0´) maps (unmaps) “inttype” to pin “INT2”.
Note: “inttype” to be replaced with the precise notation, given in the memory map in chapter 6.
Example: For flat interrupt (int1_flat): Setting (0x19) int1_flat to ´1´ maps int1_flat to pin “INT1”.
Bosch Sensortec
BMA255
Data sheet
Page 28
4.7.3 Electrical behaviour (INT pin# to open-drive or push-pull)
Both interrupt pins can be configured to show the desired electrical behaviour. The ´active´ level
of each interrupt pin is determined by the (0x20) int1_lvl and (0x20) int2_lvl bits.
If (0x20) int1_lvl = ´1´ (´0´) / (0x20) int2_lvl = ´1´ (´0´), then pin “INT1” / pin “INT2” is active ´1´
(´0´). The characteristic of the output driver of the interrupt pins may be configured with bits
(0x20) int1_od and (0x20) int2_od. By setting bits (0x20) int1_od / (0x20) int2_od to ´1´, the
output driver shows open-drive characteristic, by setting the configuration bits to ´0´, the output
driver shows push-pull characteristic. When open-drive characteristic is selected in the design,
external pull-up or pull-down resistor should be applied according the int_lvl configuration.
4.7.4 New data interrupt
This interrupt serves for synchronous reading of acceleration data. It is generated after storing a
new value of z-axis acceleration data in the data register. The interrupt is cleared automatically
when the next data acquisition cycle starts. The interrupt status is ´0´ for at least 50µs.
The interrupt mode of the new data interrupt is fixed to non-latched.
It is enabled (disabled) by writing ´1´ (´0´) to bit (0x17) data_en. The interrupt status is stored in
bit (0x0A) data_int.
Due to the settling time of the filter, the first interrupt after wake-up from suspend or standby
mode will take longer than the update time.
Bosch Sensortec
BMA255
Data sheet
Page 29
4.7.5 Slope / any-motion detection
Slope / any-motion detection uses the slope between successive acceleration signals to detect
changes in motion. An interrupt is generated when the slope (absolute value of acceleration
difference) exceeds a preset threshold. It is cleared as soon as the slope falls below the
threshold. The principle is made clear in figure 7.
acceleration
acc(t0)
acc(t0−1/(2*bw))
time
slope(t0)=acc(t0)−acc(t0−1/(2*bw))
slope
slope_th
time
slope_dur
slope_dur
INT
time
Figure 7: Principle of any-motion detection
The threshold is defined through register (0x28) slope_th. In terms of scaling 1 LSB of (0x28)
slope_th corresponds to 3.91 mg in 2g-range (7.81 mg in 4g-range, 15.6 mg in 8g-range and
31.3 mg in 16g-range). Therefore the maximum value is 996 mg in 2g-range (1.99g in 4grange, 3.98g in 8g-range and 7.97g in 16g-range).
The time difference between the successive acceleration signals depends on the selected
bandwidth and equates to 1/(2*bandwidth) (t=1/(2*bw)). In order to suppress false triggers, the
interrupt is only generated (cleared) if a certain number N of consecutive slope data points is
larger (smaller) than the slope threshold given by (0x28) slope_th. This number is set by the
(0x27) slope_dur bits. It is N = (0x27) slope_dur + 1 for (0x27).
Example: (0x27) slope_dur = 00b, …, 11b = 1decimal, …, 4decimal.
Bosch Sensortec
BMA255
Data sheet
Page 30
4.7.5.1 Enabling (disabling) for each axis
Any-motion detection can be enabled (disabled) for each axis separately by writing ´1´ (´0´) to
bits (0x16) slope_en_x, (0x16) slope_en_y, (0x16) slope_en_z. The criteria for any-motion
detection are fulfilled and the slope interrupt is generated if the slope of any of the enabled axes
exceeds the threshold (0x28) slope_th for [(0x27) slope_dur +1] consecutive times. As soon as
the slopes of all enabled axes fall or stay below this threshold for [(0x27) slope_dur +1]
consecutive times the interrupt is cleared unless interrupt signal is latched.
4.7.5.2 Axis and sign information of slope / any motion interrupt
The interrupt status is stored in bit (0x09) slope_int. The any-motion interrupt supplies additional
information about the detected slope. The axis which triggered the interrupt is given by that one
of bits (0x0B) slope_first_x, (0x0B) slope_first_y, (0x0B) slope_first_z that contains a value of
´1´. The sign of the triggering slope is held in bit (0x0B) slope_sign until the interrupt is
retriggered. If (0x0B) slope_sign = ´0´ (´1´), the sign is positive (negative).
Bosch Sensortec
BMA255
Data sheet
Page 31
4.7.6 Tap sensing
Tap sensing has a functional similarity with a common laptop touch-pad or clicking keys of a
computer mouse. A tap event is detected if a pre-defined slope of the acceleration of at least
one axis is exceeded. Two different tap events are distinguished: A ‘single tap’ is a single event
within a certain time, followed by a certain quiet time. A ‘double tap’ consists of a first such
event followed by a second event within a defined time frame.
Single tap interrupt is enabled (disabled) by writing ´1´ (´0´) to bit (0x16) s_tap_en. Double tap
interrupt is enabled (disabled) by writing ´1´ (´0´) to bit (0x16) d_tap_en.
While temporary latching is used do not simultaneously enable single tap interrupt and double
tap interrupt.
The status of the single tap interrupt is stored in bit (0x09) s_tap_int, the status of the double
tap interrupt is stored in bit (0x09) d_tap_int.
The slope threshold for detecting a tap event is set by bits (0x2B) tap_th. The meaning of
(0x2B) tap_th depends on the range setting. 1 LSB of (0x2B) tap_th corresponds to a slope of
62.5mg in 2g-range, 125mg in 4g-range, 250mg in 8g-range, and 500mg in 16g-range.
In figure 8 the meaning of the different timing parameters is visualized:
slope
1st tap
2nd tap
tap_th
time
tap_shock
tap_quiet
tap_dur
tap_shock
tap_quiet
single tap detection
12.5 ms
time
double tap detection
12.5 ms
time
Figure 8: Timing of tap detection
Bosch Sensortec
BMA255
Data sheet
Page 32
The parameters (0x2A) tap_shock and (0x2A) tap_quiet apply to both single tap and double tap
detection, while (0x2A) tap_dur applies to double tap detection only. Within the duration of
(0x2A) tap_shock any slope exceeding (0x2B) tap_th after the first event is ignored. Contrary to
this, within the duration of (0x2A) tap_quiet no slope exceeding (0x2B) tap_th must occur,
otherwise the first event will be cancelled.
4.7.6.1 Single tap detection
A single tap is detected and the single tap interrupt is generated after the combined durations of
(0x2A) tap_shock and (0x2A) tap_quiet, if the corresponding slope conditions are fulfilled. The
interrupt is cleared after a delay of 12.5 ms.
Do not map single-tap to any INT pin if you do not want to use it.
4.7.6.2 Double tap detection
A double tap interrupt is generated if an event fulfilling the conditions for a single tap occurs
within the set duration in (0x2A) tap_dur after the completion of the first tap event. The interrupt
is automatically cleared after a delay of 12.5 ms.
4.7.6.3 Selecting the timing of tap detection
For each of parameters (0x2A) tap_shock and (0x2A) tap_quiet two values are selectable. By
writing ´0´ (´1´) to bit (0x2A) tap_shock the duration of (0x2A) tap_shock is set to 50 ms (75
ms). By writing ´0´ (´1´) to bit (0x2A) tap_quiet the duration of (0x2A) tap_quiet is set to 30 ms
(20 ms).
The length of (0x2A) tap_dur can be selected by setting the (0x2A) tap_dur bits according to
Table 11:
Table 11: Selection of tap_dur
(0x2A)
tap_dur
000b
001b
010b
011b
100b
101b
110b
111b
length of tap_dur
50 ms
100 ms
150 ms
200 ms
250 ms
375 ms
500 ms
700 ms
Bosch Sensortec
BMA255
Data sheet
Page 33
4.7.6.4 Axis and sign information of tap sensing
The sign of the slope of the first tap which triggered the interrupt is stored in bit (0x0B) tap_sign
(´0´ means positive sign, ´1´ means negative sign). The value of this bit persists after clearing
the interrupt.
The axis which triggered the interrupt is indicated by bits (0x0B) tap_first_x, (0x0B) tap_first_y,
and (0x0B) tap_first_z.
The bit corresponding to the triggering axis contains a ´1´ while the other bits hold a ´0´. These
bits are cleared together with clearing the interrupt status.
4.7.6.5 Tap sensing in low power mode
In low-power mode, a limited number of samples is processed after wake-up to decide whether
an interrupt condition is fulfilled. The number of samples is selected by bits (0x2B) tap_samp
according to Table 12.
Table 12: Meaning of (0x2B) tap_samp
(0x2B)
tap_samp
00b
01b
10b
11b
Number of Samples
2
4
8
16
Bosch Sensortec
BMA255
Data sheet
Page 34
4.7.7 Orientation recognition
The orientation recognition feature informs on an orientation change of the sensor with respect
to the gravitational field vector ‘g’. The measured acceleration vector components with respect
to the gravitational field are defined as shown in figure 9.
Figure 9: Definition of vector components
Therefore, the magnitudes of the acceleration vectors are calculated as follows:
acc_x = 1g x sin x cos
acc_y = −1g x sin x sin
acc_z = 1g x cos
acc_y/acc_x = −tan
Depending on the magnitudes of the acceleration vectors the orientation of the device in the
space is determined and stored in the three (0x0C) orient bits. These bits may not be reset in
the sleep phase of low-power mode. There are three orientation calculation modes with different
thresholds for switching between different orientations: symmetrical, high-asymmetrical, and
low-asymmetrical. The mode is selected by setting the (0x2C) orient_mode bits as given in
Table 13.
Table 13: Orientation mode settings
(0x2C)
orient_mode
00b
01b
10b
11b
Orientation Mode
symmetrical
high-asymmetrical
low-asymmetrical
symmetrical
Bosch Sensortec
BMA255
Data sheet
Page 35
For each orientation mode the (0x0C) orient bits have a different meaning as shown in Table 14
to Table 16:
Table 14: Meaning of the (0x0C) orient bits in symmetrical mode
(0x0C)
orient
Name
Angle
x00
portrait upright
315° < < 45°
x01
portrait upside down
135° < < 225°
x10
landscape left
45° < < 135°
x11
landscape right
225° < < 315°
Condition
|acc_y| < |acc_x| - ‘hyst’
and acc_x - ‘hyst’’ ≥ 0
and acc_x + ‘hyst’ < 0
|acc_y| ≥ |acc_x| + ‘hyst’
and acc_y < 0
and acc_y ≥ 0
Table 15: Meaning of the (0x0C) orient bits in high-asymmetrical mode
(0x0C)
orient
Name
Angle
x00
portrait upright
297° < < 63°
x01
117° < < 243°
x10
landscape left
63° < < 117°
x11
landscape right
243° < < 297°
Condition
|acc_y| < 2∙|acc_x| - ‘hyst’
and acc_x - ‘hyst’ ≥ 0
|acc_y| ≥ 2∙|acc_x| + ‘hyst’
and acc_y < 0
and acc_y ≥ 0
Table 16: Meaning of the (0x0C) orient bits in low-asymmetrical mode
(0x0C)
orient
Name
Angle
x00
portrait upright
333° < < 27°
x01
153° < < 207°
x10
landscape left
27° < < 153°
x11
landscape right
207° < < 333°
Condition
|acc_y| < 0.5∙|acc_x| - ‘hyst’
|acc_y| ≥ 0.5∙|acc_x| + ‘hyst’
and acc_y < 0
and acc_y ≥ 0
In the preceding tables, the parameter ‘hyst’ stands for a hysteresis, which can be selected by
setting the (0x2C) orient_hyst bits. 1 LSB of (0x2C) orient_hyst always corresponds to 62.5 mg,
in any g-range (i.e. increment is independent from g-range setting). It is important to note that
by using a hysteresis ≠ 0 the actual switching angles become different from the angles given in
the tables since there is an overlap between the different orientations.
The most significant bit of the (0x0C) orient bits (which is displayed as an ´x´ in the above given
tables) contains information about the direction of the z-axis. It is set to ´0´ (´1´) if acc_z ≥ 0
(acc_z < 0).
Bosch Sensortec
BMA255
Data sheet
Page 36
Figure 10 shows the typical switching conditions between the four different orientations for the
symmetrical mode i.e. without hysteresis:
portrait
portraitupright
upright
landscape left
portrait
portraitupside
upside
down
landscape
landscaperight
right
portrait upright
2
1.5
1
0.5
90
135
180
225
270
315
360
-0.5
acc_y/acc_x
-1
acc_x/sin(theta)
-1.5
acc_y/sin(theta)
-2
phi
Figure 10: Typical orientation switching conditions w/o hysteresis
The orientation interrupt is enabled (disabled) by writing ´1´ (´0´) to bit (0x16) orient_en. The
interrupt is generated if the value of (0x0C) orient has changed. It is automatically cleared after
one stable period of the (0x0C) orient value. The interrupt status is stored in the (0x09)
orient_int bit. The register (0x0C) orient always reflects the current orientation of the device,
irrespective of which interrupt mode has been selected. Bit (0x0C) orient reflects the device
orientation with respect to the z-axis. The bits (0x0C) orient reflect the device orientation
in the x-y-plane. The conventions associated with register (0x0C) orient are detailed in chapter
6.
Bosch Sensortec
BMA255
Data sheet
Page 37
4.7.7.1 Orientation blocking
The change of the (0x0C) orient value and – as a consequence – the generation of the interrupt
can be blocked according to conditions selected by setting the value of the (0x2C)
orient_blocking bits as described by Table 17.
Table 17: Blocking conditions for orientation recognition
(0x2C)
orient_blocking
00b
01b
10b
11b
Conditions
no blocking
theta blocking
or
acceleration in any axis > 1.5g
theta blocking
or
acceleration slope in any axis > 0.2 g
or
theta blocking
or
acceleration slope in any axis > 0.4 g
or
acceleration in any axis > 1.5g and value of orient is
not stable for at least 100 ms
The theta blocking is defined by the following inequality:
tan
blocking _ theta
8
The parameter blocking_theta of the above given equation stands for the contents of the (0x2D)
orient_theta bits. It is possible to define a blocking angle between 0° and 44.8°. The internal
blocking algorithm saturates the acceleration values before further processing. As a
consequence, the blocking angles are strictly valid only for a device at rest; they can be
different if the device is moved.
Example:
To get a maximum blocking angle of 19° the parameter blocking_theta is determined in the
following way: (8 * tan(19°) )² = 7.588, therefore, blocking_value = 8dec = 001000b has to be
chosen.
In order to avoid unwanted generation of the orientation interrupt in a nearly flat position (z ~ 0,
sign change due to small movements or noise), a hysteresis of 0.2 g is implemented for the zaxis, i. e. a after a sign change the interrupt is only generated after |z| > 0.2 g.
4.7.7.2 Up-Down Interrupt Suppression Flag
Per default an orientation interrupt is triggered when any of the bits in register (0x0C) orient
Bosch Sensortec
BMA255
Data sheet
Page 38
changes state. The BMA255 can be configured to trigger orientation interrupts only when the
device position changes in the x-y-plane while orientation changes with respect to the z-axis are
ignored. A change of the orientation of the z-axis, and hence a state change of bit (0x0C)
orient is ignored (considered) when bit (0x2D) orient_ud_en is set to ‘0’ (‘1’).
Bosch Sensortec
BMA255
Data sheet
Page 39
4.7.8 Flat detection
The flat detection feature gives information about the orientation of the devices´ z-axis relative
to the g-vector, i. e. it recognizes whether the device is in a flat position or not.
The flat angle is adjustable by (0x2E) flat_theta from 0° to 44.8°. The flat angle can be set
according to following formula:
1
atan
flat_theta
8
A hysteresis of the flat detection can be enabled by (0x2F) flat_hy bits. In this case the flat
position is set if the angle drops below following threshold:
1
flat _ hy flat _ hy
hyst,ll atan
flat_theta 1
8
1024
16
The flat position is reset if the angle exceeds the following threshold:
1
flat _ hy flat _ hy
hyst,ul atan flat_theta 1
8
1024
16
The flat interrupt is enabled (disabled) by writing ´1´ (´0´) to bit (0x16) flat_en. The flat value is
stored in the (0x0C) flat bit if the interrupt is enabled. This value is ´1´ if the device is in the flat
position, it is ´0´ otherwise. The flat interrupt is generated if the flat value has changed and the
new value is stable for at least the time given by the (0x2F) flat_hold_time bits. A flat interrupt
may be also generated if the flat interrupt is enabled. The actual status of the interrupt is stored
in the (0x09) flat_int bit. The flat orientation of the sensor can always be determined from
reading the (0x0C) flat bit after interrupt generation. If unlatched interrupt mode is used, the
(0x09) flat_int value and hence the interrupt is automatically cleared after one sample period. If
temporary or latched interrupt mode is used, the (0x09) flat_int value is kept fixed until the latch
time expires or the interrupt is reset.
The meaning of the (0x2F) flat_hold_time bits can be seen from Table 18.
Table 18: Meaning of flat_hold_time
(0x2F)
flat_hold_time
00b
01b
10b
11b
Time
512 ms
1024 ms
2048 ms
Bosch Sensortec
BMA255
Data sheet
Page 40
4.7.9 Low-g interrupt
This interrupt is based on the comparison of acceleration data against a low-g threshold, which
is most useful for free-fall detection.
The interrupt is enabled (disabled) by writing ´1´ (´0´) to the (0x17) low_en bit. There are two
modes available, ‘single’ mode and ‘sum’ mode. In ‘single’ mode, the acceleration of each axis
is compared with the threshold; in ‘sum’ mode, the sum of absolute values of all accelerations
|acc_x| + |acc_y| + |acc_z| is compared with the threshold. The mode is selected by the
contents of the (0x24) low_mode bit: ´0´ means ‘single’ mode, ´1´ means ‘sum’ mode.
The low-g threshold is set through the (0x23) low_th register. 1 LSB of (0x23) low_th always
corresponds to an acceleration of 7.81 mg (i.e. increment is independent from g-range setting).
A hysteresis can be selected by setting the (0x24) low_hy bits. 1 LSB of (0x24) low_hy always
corresponds to an acceleration difference of 125 mg in any g-range (as well, increment is
The low-g interrupt is generated if the absolute values of the acceleration of all axes (´and´
relation, in case of single mode) or their sum (in case of sum mode) are lower than the
threshold for at least the time defined by the (0x22) low_dur register. The interrupt is reset if the
absolute value of the acceleration of at least one axis (´or´ relation, in case of single mode) or
the sum of absolute values (in case of sum mode) is higher than the threshold plus the
hysteresis for at least one data acquisition. In bit (0x09) low_int the interrupt status is stored.
The relation between the content of (0x22) low_dur and the actual delay of the interrupt
generation is: delay [ms] = [(0x22) low_dur + 1] • 2 ms. Therefore, possible delay times range
from 2 ms to 512 ms.
Bosch Sensortec
BMA255
Data sheet
Page 41
4.7.10 High-g interrupt
This interrupt is based on the comparison of acceleration data against a high-g threshold for the
detection of shock or other high-acceleration events.
The high-g interrupt is enabled (disabled) per axis by writing ´1´ (´0´) to bits (0x17) high_en_x,
(0x17) high_en_y, and (0x17) high_en_z, respectively. The high-g threshold is set through the
(0x26) high_th register. The meaning of an LSB of (0x26) high_th depends on the selected grange: it corresponds to 7.81 mg in 2g-range, 15.63 mg in 4g-range, 31.25 mg in 8g-range, and
62.5 mg in 16g-range (i.e. increment depends from g-range setting).
A hysteresis can be selected by setting the (0x24) high_hy bits. Analogously to (0x26) high_th,
the meaning of an LSB of (0x24) high_hy is g-range dependent: It corresponds to an
acceleration difference of 125 mg in 2g-range, 250 mg in 4g-range, 500 mg in 8g-range, and
1000mg in 16g-range (as well, increment depends from g-range setting).
The high-g interrupt is generated if the absolute value of the acceleration of at least one of the
enabled axes (´or´ relation) is higher than the threshold for at least the time defined by the
(0x25) high_dur register. The interrupt is reset if the absolute value of the acceleration of all
enabled axes (´and´ relation) is lower than the threshold minus the hysteresis for at least the
time defined by the (0x25) high_dur register. In bit (0x09) high_int the interrupt status is stored.
The relation between the content of (0x25) high_dur and the actual delay of the interrupt
generation is delay [ms] = [(0x22) low_dur + 1] • 2 ms. Therefore, possible delay times range
from 2 ms to 512 ms. The interrupt will be cleared immediately once acceleration is lower than
threshold.
4.7.10.1 Axis and sign information of high-g interrupt
The axis which triggered the interrupt is indicated by bits (0x0C) high_first_x, (0x0C)
high_first_y, and (0x0C) high_first_z. The bit corresponding to the triggering axis contains a ´1´
while the other bits hold a ´0´. These bits are cleared together with clearing the interrupt status.
The sign of the triggering acceleration is stored in bit (0x0C) high_sign. If (0x0C) high_sign = ´0´
Bosch Sensortec
BMA255
Data sheet
Page 42
4.7.11 No-motion / slow motion detection
The slow-motion/no-motion interrupt engine can be configured in two modes.
In slow-motion mode an interrupt is triggered when the measured slope of at least one enabled
axis exceeds the programmable slope threshold for a programmable number of samples.
Hence the engine behaves similar to the any-motion interrupt, but with a different set of
parameters. In order to suppress false triggers, the interrupt is only generated (cleared) if a
certain number N of consecutive slope data points is larger (smaller) than the slope threshold
given by (0x27) slo_no_mot_dur. The number is N = (0x27) slo_no_mot_dur + 1.
In no-motion mode an interrupt is generated if the slope on all selected axes remains smaller
than a programmable threshold for a programmable delay time. Figure 11 shows the timing
diagram for the no-motion interrupt. The scaling of the threshold value is identical to that of the
slow-motion interrupt. However, in no-motion mode register (0x27) slo_no_mot_dur defines the
delay time before the no-motion interrupt is triggered. Table 19 lists the delay times adjustable
with register (0x27) slo_no_mot_dur. The timer tick period is 1 second. Hence using short delay
times can result in considerable timing uncertainty.
If bit (0x18) slo_no_mot_sel is set to ‘1’ (‘0’) the no-motion/slow-motion interrupt engine is
configured in the no-motion (slow-motion) mode. Common to both modes, the engine monitors
the slopes of the axes that have been enabled with bits (0x18) slo_no_mot_en_x, (0x18)
slo_no_mot_en_y, and (0x18) slo_no_mot_en_z for the x-axis, y-axis and z-axis, respectively.
The measured slope values are continuously compared against the threshold value defined in
register (0x29) slo_no_mot_th. The scaling is such that 1 LSB of (0x29) slo_no_mot_th
corresponds to 3.91 mg in 2g-range (7.81 mg in 4g-range, 15.6 mg in 8g-range and 31.3 mg in
16g-range). Therefore the maximum value is 996 mg in 2g-range (1.99g in 4g-range, 3.98g in
8g-range and 7.97g in 16g-range). The time difference between the successive acceleration
samples depends on the selected bandwidth and equates to 1/(2 * bw).
Table 19: No-motion time-out periods
(0x27)
slo_no_mot_dur
2
14
15
Delay
time
1s
2s
3s
15 s
16 s
(0x27)
slo_no_mot_dur
16
17
18
19
Delay
time
40 s
48 s
56 s
64 s.
72 s
80 s
(0x27)
slo_no_mot_dur
32
33
34
62
63
Delay
Time
88 s
96 s
104 s
328 s
336 s
Note: slo_no_mot_dur values 22 to 31 are not specified
Bosch Sensortec
BMA255
Data sheet
acceleration
Page 43
acc(t0+Δt)
acc(t0)
slope
axis x, y, or z
slope(t0+Δt)= acc(t0+Δt) - acc(t0)
axis x, y, or z
slo_no_mot_th
-slo_no_mot_th
slo_no_mot_dur
timer
INT
time
Figure 11: Timing of No-motion interrupt
Bosch Sensortec
BMA255
Data sheet
Page 44
4.8 Softreset
A softreset causes all user configuration settings to be overwritten with their default value and
the sensor to enter normal mode.
A softreset is initiated by means of writing value 0xB6 to register (0x14) softreset. Subsequently
a waiting time of tw,up1 (max.) is required prior to accessing any configuration registers.
Bosch Sensortec
BMA255
Data sheet
Page 45
5. FIFO Operation
5.1 FIFO Operating Modes
The BMA255 features an integrated FIFO memory capable of storing up to 32 frames.
Conceptually each frame consists of three 16 bit words corresponding to the x, y and z- axis,
which are sampled at the same point in time. At the core of the FIFO is a buffer memory, which
can be configured to operate in the following modes:
FIFO Mode: In FIFO mode the acceleration data of the selected axes are stored in the
buffer memory. If enabled, a watermark interrupt is triggered when the buffer has filled
up to a configurable level. The buffer will be continuously filled until the fill level reaches
32 frames. When it is full the data collection is stopped, and all additional samples are
ignored. Once the buffer is full, a FIFO-full interrupt is generated if it has been enabled.
STREAM Mode: In STREAM mode the acceleration data of the selected axes are
stored in the buffer until it is full. The buffer has a depth of 31 frames. When the buffer is
full the data collection continues and oldest entry is discarded. If enabled, a watermark
interrupt is triggered when the buffer is filled to a configurable level. Once the buffer is
BYPASS Mode: In bypass mode, only the current sensor data can be read out from the
FIFO address. Essentially, the FIFO behaves like the STREAM mode with a depth of 1.
Compared to reading the data from the normal data registers, the advantage to the user
is that the packages X, Y, Z are from the same timestamp, while the data registers are
updated sequentially and hence mixing of data from different axes can occur.
The primary FIFO operating mode is selected with register (0x3E) fifo_mode according to ‘00b’
for BYPASS mode, ‘01b’ for FIFO mode, and ‘10b’ for STREAM mode. Writing to register
(0x3E) clears the buffer content and resets the FIFO-full and watermark interrupts. When
reading register (0x3E) fifo_mode always contains the current operating mode.
Bosch Sensortec
BMA255
Data sheet
Page 46
5.2 FIFO Data Readout
The FIFO stores the data that are also available at the acceleration read-out registers (0x02) to
(0x07). Thus, all configuration settings apply to the FIFO data as well as the acceleration data
readout registers. The FIFO read out is possible through register (0x3F). The readout can be
performed using burst mode since the read address counter is no longer incremented, when it
has reached address (0x3F). This implies that the trapping also occurs when the burst read
access starts below address (0x3F). A single burst can read out one or more frames at a time.
Register (0x3E) fifo_data_select controls the acceleration data of which axes are stored in the
FIFO. Possible settings for register (0x3E) fifo_data_select are ‘00b’ for x, y- and z-axis, ‘01b’
for x-axis only, ‘10b’ for y-axis, ‘11b’ for z-axis only. The depth of the FIFO is independent of
whether all or a single axis have been selected. Writing to register (0x3E) clears the buffer
If all axes are enabled, the format of the data read-out from register (0x3F) is as follows:
X LSB
X MSB
Y LSB
Y MSB
Z LSB
Z MSB
Frame 1
If only one axis is enabled, the format of the data read-out from register (0x3F) is as follows
(example shown: y-axis only, other axes are equivalent).
Y LSB
Y MSB
Frame 1
Y LSB
Y MSB
Frame 2
If a frame is not completely read due to an incomplete read operation, the remaining part of the
frame is discarded. In this case the FIFO aligns to the next frame during the next read
operation. In order for the discarding mechanism to operate correctly, there must be a delay of
at least 1.5 us between the last data bit of the partially read frame and the first address bit of the
next FIFO read access. Otherwise frames must not be read out partially.
If the FIFO is read beyond the FIFO fill level zeroes (0) will be read. If the FIFO is read beyond
the FIFO fill level the read or burst read access time must not exceed the sampling time tSAMPLE.
Otherwise frames may be lost.
5.3 FIFO Frame Counter and Overrun Flag
Register (0x0E) fifo_frame_counter reflects the current fill level of the buffer. If additional frames
are written to the buffer although the FIFO is full, the (0x0E) fifo_overrun bit is set to ‘1’. The
FIFO buffer is cleared, the FIFO fill level indicated in register (0x0E) fifo_frame_counter and the
(0x0E) fifo_overrun bit are both set to ‘0’ each time one a write access to one of the FIFO
configuration registers (0x3E) or (0x30) occurs. The (0x0E) fifo_overrun bit is not reset when
the FIFO fill level (0x0E) fifo_frame_counter has decremented to ‘0’ due to reading from register
(0x3F).
Bosch Sensortec
BMA255
Data sheet
Page 47
5.4 FIFO Interrupts
The FIFO controller can generate two different interrupt events, a FIFO-full and a watermark
event. The FIFO-full and watermark interrupts are functional in all FIFO operating modes. The
watermark interrupt is asserted when the fill level in the buffer has reached the frame count
defined by register (0x30) fifo_water_mark_trigger_retain. In order to enable (disable) the
watermark interrupt, the (0x17) int_fwm_en bit must be set to ‘1’ (‘0’). To map the watermark
interrupt signal to INT1 pin (INT2 pin), (0x1A) int1_fwm ((0x1A) int2_fwm) bit must be set to ‘1’.
The status of the watermark interrupt may be read back through the (0x0A) fifo_wm_int bit.
Writing to register (0x30) fifo_water_mark_trigger_retain clears the FIFO buffer.
The FIFO-full interrupt is triggered when the buffer has been completely filled. In FIFO mode
this occurs 32, in STREAM mode 31 samples, and in BYPASS mode 1 sample after the buffer
has been cleared. In order to enable the FIFO-full interrupt, bit (0x17) int_ffull_en as well as one
or both of bits (0x1A) int1_fful or (0x1A) int2_fful must also be set to ‘1’. The status of the FIFOfull interrupt may be read back through bit (0x0A) fifo_full_int.
Bosch Sensortec
BMA255
Data sheet
Page 48
6. Register description
6.1 General remarks
The entire communication with the device is performed by reading from and writing to registers.
Registers have a width of 8 bits; they are mapped to a common space of 64 addresses from
(0x00) up to (0x3F). Within the used range there are several registers which are either
completely or partially marked as ‘reserved’. Any reserved bit is ignored when it is written and
no specific value is guaranteed when read. It is recommended not to use registers at all which
are completely marked as ‘reserved’. Furthermore it is recommended to mask out (logical and
with zero) reserved bits of registers which are partially marked as reserved.
Registers with addresses from (0x00) up to (0x0E) are read-only. Any attempt to write to these
registers is ignored. There are bits within some registers that trigger internal sequences. These
bits are configured for write-only access, e. g. (0x21) reset_int or the entire (0x14) softreset
register, and read as value ´0´.
Bosch Sensortec
BMA255
Data sheet
Page 49
6.2 Register map
Register Address
0x3F
0x3E
0x3D
0x3C
0x3B
0x3A
0x39
0x38
0x37
0x36
0x35
0x34
0x33
0x32
0x31
0x30
0x2F
0x2E
0x2D
0x2C
0x2B
0x2A
0x29
0x28
0x27
0x26
0x25
0x24
0x23
0x22
0x21
0x20
0x1F
0x1E
0x1D
0x1C
0x1B
0x1A
0x19
0x18
0x17
0x16
0x15
0x14
0x13
0x12
0x11
0x10
0x0F
0x0E
0x0D
0x0C
0x0B
0x0A
0x09
0x08
0x07
0x06
0x05
0x04
0x03
0x02
0x01
0x00
bit7
bit6
bit5
bit4
bit3
bit2
bit1
bit0
Access Default
fifo_data_output_register
fifo_mode
fifo_data_select
GP1
GP0
offset_z
offset_y
offset_x
offset_target_y
cal_rdy
offset_target_z
cal_trigger
offset_reset
nvm_remain
offset_target_x
hp_z_en
hp_y_en
nvm_load
i2c_wdt_en
nvm_rdy
self_test_sign
cut_off
hp_x_en
i2c_wdt_sel
spi3
nvm_prog_trig
nvm_prog_mode
self_test_axis
fifo_water_mark_level_trigger_retain
flat_hold_time
flat_hy
flat_theta
orient_theta
orient_blocking
tap_th
orient_ud_en
orient_hyst
tap_samp
tap_quiet
tap_shock
orient_mode
tap_dur
slo_no_mot_th
slope_th
slo_no_mot_dur
high_th
high_dur
slope_dur
high_hy
low_mode
low_hy
low_th
low_dur
reset_int
latch_int
int2_lvl
int1_od
int2_od
int1_lvl
int_src_data
int_src_tap
int_src_slo_no_mot
int_src_slope
int_src_high
int_src_low
int2_slope
int1_ffull
int1_slope
slo_no_mot_en_z
high_en_z
slope_en_z
int2_high
int1_fwm
int1_high
slo_no_mot_en_y
high_en_y
slope_en_y
int2_low
int1_data
int1_low
slo_no_mot_en_x
high_en_x
slope_en_x
int2_flat
int2_data
int1_flat
int2_orient
int2_fwm
int1_orient
int2_s_tap
int2_ffull
int1_s_tap
int2_d_tap
int2_slo_no_mot
int1_d_tap
int_ffull_en
s_tap_en
data_en
d_tap_en
int1_slo_no_mot
slo_no_mot_sel
low_en
flat_en
int_fwm_en
orient_en
softreset
data_high_bw
suspend
shadow_dis
lowpower_mode
lowpower_en
sleeptimer_mode low_power_mode (reserved)
deep_suspend
sleep_dur
bw
range
fifo_overrun
flat
tap_sign
data_int
flat_int
fifo_frame_counter
tap_first_z
fifo_wm_int
orient_int
orient
tap_first_y
fifo_full_int
s_tap_int
tap_first_x
high_sign
slope_sign
high_first_z
slope_first_z
high_first_y
slope_first_y
high_first_x
slope_first_x
slope_int
high_int
low_int
d_tap_int
slo_no_mot_int
temp
acc_z_msb
acc_z_lsb
new_data_z
acc_y_msb
acc_y_lsb
new_data_y
acc_x_msb
acc_x_lsb
new_data_x
chip_id
ro
w/r
w/r
w/r
w/r
w/r
w/r
w/r
w/r
w/r
w/r
w/r
w/r
w/r
w/r
w/r
w/r
w/r
w/r
w/r
w/r
w/r
w/r
w/r
w/r
w/r
w/r
w/r
w/r
w/r
w/r
w/r
w/r
w/r
w/r
w/r
w/r
w/r
w/r
w/r
w/r
w/r
w/r
wo
w/r
w/r
w/r
w/r
w/r
ro
w/r
ro
ro
ro
ro
ro
ro
ro
ro
ro
ro
ro
ro
ro
0x00
0x00
0xFF
0x00
0x00
0x00
0x00
0x00
0x00
0x10
0x00
0x00
0xF0
0x00
0xFF
0x00
0x11
0x08
0x48
0x18
0x0A
0x04
0x14
0x14
0x00
0xC0
0x0F
0x81
0x30
0x09
0x00
0x05
0xFF
0x00
0xFF
0xFF
0x00
0x00
0x00
0x00
0x00
0x00
0xFF
0x00
0x00
0x00
0x00
0x0F
0x03
0x00
0xFF
0x00
0x00
0x00
0x00
0x00
0x00
0x00
0x00
0x00
0x00
0x00
-0xFA
common w/r registers: Application specific settings which are not equal to the default settings,
must be re-set to its designated values after POR, soft-reset and wake up from deep suspend.
user w/r registers: Initial default content = 0x00. Freely programmable by the user.
Remains unchanged after POR, soft-reset and wake up from deep suspend.
Figure 12: Register map
BST-BMA255-DS004-05 | Revision 1.2 | August 2014
Bosch Sensortec
© Bosch Sensortec GmbH reserves all rights even in the event of industrial property rights. We reserve all rights of disposal such as copying and passing on to
third parties. BOSCH and the symbol are registered trademarks of Robert Bosch GmbH, Germany.
Note: Specifications within this document are subject to change without notice.
BMA255
Data sheet
Page 50
Register 0x00 (BGW_CHIPID)
The register contains the chip identification code.
Name
Bit
Read/Write
Reset
Value
Content
0x00
7
R
n/a
Bit
Read/Write
Reset
Value
Content
3
R
n/a
chip_id:
BGW_CHIPID
6
R
n/a
5
R
n/a
4
R
n/a
2
R
n/a
1
R
n/a
R
n/a
chip_id
chip_id
Fixed value b’1111’1010
Register 0x02 (ACCD_X_LSB)
The register contains the least-significant bits of the X-channel acceleration readout value.
When reading out X-channel acceleration values, data consistency is guaranteed if the
ACCD_X_LSB is read out before the ACCD_X_MSB and shadow_dis=’0’. In this case, after the
ACCD_X_LSB has been read, the value in the ACCD_X_MSB register is locked until the
ACCD_X_MSB has been read. This condition is inherently fulfilled if a burst-mode read access
is performed. Acceleration data may be read from register ACCD_X_LSB at any time except
during power-up and in DEEP_SUSPEND mode.
Name
Bit
Read/Write
Reset
Value
Content
0x02
7
R
n/a
Bit
Read/Write
Reset
Value
Content
acc_x_lsb:
undefined:
new_data_x:
ACCD_X_LSB
6
R
n/a
5
R
n/a
4
R
n/a
3
R
n/a
2
R
n/a
1
R
n/a
R
n/a
undefined
undefined
undefined
new_data_x
acc_x_lsb
Least significant 4 bits of acceleration read-back value; (two’s-complement
format)
random data; to be ignored.
‚0’: acceleration value has not been updated since it has been read out last
‚1’: acceleration value has been updated since it has been read out last
Bosch Sensortec
BMA255
Data sheet
Page 51
Register 0x03 (ACCD_X_MSB)
The register contains the most-significant bits of the X-channel acceleration readout value.
is performed. Acceleration data may be read from register ACCD_X_MSB at any time except
Name
Bit
Read/Write
Reset
Value
Content
0x02
7
R
n/a
Bit
Read/Write
Reset
Value
Content
3
R
n/a
ACCD_X_MSB
6
R
n/a
5
R
n/a
4
R
n/a
2
R
n/a
1
R
n/a
R
n/a
acc_x_msb
acc_x_msb
acc_x_msb: Most significant 8 bits of acceleration read-back value (two’s-complement
format)
Bosch Sensortec
BMA255
Data sheet
Page 52
Register 0x04 (ACCD_Y_LSB)
The register contains the least-significant bits of the Y-channel acceleration readout value.
When reading out Y-channel acceleration values, data consistency is guaranteed if the
ACCD_Y_LSB is read out before the ACCD_Y_MSB and shadow_dis=’0’. In this case, after the
ACCD_Y_LSB has been read, the value in the ACCD_Y_MSB register is locked until the
ACCD_Y_MSB has been read. This condition is inherently fulfilled if a burst-mode read access
is performed. Acceleration data may be read from register ACCD_Y_LSB at any time except
Name
Bit
Read/Write
Reset
Value
Content
0x04
7
R
n/a
Bit
Read/Write
Reset
Value
Content
acc_y_lsb:
undefined:
new_data_y:
ACCD_Y_LSB
6
R
n/a
5
R
n/a
4
R
n/a
3
R
n/a
2
R
n/a
1
R
n/a
R
n/a
undefined
undefined
undefined
new_data_y
acc_y_lsb
format)
Bosch Sensortec
BMA255
Data sheet
Page 53
Register 0x05 (ACCD_Y_MSB)
The register contains the most-significant bits of the Y-channel acceleration readout value.
is performed. Acceleration data may be read from register ACCD_Y_MSB at any time except
Name
Bit
Read/Write
Reset
Value
Content
0x05
7
R
n/a
Bit
Read/Write
Reset
Value
Content
3
R
n/a
ACCD_Y_MSB
6
R
n/a
5
R
n/a
4
R
n/a
2
R
n/a
1
R
n/a
R
n/a
acc_y_msb
acc_y_msb
acc_y_msb: Most significant 8 bits of acceleration read-back value (two’s-complement
format)
Bosch Sensortec
BMA255
Data sheet
Page 54
Register 0x06 (ACCD_Z_LSB)
The register contains the least-significant bits of the Z-channel acceleration readout value.
When reading out Z-channel acceleration values, data consistency is guaranteed if the
ACCD_Z_LSB is read out before the ACCD_Z_MSB and shadow_dis=’0’. In this case, after the
ACCD_Z_LSB has been read, the value in the ACCD_Z_MSB register is locked until the
ACCD_Z_MSB has been read. This condition is inherently fulfilled if a burst-mode read access
is performed. Acceleration data may be read from register ACCD_Z_LSB at any time except
Name
Bit
Read/Write
Reset
Value
Content
0x06
7
R
n/a
ACCD_Z_LSB
6
R
n/a
5
R
n/a
4
R
n/a
Bit
Read/Write
Reset
Value
Content
3
R
n/a
2
R
n/a
1
R
n/a
R
n/a
undefined
undefined
undefined
new_data_z
acc_z_lsb
Acc_z_lsb: Least significant 4 bits of acceleration read-back value; (two’s-complement
format)
undefined:
new_data_z:
Bosch Sensortec
BMA255
Data sheet
Page 55
Register 0x07 (ACCD_Z_MSB)
The register contains the most-significant bits of the Z-channel acceleration readout value.
is performed. Acceleration data may be read from register ACCD_Z_MSB at any time except
Name
Bit
Read/Write
Reset
Value
Content
0x07
7
R
n/a
Bit
Read/Write
Reset
Value
Content
3
R
n/a
ACCD_Z_MSB
6
R
n/a
5
R
n/a
4
R
n/a
2
R
n/a
1
R
n/a
R
n/a
acc_z_msb
acc_z_msb
acc_z_msb: Most significant 8 bits of acceleration read-back value (two’s-complement
format)
Bosch Sensortec
BMA255
Data sheet
Page 56
Register 0x08 (ACCD_TEMP)
The register contains the current chip temperature represented in two’s complement format. A
readout value of temp=0x00 corresponds to a temperature of 23°C.
Name
Bit
Read/Write
Reset
Value
Content
0x08
7
R
n/a
Bit
Read/Write
Reset
Value
Content
3
R
n/a
temp:
ACCD_TEMP
6
R
n/a
5
R
n/a
4
R
n/a
2
R
n/a
1
R
n/a
R
n/a
temp
temp
Temperature value (two s-complement format)
Bosch Sensortec
BMA255
Data sheet
Page 57
Register 0x09 (INT_STATUS_0)
The register contains interrupt status flags. Each flag is associated with a specific interrupt
function. It is set when the associated interrupt triggers. The setting of latch_int controls if
the interrupt signal and hence the respective interrupt flag will be permanently latched,
temporarily latched or not latched. The interrupt function associated with a specific status flag
must be enabled.
Name
Bit
Read/Write
Reset
Value
Content
0x09
7
R
n/a
INT_STATUS_0
6
R
n/a
5
R
n/a
4
R
n/a
flat_int
orient_int
s_tap_int
d_tap_int
Bit
Read/Write
Reset
Value
Content
3
R
n/a
2
R
n/a
1
R
n/a
R
n/a
slo_no_mot_int
slope_int
high_int
low_int
flat_int:
orient_int:
s_tap_int:
d_tap_int
slo_not_mot_int:
slope_int:
high_int:
low_int:
flat interrupt status: ‘0’inactive, ‘1’ active
orientation interrupt status: ‘0’inactive, ‘1’ active
single tap interrupt status: ‘0’inactive, ‘1’ active
double tap interrupt status: ‘0’inactive, ‘1’ active
slow/no-motion interrupt status: ‘0’inactive, ‘1’ active
slope interrupt status: ‘0’inactive, ‘1’ active
high-g interrupt status: ‘0’inactive, ‘1’ active
low-g interrupt status: ‘0’inactive, ‘1’ active
Bosch Sensortec
BMA255
Data sheet
Page 58
Register 0x0A (INT_STATUS_1)
function. It is set when the associated interrupt engine triggers. The setting of latch_int
controls if the interrupt signal and hence the respective interrupt flag will be permanently
latched, temporarily latched or not latched. The interrupt function associated with a specific
status flag must be enabled.
Name
Bit
Read/Write
Reset
Value
Content
0x0A
7
R
n/a
INT_STATUS_1
6
R
n/a
5
R
n/a
4
R
n/a
data_int
fifo_wm_int
fifo_full_int
reserved
Bit
Read/Write
Reset
Value
Content
3
R
n/a
2
R
n/a
1
R
n/a
R
n/a
data_int:
fifo_wm_int:
fifo_full_int:
reserved:
reserved
data ready interrupt status: ‘0’inactive, ‘1’ active
FIFO watermark interrupt status: ‘0’inactive, ‘1’ active
FIFO full interrupt status: ‘0’inactive, ‘1’ active
reserved, write to ‘0’
Bosch Sensortec
BMA255
Data sheet
Page 59
Register 0x0B (INT_STATUS_2)
engine. It is set when the associated interrupt engine triggers. The setting of latch_int
Name
Bit
Read/Write
Reset
Value
Content
0x0B
7
R
n/a
INT_STATUS_2
6
R
n/a
5
R
n/a
4
R
n/a
tap_sign
tap_first_z
tap_first_y
tap_first_x
Bit
Read/Write
Reset
Value
Content
3
R
n/a
2
R
n/a
1
R
n/a
R
n/a
slope_sign
slope_first_z
slope_first_y
slope_first_x
tap_sign:
tap_first_z:
tap_first_y:
tap_first_x:
slope_sign:
slope_first_z:
slope_first_y:
slope_first_x:
sign of single/double tap triggering signal was ‘0’positive, or ‘1’ negative
single/double tap interrupt: ‘1’ triggered by, or ‘0’not triggered by z-axis
single/double tap interrupt: ‘1’ triggered by, or ‘0’not triggered by y-axis
single/double tap interrupt: ‘1’ triggered by, or ‘0’not triggered by x-axis
slope sign of slope tap triggering signal was ‘0’positive, or ‘1’ negative
slope interrupt: ‘1’ triggered by, or ‘0’not triggered by z-axis
slope interrupt: ‘1’ triggered by, or ‘0’not triggered by y-axis
slope interrupt: ‘1’ triggered by, or ‘0’not triggered by x-axis
Bosch Sensortec
BMA255
Data sheet
Page 60
Register 0x0C (INT_STATUS_3)
engine. It is set when the associated interrupt engine triggers. With the exception of orient
the setting of latch_int controls if the interrupt signal and hence the respective interrupt
flag will be permanently latched, temporarily latched or not latched. The interrupt function
associated with a specific status flag must be enabled.
Name
Bit
Read/Write
Reset
Value
Content
0x0C
7
R
n/a
INT_STATUS_3
6
R
n/a
flat
orient
Bit
Read/Write
Reset
Value
Content
3
R
n/a
high_sign
flat:
orient:
orient:
high_sign:
high_first_z:
high_first_y:
high_first_x:
5
R
n/a
4
R
n/a
2
R
n/a
1
R
n/a
R
n/a
high_first_z
high_first_y
high_first_x
device is in ‘1’ flat, or ‘0’ non flat position;
only valid if (0x16) flat_en = ‘1’
Orientation value of z-axis: ´0´ upward looking, or ´1´ downward
looking. The flag always reflect the current orientation status, independent of
the setting of latch_int. The flag is not updated as long as an
orientation blocking condition is active.
orientation value of x-y-plane:
‘00’portrait upright;
‘01’portrait upside down;
‘10’landscape left;
‘11’landscape right;
The flags always reflect the current orientation status, independent of the
setting of latch_int. The flag is not updated as long as an orientation
sign of acceleration signal that triggered high-g interrupt was ‘0’positive, ‘1’
negative
high-g interrupt: ‘1’ triggered by, or ‘0’not triggered by z-axis
high-g interrupt: ‘1’ triggered by, or ‘0’not triggered by y-axis
high-g interrupt: ‘1’ triggered by, or ‘0’not triggered by x-axis
Bosch Sensortec
BMA255
Data sheet
Page 61
Register 0x0E (FIFO_STATUS)
The register contains FIFO status flags.
Name
Bit
Read/Write
Reset
Value
Content
0x0E
7
R
n/a
FIFO_STATUS
6
R
n/a
fifo_overrun
fifo_frame_counter
Bit
Read/Write
Reset
Value
Content
3
R
n/a
2
R
n/a
5
R
n/a
1
R
n/a
4
R
n/a
R
n/a
fifo_frame_counter
fifo_overrun:
FIFO overrun condition has ‘1’ occurred, or ‘0’not occurred; flag can be
cleared by writing to the FIFO configuration register FIFO_CONFIG_1 only
fifo_frame_counter:
Current fill level of FIFO buffer. An empty FIFO corresponds to
0x00. The frame counter can be cleared by reading out all frames from the
FIFO buffer or writing to the FIFO configuration register FIFO_CONFIG_1.
Bosch Sensortec
BMA255
Data sheet
Page 62
Register 0x0F (PMU_RANGE)
The register allows the selection of the accelerometer g-range.
Name
Bit
Read/Write
Reset
Value
Content
0x0F
7
R/W
Bit
Read/Write
Reset
Value
Content
3
R/W
PMU_RANGE
6
R/W
R/W
R/W
R/W
R/W
1
R/W
1
reserved
range:
reserved:
range
Selection of accelerometer g-range:
´0011b´ ±2g range; ´0101b´ ±4g range; ´1000b´ ±8g range;
´1100b´ ±16g range; all other settings reserved (do not use)
write ‘0’
Register 0x10 (PMU_BW)
The register allows the selection of the acceleration data filter bandwidth.
Name
Bit
Read/Write
Reset
Value
Content
0x10
7
R/W
Bit
Read/Write
Reset
Value
Content
3
R/W
1
PMU_BW
6
R/W
R/W
reserved
4
R/W
bw
bw:
reserved:
2
R/W
1
1
R/W
1
R/W
1
bw
Selection of data filter bandwidth:
´00xxxb´ 7.81 Hz,
´01000b´ 7.81 Hz, ´01001b´ 15.63 Hz,
´01010b´ 31.25 Hz, ´01011b´ 62.5 Hz, ´01100b´ 125 Hz,
´01101b´ 250 Hz,
´01110b´ 500 Hz, ´01111b´ 1000 Hz,
´1xxxxb´ 1000 Hz
write ‘0’
Bosch Sensortec
BMA255
Data sheet
Page 63
Register 0x11 (PMU_LPW)
Selection of the main power modes and the low power sleep period.
Name
Bit
Read/Write
Reset
Value
Content
0x11
7
R/W
PMU_LPW
6
R/W
R/W
R/W
suspend
lowpower_en
deep_suspend
sleep_dur
Bit
Read/Write
Reset
Value
Content
3
R/W
R/W
R/W
R/W
sleep_dur
reserved
suspend, low_power_en, deep_suspend:
Main power mode configuration setting {suspend; lowpower_en;
deep_suspend}:
{0; 0; 0}
NORMAL mode;
{0; 0; 1}
DEEP_SUSPEND mode;
{0; 1; 0}
LOW_POWER mode;
{1; 0; 0}
SUSPEND mode;
{all other}
illegal
Please note that only certain power mode transitions are permitted.
sleep_dur: Configures the sleep phase duration in LOW_POWER mode:
´0000b´ to ´0101b´
0.5 ms,
´0110b´ 1 ms,
´0111b´
2 ms,
´1000b´ 4 ms,
´1001b´
6 ms,
´1010b´ 10 ms,
´1011b´
25 ms,
´1100b´ 50 ms,
´1101b´
100 ms,
´1110b´ 500 ms,
´1111b´
1s
Please note, that all application specific settings which are not equal to the default settings
(refer to 6.2 register map), must be re-set to its designated values after DEEP_SUSPEND.
Bosch Sensortec
BMA255
Data sheet
Page 64
Register 0x12 (PMU_LOW_POWER)
Configuration settings for low power mode.
Name
Bit
Read/Write
Reset
Value
Content
0x12
7
R/W
PMU_LOW_POWER
6
5
R/W
R/W
R/W
reserved
lowpower_mode
sleeptimer_mode
reserved
Bit
Read/Write
Reset
Value
Content
3
R/W
R/W
R/W
R/W
reserved
lowpower_mode: select ‘0’ LPM1, or ‘1´ LPM2 configuration for SUSPEND and
LOW_POWER mode. In the LPM1 configuration the power consumption in
LOW_POWER mode and SUSPEND mode is significantly reduced when
compared to LPM2 configuration, but the FIFO is not accessible and writing
to registers must be slowed down. In the LPM2 configuration the power
consumption in LOW_POWER mode is reduced compared to NORMAL
mode, but the FIFO is fully accessible and registers can be written to at full
speed.
sleeptimer_mode: when in LOW_POWER mode ‘0’ use event-driven time-base mode
(compatible with BMA250), or ‘1´ use equidistant sampling time-base
mode. Equidistant sampling of data into the FIFO is maintained in
equidistant time-base mode only.
reserved:
write ‘0’
Bosch Sensortec
BMA255
Data sheet
Page 65
Register 0x13 (ACCD_HBW)
Acceleration data acquisition and data output format.
Name
Bit
Read/Write
Reset
Value
Content
0x13
7
R/W
data_high_bw
ACCD_HBW
6
R/W
0 (1 in 8-bit
mode)
shadow_dis
Bit
Read/Write
Reset
Value
Content
3
R/W
R/W
data_high_bw:
shadow_dis:
reserved:
5
R/W
R/W
reserved
1
R/W
R/W
reserved
select whether ‘1´ unfiltered, or ‘0’ filtered data may be read from the
acceleration data registers.
‘1´ disable, or ‘0’ the shadowing mechanism for the acceleration data
output registers. When shadowing is enabled, the content of the acceleration
data component in the MSB register is locked, when the component in the
LSB is read, thereby ensuring the integrity of the acceleration data during
read-out. The lock is removed when the MSB is read.
write ‘0’
Bosch Sensortec
BMA255
Data sheet
Page 66
Register 0x14 (BGW_SOFTRESET)
Controls user triggered reset of the sensor.
Name
Bit
Read/Write
Reset
Value
Content
0x14
7
W
Bit
Read/Write
Reset
Value
Content
3
W
softreset:
BGW_SOFTRESET
6
5
W
W
W
W
W
softreset
1
W
softreset
0xB6 triggers a reset. Other values are ignored. Following a delay, all
user configuration settings are overwritten with their default state or the
setting stored in the NVM, wherever applicable. This register is functional in
all operation modes. Please note that all application specific settings which
are not equal to the default settings (refer to 6.2 register map), must be
reconfigured to their designated values.
Register 0x16 (INT_EN_0)
Controls which interrupt engines in group 0 are enabled.
Name
Bit
Read/Write
Reset
Value
Content
0x16
7
R/W
INT_EN_0
6
R/W
R/W
R/W
flat_en
orient_en
s_tap_en
d_tap_en
Bit
Read/Write
Reset
Value
Content
3
R/W
R/W
R/W
R/W
reserved
slope_en_z
slope_en_y
slope_en_x
flat_en:
orient_en:
s_tap_en:
d_tap_en
reserved:
slope_en_z:
slope_en_y:
slope_en_x:
flat interrupt: ‘0’disabled, or ‘1’ enabled
orientation interrupt: ‘0’disabled, or ‘1’ enabled
single tap interrupt: ‘0’disabled, or ‘1’ enabled
double tap interrupt: ‘0’disabled, or ‘1’ enabled
write ‘0’
slope interrupt, z-axis component: ‘0’disabled, or ‘1’ enabled
slope interrupt, y-axis component: ‘0’disabled, or ‘1’ enabled
slope interrupt, x-axis component: ‘0’disabled, or ‘1’ enabled
Bosch Sensortec
BMA255
Data sheet
Page 67
Register 0x17 (INT_EN_1)
Controls which interrupt engines in group 1 are enabled.
Name
Bit
Read/Write
Reset
Value
Content
0x17
7
R/W
INT_EN_1
6
R/W
R/W
R/W
reserved
int_fwm_en
int_ffull_en
data_en
Bit
Read/Write
Reset
Value
Content
3
R/W
R/W
R/W
R/W
low_en
high_en_z
high_en_y
high_en_x
reserved:
int_fwm_en:
int_ffull_en:
data_en
low_en:
high_en_z:
high_en_y:
high_en_x:
write ‘0’
FIFO watermark interrupt: ‘0’disabled, or ‘1’ enabled
FIFO full interrupt: ‘0’disabled, or ‘1’ enabled
data ready interrupt: ‘0’disabled, or ‘1’ enabled
low-g interrupt: ‘0’disabled, or ‘1’ enabled
high-g interrupt, z-axis component: ‘0’disabled, or ‘1’ enabled
high-g interrupt, y-axis component: ‘0’disabled, or ‘1’ enabled
high-g interrupt, x-axis component: ‘0’disabled, or ‘1’ enabled
Bosch Sensortec
BMA255
Data sheet
Page 68
Register 0x18 (INT_EN_2)
Controls which interrupt engines in group 2 are enabled.
Name
Bit
Read/Write
Reset
Value
Content
0x18
7
R/W
INT_EN_2
6
R/W
R/W
R/W
Bit
Read/Write
Reset
Value
Content
3
R/W
R/W
R/W
R/W
slo_no_mot_sel
slo_no_mot_en_z
slo_no_mot_en_y
slo_no_mot_en_x
reserved
reserved:
write ‘0’
slo_no_mot_sel: select ‘0’slow-motion, ‘1’ no-motion interrupt function
slo_no_mot_en_z: slow/n-motion interrupt, z-axis component: ‘0’disabled, or ‘1’ enabled
slo_no_mot_en_y: slow/n-motion interrupt, y-axis component: ‘0’disabled, or ‘1’ enabled
slo_no_mot_en_x: slow/n-motion interrupt, x-axis component: ‘0’disabled, or ‘1’ enabled
Bosch Sensortec
BMA255
Data sheet
Page 69
Register 0x19 (INT_MAP_0)
Controls which interrupt signals are mapped to the INT1 pin.
Name
Bit
Read/Write
Reset
Value
Content
0x19
7
R/W
INT_MAP_0
6
R/W
R/W
R/W
int1_flat
int1_orient
int1_s_tap
int1_d_tap
Bit
Read/Write
Reset
Value
Content
3
R/W
R/W
R/W
R/W
int1_slo_no_mot
int1_slope
int1_high
int1_low
int1_flat:
int1_orient:
int1_s_tap:
int1_d_tap:
int1_slo_no_mot:
int1_slope:
int1_high:
int1_low:
map flat interrupt to INT1 pin: ‘0’disabled, or ‘1’ enabled
map orientation interrupt to INT1 pin: ‘0’disabled, or ‘1’ enabled
map single tap interrupt to INT1 pin: ‘0’disabled, or ‘1’ enabled
map double tap interrupt to INT1 pin: ‘0’disabled, or ‘1’ enabled
map slow/no-motion interrupt to INT1 pin: ‘0’disabled, or ‘1’ enabled
map slope interrupt to INT1 pin: ‘0’disabled, or ‘1’ enabled
map high-g to INT1 pin: ‘0’disabled, or ‘1’ enabled
map low-g to INT1 pin: ‘0’disabled, or ‘1’ enabled
Bosch Sensortec
BMA255
Data sheet
Page 70
Register 0x1A (INT_MAP_1)
Controls which interrupt signals are mapped to the INT1 and INT2 pins.
Name
Bit
Read/Write
Reset
Value
Content
0x1A
7
R/W
INT_MAP_1
6
R/W
R/W
R/W
int2_data
int2_fwm
int2_ffull
reserved
Bit
Read/Write
Reset
Value
Content
3
R/W
R/W
R/W
R/W
reserved
int1_ffull
int1_fwm
int1_data
int2_data:
int2_fwm:
int2_ffull:
reserved:
int1_ffull:
int1_fwm:
int1_data:
map data ready interrupt to INT2 pin: ‘0’disabled, or ‘1’ enabled
map FIFO watermark interrupt to INT2 pin: ‘0’disabled, or ‘1’ enabled
map FIFO full interrupt to INT2 pin: ‘0’disabled, or ‘1’ enabled
write ‘0’
map FIFO full interrupt to INT1 pin: ‘0’disabled, or ‘1’ enabled
map FIFO watermark interrupt to INT1 pin: ‘0’disabled, or ‘1’ enabled
map data ready interrupt to INT1 pin: ‘0’disabled, or ‘1’ enabled
Bosch Sensortec
BMA255
Data sheet
Page 71
Register 0x1B (INT_MAP_2)
Controls which interrupt signals are mapped to the INT2 pin.
Name
Bit
Read/Write
Reset
Value
Content
0x1B
7
R/W
INT_MAP_2
6
R/W
R/W
R/W
int2_flat
int2_orient
int2_s_tap
int2_d_tap
Bit
Read/Write
Reset
Value
Content
3
R/W
R/W
R/W
R/W
int2_slo_no_mot
int2_slope
int2_high
int2_low
int2_flat:
int2_orient:
int2_s_tap:
int2_d_tap:
int2_slo_no_mot:
int2_slope:
int2_high:
int2_low:
map flat interrupt to INT2 pin: ‘0’disabled, or ‘1’ enabled
map orientation interrupt to INT2 pin: ‘0’disabled, or ‘1’ enabled
map single tap interrupt to INT2 pin: ‘0’disabled, or ‘1’ enabled
map double tap interrupt to INT2 pin: ‘0’disabled, or ‘1’ enabled
map slow/no-motion interrupt to INT2 pin: ‘0’disabled, or ‘1’ enabled
map slope interrupt to INT2 pin: ‘0’disabled, or ‘1’ enabled
map high-g to INT2 pin: ‘0’disabled, or ‘1’ enabled
map low-g to INT2 pin: ‘0’disabled, or ‘1’ enabled
Bosch Sensortec
BMA255
Data sheet
Page 72
Register 0x1E (INT_SRC)
Contains the data source definition for interrupts with selectable data source.
Name
Bit
Read/Write
Reset
Value
Content
0x1E
7
R/W
Bit
Read/Write
Reset
Value
Content
3
R/W
int_src_slo_no_m
ot
INT_SRC
6
R/W
R/W
R/W
int_src_data
int_src_tap
2
R/W
R/W
R/W
int_src_slope
int_src_high
int_src_low
reserved
reserved:
write ‘0’
int_src_data:
select ‘0’filtered, or ‘1’ unfiltered data for new data interrupt
int_src_tap:
select ‘0’filtered, or ‘1’ unfiltered data for single-/double tap interrupt
int_src_slo_no_mot: select ‘0’filtered, or ‘1’ unfiltered data for slow/no-motion interrupt
int_src_slope:
select ‘0’filtered, or ‘1’ unfiltered data for slope interrupt
int_src_high:
select ‘0’filtered, or ‘1’ unfiltered data for high-g interrupt
int_src_low:
select ‘0’filtered, or ‘1’ unfiltered data for low-g interrupt
Bosch Sensortec
BMA255
Data sheet
Page 73
Register 0x20 (INT_OUT_CTRL)
Contains the behavioural configuration (electrical behaviour) of the interrupt pins.
Name
Bit
Read/Write
Reset
Value
Content
0x20
7
R/W
Bit
Read/Write
Reset
Value
Content
reserved:
int2_od:
int2_lvl:
int1_od:
int1_lvl:
INT_OUT_CTRL
6
R/W
R/W
R/W
R/W
R/W
1
1
R/W
R/W
1
int2_od
int2_lvl
int1_od
int1_lvl
reserved
write ‘0’
select ‘0’push-pull, or ‘1’ open drain behavior for INT2 pin
select ‘0’active low, or ‘1’active high level for INT2 pin
select ‘0’push-pull, or ‘1’ open drain behavior for INT1 pin
select ‘0’active low, or ‘1’active high level for INT1 pin
Bosch Sensortec
BMA255
Data sheet
Page 74
Register 0x21 (INT_RST_LATCH)
Contains the interrupt reset bit and the interrupt mode selection.
Name
Bit
Read/Write
Reset
Value
Content
0x21
7
W
INT_RST_LATCH
6
5
R/W
R/W
reset_int
Reserved
Bit
Read/Write
Reset
Value
Content
3
R/W
R/W
reset_int:
reserved:
latch_int:
1
R/W
R/W
R/W
latch_int
write ‘1’ clear any latched interrupts, or ‘0’ keep latched interrupts
active
write ‘0’
´0000b´ non-latched,
´0001b´ temporary, 250 ms,
´0010b´ temporary, 500 ms, ´0011b´ temporary, 1 s,
´0100b´ temporary, 2 s,
´0101b´ temporary, 4 s,
´0110b´ temporary, 8 s,
´0111b´ latched,
´1000b´ non-latched,
´1001b´ temporary, 250 s,
´1010b´ temporary, 500 s, ´1011b´ temporary, 1 ms,
´1100b´ temporary, 12.5 ms, ´1101b´ temporary, 25 ms,
´1110b´ temporary, 50 ms, ´1111b´ latched
Register 0x22 (INT_0)
Contains the delay time definition for the low-g interrupt.
Name
Bit
Read/Write
Reset
Value
Content
0x22
7
W
Bit
Read/Write
Reset
Value
Content
3
R/W
1
low_dur:
INT_0
6
R/W
R/W
R/W
R/W
R/W
R/W
1
low_dur
low_dur
low-g interrupt trigger delay according to [low_dur + 1] • 2 ms in a
range from 2 ms to 512 ms; the default corresponds to a delay of 20 ms.
Bosch Sensortec
BMA255
Data sheet
Page 75
Register 0x23 (INT_1)
Contains the threshold definition for the low-g interrupt.
Name
Bit
Read/Write
Reset
Value
Content
0x23
7
W
Bit
Read/Write
Reset
Value
Content
3
R/W
low_th:
INT_1
6
R/W
R/W
1
4
R/W
1
2
R/W
R/W
R/W
low_th
low_th
low-g interrupt trigger threshold according to low_th • 7.81 mg in a
range from 0 g to 1.992 g; the default value corresponds to an acceleration
of 375 mg
Register 0x24 (INT_2)
Contains the low-g interrupt mode selection, the low-g interrupt hysteresis setting, and the highg interrupt hysteresis setting.
Name
Bit
Read/Write
Reset
Value
Content
0x24
7
R/W
1
Bit
Read/Write
Reset
Value
Content
3
R/W
R/W
R/W
reserved
low_mode
low_hy
high_hy:
low_mode:
low_hy:
INT_2
6
R/W
high_hy
5
R/W
R/W
reserved
R/W
1
hysteresis of high-g interrupt according to high_hy · 125 mg (2-g
range), high_hy · 250 mg (4-g range), high_hy · 500 mg (8-g
range), or high_hy · 1000 mg (16-g range)
select low-g interrupt ‘0’ single-axis mode, or ‘1’ axis-summing mode
hysteresis of low-g interrupt according to low_hy · 125 mg independent
of the selected accelerometer g-range
Bosch Sensortec
BMA255
Data sheet
Page 76
Register 0x25 (INT_3)
Contains the delay time definition for the high-g interrupt.
Name
Bit
Read/Write
Reset
Value
Content
0x25
7
R/W
Bit
Read/Write
Reset
Value
Content
3
R/W
1
high_dur:
INT_3
6
R/W
R/W
R/W
R/W
1
1
R/W
1
R/W
1
high_dur
high_dur
high-g interrupt trigger delay according to [high_dur + 1] • 2 ms in a
range from 2 ms to 512 ms; the default corresponds to a delay of 32 ms.
Register 0x26 (INT_4)
Contains the threshold definition for the high-g interrupt.
Name
Bit
Read/Write
Reset
Value
Content
0x26
7
R/W
1
Bit
Read/Write
Reset
Value
Content
3
R/W
high_th:
INT_4
6
R/W
1
5
R/W
R/W
R/W
R/W
R/W
high_th
high_th
threshold of high-g interrupt according to high_th · 7.81 mg (2-g range),
high_th · 15.63 mg (4-g range), high_th · 31.25 mg (8-g range),
or high_th · 62.5 mg (16-g range)
Bosch Sensortec
BMA255
Data sheet
Page 77
Register 0x27 (INT_5)
Contains the definition of the number of samples to be evaluated for the slope interrupt (anymotion detection) and the slow/no-motion interrupt trigger delay.
Name
Bit
Read/Write
Reset
Value
Content
0x27
7
R/W
Bit
Read/Write
Reset
Value
Content
3
R/W
INT_5
6
R/W
R/W
R/W
R/W
R/W
slo_no_mot_dur
2
R/W
slo_no_mot_dur
slope_dur
slo_no_mot_dur:
Function depends on whether the slow-motion or no-motion
interrupt function has been selected. If the slow-motion interrupt function has
been enabled (slo_no_mot_sel = ‘0’) then [slo_no_mot_dur+1]
consecutive slope data points must be above the slow/no-motion threshold
(slo_no_mot_th) for the slow-/no-motion interrupt to trigger. If the no-motion
interrupt function has been enabled (slo_no_mot_sel = ‘1’) then
slo_no_motion_dur defines the time for which no slope data points
must exceed the slow/no-motion threshold (slo_no_mot_th) for the slow/nomotion interrupt to trigger. The delay time in seconds may be calculated
according with the following equation:
slope_dur:
slo_no_mot_dur=’b00’ [slo_no_mot_dur + 1]
slo_no_mot_dur=’b01’ [slo_no_mot_dur · 4 + 20]
slo_no_mot_dur=’1’ [slo_no_mot_dur · 8 + 88]
slope interrupt triggers if [slope_dur+1] consecutive slope data points
are above the slope interrupt threshold slope_th
Bosch Sensortec
BMA255
Data sheet
Page 78
Register 0x28 (INT_6)
Contains the threshold definition for the any-motion interrupt.
Name
Bit
Read/Write
Reset
Value
Content
0x28
7
R/W
Bit
Read/Write
Reset
Value
Content
3
R/W
slope_th:
INT_6
6
R/W
R/W
R/W
1
2
R/W
1
1
R/W
R/W
slope_th
slope_th
Threshold of the any-motion interrupt. It is range-dependent and defined as a
sample-to-sample difference according to
slope_th · 3.91 mg (2-g range) /
slope_th · 7.81 mg (4-g range) /
slope_th · 15.63 mg (8-g range) /
slope_th · 31.25 mg (16-g range)
Register 0x29 (INT_7)
Contains the threshold definition for the slow/no-motion interrupt.
Name
Bit
Read/Write
Reset
Value
Content
0x29
7
R/W
Bit
Read/Write
Reset
Value
Content
3
R/W
INT_7
6
R/W
R/W
R/W
1
1
R/W
R/W
slo_no_mot_th
2
R/W
1
slo_no_mot_th
slo_no_mot_th: Threshold of slow/no-motion interrupt. It is range-dependent and defined
as a sample-to-sample difference according to
slo_no_mot_th · 3.91 mg (2-g range),
slo_no_mot_th · 7.81 mg (4-g range),
slo_no_mot_th · 15.63 mg (8-g range),
slo_no_mot_th · 31.25 mg (16-g range)
Bosch Sensortec
BMA255
Data sheet
Page 79
Register 0x2A (INT_8)
Contains the timing definitions for the single tap and double tap interrupts.
Name
Bit
Read/Write
Reset
Value
Content
0x2A
7
R/W
INT_8
6
R/W
R/W
R/W
tap_quiet
tap_shock
reserved
reserved
Bit
Read/Write
Reset
Value
Content
3
R/W
R/W
1
1
R/W
R/W
reserved
tap_dur
tap_quiet:
tap_shock:
reserved:
tap_dur:
selects a tap quiet duration of ‘0’ 30 ms, ‘1’ 20 ms
selects a tap shock duration of ‘0’ 50 ms, ‘1’75 ms
write ‘0’
selects the length of the time window for the second shock event for double
tap detection according to ´000b´ 50 ms, ´001b´ 100 ms, ´010b´ 150
ms, ´011b´ 200 ms, ´100b´ 250 ms, ´101b´ 375 ms, ´110b´ 500
ms, ´111b´ 700 ms.
Bosch Sensortec
BMA255
Data sheet
Page 80
Register 0x2B (INT_9)
Contains the definition of the number of samples processed by the single / double-tap interrupt
engine after wake-up in low-power mode. It also defines the threshold definition for the single
Name
Bit
Read/Write
Reset
Value
Content
0x2B
7
R/W
Bit
Read/Write
Reset
Value
Content
3
R/W
1
tap_samp:
reserved:
tap_th:
INT_9
6
R/W
tap_samp
2
R/W
R/W
R/W
reserved
tap_th
1
R/W
1
R/W
tap_th
selects the number of samples that are processed after wake-up in the lowpower mode according to ´00b´ 2 samples, ´01b´ 4 samples, ´10b´ 8
samples, and ´11b´ 16 samples
write ‘0’
threshold of the single/double-tap interrupt corresponding to an acceleration
difference of tap_th · 62.5mg (2g-range), tap_th · 125mg (4grange), tap_th · 250mg (8g-range), and tap_th · 500mg (16grange).
Bosch Sensortec
BMA255
Data sheet
Page 81
Register 0x2C (INT_A)
Contains the definition of hysteresis, blocking, and mode for the orientation interrupt
Name
Bit
Read/Write
Reset
Value
Content
0x2C
7
R/W
INT_A
6
R/W
reserved
orient_hyst
Bit
Read/Write
Reset
Value
Content
3
R/W
1
2
R/W
orient_blocking
5
R/W
R/W
1
1
R/W
R/W
orient_mode
reserved:
write ‘0’
orient_hyst: sets the hysteresis of the orientation interrupt; 1 LSB corresponds to 62.5 mg
irrespective of the selected g-range
orient_blocking:
selects the blocking mode that is used for the generation of the
orientation interrupt. The following blocking modes are available:
´00b´ no blocking,
´01b´ theta blocking or acceleration in any axis > 1.5g,
´10b´ ,theta blocking or acceleration slope in any axis > 0.2 g or
´11b´ theta blocking or acceleration slope in any axis > 0.4 g or
acceleration in any axis > 1.5g and value of orient is not stable for
at least 100ms
orient_mode: sets the thresholds for switching between the different orientations. The
settings: ´00b´ symmetrical, ´01b´ high-asymmetrical, ´10b´ lowasymmetrical, ´11b´ symmetrical.
Bosch Sensortec
BMA255
Data sheet
Page 82
Register 0x2D (INT_B)
Contains the definition of the axis orientation, up/down masking, and the theta blocking angle
for the orientation interrupt.
Name
Bit
Read/Write
Reset
Value
Content
0x2D
7
R/W
n/a
INT_B
6
R/W
1
5
R/W
reserved
orient_ud_en
orient_theta
Bit
Read/Write
Reset
Value
Content
3
R/W
1
2
R/W
R/W
R/W
R/W
orient_theta
orient_ud_en:
change of up/down-bit ´1´ generates an orientation interrupt, ´0´ is
ignored and will not generate an orientation interrupt
orient_theta: defines a blocking angle between 0° and 44.8°
Register 0x2E (INT_C)
Contains the definition of the flat threshold angle for the flat interrupt.
Name
Bit
Read/Write
Reset
Value
Content
0x2E
7
R/W
n/a
Bit
Read/Write
Reset
Value
Content
3
R/W
1
reserved:
flat_theta:
INT_C
6
R/W
n/a
reserved
5
R/W
R/W
flat_theta
2
R/W
R/W
R/W
flat_theta
write ‘0’
defines threshold for detection of flat position in range from 0° to 44.8°.
Bosch Sensortec
BMA255
Data sheet
Page 83
Register 0x2F (INT_D)
Contains the definition of the flat interrupt hold time and flat interrupt hysteresis.
Name
Bit
Read/Write
Reset
Value
Content
0x2F
7
R/W
INT_D
6
R/W
Bit
Read/Write
Reset
Value
Content
3
R/W
R/W
reserved
flat_hy
reserved
5
R/W
R/W
1
flat_hold_time
1
R/W
R/W
1
reserved:
write ‘0’
flat_hold_time: delay time for which the flat value must remain stable for the flat interrupt
to be generated: ´00b´ 0 ms, ´01b´ 512 ms, ´10b´ 1024 ms,
´11b´ 2048 ms
flat_hy:
defines flat interrupt hysteresis; flat value must change by more than twice
the value of flat interrupt hysteresis to detect a state change. For details see
chapter 4.7.8.
‘000b’ hysteresis of the flat detection disabled
Bosch Sensortec
BMA255
Data sheet
Page 84
Register 0x30 (FIFO_CONFIG_0)
Contains the FIFO watermark level.
Name
Bit
Read/Write
Reset
Value
Content
0x30
7
R/W
n/a
Bit
Read/Write
Reset
Value
Content
3
R/W
FIFO_CONFIG_0
6
R/W
n/a
reserved
5
R/W
R/W
fifo_water_mark_level_trigger_retain<
5:4>
2
R/W
R/W
R/W
reserved:
write ‘0’
fifo_water_mark_level_trigger_retain:
fifo_water_mark_level_trigger_retain defines the FIFO watermark level.
An interrupt will be generated, when the number of entries in the FIFO is
equal to fifo_water_mark_level_trigger_retain;
Bosch Sensortec
BMA255
Data sheet
Page 85
Register 0x32 (PMU_SELF_TEST)
Contains the settings for the sensor self-test configuration and trigger.
Name
Bit
Read/Write
Reset
Value
Content
0x32
7
R/W
Bit
Read/Write
Reset
Value
Content
3
R/W
R/W
R/W
reserved
self_test_sign
self_test-axis
reserved:
self_test_sign:
self_test_axis:
PMU_SELF_TEST
6
5
R/W
R/W
R/W
reserved
R/W
write ‘0x0’
select sign of self-test excitation as ´1´ positive, or ´0´ negative
select axis to be self-tested: ´00b´ self-test disabled, ´01b´ x-axis, ´10b´
y-axis, or ´11b´ z-axis; when a self-test is performed, only the
acceleration data readout value of the selected axis is valid; after the selftest has been enabled a delay of a least 50 ms is necessary for the read-out
value to settle
Bosch Sensortec
BMA255
Data sheet
Page 86
Register 0x33 (TRIM_NVM_CTRL)
Contains the control settings for the few-time programmable non-volatile memory (NVM).
Name
Bit
Read/Write
Reset
Value
Content
0x33
7
R
n/a
TRIM_NVM_CTRL
6
5
R
R
n/a
n/a
4
R
n/a
Bit
Read/Write
Reset
Value
Content
3
R/W
R
n/a
1
W
R/W
nvm_load
nvm_rdy
nvm_prog_trig
nvm_prog_mode
nvm_remain
nvm_remain:
number of remaining write cycles permitted for NVM; the number is
decremented each time a write to the NVM is triggered
nvm_load:
´1´ trigger, or ‘0’ do not trigger an update of all configuration registers
from NVM; the nvm_rdy flag must be ‘1’ prior to triggering the update
nvm_rdy:
status of NVM controller: ´0´ NVM write / NVM update operation is in
progress, ´1´ NVM is ready to accept a new write or update trigger
nvm_prog_trig:
‘1’ trigger, or ‘0’ do not trigger an NVM write operation; the trigger is
only accepted if the NVM was unlocked before and nvm_remain is
greater than ‘0’; flag nvm_rdy must be ‘1’ prior to triggering the write cycle
nvm_prog_mode: ‘1’ unlock, or ‘0’ lock NVM write operation
Bosch Sensortec
BMA255
Data sheet
Page 87
Register 0x34 (BGW_SPI3_WDT)
Contains settings for the digital interfaces.
Name
Bit
Read/Write
Reset
Value
Content
0x34
7
R/W
Bit
Read/Write
Reset
Value
Content
reserved:
i2c_wdt_en:
i2c_wdt_sel:
spi3:
BGW_SPI3_WDT
6
5
R/W
R/W
R/W
R/W
R/W
R/W
R/W
reserved
i2c_wdt_en
i2c_wdt_sel
spi3
reserved
write ‘0’
if I²C interface mode is selected then ‘1´ enable, or ‘0’ disables the
watchdog at the SDI pin (= SDA for I²C)
select an I²C watchdog timer period of ‘0’ 1 ms, or ‘1’ 50 ms
select ´0´ 4-wire SPI, or ´1´ 3-wire SPI mode
Bosch Sensortec
BMA255
Data sheet
Page 88
Register 0x36 (OFC_CTRL)
Contains control signals and configuration settings for the fast and the slow offset
compensation.
Name
Bit
Read/Write
Reset
Value
Content
0x36
7
W
OFC_CTRL
6
W
offset_reset
cal_trigger
Bit
Read/Write
Reset
Value
Content
3
R/W
R/W
R/W
R/W
reserved
hp_z_en
hp_y_en
hp_x_en
5
W
R
cal_rdy
offset_reset:
´1´ set all offset compensation registers (0x38 to 0x3A) to zero, or ‘0’
keep their values
offset_trigger: trigger fast compensation for ´01b´ x-axis, ´10b´ y-axis, or ´11b´
z-axis; ´00b´ do not trigger offset compensation; offset compensation
must not be triggered when cal_rdy is ‘0’
cal_rdy:
indicates the state of the fast compensation: ´0´ offset compensation is in
progress, or ´1´ offset compensation is ready to be retriggered
reserved:
write ‘0’
hp_z_en:
‘1´ enable, or ‘0’ disable slow offset compensation for the z-axis
hp_y_en:
‘1´ enable, or ‘0’ disable slow offset compensation for the y-axis
hp_x_en:
‘1´ enable, or ‘0’ disable slow offset compensation for the x-axis
Bosch Sensortec
BMA255
Data sheet
Page 89
Register 0x37 (OFC_SETTING)
Contains configuration settings for the fast and the slow offset compensation.
Name
Bit
Read/Write
Reset
Value
Content
0x37
7
R/W
OFC_SETTING
6
R/W
reserved
offset_target_z
offset_target_y
Bit
Read/Write
Reset
Value
Content
3
R/W
R/W
R/W
offset_target_y
offset_target_x
5
R/W
R/W
R/W
cut_off
reserved:
write ‘0’
offset_target_z: offset compensation target value for z-axis is ´00b´ 0 g, ´01b´ +1 g,
´10b´ -1 g, or ´11b´ 0 g
offset_target_y: offset compensation target value for y-axis is ´00b´ 0 g, ´01b´ +1 g,
offset_target_x: offset compensation target value for x-axis is ´00b´ 0 g, ´01b´ +1 g,
cut_off:
(0x37)
cut_off
high-pass filter
bandwidth
Example
bw = 500 Hz
0b
1b
*bw: please insert selected decimal data bandwidth value [Hz] from table 4
Bosch Sensortec
BMA255
Data sheet
Page 90
Register 0x38 (OFC_OFFSET_X)
Contains the offset compensation value for x-axis acceleration readout data.
Name
Bit
Read/Write
Reset
Value
Content
0x38
7
R/W
Bit
Read/Write
Reset
Value
Content
3
R/W
offset_ x:
OFC_OFFSET_X
6
R/W
R/W
R/W
R/W
R/W
R/W
offset_x
offset_x
offset value, which is subtracted from the internal filtered and unfiltered xaxis acceleration data; the offset value is represented with two’s complement
notation, with a mapping of +127 +0.992g, 0 0 g, and -128 -1 g; the
scaling is independent of the selected g-range; the content of the
offset_x may be written to the NVM; it is automatically restored from
the NVM after each power-on or softreset; offset_x may be written
directly by the user; it is generated automatically after triggering the fast
offset compensation procedure for the x-axis
Bosch Sensortec
BMA255
Data sheet
Page 91
Register 0x39 (OFC_OFFSET_Y)
Contains the offset compensation value for y-axis acceleration readout data.
Name
Bit
Read/Write
Reset
Value
Content
0x39
7
R/W
Bit
Read/Write
Reset
Value
Content
3
R/W
offset_ y:
OFC_OFFSET_Y
6
R/W
R/W
R/W
R/W
R/W
R/W
offset_y
offset_y
offset value, which is subtracted from the internal filtered and unfiltered yaxis acceleration data; the offset value is represented with two’s complement
offset_y may be written to the NVM; it is automatically restored from
the NVM after each power-on or softreset; offset_y may be written
offset compensation procedure for the y-axis
Bosch Sensortec
BMA255
Data sheet
Page 92
Register 0x3A (OFC_OFFSET_Z)
Contains the offset compensation value for z-axis acceleration readout data.
Name
Bit
Read/Write
Reset
Value
Content
0x3A
7
R/W
Bit
Read/Write
Reset
Value
Content
3
R/W
offset_ z:
OFC_OFFSET_Z
6
R/W
R/W
R/W
R/W
R/W
R/W
offset_z
offset_z
offset value, which is subtracted from the internal filtered and unfiltered zaxis acceleration data; the offset value is represented with two’s complement
offset_z may be written to the NVM; it is automatically restored from
the NVM after each power-on or softreset; offset_z may be written
offset compensation procedure for the z-axis
Register 0x3B (TRIM_GP0)
Contains general purpose data register with NVM back-up.
Name
Bit
Read/Write
Reset
Value
Content
0x3B
7
R/W
Bit
Read/Write
Reset
Value
Content
3
R/W
GP0:
TRIM_GP0
6
R/W
R/W
R/W
R/W
R/W
R/W
GP0
GP0
general purpose NVM image register not linked to any sensor-specific
functionality; register may be written to NVM and is restored after each
power-up or softreset
Bosch Sensortec
BMA255
Data sheet
Page 93
Register 0x3C (TRIM_GP1)
Name
Bit
Read/Write
Reset
Value
Content
0x3C
7
R/W
Bit
Read/Write
Reset
Value
Content
3
R/W
GP1:
TRIM_GP1
6
R/W
R/W
R/W
R/W
R/W
R/W
GP1
GP1
Bosch Sensortec
BMA255
Data sheet
Page 94
Register 0x3E (FIFO_CONFIG_1)
Contains FIFO configuration settings. The FIFO buffer memory is cleared and the fifo-full flag is
cleared when writing to FIFO_CONFIG_1 register.
Name
Bit
Read/Write
Reset
Value
Content
0x3E
7
R/W
Bit
Read/Write
Reset
Value
Content
3
R/W
FIFO_CONFIG_1
6
R/W
fifo_mode
Reserved
5
R/W
R/W
Reserved
2
R/W
R/W
R/W
fifo_data_select
fifo_mode:
selects the FIFO operating mode:
´00b´ BYPASS (buffer depth of 1 frame; old data is discarded),
´01b´ FIFO (data collection stops when buffer is filled with 32 frames),
´10b´ STREAM (sampling continues when buffer is full; old is discarded),
´11b´ reserved, do not use
fifo_data_select:
selects whether ´00b´ X+Y+Z, ´01b´ X only, ´10b´ Y only,
´11b´ Z only acceleration data are stored in the FIFO
Bosch Sensortec
BMA255
Data sheet
Page 95
Register 0x3F (FIFO_DATA)
FIFO data readout register. The format of the LSB and MSB components corresponds to that of
the acceleration data readout registers. The new data flag is preserved. Read burst access may
be used since the address counter will not increment when the read burst is started at the
address of FIFO_DATA. The entire frame is discarded when a fame is only partially read out.
Name
Bit
Read/Write
Reset
Value
Content
0x3F
7
R
n/a
Bit
Read/Write
Reset
Value
Content
3
R
n/a
FIFO_DATA
6
R
n/a
5
R
n/a
4
R
n/a
1
R
n/a
R
n/a
2
R
n/a
fifo_data_output_register:
FIFO data readout; data format depends on the setting of
register fifo_data_select:
if X+Y+Z data are selected, the data of frame n is reading out in the order of
X-lsb(n), X-msb(n), Y-lsb(n), Y-msb(n), Z-lsb(n), Z-msb(n);
if X-only is selected, the data of frame n and n+1 are reading out in the order
of X-lsb(n), X-msb(n), X-lsb(n+1), X-msb(n+1); the Y-only and Z-only modes
behave analogously
Bosch Sensortec
BMA255
Data sheet
Page 96
7. Digital interfaces
The BMA255 supports two serial digital interface protocols for communication as a slave with a
host device (when operating in general mode): SPI and I²C. The active interface is selected by
the state of the Pin#11 (PS) ‘protocol select’ pin: ´0´ (´1´) selects SPI (I²C). For details please
refer to section 8).
By default, SPI operates in the standard 4-wire configuration. It can be re-configured by
software to work in 3-wire mode instead of standard 4-wire mode.
Both interfaces share the same pins. The mapping for each interface is given in the following
table:
Table 20: Mapping of the interface pins
Pin#
Name
use w/
SPI
use w/
I²C
1
SDO
SDO
address
2
SDx
SDI
SDA
10
CSB
CSB
unused
Chip Select (enable)
12
SCx
SCK
SCL
SPI: Serial Clock
I²C: Serial Clock
Description
SPI: Data Output (4-wire mode)
I²C: Used to set LSB of I²C address
SPI: Data Input (4-wire mode) Data Input / Output (3-wire
mode)
I²C: Serial Data
The following table shows the electrical specifications of the interface pins:
Table 21: Electrical specification of the interface pins
Parameter
Symbol
Condition
Min
Typ
Max
Units
Pull-up Resistance,
CSB pin
Rup
Internal Pull-up
Resistance to
VDDIO
75
100
125
k
Input Capacitance
Cin
5
10
pF
I²C Bus Load
Capacitance (max.
drive capability)
CI2C_Load
400
pF
Bosch Sensortec
BMA255
Data sheet
Page 97
7.1 Serial peripheral interface (SPI)
The timing specification for SPI of the BMA255 is given in the following table:
Table 22: SPI timing
Parameter
Clock Frequency
SCK Low Pulse
SCK High Pulse
SDI Setup Time
SDI Hold Time
Condition
Max
Units
Max. Load on SDI
or SDO = 25pF,
VDDIO ≥ 1.62V
fSPI
10
MHz
VDDIO < 1.62V
7.5
MHz
tSCKL
tSCKH
tSDO_OD
Min
tSDI_setup
tSDI_hold
SDO Output Delay
CSB Setup Time
CSB Hold Time
Idle time between
write accesses, normal
mode, standby mode,
low-power mode 2
Idle time between
write accesses,
suspend mode, lowpower mode 1
Symbol
Load = 25pF,
VDDIO ≥ 1.62V
Load = 25pF,
VDDIO < 1.62V
Load = 250pF,
VDDIO > 2.4V
ns
ns
ns
ns
30
ns
50
ns
40
ns
tCSB_setup
tCSB_hold
ns
ns
tIDLE_wacc_nm
2
µs
tIDLE_wacc_sum
450
µs
Bosch Sensortec
BMA255
Data sheet
Page 98
The following figure shows the definition of the SPI timings given in the following figure:
tCSB_setup
tCSB_hold
CSB
SCK
tSCKL tSCKH
SDI
SDO
tSDI_setup
tSDI_hold
tSDO_OD
Figure 13: SPI timing diagram
The SPI interface of the BMA255 is compatible with two modes, ´00´ and ´11´. The automatic
selection between [CPOL = ´0´ and CPHA = ´0´] and [CPOL = ´1´ and CPHA = ´1´] is controlled
based on the value of SCK after a falling edge of CSB.
Two configurations of the SPI interface are supported by the BMA255: 4-wire and 3-wire. The
same protocol is used by both configurations. The device operates in 4-wire configuration by
default. It can be switched to 3-wire configuration by writing ´1´ to (0x34) spi3. Pin SDI is used
as the common data pin in 3-wire configuration.
For single byte read as well as write operations, 16-bit protocols are used. The BMA255 also
supports multiple-byte read operations.
In SPI 4-wire configuration CSB (chip select low active), SCK (serial clock), SDI (serial data
input), and SDO (serial data output) pins are used. The communication starts when the CSB is
pulled low by the SPI master and stops when CSB is pulled high. SCK is also controlled by SPI
master. SDI and SDO are driven at the falling edge of SCK and should be captured at the rising
edge of SCK.
Bosch Sensortec
BMA255
Data sheet
Page 99
The basic write operation waveform for 4-wire configuration is depicted in figure 14. During the
entire write cycle SDO remains in high- impedance state.
CSB
SCK
SDI
R/W
AD6
AD5
AD4
AD3
AD2
AD1
SDO
AD0
DI7
DI6
DI5
DI4
DI3
DI2
DI1
DI0
Z
tri-state
Figure 14: 4-wire basic SPI write sequence (mode ´11´)
The basic read operation waveform for 4-wire configuration is depicted in figure 15:
CSB
SCK
SDI
R/W
AD6
AD5
AD4
AD3
AD2
AD1
AD0
SDO
DO7 DO6 DO5 DO4 DO3 DO2 DO1 DO0 tri-state
Figure 15: 4-wire basic SPI read sequence (mode ´11´)
Bosch Sensortec
BMA255
Data sheet
Page 100
The data bits are used as follows:
Bit0: Read/Write bit. When 0, the data SDI is written into the chip. When 1, the data SDO from
the chip is read.
Bit1-7: Address AD(6:0).
Bit8-15: when in write mode, these are the data SDI, which will be written into the address.
When in read mode, these are the data SDO, which are read from the address.
Multiple read operations are possible by keeping CSB low and continuing the data transfer.
Only the first register address has to be written. Addresses are automatically incremented after
each read access as long as CSB stays active low.
The principle of multiple read is shown in figure 16:
Control byte
Start
RW
CSB
Register adress (02h)
X
Data byte
Data byte
Data byte
Data register - adress 02h
Data register - adress 03h
Data register - adress 04h
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
Stop
X
X
CSB
1
Figure 16: SPI multiple read
In SPI 3-wire configuration CSB (chip select low active), SCK (serial clock), and SDI (serial
data input and output) pins are used. The communication starts when the CSB is pulled low by
the SPI master and stops when CSB is pulled high. SCK is also controlled by SPI master. SDI
is driven (when used as input of the device) at the falling edge of SCK and should be captured
(when used as the output of the device) at the rising edge of SCK.
The protocol as such is the same in 3-wire configuration as it is in 4-wire configuration. The
basic operation waveform (read or write access) for 3-wire configuration is depicted in figure 17:
CSB
SCK
SDI
RW
AD6
AD5
AD4
AD3
AD2
AD1
AD0
DI7
DI6
DI5
DI4
DI3
DI2
DI1
DI0
Figure 17: 3-wire basic SPI read or write sequence (mode ´11´)
Bosch Sensortec
BMA255
Data sheet
Page 101
7.2 Inter-Integrated Circuit (I²C)
The I²C bus uses SCL (= SCx pin, serial clock) and SDA (= SDx pin, serial data input and
output) signal lines. Both lines are connected to VDDIO externally via pull-up resistors so that they
are pulled high when the bus is free.
The I²C interface of the BMA255 is compatible with the I²C Specification UM10204 Rev. 03 (19
June 2007), available at http://www.nxp.com. The BMA255 supports I²C standard mode and
fast mode, only 7-bit address mode is supported.
The default I²C address of the device is 0011000b (0x18). It is used if the SDO pin is pulled to
´GND´. The alternative address 0011001b (0x19) is selected by pulling the SDO pin to ´VDDIO´.
The timing specification for I²C of the BMA255 is given in Table 23:
Table 23: I²C timings
Parameter
Symbol
Clock Frequency
SCL Low Period
SCL High Period
SDA Setup Time
SDA Hold Time
Setup Time for a
repeated Start
Condition
Hold Time for a Start
Condition
Setup Time for a Stop
Condition
Time before a new
Transmission can
start
Idle time between
write accesses,
normal mode, standby
mode, low-power
mode 2
Idle time between
write accesses,
fSCL
tLOW
tHIGH
Condition
Min
tSUDAT
tHDDAT
1.3
0.6
0.1
0.0
tSUSTA
0.6
Max
Units
400
kHz
s
tHDSTA
0.6
tSUSTO
0.6
tBUF
1.3
tIDLE_wacc_n
m
tIDLE_wacc_s
um
2
µs
450
µs
Bosch Sensortec
BMA255
Data sheet
Page 102
Figure 18 shows the definition of the I²C timings given in Table 23:
SDA
tBUF
tf
tLOW
SCL
tHIGH
tr
tHDSTA
tHDDAT
tSUDAT
SDA
tSUSTA
tSUSTO
Figure 18: I²C timing diagram
The I²C protocol works as follows:
START: Data transmission on the bus begins with a high to low transition on the SDA line while
SCL is held high (start condition (S) indicated by I²C bus master). Once the START signal is
transferred by the master, the bus is considered busy.
STOP: Each data transfer should be terminated by a Stop signal (P) generated by master. The
STOP condition is a low to HIGH transition on SDA line while SCL is held high.
ACK: Each byte of data transferred must be acknowledged. It is indicated by an acknowledge
bit sent by the receiver. The transmitter must release the SDA line (no pull down) during the
acknowledge pulse while the receiver must then pull the SDA line low so that it remains stable
low during the high period of the acknowledge clock cycle.
In the following diagrams these abbreviations are used:
S
P
ACKS
ACKM
NACKM
RW
Start
Stop
Acknowledge by slave
Acknowledge by master
Not acknowledge by master
Read / Write
A START immediately followed by a STOP (without SCK toggling from logic “1” to logic “0”) is
not supported. If such a combination occurs, the STOP is not recognized by the device.
Bosch Sensortec
BMA255
Data sheet
Page 103
I²C write access:
I²C write access can be used to write a data byte in one sequence.
The sequence begins with start condition generated by the master, followed by 7 bits slave
address and a write bit (RW = 0). The slave sends an acknowledge bit (ACK = 0) and releases
the bus. Then the master sends the one byte register address. The slave again acknowledges
the transmission and waits for the 8 bits of data which shall be written to the specified register
address. After the slave acknowledges the data byte, the master generates a stop signal and
terminates the writing protocol.
Example of an I²C write access:
Control byte
Slave Adress
Start
S
1
Register adress (0x10)
RW ACKS
Data byte
Data (0x09)
ACKS
X
X
X
X
X
ACKS Stop
X
X
X
P
Figure 19: I²C write
I²C read access:
I²C read access also can be used to read one or multiple data bytes in one sequence.
A read sequence consists of a one-byte I²C write phase followed by the I²C read phase. The
two parts of the transmission must be separated by a repeated start condition (Sr). The I²C write
phase addresses the slave and sends the register address to be read. After slave
acknowledges the transmission, the master generates again a start condition and sends the
slave address together with a read bit (RW = 1). Then the master releases the bus and waits for
the data bytes to be read out from slave. After each data byte the master has to generate an
acknowledge bit (ACK = 0) to enable further data transfer. A NACKM (ACK = 1) from the
master stops the data being transferred from the slave. The slave releases the bus so that the
master can generate a STOP condition and terminate the transmission.
The register address is automatically incremented and, therefore, more than one byte can be
sequentially read out. Once a new data read transmission starts, the start address will be set to
the register address specified in the latest I²C write command. By default the start address is
set at 0x00. In this way repetitive multi-bytes reads from the same starting address are possible.
In order to prevent the I²C slave of the device to lock-up the I²C bus, a watchdog timer (WDT) is
implemented. The WDT observes internal I²C signals and resets the I²C interface if the bus is
locked-up by the BMA255. The activity and the timer period of the WDT can be configured
through the bits (0x34) i2c_wdt_en and (0x34) i2c_wdt_sel.
Writing ´1´ (´0´) to (0x34) i2c_wdt_en activates (de-activates) the WDT. Writing ´0´ (´1´) to
(0x34) i2c_wdt_se selects a timer period of 1 ms (50 ms).
Bosch Sensortec
BMA255
Data sheet
Page 104
Example of an I²C read access:
Slave Adress
Start
S
1
RW ACKS
dummy
Control byte
X
Register adress (0x02)
ACKS
Data byte
Slave Adress
Start
Sr
1
Read Data (0x02)
RW ACKS
Data byte
X
X
X
X
X
X
Read Data (0x03)
ACKM
X
X
X
X
X
Data byte
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
X
Data byte
Data byte
Read Data (0x07)
X
X
X
Read Data (0x05)
ACKM
Read Data (0x06)
X
X
Data byte
Read Data (0x04)
X
ACKM
X
ACKM
X
X
X
X
X
X
X
X
ACKM
X
X
NACK
X
X
Stop
P
Figure 20: I²C multiple read
7.2.1 SPI and I²C Access Restrictions
In order to allow for the correct internal synchronisation of data written to the BMA255, certain
access restrictions apply for consecutive write accesses or a write/read sequence through the
SPI as well as I2C interface. The required waiting period depends on whether the device is
operating in normal mode (or standby mode, or low-power mode 2) or suspend mode (or lowpower mode 1).
As illustrated in figure 21, an interface idle time of at least 2 µs is required following a write
operation when the device operates in normal mode (or standby mode, or low-power mode 2).
In suspend mode (or low-power mode 1) an interface idle time of least 450 µs is required.
X-after-Write
Write-Operation
X-Operation
Register Update Period
(> 2us / 450us)
Figure 21: Post-Write Access Timing Constraints
Bosch Sensortec
BMA255
Data sheet
Page 105
8. Pin-out and connection diagram
8.1 Pin-out
Top View
Pads not visible!
Bottom View
Pads visible!
Figure 22: Pin-out top view
Figure 23: Pin-out bottom view
Table 24: Pin description
Pin#
Name
I/O Type
1
SDO
Digital out
2
SDx
Digital I/O
3
VDDIO
Supply
4
5
6
NC
INT1
INT2
-Digital out
Digital out
7
VDD
Supply
8
9
10
GNDIO
GND
CSB
Ground
Ground
Digital in
11
PS
Digital in
12
SCx
Digital in
Description
Serial data output in SPI
Address select in I²C mode
see chapter 7.2
SDA serial data I/O in I²C
SDI serial data input in SPI
4W
SDA serial data I/O in SPI
3W
Digital I/O supply voltage
(1.2V … 3.6V)
Interrupt output 1 *
Interrupt output 2 *
Power supply for analog &
digital domain (1.62V …
3.6V)
Ground for I/O
Ground for digital & analog
Chip select for SPI mode
Protocol select (GND = SPI,
VDDIO = I²C)
SCK for SPI serial clock
SCL for I²C serial clock
in SPI 4W
Connect to
In SPI 3W
in I²C
SDO
DNC (float)
GND for default
addr.
SDI
SDA
SDA
VDDIO
VDDIO
VDDIO
GND
INT1
INT2
GND
INT1
INT2
GND
INT1
INT2
VDD
VDD
VDD
GND
GND
CSB
GND
GND
CSB
GND
GND
DNC (float)
GND
GND
VDDIO
SCK
SCK
SCL
* If INT1 and/or INT2 are not used, please do not connect them (DNC).
Bosch Sensortec
BMA255
Data sheet
Page 106
8.2 Connection diagram 4-wire SPI
Figure 24: 4-wire SPI connection
Note: the recommended value for C1, C2 is 100 nF.
Bosch Sensortec
BMA255
Data sheet
Page 107
8.3 Connection diagram 3-wire SPI
Figure 25: 3-wire SPI connection
Bosch Sensortec
BMA255
Data sheet
Page 108
8.4 Connection diagram I2C
Figure 26: I²C connection
Bosch Sensortec
BMA255
Data sheet
Page 109
9. Package
9.1 Outline dimensions
The sensor housing is a standard LGA package. Its dimensions are the following.
Pin1 marking:
Metal pad internally connected to GND
(external connection not recommended)
Figure 27: Package outline dimensions
Bosch Sensortec
BMA255
Data sheet
Page 110
9.2 Sensing axes orientation
If the sensor is accelerated in the indicated directions, the corresponding channel will deliver a
positive acceleration signal (dynamic acceleration). If the sensor is at rest and the force of
gravity is acting along the indicated directions, the output of the corresponding channel will be
negative (static acceleration).
Example: If the sensor is at rest or at uniform motion in a gravity field according to the figure
given below, the output signals are:
± 0g for the X channel
± 0g for the Y channel
+ 1g for the Z channel
Figure 28: Orientation of sensing axis
The following table lists all corresponding output signals on X, Y, and Z while the sensor is at
rest or at uniform motion in a gravity field under assumption of a ±2g range setting and a top
down gravity vector as shown above.
Table 25: Output signals depending on sensor orientation
Output Signal X
0g / 0LSB
1g / 1024LSB
0g / 0LSB -1g / -1024LSB
Output Signal Y -1g / -1024LSB
0g / 0LSB 1g / 1024LSB
0g / 0LSB
Output Signal Z
0g / 0LSB
0g / 0LSB
0g / 0LSB
0g / 0LSB
upright
upright
Sensor Orientation
(gravity vector )
0g / 0LSB
0g / 0LSB
0g / 0LSB
0g / 0LSB
1g / 1024LSB -1g / -1024LSB
Bosch Sensortec
BMA255
Data sheet
Page 111
9.3 Landing Pattern Recommendation
For the design of the landing patterns, we recommend the following dimensioning:
Figure 29: Landing patterns; dimensions are in mm
Same tolerances as given for the outline dimensions (Chapter 9.1, Figure 27) should be
assumed.
A wiring no-go area in the top layer of the PCB below the sensor is strongly recommended (e.g.
no vias, wires or other metal structures).
Bosch Sensortec
BMA255
Data sheet
Page 112
9.4 Marking
9.4.1 Mass production samples
Table 26: Marking of mass production samples
Labeling
CCC
TL
Name
Symbol
Remark
Lot counter
CCC
3 alphanumeric digits, variable
to generate mass production trace-code
Product number
T
1 alphanumeric digit, fixed
to identify product type, T = “K”
Sub-con ID
L
1 alphanumeric digit, variable
to identify sub-con
Pin 1 identifier
9.4.2 Engineering samples
Table 27: Marking of engineering samples
Labeling
XXN
CC
Name
Symbol
Remark
Eng. sample ID
N
1 alphanumeric digit, fixed to identify
engineering sample, N = “ * ” or “e” or “E”
Sample ID
XX
2 alphanumeric digits, variable
to generate trace-code.
Counter ID
CC
Pin 1 identifier
Bosch Sensortec
BMA255
Data sheet
Page 113
9.5 Soldering guidelines
The moisture sensitivity level of the BMA255 sensors corresponds to JEDEC Level 1, see also
IPC/JEDEC J-STD-020C
"Joint Industry Standard: Moisture/Reflow Sensitivity
Classification for non-hermetic Solid State Surface Mount Devices"
IPC/JEDEC J-STD-033A "Joint Industry Standard: Handling, Packing, Shipping and Use of
Moisture/Reflow Sensitive Surface Mount Devices"
The sensor fulfils the lead-free soldering requirements of the above-mentioned IPC/JEDEC
standard, i.e. reflow soldering with a peak temperature up to 260°C.
Figure 30: Soldering profile
Bosch Sensortec
BMA255
Data sheet
Page 114
9.6 Handling instructions
Micromechanical sensors are designed to sense acceleration with high accuracy even at low
amplitudes and contain highly sensitive structures inside the sensor element. The MEMS
sensor can tolerate mechanical shocks up to several thousand g's. However, these limits might
be exceeded in conditions with extreme shock loads such as e.g. hammer blow on or next to
the sensor, dropping of the sensor onto hard surfaces etc.
We recommend to avoid g-forces beyond the specified limits during transport, handling and
mounting of the sensors in a defined and qualified installation process.
This device has built-in protections against high electrostatic discharges or electric fields (e.g.
2kV HBM); however, anti-static precautions should be taken as for any other CMOS
component. Unless otherwise specified, proper operation can only occur when all terminal
voltages are kept within the supply voltage range. Unused inputs must always be tied to a
defined logic voltage level.
Bosch Sensortec
BMA255
Data sheet
Page 115
9.7 Tape and reel specification
The BMA255 is shipped in a standard cardboard box.
The box dimension for 1 reel is: L x W x H = 35cm x 35cm x 6cm.
BMA255 quantity: 10,000pcs per reel, please handle with care.
Figure 31: Tape and reel dimensions in mm
Bosch Sensortec
BMA255
Data sheet
Page 116
9.7.1 Orientation within the reel
Processing direction
Figure 32: Orientation of the BMA255 devices relative to the tape
BST-BMA255-DS004-05 | Revision 1.2 | August 2014
Bosch Sensortec
© Bosch Sensortec GmbH reserves all rights even in the event of industrial property rights. We reserve all rights of disposal such as copying and passing on to
third parties. BOSCH and the symbol are registered trademarks of Robert Bosch GmbH, Germany.
Note: Specifications within this document are subject to change without notice.
BMA255
Data sheet
Page 117
9.8 Environmental safety
The BMA255 sensor meets the requirements of the EC restriction of hazardous substances
(RoHS) directive, see also:
Directive 2002/95/EC of the European Parliament and of the Council of 8 September
2011 on the restriction of the use of certain hazardous substances in electrical and
electronic equipment.
9.8.1 Halogen content
The BMA255 is halogen-free. For more details on the analysis results please contact your
Bosch Sensortec representative.
9.8.2 Internal package structure
Within the scope of Bosch Sensortec’s ambition to improve its products and secure the mass
product supply, Bosch Sensortec qualifies additional sources (e.g. 2nd source) for the LGA
package of the BMA255.
While Bosch Sensortec took care that all of the technical packages parameters are described
above are 100% identical for all sources, there can be differences in the chemical content and
the internal structural between the different package sources.
However, as secured by the extensive product qualification process of Bosch Sensortec, this
has no impact to the usage or to the quality of the BMA255 product.
Bosch Sensortec
BMA255
Data sheet
Page 118
10. Legal disclaimer
10.1 Engineering samples
Engineering Samples are marked with an asterisk (*) or (e) or (E). Samples may vary from the
valid technical specifications of the product series contained in this data sheet. They are
therefore not intended or fit for resale to third parties or for use in end products. Their sole
purpose is internal client testing. The testing of an engineering sample may in no way replace
the testing of a product series. Bosch Sensortec assumes no liability for the use of engineering
samples. The Purchaser shall indemnify Bosch Sensortec from all claims arising from the use of
engineering samples.
10.2 Product use
Bosch Sensortec products are developed for the consumer goods industry. They may only be
used within the parameters of this product data sheet. They are not fit for use in life-sustaining
or security sensitive systems. Security sensitive systems are those for which a malfunction is
expected to lead to bodily harm or significant property damage. In addition, they are not fit for
use in products which interact with motor vehicle systems.
The resale and/or use of products are at the purchaser’s own risk and his own responsibility.
The examination of fitness for the intended use is the sole responsibility of the Purchaser.
The purchaser shall indemnify Bosch Sensortec from all third party claims arising from any
product use not covered by the parameters of this product data sheet or not approved by Bosch
Sensortec and reimburse Bosch Sensortec for all costs in connection with such claims.
The purchaser must monitor the market for the purchased products, particularly with regard to
product safety, and inform Bosch Sensortec without delay of all security relevant incidents.
10.3 Application examples and hints
With respect to any examples or hints given herein, any typical values stated herein and/or any
information regarding the application of the device, Bosch Sensortec hereby disclaims any and
all warranties and liabilities of any kind, including without limitation warranties of noninfringement of intellectual property rights or copyrights of any third party. The information given
in this document shall in no event be regarded as a guarantee of conditions or characteristics.
They are provided for illustrative purposes only and no evaluation regarding infringement of
intellectual property rights or copyrights or regarding functionality, performance or error has
been made.
Bosch Sensortec
BMA255
Data sheet
Page 119
11. Document history and modification
Rev. No
0.1
0.2
0.3
0.4
0.5
0.6
0.7
1.0
1.1
1.2
Chapter
All
1, 4.1, 4.2,
6.2, 7.1,
9.3
4.5.2,
4.7.8, 6.2,
9.1, 9.3
1, 4.2,
4.7.3,
4.7.7, 6.2,
9.3, 9.4.1,
9.8
4.7
6.2
4.2
4.5.1
4.7.6
6.2
7.2
Description of modification/changes
Initial internal release
Internal revision, not for release
Initial external release
Date
01 June 2012
Update
24 Sep 2012
Update
22 Oct 2012
Update
21 May 2013
01 August 2012
Update Single tap; update high-g interrupt
12.12.13
Update 0x0F; update 0x2B; update 0x32
sleeptimer_en->sleeptimer_mode,
linguistic
01 August 2014
improvement: “… a wake-up time of at least …
Slow compensation update (High-pass filter cut
off frequency)
Tap sensing update (temporary latched interrupt)
0x37 cut_of update
I²C description update
Gerhard-Kindler-Strasse 8
72770 Reutlingen / Germany
contact@bosch-sensortec.com
www.bosch-sensortec.com
Modifications reserved | Printed in Germany
Specifications subject to change without notice
Document number: BST-BMA255-DS004-05
Revision_1.2_August 2014
Bosch Sensortec
