Bosch Sensortec
BHI260
Shuttle Board
GENERAL DESCRIPTION
Bosch Sensortec’s BHI260 shuttle board is a PCB with the
BHI260, a smart sensor hub with integrated IMU sensor,
mounted on it.
In addition to the BHI260, the board includes
on M2 master interface (configured as I2C):
a BME280 environmental sensor (p, rH, T)
a BMM150 magnetometer
an AK09915 magnetometer
on QSPI interface:
a W25Q32FWSSI 4M-Byte flash memory
connected to the BHI260.
Addition sensors can be connected to the M3 I2C bus, using
connector J8.
The shuttle board allows easy access to pins of the smart sensor
hub via a simple socket. The shuttle board comes pre-mounted
on a level-shifter board, which allows the PCB stack to be directly
plugged into Bosch Sensortec’s advanced development tool
(application board).
Block diagram of BHI260 shuttle board
BHI260 shuttle board mounted on level-shifter
board (product photo may differ from real
product appearance).
Do not connect the shuttle board directly to the
application board, as this can lead to severe
damage of the shuttle board and its components.
Connection of shuttle board, level shifter board
and application board
Bosch Sensortec | BHI260
Designator
J1
2|6
Function
Shuttle board
connector
Description
Pin number
Pin name
Description
1
VDD
Power supply (1.8V only!)
2
VDDIO
3,23
GND
Ground
4,15
MISO
Master-input-slave-output data pin of SPI bus
(connected to BHI260 host interface)
5,17
MOSI
6,18
SCK
7
CS
21
INT
Master-output-slave-input data pin of SPI bus, or SDA
of I2C bus (connected to BHI260 host interface)
Clock pin of both SPI and I2C bus (connected to
Chip selection pin of SPI bus (connected to BHI260
host interface)
Host interrupt pin (connected to BHI260 host interrupt)
13,12,11,
10,28,27,
26,25,24
COD[x]
8,9,14,
15,16,19,
20,22,
NC
Device code for Application board, COD of BHI260
shuttle board is [100011001].
Not used.
J2,J3,J4
Access points to
BHI260 supply
(e.g. for power
measurement)
J2: BHI260 VDD pad
J3: BHI260 VDDIO pad
J4: BHI260_GND (GND+GNDIO) line
J5,J6
Pull-up resistors
for host interface
running in I2C
mode
J5: BHI260 HSCX pad(SCK)
J6: BHI260 HSDX pad(SDA)
J7
Boot source
selection
J7: BHI260 HOSTBOOT pad
J8
M3 I2C interface
for bus
extensions
J18
J19,J20
2-wire JTAG
connector
Bus master
selection for I2C
sensors on
shuttle board
Pin number
Pin name
Description
M3_SDA
SDA pin of M3, with a 4.7kohm pull-up to 1.8V
VDDIO
2
M3_SCL
SCL pin of M3, with a 4.7kohm pull-up to 1.8V VDDIO
3
GND
Pin number
Pin name
1
TMS
2,3
NC
Not used.
4
CLK
CLK pin of 2-wire JTAG.
5
GND
Ground pin.
6
VDDIO
1
Ground pin.
Description
TMS pin of 2-wire JTAG.
Power supply of JTAG, connected to VDDIO of
BHI260.
Jumper setting
Bus master of sensors
M2 (Left)
M2 of BHI260
AUX (Right)
AUX of BHI260
Data & Specification are preliminary and subject to change without notice | | Bosch Sensortec GmbH reserves all
rights even in the event of industrial property rights. We reserve all rights of disposal such as copying and passing on to
third parties. BOSCH and the symbol are registered trademarks of Robert Bosch GmbH, Germany.
Doc.-Number: BST-DHW-FL026-01 / Version_1.0_060618
BHI260 shuttle board layout – placement (top, bottom)
3|6
BHI260 shuttle board outline dimensions (in mm)
BHI260 shuttle board schematics
4|6
Headquarters
Gerhard-Kindler-Strasse 9
72770 Reutlingen · Germany
Telephone +49 7121 3535 900
Fax +49 7121 3535 909
www.bosch-sensortec.com
很抱歉,暂时无法提供与“BHI260AB”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+35.83440
- 200+13.86720
- 500+13.38120
- 1000+13.14360
