PLA-PIN-01
PLA-PIN-01
    DREMEL
    DREMEL PLA-PIN-01 3D PLA PINK 0.
PLA-PIN-01 数据手册
Dremel Digilab 3D Filament PLA Benefits New material formulation Improved print quality, reliability and filament shelf life 50% more filament per spool More prints per spool at the same price! Extensively tested with Dremel 3D printers Settings pre-prgrammed into Dremel 3D45, 3D40 and 3D20 software for optimal print results Automatic spool recognition (with 3D45) 3D45 automatically detects the filament spool and adjusts print settings based on the material. It also keeps track of the filament on the spools and warns if there isn’t enough to complete the print. February 1st, 2019 Description Model Number Engineering Number 3D PLA White 0.75kg PLA-WHI-01 2615PL01AA $ 080596055707 3D PLA Black 0.75kg PLA-BLA-01 2615PL02AA $ 080596055714 3D PLA Red 0.75kg PLA-RED-01 2615PL03AA $ 080596055721 3D PLA Orange 0.75kg PLA-ORA-01 2615PL04AA $ 080596055738 3D PLA Purple 0.75kg PLA-PUR-01 2615PL05AA $ 080596055745 3D PLA Blue 0.75kg PLA-BLU-01 2615PL06AA $ 080596055752 3D PLA Green 0.75kg PLA-GRE-01 2615PL07AA $ 080596055769 3D PLA Yellow 0.75kg** PLA-YEL-01 2615PL08AA $ 080596055776 3D PLA Pink 0.75kg PLA-PIN-01 2615PL09AA $ 080596055783 PLA Features 3D PLA Silver 0.75kg PLA-SIL-01 2615PL10AA $ 080596055790 3D PLA Gold 0.75kg PLA-GOL-01 2615PL11AA $ 080596055806 3D PLA Translucent 0.75kg PLA-TRA-01 2615PL12AA $ 080596055813 PLA is best used to reliably create high detail parts. It is best for cosmetic prints used in low-stress applications. It is perfect for beginners due to ease of printing. Dremel PLA is a high-quality PLA designed for reliability and ease of printing. It has a high softening temperature to minimize risk of nozzle jams while maintaining print quality. ** New! 1 General Features Start of Launch PT‐RT/PXF | 2019‐10‐23 © 2019 Robert Bosch LLC and affiliates. All rights reserved. Retail UPC Dremel Digilab 3D Filament ECO‐ABS Start of Launch February 1st, 2019 Description Model Number Engineering Number 3D ECO-ABS White 0.75kg ECO-WHI-01 2615EA01AA $ 080596055820 3D ECO-ABS Black 0.75kg ECO-BLA-01 2615EA02AA $ 080596055837 Retail UPC General Features Benefits New material formulation Improved print quality, reliability and filament shelf life 50% more filament per spool More prints per spool at the same price! Extensively tested with Dremel 3D45 Settings pre-prgrammed into Dremel 3D45 software for optimal print results Automatic spool recognition (with 3D45) 3D45 automatically detects the filament spool and adjusts print settings based on the material. It also keeps track of the filament on the spools and warns if there isn’t enough to complete the print. ECO-ABS Features ECO-ABS is a modified version of PLA that offers the same high detail finish but with added strength and toughness. It is a good alternative to ABS. Dremel ECO-ABS delivers exceptional mechanical properties and printing quality. It also has a high softening temperature to minimize risk of nozzle jams. 2 PT‐RT/PXF | 2019‐10‐23 © 2019 Robert Bosch LLC and affiliates. All rights reserved. Dremel Digilab 3D Filament PETG Start of Launch February 1st, 2019 Description Model Number Engineering Number PETG-TRA-01 2615PG12AA 3D PETG Translucent 0.75kg Retail $ UPC General Features Benefits New material formulation Improved print quality, reliability and filament shelf life 50% more filament per spool More prints per spool at the same price! Extensively tested with Dremel 3D45 Settings pre-prgrammed into Dremel 3D45 software for optimal print results Automatic spool recognition (with 3D45) 3D45 automatically detects the filament spool and adjusts print settings based on the material. It also keeps track of the filament on the spools and warns if there isn’t enough to complete the print. 080596055868 PETG Features PETG combines the strength and ease of printing of ECO-ABS with added durability for mechanical parts that may wear. 3 PT‐RT/PXF | 2019‐10‐23 © 2019 Robert Bosch LLC and affiliates. All rights reserved.
PLA-PIN-01 价格&库存
很抱歉,暂时无法提供与“PLA-PIN-01”相匹配的价格&库存,您可以联系我们找货
