B496202
B496202
    BOTRON
    电离器 悬挂式 110VAC,220VAC
B496202 数据手册
Botron B496201 Technical Data Sheet Overview: Botron’s B496201 Intelligent Air DC-Ionizer Benchtop Ionizer is internet ready and monitored with a built-in LED screen. The B496201 is a high frequency unit that provides both reliability and performance. It’s lightweight and compact design combined with an adjustable blowing angle makes it a versatile bench top application. Comes with Auto Ion Balance, Abnormal HV monitoring system and Self Cleaning Emitter Points. Product Notes and Features • DC Technology • Variable Speed Control • Internet Ready • Monitored Software PERFORMANCE • Self-Cleaning Ion balance +/- 5v Positive decay times range from (sec) 0.9 at 1’ to 2.8 at 3’ Negative decay times range from (sec) 1.1 at 1’ to 3.6 at 3’ *All results are based according to EOS/ESD-STM 3.1-2000. *Results may vary based on test conditions. PROPERTIES SPECIFICATIONS Power supply: Current consumption: Output HV: Air volume: Noise level: Temperature: Humidity: Ozone: Indicators: Controls: Mounting: Emitter: Dimensions: Weight: 110V/220V 50/60Hz 12W AC2200V - 68KHz < 2.5 m³ /min 60dB at 3’ 0 – 40 C 20 – 70% RH < 0.03ppm LCD Display On/Off switch, Speed Control Adjustable stand/bracket Tungsten Alloy 9.8”H x 6”W x 3.3”D 4 lbs 1 of 2 APPLICATIONS OPERATION As with all of Botron’s ionization units, the B496201 is designed neutralize electrostatic charge in personal bench top environments, sensitive materials assembly, packaging, clean room and laboratories. The unit can be mounted but is not limited to the underside of shelving, ceilings and walls. Power on unit and adjust air flow for maximum neutralization. Aim unit at the area or items to be neutralized. INSTALLATION PART NUMBERS 1. Remove contents from package. 2. Mount the ionizer in desired position. 3. Make sure there are no obstructions between the target area and ionizer. 4. Install power cord securely. 5. Turn switch on. 6. Adjust air flow accordingly. B496201 Intelligent Benchtop Ionizer B496202 Intelligent 2 Fan Overhead Ionizer B496203 Intelligent 3 Fan Overhead Ionizer MAINTENANCE Botron’s Intelligent Ionizers are equipped with a self cleaning mechanism that operates when starting up and powering down. The display will indicate if further cleaning is needed if the ion balance appears less stable. Botron Company Inc. | 21601 N. 21st Ave. Phoenix AZ 85027 | Ph# 623-582-6700 | Fax# 623-582-6776 Disclaimer. All statements of technical information are believed to be true and are based upon tests we believe to be reliable. The proper use and application for this product must be the responsibility of the user. The statements herein shall have no force or effect. 2 of 2
B496202 价格&库存
很抱歉,暂时无法提供与“B496202”相匹配的价格&库存,您可以联系我们找货
