B9703
B9703
    BOTRON
    软线(用于衬垫,腕带) 10'(3.05m) 1 MOhms 黑色
B9703 数据手册
Botron B9703 Technical Data Sheet Overview: Low profile common point ground includes a 10' long black PVC cord made with 7 strand tinsel wire to #10 ring terminal. Dual standard banana jacks allow two workers the ability to plug into onto one ground point. The molded connection point houses a 1 meg Ohm 1/4 watt resistor and attaches to table mats via 10mm stud. PROPERTIES SPECIFICATIONS Material: Resistors: Ring Terminal: Cord: Jacks: Snap: Colors: Molded Low Profile design 1 meg Ohm 1/4 watt #10 10’ black 7 strand tinsel wire PVC 2 Standard banana jacks Molded in (10mm) male snap Black Product Notes and Features • Reliable Path to Ground • Saves Work Space • Low Profile Design APPLICATIONS A reliable and durable work station grounding unit that allows two workers to be grounded at the same time. Non-slip banana jacks maintain an excellent connection to various wrist strap sets. The parking jacks help keep workstations clutter free. Molded construction resists bending and helps protect resistors. PART NUMBERS B9703 Common Point Ground Botron Company Inc. | 325 W. Melinda Ln Phoenix AZ 85027 | Ph# 623-582-6700 | Fax# 623-582-6776 Disclaimer. All statements of technical information are believed to be true and are based upon tests we believe to be reliable. The proper use and application for this product must be the responsibility of the user. The statements herein shall have no force or effect. 1 of 1
B9703
物料型号:B9703 Common Point Ground
器件简介:这是一种低剖面共地点接地装置,包括一根10英尺长的黑色PVC外皮,由7股锡丝制成的电线,配有#10环形端子。双标准香蕉插座允许两名工作人员同时接入一个接地点。模制连接点内装有1兆欧姆1/4瓦电阻,并通过10mm的公桩附着在台垫上。
引脚分配:双标准香蕉插座,模制在10mm的男性快拆插座中。
参数特性: - 材料:未具体说明 - 电阻:模制低剖面设计,1兆欧姆1/4瓦 - 环形端子:#10 - 电线:10英尺黑色7股锡丝PVC
功能详解:该装置是一个可靠且耐用的工作站接地单元,允许两名工作人员同时接地。防滑香蕉插座与各种手腕带设置保持极佳的连接。模制结构抗弯曲,有助于保护电阻。
应用信息:适用于需要两名工作人员同时接地的工作站,具有节省工作空间和低剖面设计的优点。
封装信息:模制连接点,10mm公桩。
B9703 价格&库存
很抱歉,暂时无法提供与“B9703”相匹配的价格&库存,您可以联系我们找货
