BD216-0012
BD216-0012
    BOWMAN
    COVER YOUR COUGH COMPLIANCE KIT
BD216-0012 数据手册
BD216-0012 Cover Your Cough Compliance Kit Product Description: • Kit Includes: - RS005-0212 Respiratory Hygiene Station - Locking ◦ Holds two boxes of face masks, one - two boxes of facial tissues or one box of gloves, and one hand sanitizer dispenser ◦ Quartz Beige ABS Plastic - MP-075 Sign Holder - Horizontal ◦ Holds 11" x 8.5" signage ◦ Clear PETG Plastic • Assembly hardware included Primary Area for Product Usage: • All ports of entry • Anywhere respiratory hygiene products are needed Dispenses: Mounting Specifications: • 22.25"W x 22.40"H x 5.00"D (56.5 cm x 56.9 cm x 12.7 cm) • 5.0 lbs (2.3 kg) - approximated 10.98 Package Specifications: 3.65 5.75 • Package Quantity: 1 complete kit per case • 24"L x 16"W x 6"H (61.0 cm x 40.6 cm x 15.2 cm) • 7.0 lbs (3.2 kg) - approximated 8.75 1.333 0.75 Product Specifications (overall assembled dimensions): Sanitizer, face masks, and tissues not included 4.75 • Left: Dispensing unit no larger than 8.35"W x 14.75"H x 5.00"D (21.2 cm x 37.5 cm x 12.7 cm) • [Note: Refer to automatic dispensing specifications on detection distance requirements.] • Middle: Box(es) no larger than 7.75"W x 5.00"H x 4.75"D (19.7 cm x 12.7 cm x 12.1 cm) • Right: Box(es) no larger than 5.50"W x 10.00"H x 4.75"D (13.7 cm x 25.4 cm x 12.2 cm) 6.25 R.094 (2x) Ø.250 (2x) Product Videos: BowmanDispensers.com/Product-Videos BOWMAN Dispensers 20325 71 st Ave NE, Suite D, Arlington, WA 98223 800.962.4660 • www.BowmanDispensers.com BD216-0012 Cover Your Cough Compliance Kit Assembly Instructions Installation Always mount dispensers securely prior to loading with product. 1 2 To mount the MP-075 Sign Holder, align the holes of the holder with the holes of the dispenser. With a flathead screwdriver, attach using (2x) barrel screws included with sign holder. 3 Rubber feet For placing on counter, attach (4x) self-adhesive rubber feet at each of the bottom corners (included). Thumb access to signage goes toward back of dispenser. 4 Dispenser can also be mounted securely to a wall through keyholes and screw holes in back with screws approved and supplied by building maintenance. All four mounting holes provided must be used. Parts included: • Respiratory Hygiene Station • Sign Holder • Hardware ◦ (4x) rubber feet ◦ (2x) barrel screws Tools Required: • Flathead Screwdriver BD216-0012 - Installation Information subject to change without notice. Dimensions are approximate. (Not to scale) BOWMAN Dispensers 20325 71st Ave NE, Suite D, Arlington, WA 98223 800.962.4660 • www.BowmanDispensers.com ©2019 BOWMAN® Manufacturing Company, Inc. All Rights Reserved. Product specifications subject to change without notification. Consumables not included. BD2160012TDSb BD216-0012 Cover Your Cough Compliance Kit Characteristics & Care RS005-0212 MP-075 ABS Plastic PETG Plastic Material Characteristics Designed for Long-Term, Heavy-Duty Applications Designed for Long-Term, Heavy-Duty Applications The combination of copolymers (Acrylonitrile, Butadiene, and Styrene) gives ABS an excellent combination of strength, rigidity, and toughness. Copolyester resin is designed for heavy-duty applications, and is used by BOWMAN® Dispensers. We never use acrylic in our products. ABS is chemical and stress-crack resistant. It is tough, dimensionally stable, and will hold up to long-term use. It possesses high strength and performance characteristics at a reasonable cost. Copolyester (PETG) is typically 15-20 times tougher than general purpose acrylic. PETG is made to withstand handling and reduce losses due to breakage. PETG resists a variety of chemicals and commonly used cleaning agents. It is tough and durable (not brittle), providing years of trouble-free functionality and long life. Clear optical characteristics mean the viewer can see the content, read text, and see true colors through the material. It complies with FDA regulations for food contact. Care and Cleaning Use mild soap and water to clean. Petroleum-based oils, solvents, and paints should not be used. Standard hospital cleaning supplies can be used. BD216-0012 - Characteristics & Care Information subject to change without notice. Dimensions are approximate. (Not to scale) Most cleaning chemicals do not weaken the surface or cause damage to the material. Suggested cleaning method is to use a soft cloth, warm water, and mild soap. BOWMAN Dispensers 20325 71st Ave NE, Suite D, Arlington, WA 98223 800.962.4660 • www.BowmanDispensers.com
BD216-0012 价格&库存
很抱歉,暂时无法提供与“BD216-0012”相匹配的价格&库存,您可以联系我们找货
