BD670-0012
BD670-0012
    BOWMAN
    PROTECTIVE WEAR ISOLATION BUNDLE
BD670-0012 数据手册
BD670-0012 Protection System Isolation Bundle Product Description: • Bundle Includes: - LD-070 Protection System ◦ Holds disposable or reusable gowns, aprons, or coveralls/jumpsuits, three boxes of gloves, one box of earloop masks, and one box of shield masks ◦ Quartz Beige ABS Plastic - MB-600 Hanger - Door - Standard ◦ Hooks over top of door no thicker than 2.44" ◦ Quartz Beige Powder-Coated Steel Primary Area for Product Usage: • Anywhere protective equipment products are needed Dispenses: Product Specifications (overall assembled dimensions): • 20.05"W x 36.16"H x 7.30"D (50.9 cm x 91.8 cm x 18.5 cm) • 5.4 lbs (2.4 kg) - approximated Consumables not included Mounting Specifications: • Left: Protection System, Right: Door Hanger Package Specifications: Product Videos: BowmanDispensers.com/Product-Videos 2.50 1.50 • Package Quantity: 1 per case • 29"W x 6"H x 23"D (73.7 cm x 15.2 cm x 58.4 cm) • 8.0 lbs (3.6 kg) - approximated 6.00 12.13 • Top: Box(es) no larger than 5.00"W x 10.00"H x 4.49"D (12.7 cm x 25.4 cm x 11.4 cm) • Bottom left: Gowns, aprons, or coveralls/jumpsuits no larger than 11.38"W x 15.30"H x 4.53"D (28.9 cm x 37.4 cm x 11.5 cm) • Middle right: Box(es) no larger than 8.39"W x 5.24"H x 4.49"D (21.3 cm x 13.3 cm x 11.4 cm) • Bottom right: Box(es) no larger than 8.39"W x 9.80"H x 4.49"D (21.3 cm x 24.9 cm x 11.4 cm) BOWMAN Dispensers 20325 71 st Ave NE, Suite D, Arlington, WA 98223 800.962.4660 • www.BowmanDispensers.com BD670-0012 Protection System Isolation Bundle Assembly Instructions Installation Always mount dispensers securely prior to loading with product. • Proper Hanging Procedure: 1) Attach hanger securely - back of hanger must lay flush against surface. Care and Construction ABS Plastic Material Characteristics Designed for Long-Term, Heavy-Duty Applications The combination of copolymers (Acrylonitrile, Butadiene, and Styrene) gives ABS an excellent combination of strength, rigidity, and toughness. ABS is chemical, stress-crack resistant, dimensionally stable, and will hold up to long-term use. It possesses high strength and performance characteristics at a reasonable cost. Care and Cleaning Use mild soap and water to clean. Petroleum-based oils, solvents, and paints should not be used. Standard hospital cleaning supplies are approved for use on our ABS plastic products. 1 Powder-Coated Steel 1) Hang dispenser on hanger. 2) Load product in dispenser. 3) To remove, reverse order of steps. Material Characteristics Designed for Long-Term Use Our steel dispensers and stands are coated with polyester powders which makes them highly resistant to corrosion. Powder-coated steel is ideal for dispensers used in a healthcare or an industrial setting because it is impact resistant and is not effected by extremes in temperature. Dispensers and stands made of powder-coated steel are both attractive and functional, providing years of service. Care and Cleaning 2 For best results, clean by washing the surface with a diluted solution of a mild, non-abrasive detergent in cold or warm water and a non-abrasive cloth. Standard hospital cleaning supplies can be used. Parts included:  Protection System  Door Hanger Tools Required: Dry with a soft cloth. Do not use any solvent-based materials, abrasives (e.g. Scotch-brite, steel wool), or apply excessive force during cleaning. • No tools required to assemble dispenser BD670-0012 - Installation Information subject to change without notice. Dimensions are approximate. (Not to scale) BOWMAN Dispensers 20325 71st Ave NE, Suite D, Arlington, WA 98223 800.962.4660 • www.BowmanDispensers.com ©2019 BOWMAN® Manufacturing Company, Inc. All Rights Reserved. Product specifications subject to change without notification. Consumables not included. BD6700012TDSb
BD670-0012 价格&库存
很抱歉,暂时无法提供与“BD670-0012”相匹配的价格&库存,您可以联系我们找货
