BD990-0020
BD990-0020
    BOWMAN
    COVER YOUR COUGH COMPLIANCE KIT
BD990-0020 数据手册
BD990-0020 Cover Your Cough Compliance Kit Product Description: • Kit Includes: - RS009-0420 Respiratory Hygiene Station - Locking ◦ Holds two boxes of face masks, one - two boxes of facial tissues or one box of gloves, and one hand sanitizer dispenser ◦ Black Powder-Coated Steel - KS010-0420 Floor Stand ◦ Black Powder-Coated Steel - MP-075 Sign Holder - Horizontal ◦ Holds 11" x 8.5" signage ◦ Clear PETG Plastic • Assembly hardware included Primary Area for Product Usage: • All ports of entry • Anywhere respiratory hygiene products are needed Dispenses: • Left: Dispensing unit no larger than 8.40"W x 14.80"H x 5.00"D (21.2 cm x 37.5 cm x 12.7 cm) • [Note: Refer to automatic dispensing specifications on detection distance requirements.] • Middle: Box(es) no larger than 8.00”W x 9.50”H x 4.75”D (20.3 cm x 24.1 cm x 12.1 cm) • Right: Box(es) no larger than 5.50”W x 9.50”H x 4.75”D (13.7 cm x 24.1 cm x 12.1 cm) Sanitizer dispenser, face masks, and tissues not included Product Specifications (overall assembled dimensions): • 22.25"W x 57.98"H x 17.00"D (56.5 cm x 147.3 cm x 43.2 cm) • 22.5 lbs (10.2 kg) - approximated Package Specifications: • Package Quantity: 1 per case • 36"L x 20"W x 6"H (91.4 cm x 50.8 cm x 15.2 cm) • 27.0 lbs (12.2 kg) - approximated Product Videos: BowmanDispensers.com/Product-Videos BOWMAN Dispensers 20325 71 st Ave NE, Suite D, Arlington, WA 98223 800.962.4660 • www.BowmanDispensers.com BD990-0020 Cover Your Cough Compliance Kit Assembly Instructions Assembly Always mount dispensers securely prior to loading with product. Base Column Assembly with Top Plate Bottom of column Top of column 1 To secure base to column, turn column upside down (with top plate down) and place base inverted, as shown, on column. Base 2 3 Use Phillips screwdriver to secure base to column with (4x) screws (10-32 x 5/16"). Turn stand right side up, so the base is on the floor. Mounting holes for hand sanitizer 4 Top Plate of column Attach the RS009-0420 Respiratory Hygiene Station to the column using (4x) screws included with stand. One pair of screw holes is located in the hand sanitizer dispener section; the second pair are inside the facemask section and can be accessed with the lid open. Tighten all screws. 5 6 To mount the MP-075 Sign Holder, align the mounting holes of the holder with the holes on the top front of the dispenser. Attach using (2x) barrel screws included with sign holder. Attach hand sanitizer dispenser using VHB tape or mounting holes provided. Parts included: • • • • Base Column Hygiene Station Sign Holder • Hardware ◦ (8x) 10-32 x 5/16" Phillips head screws ◦ (2x) barrel screws Tools Required: • Phillips Screwdriver BD990-0020 - Assembly Information subject to change without notice. Dimensions are approximate. (Not to scale) • Flathead Screwdriver BOWMAN Dispensers 20325 71st Ave NE, Suite D, Arlington, WA 98223 800.962.4660 • www.BowmanDispensers.com ©2020 BOWMAN® Manufacturing Company, Inc. All Rights Reserved. Product specifications subject to change without notification. Consumables not included. BD9900020TDSa BD990-0020 Cover Your Cough Compliance Kit Characteristics & Care MP-075 RS009-0420 & KS010-0420 Powder-Coated Steel PETG Plastic Material Characteristics Designed for Long-Term Use Designed for Long-Term, Heavy-Duty Applications Our steel dispensers and stands are coated with polyester powders which makes them highly resistant to corrosion. Copolyester resin is designed for heavy-duty applications, and is used by BOWMAN® Dispensers. We never use acrylic in our products. Powder-coated steel is ideal for dispensers used in a healthcare or an industrial setting because it is impact resistant and is not affected by extremes in temperature. Copolyester (PETG) is typically 15-20 times tougher than general purpose acrylic. PETG is made to withstand handling and reduce losses due to breakage. Dispensers and stands made of powder-coated steel are both attractive and functional, providing years of service. PETG resists a variety of chemicals and commonly used cleaning agents. It is tough and durable (not brittle), providing years of trouble-free functionality and long life. Clear optical characteristics mean the viewer can see the content, read text, and see true colors through the material. It complies with FDA regulations for food contact. Care and Cleaning For best results, clean by washing the surface with a diluted solution of a mild, non-abrasive detergent in cold or warm water and a non-abrasive cloth. Standard hospital cleaning supplies can be used. Most cleaning chemicals do not weaken the surface or cause damage to the material. Suggested cleaning method is to use a soft cloth, warm water, and mild soap. Dry with a soft cloth. Do not use any solvent-based materials, abrasives (e.g. Scotch-brite, steel wool), or apply excessive force during cleaning. BD990-0020 - Characteristics & Care Information subject to change without notice. Dimensions are approximate. (Not to scale) BOWMAN Dispensers 20325 71st Ave NE, Suite D, Arlington, WA 98223 800.962.4660 • www.BowmanDispensers.com
BD990-0020 价格&库存
很抱歉,暂时无法提供与“BD990-0020”相匹配的价格&库存,您可以联系我们找货
