BG002-0111
BG002-0111
    BOWMAN
    BAG DISPENSER - DOUBLE
BG002-0111 数据手册
BG002-0111 Bag Dispenser - Double Product Description: • • • • Bag Dispenser - Double Holds two rolls of bags (up to 9.50” long and 3.50” in diameter) Two-way keyholes for vertical or horizontal wall mounting Made of Clear PETG Plastic Primary Area for Product Usage: • Any location which requires bags for storage or refuse at the point of use: laboratory, food service, O.R., clinical areas, dental, veterinary Dispenses: • Two rolls of individual-sized biohazard, linen, or refuse bags • Rolls no larger than 9.50˝W x Ø3.50˝ (24.1 cm x 8.9 cm) Package Specifications: • Package Quantity: 6 per case • 16˝W x 12˝H x 12˝D (40.6 cm x 30.5 cm x 30.5 cm) • 7.0 lbs (3.2 kg) - approximated Product Specifications (overall external dimensions): • 10.13˝W x 7.13˝H x 3.95˝D (25.7 cm x 18.0 cm x 10.0 cm) • 1.0 lbs (0.4 kg) - approximated Mounting Specifications: Alternative Products (each sold separately): • BG001-0111, Bag Dispenser - Single, Clear PETG Plastic • BG002-0512, Bag Dispenser - Double, Quartz Beige Powder-Coated Aluminum • BG002-0212, Bag Dispenser - Double, Quartz Beige ABS Plastic 5.05˝ R.25 (4x) R.13 (2x) 1.30˝ BG001-0111 1.50˝ 7.00˝ Ø.25 (2x) BG002-0512 Product Videos: BowmanDispensers.com/Product-Videos BG002-0212 BOWMAN Dispensers 20325 71 st Ave NE, Suite D, Arlington, WA 98223 800.962.4660 • www.BowmanDispensers.com BG002-0111 Bag Dispenser - Double Installation Instructions/Characteristics & Care Installation Always mount dispensers securely prior to loading with product. • Clear design enables unobstructed view of contents and supply level. • Curved cutout opening contains roll while dispensing and permits easy access. Care and Construction PETG Plastic Material Characteristics Designed for Long-Term Heavy-Duty Applications Copolyester resin is designed for heavy-duty applications, and is used by BOWMAN® Dispensers. We never use acrylic in our products. Copolyester (PETG) is typically 15-20 times tougher than general purpose acrylic. PETG is made to withstand handling and reduce losses due to breakage. PETG resists a variety of chemicals and commonly used cleaning agents. It is tough and durable (not brittle), providing years of trouble-free functionality and long life. 1 • Mount securely to a wall with screws approved and supplied by building maintenance. Clear optical characteristics mean the viewer can see the content, read text, and see true colors through the material. It complies with FDA regulations for food contact. Care and Cleaning Most cleaning chemicals do not weaken the surface or cause damage to the material. Suggested cleaning method is to use a soft cloth, warm water, and mild soap. 2 Parts included: • Dispenser Tools Required: • No tools required to assemble dispenser BG002-0111 - Installation/Characteristics & Care Information subject to change without notice. Dimensions are approximate. (Not to scale) BOWMAN Dispensers 20325 71st Ave NE, Suite D, Arlington, WA 98223 800.962.4660 • www.BowmanDispensers.com ©2018 BOWMAN® Manufacturing Company, Inc. All Rights Reserved. Product specifications subject to change without notification. Consumables not included. BG0020111TDSb
BG002-0111 价格&库存
很抱歉,暂时无法提供与“BG002-0111”相匹配的价格&库存,您可以联系我们找货
