BG002-0512
BG002-0512
    BOWMAN
    BAG DISPENSER - DOUBLE
BG002-0512 数据手册
BG002-0512 Bag Dispenser - Double Product Description: • • • • Bag Dispenser - Double Holds two rolls of bags (up to 9.50” long and 3.50” in diameter) Two-way keyholes for vertical or horizontal wall mounting Made of Quartz Beige Powder-Coated Aluminum Primary Area for Product Usage: • Any location which requires bags for storage or refuse at the point of use: laboratory, food service, O.R., clinical areas, dental, veterinary Dispenses: • Two rolls of individual-sized biohazard, linen, or refuse bags • Rolls no larger than 9.50˝W x Ø3.50˝ (24.1 cm x 8.9 cm) Package Specifications: • Package Quantity: 6 per case • 16˝W x 12˝H x 12˝D (40.6 cm x 30.5 cm x 30.5 cm) • 10.0 lbs (4.5 kg) - approximated Product Specifications (overall external dimensions): • 10.05˝W x 7.00˝H x 3.90˝D (25.5 cm x 17.8 cm x 9.9 cm) • 1.3 lbs (0.6 kg) - approximated Alternative Products (each sold separately): Mounting Specifications: • BG002-0111, Bag Dispenser - Double, Clear PETG Plastic • BG002-0512, Bag Dispenser - Double, Quartz Beige ABS Plastic • BG001-0512, Bag Dispenser - Single, Quartz Beige Powder-Coated Aluminum R.25 (4x) R.13 (2x) 1.30˝ 5.05˝ BG001-0512 1.50˝ 7.00˝ Ø.25 (2x) BG002-0111 Product Videos: BowmanDispensers.com/Product-Videos BG002-0212 BOWMAN Dispensers 20325 71 st Ave NE, Suite D, Arlington, WA 98223 800.962.4660 • www.BowmanDispensers.com BG002-0512 Bag Dispenser - Double Installation Instructions/Characteristics & Care Installation Always mount dispensers securely prior to loading with product. • Curved cutout opening contains roll while dispensing and permits easy access. Care and Construction Powder-Coated Aluminum Material Characteristics Designed for Long-Term Use Our powder-coated aluminum dispensers resist corrosion, chipping, and flaking. It is lightweight, yet high in strength. This material will provide long-lasting products that hold up well, even in tough environments. Powder-coated aluminum is ideal for dispensers used in a healthcare or industrial settings. It is impact resistant and is not affected by extremes in temperature. 1 Dispensers made of powder-coated aluminum are clean, bright, and attractive, creating a professional appearance. • Mount securely to a wall with screws approved and supplied by building maintenance. Care and Cleaning For best results, clean by washing the surface with a diluted solution of a mild, non-abrasive detergent in cold or warm water and a non-abrasive cloth. Standard hospital cleaning supplies can be used. Dry with a soft cloth. Do not use any solvent-based materials, abrasives (e.g. Scotch-brite, steel wool), or apply excessive force during cleaning. 2 Parts included: • Dispenser Tools Required: • No tools required to assemble dispenser BG002-0512 - Installation/Characteristics & Care Information subject to change without notice. Dimensions are approximate. (Not to scale) BOWMAN Dispensers 20325 71st Ave NE, Suite D, Arlington, WA 98223 800.962.4660 • www.BowmanDispensers.com ©2018 BOWMAN® Manufacturing Company, Inc. All Rights Reserved. Product specifications subject to change without notification. Consumables not included. BG0020512TDSb
BG002-0512 价格&库存
很抱歉,暂时无法提供与“BG002-0512”相匹配的价格&库存,您可以联系我们找货
